PMF63UNE
20 V, N-channel Trench MOSFET
20 April 2016
Product data sheet
1. General description
N-channel enhancement mode Field-Effect Transistor (FET) in a very small SOT323
(SC-70) Surface-Mounted Device (SMD) plastic package using Trench MOSFET
technology.
2. Features and benefits
Trench MOSFET technology
Low threshold voltage
ElectroStatic Discharge (ESD) protection > 2 kV HBM
3. Applications
LED driver
Power management
Low-side loadswitch
Switching circuits
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj = 25 °C
V
VGS
gate-source voltage
-8
8
V
ID
drain current
2.2
A
57
65
mΩ
VGS = 4.5 V; Tamb = 25 °C; t ≤ 5 s
[1]
Static characteristics
RDSon
drain-source on-state
resistance
[1]
VGS = 4.5 V; ID = 2 A; Tj = 25 °C
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for drain 6 cm .
PMF63UNE
Nexperia
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
S
souce
3
D
drain
Simplified outline
Graphic symbol
3
D
G
1
2
SC-70 (SOT323)
S
017aaa255
6. Ordering information
Table 3.
Type number
PMF63UNE
Package
Name
Description
Version
SC-70
plastic surface-mounted package; 3 leads
SOT323
7. Marking
Table 4.
Marking codes
Type number
Marking code
[1]
PMF63UNE
Z%V
[1]
PMF63UNE
Product data sheet
% = placeholder for manufacturing site code
All information provided in this document is subject to legal disclaimers.
20 April 2016
Nexperia B.V. 2017. All rights reserved
2 / 15
PMF63UNE
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
Tj = 25 °C
V
VGS
gate-source voltage
-8
8
V
ID
drain current
[1]
2.2
A
[1]
2
A
VGS = 4.5 V; Tamb = 100 °C
[1]
1.3
A
8
A
[2]
300
mW
[1]
395
mW
1.8
W
IDM
peak drain current
Tamb = 25 °C; single pulse; tp ≤ 10 µs
Ptot
total power dissipation
Tamb = 25 °C
Tsp = 25 °C
Tj
junction temperature
-55
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
IS
source current
0.37
A
[1]
[2]
Tamb = 25 °C
2
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper; tin-plated and standard
footprint.
017aaa123
120
Pder
017aaa124
120
Ider
80
80
40
40
Fig. 1.
[1]
- 25
25
75
125
Tj (°C)
Normalized total power dissipation as a
function of junction temperature
PMF63UNE
Product data sheet
175
Fig. 2.
- 25
75
125
Tj (°C)
175
Normalized continuous drain current as a
20 April 2016
25
3 / 15
PMF63UNE
Nexperia
aaa-022560
10
tp = 10 µs
Limit RDSon = VDS/ID
100 µs
ID
(A)
1 ms
1
10 ms
DC; Tsp = 25 °C
10-1
100 ms
DC; Tamb = 25 °C; 6 cm2
10-2
10-1
1
10
102
VDS (V)
IDM = single pulse
Fig. 3.
Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage
9. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance
from junction to
ambient
in free air
Rth(j-sp)
in free air; t ≤ 5 s
thermal resistance
from junction to solder
point
[1]
[2]
PMF63UNE
Product data sheet
Min
Typ
Max
Unit
[1]
363
418
K/W
[2]
276
317
K/W
[2]
238
273
K/W
60
69
K/W
footprint.
2
20 April 2016
4 / 15
PMF63UNE
Nexperia
aaa-022561
103
duty cycle = 1
Zth(j-a)
(K/W)
0.75
102
0.33
0.20
0.50
0.25
0.10
0.05
10
0.01
0.02
10-3
10-2
10-1
1
10
102
tp (s)
103
FR4 PCB, standard footprint
Fig. 4.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
aaa-022562
103
Zth(j-a)
(K/W)
duty cycle = 1
0.75
102
0.33
0.20
0.50
0.25
0.10
0.05
10
0.01
0.02
10-3
10-2
10-1
FR4 PCB, mounting pad for drain 6 cm
Fig. 5.
1
10
102
tp (s)
103
2
PMF63UNE
Product data sheet
20 April 2016
5 / 15
PMF63UNE
Nexperia
10. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
V
VGSth
gate-source threshold
voltage
ID = 250 µA; VDS = VGS; Tj = 25 °C
0.45
0.7
1
V
IDSS
drain leakage current
VDS = 20 V; VGS = 0 V; Tj = 25 °C
1
µA
IGSS
gate leakage current
VGS = 8 V; Tj = 25 °C
10
µA
VGS = -8 V; VDS = 0 V; Tj = 25 °C
-10
µA
VGS = 4.5 V; VDS = 0 V; Tj = 25 °C
5
µA
VGS = -4.5 V; VDS = 0 V; Tj = 25 °C
-5
µA
57
65
mΩ
VGS = 4.5 V; ID = 2 A; Tj = 150 °C
84
96
mΩ
VGS = 2.5 V; ID = 1.8 A; Tj = 25 °C
64
74
mΩ
VGS = 1.8 V; ID = 0.8 A; Tj = 25 °C
78
88
mΩ
RDSon
resistance
gfs
forward
transconductance
VDS = 5 V; ID = 2 A; Tj = 25 °C
9
S
RG
gate resistance
f = 1 MHz; Tj = 25 °C
1.8
Ω
total gate charge
VDS = 10 V; ID = 2 A; VGS = 4.5 V;
3.9
5.85
nC
QGS
gate-source charge
Tj = 25 °C
0.3
nC
QGD
gate-drain charge
0.9
nC
Ciss
input capacitance
VDS = 10 V; f = 1 MHz; VGS = 0 V;
289
pF
Coss
output capacitance
Tj = 25 °C
51
pF
Crss
reverse transfer
capacitance
42
pF
td(on)
turn-on delay time
8
ns
tr
rise time
RG(ext) = 6 Ω; Tj = 25 °C
27
ns
td(off)
turn-off delay time
35
ns
tf
fall time
19
ns
0.7
1.2
V
Dynamic characteristics
QG(tot)
Source-drain diode
VSD
source-drain voltage
PMF63UNE
Product data sheet
IS = 0.37 A; VGS = 0 V; Tj = 25 °C
20 April 2016
6 / 15
PMF63UNE
Nexperia
aaa-022563
8
ID
(A)
ID
(A)
4.5 V
2.5 V
1.8 V
6
aaa-022564
10-3
1.6 V
min
10-4
1.4 V
typ
max
4
VGS = 1.2 V
10-5
2
Fig. 6.
2
3
4
VDS (V)
10-6
5
0.3
Tj = 25 °C
VDS = 5 V
Output characteristics: drain current as a
function of drain-source voltage; typical values Fig. 7.
Tj = 25 °C
aaa-022565
240
RDSon
(mΩ)
200
1.2 V
1.4 V
1.6 V
0.9
1.2
1.5
VGS (V)
Sub-threshold drain current as a function of
gate-source voltage
aaa-022566
160
120
120
1.8 V
80
Tj = 150 °C
80
2.5 V
VGS = 4.5 V
40
240
RDSon
(mΩ)
200
160
4
6
ID (A)
Product data sheet
4
6
VGS (V)
8
ID = 2 A
Drain-source on-state resistance as a function
of drain current; typical values
PMF63UNE
Tj = 25 °C
40
Tj = 25 °C
Fig. 8.
Fig. 9.
of gate-source voltage; typical values
20 April 2016
7 / 15
PMF63UNE
Nexperia
aaa-022567
8
aaa-022568
1.6
ID
(A)
a
6
1.2
4
0.8
2
0.4
Tj = 150 °C
Tj = 25 °C
1
1.5
2
2.5
VGS (V)
VDS > ID x RDSon
Fig. 10. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
60
120
C
(pF)
102
typ
0.5
min
Coss
Crss
60
120
Tj (°C)
10
10-1
180
ID = 250 μA; VDS = VGS
Product data sheet
1
10
VDS (V)
102
Fig. 12. Gate-source threshold voltage as a function of
ambient temperature
PMF63UNE
Ciss
max
1
180
aaa-022570
103
VGS(th)
(V)
Tj (°C)
Fig. 11. Normalized drain-source on-state resistance
as a function of ambient temperature; typical
values
aaa-022569
1.5
Fig. 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
20 April 2016
8 / 15
PMF63UNE
Nexperia
aaa-022572
5
VDS
VGS
(V)
ID
4
VGS(pl)
3
VGS(th)
VGS
2
QGS1
1
QGS2
2
3
4
QG (nC)
QGS
QGD
QG(tot)
003aaa508
Fig. 15. Gate charge waveform definitions
5
Fig. 14. Gate-source voltage as a function of gate
charge; typical values
aaa-022573
1.5
IS
(A)
1.2
0.9
Tj = 150 ºC
Tj = 25 ºC
0.6
0.3
0.4
0.6
0.8
1.0
VSD (V)
VGS = 0 V
Fig. 16. Source current as a function of source-drain voltage; typical values
11. Test information
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig. 17. Duty cycle definition
PMF63UNE
Product data sheet
20 April 2016
9 / 15
PMF63UNE
Nexperia
12. Package outline
Plastic surface-mounted package; 3 leads
SOT323
D
B
E
A
X
HE
y
v M A
3
Q
A
A1
1
c
2
e1
bp
Lp
w M B
e
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
1.1
0.8
0.1
0.4
0.3
0.25
0.10
2.2
1.8
1.35
1.15
1.3
0.65
2.2
2.0
0.45
0.15
0.23
0.13
0.2
0.2
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
SOT323
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
04-11-04
06-03-16
SC-70
Fig. 18. Package outline SC-70 (SOT323)
PMF63UNE
Product data sheet
20 April 2016
10 / 15
PMF63UNE
Nexperia
13. Soldering
2.65
1.85
1.325
solder lands
solder resist
2
2.35
0.6
(3×)
3
solder paste
1.3
occupied area
0.5
(3×)
1
Dimensions in mm
0.55
(3×)
sot323_fr
Fig. 19. Reflow soldering footprint for SC-70 (SOT323)
4.6
2.575
1.425
(3×)
solder lands
solder resist
occupied area
1.8
3.65 2.1
09
(2×)
Dimensions in mm
preferred transport
direction during soldering
sot323_fw
Fig. 20. Wave soldering footprint for SC-70 (SOT323)
PMF63UNE
Product data sheet
20 April 2016
11 / 15
PMF63UNE
Nexperia
14. Revision history
Table 8.
Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMF63UNE v.1
20160420
Product data sheet
PMF63UNE
Product data sheet
20 April 2016
12 / 15
PMF63UNE
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
15. Legal information
15.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
15.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
PMF63UNE
Product data sheet
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
20 April 2016
13 / 15
PMF63UNE
Nexperia
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor
tested in accordance with automotive testing or application requirements.
Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PMF63UNE
Product data sheet
20 April 2016
14 / 15
PMF63UNE
Nexperia
16. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................3
9
Thermal characteristics .........................................4
10
Characteristics ....................................................... 6
11
Test information ..................................................... 9
12
Package outline ................................................... 10
13
Soldering .............................................................. 11
14
Revision history ................................................... 12
15
15.1
15.2
15.3
15.4
Legal information .................................................13
Data sheet status ............................................... 13
Definitions ...........................................................13
Disclaimers .........................................................13
Trademarks ........................................................ 14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 20 April 2016
PMF63UNE
Product data sheet
20 April 2016
15 / 15
