BUK7610-55AL
N-channel TrenchMOS standard level FET
Rev. 02 — 9 January 2008
Product data sheet
1. Product profile
1.1 General description
N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using
Nexperia General-Purpose Automotive (GPA) TrenchMOS technology specifically
optimized for linear operation. This product has been designed and qualified to the
appropriate AEC standard for use in automotive critical applications.
1.2 Features
175 °C rated
Stable operation in linear mode
Q101 compliant
1.3 Applications
12 V and 24 V loads
DC linear motor control
Automotive systems
Repetitive clamped inductive switching
1.4 Quick reference data
Table 1.
Quick reference
Symbol
Parameter
Conditions
ID
drain current
VGS = 10 V; Tmb = 25 °C;
see Figure 4 and 1
Ptot
total power dissipation
Min
Typ
Max
Unit
75
A
Tmb = 25 °C; see Figure 2
300
W
ID = 75 A; Vsup ≤ 55 V;
RGS = 50 Ω; VGS = 10 V;
Tj(init) = 25 °C; unclamped
inductive load
1.1
J
VGS = 10 V; ID = 25 A;
Tj = 25 °C; see Figure 12 and
13
8.5
10
mΩ
[1]
Avalanche ruggedness
EDS(AL)S
non-repetitive
drain-source
avalanche energy
Static characteristics
RDSon
[1]
drain-source on-state
resistance
Continuous current is limited by package.
BUK7610-55AL
Nexperia
2. Pinning information
Table 2.
Pinning
Pin
Symbol
Description
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base;
connected to drain
Simplified outline
Graphic symbol
D
mb
G
mbb076
S
2
1
3
SOT404 (D2PAK)
3. Ordering information
Table 3.
Type number
BUK7610-55AL
Package
Name
Description
Version
D2PAK
plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead SOT404
cropped)
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
Conditions
Min
Max
Unit
55
V
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
VDGR
drain-gate voltage
RGS = 20 kΩ
VGS
gate-source voltage
ID
drain current
55
V
-20
V
Tmb = 25 °C; VGS = 10 V; see Figure 4 and 1
[1][2]
122
A
[3]
75
A
Tmb = 100 °C; VGS = 10 V; see Figure 4
[3]
75
A
IDM
peak drain current
Tmb = 25 °C; tp ≤ 10 μs; pulsed
490
A
Ptot
300
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
1.1
J
J
122
A
490
A
EDS(AL)S non-repetitive
drain-source avalanche
energy
ID = 75 A; Vsup ≤ 55 V; RGS = 50 Ω;
VGS = 10 V; Tj(init) = 25 °C; unclamped
inductive load
EDS(AL)R repetitive drain-source
avalanche energy
see Figure 3
[4][5]
[6]
Source-drain diode
IS
ISM
source current
peak source current
Tmb = 25 °C
[1][2]
Tmb = 25 °C
[3]
tp ≤ 10 μs; pulsed; Tmb = 25 °C
BUK7610-55AL_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 13
BUK7610-55AL
Nexperia
[1]
Current is limited by power dissipation chip rating.
[2]
Refer to document 9397 750 12572 for further information.
[3]
[4]
Single shot avalanche rating limited by maximum junction temperature of 175 °C.
[5]
Repetitive avalanche rating limited by average junction temperature of 170 °C.
[6]
Refer to application note AN10273 for further information.
003aaa726
150
03aa16
120
ID
(A)
Pder
100
80
(1)
50
40
100
150
Tmb (°C)
200
VGS 10 V
50
P der =
(1) Capped at 75 A due to package.
Fig 1. Continuous drain current as a function of
mounting base temperature
P tot
P tot (25°C )
100
150
Tmb (°C)
200
× 100 %
Fig 2. Normalized total power dissipation as a
function of mounting base temperature
003aaa739
102
(1)
IAV
(A)
(2)
Tj = 25 ˚C
10
150 ˚C
(3)
1
10-1
10-2
10-1
1
tAV (ms)
10
(1) Singleíshot.
(2) Singleíshot.
(3) Repetitive.
Fig 3. Single-shot and repetitive avalanche rating; avalanche current as a function of a
BUK7610-55AL_2
Product data sheet
3 of 13
BUK7610-55AL
Nexperia
003aaa737
103
Limit RDSon = VDS / ID
ID
(A)
tp = 10 μ s
100 μ s
102
(1)
1 ms
DC
10 ms
10
100 ms
1
1
10
102
VDS (V)
Tmb = 25 °C; IDM is single pulse
Fig 4. Safe operating area; continuous and peak drain currents as a function of drain-source voltage
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-a)
thermal resistance
from junction to
ambient
mounted on a printed-circuit
board; minimum footprint; vertical
in still air
50
K/W
Rth(j-mb)
thermal resistance
from junction to
mounting base
see Figure 5
0.25
0.5
K/W
BUK7610-55AL_2
Product data sheet
4 of 13
BUK7610-55AL
Nexperia
003aaa734
1
Zth(j-mb)
(K/W) δ = 0.5
0.2
10-1
0.1
0.05
0.02
δ=
P
10-2
single shot
tp
T
t
tp
T
10-3
10-6
10-5
10-4
10-3
10-2
10-1
tp (s)
1
Fig 5. Transient thermal impedance from junction to mounting base as a function of pulse duration
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
ID = 250 μA; VGS = 0 V;
Tj = -55 °C
50
V
Tj = 25 °C
55
V
2
3
4
V
ID = 1 mA; VDS = VGS;
Tj = 175 °C; see Figure 10 and
11
1
V
Tj = -55 °C; see Figure 10 and 11
4.4
V
VDS = 55 V; VGS = 0 V;
Tj = 175 °C
500
μA
VDS = 55 V; VGS = 0 V; Tj = 25 °C
0.05
10
μA
VDS = 0 V; VGS = +20 V;
Tj = 25 °C
2
100
nA
VDS = 0 V; VGS = -20 V;
Tj = 25 °C
2
100
nA
Tj = 175 °C; see Figure 12 and
13
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C;
see Figure 12 and 13
8.5
10
mΩ
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain-source
breakdown voltage
gate-source threshold ID = 1 mA; VDS = VGS; Tj = 25 °C;
voltage
drain leakage current
gate leakage current
resistance
BUK7610-55AL_2
Product data sheet
5 of 13
BUK7610-55AL
Nexperia
Table 6.
Symbol
Characteristics …continued
Parameter
Conditions
Min
Typ
Max
Unit
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 16
0.85
1.2
V
Source-drain diode
VSD
source-drain voltage
trr
reverse recovery time IS = 20 A; dIS/dt = -100 A/μs;
VGS = 0 V; VDS = 30 V; Tj = 25 °C
73
ns
Qr
recovered charge
430
nC
Dynamic characteristics
QG(tot)
total gate charge
ID = 25 A; VDS = 44 V;
VGS = 10 V; Tj = 25 °C;
see Figure 14
124
nC
QGS
gate-source charge
see Figure 14
22
nC
QGD
gate-drain charge
see Figure 14
50
nC
VGS(pl)
gate-source plateau
voltage
ID = 25 A; VDS = 44 V; Tj = 25 °C;
see Figure 14
5
V
Ciss
input capacitance
VGS = 0 V; VDS = 25 V;
f = 1 MHz; Tj = 25 °C;
see Figure 15
4710
6280
pF
Coss
output capacitance
see Figure 15
980
1180
pF
Crss
reverse transfer
capacitance
see Figure 15
560
770
pF
td(on)
turn-on delay time
VDS = 30 V; RL = 1.2 Ω;
VGS = 10 V; RG(ext) = 10 Ω;
Tj = 25 °C
33
ns
tr
rise time
Tj = 25 °C
117
ns
td(off)
turn-off delay time
Tj = 25 °C
132
ns
tf
fall time
Tj = 25 °C
95
ns
LD
internal drain
inductance
from upper edge of drain
mounting base to center of die;
Tj = 25 °C
2.5
nH
LS
internal source
inductance
from source lead to source bond
pad; Tj = 25 °C
7.5
nH
BUK7610-55AL_2
Product data sheet
6 of 13
BUK7610-55AL
Nexperia
003aaa729
400
ID
(A)
8
9
10
15
VGS (V) = 10
9.5
9
8.5
8
7.5
7
6.5
6
5.5
5
4.5
200
100
RDSon
(mΩ)
16
14
12
300
003aaa731
4
6
10
VGS (V) = 20
5
VDS (V)
10
T j = 25 °C
100
200
300
ID (A)
400
T j = 25 °C
Fig 6. Output characteristics: drain current as a
function of drain-source voltage; typical values
003aaa732
40
gfs
(S)
Fig 7. Drain-source on-state resistance as a function
of drain current; typical values
003aaa733
150
ID
(A)
35
100
30
50
25
Tj = 175 °C
Tj = 25 °C
60
ID (A)
80
T j = 25 °C; VDS = 25 V
6
8
10
VGS (V)
VDS = 25 V
Fig 8. Forward transconductance as a function of
Fig 9. Transfer characteristics: drain current as a
function of gate-source voltage; typical values
BUK7610-55AL_2
Product data sheet
2
7 of 13
BUK7610-55AL
Nexperia
03aa32
5
03aa35
10−1
ID
(A)
VGS(th)
(V)
4
3
2
min
10−2
max
typ
10−3
min
10−4
typ
max
10−5
1
−60
120
180
10−6
Tj (°C)
2
4
6
VGS (V)
ID = 1 m A; VDS = VGS
T j = 25 °C; VDS = VGS
Fig 10. Gate-source threshold voltage as a function of
Fig 11. Sub-threshold drain current as a function of
gate-source voltage
003aaa730
18
03ne89
2
a
RDSon
(mΩ)
1.5
14
1
10
0.5
6
5
10
15
VGS (V)
T j = 25 °C; ID = 25 A
a=
Fig 12. Drain-source on-state resistance as a function
60
120
Tj (°C)
180
R DSon
R DSon (25°C )
Fig 13. Normalized drain-source on-state resistance
factor as a function of junction temperature
BUK7610-55AL_2
Product data sheet
8 of 13
BUK7610-55AL
Nexperia
003aaa735
10
003aaa738
8000
VGS
(V)
C
(pF)
Ciss
8
6000
VDS = 14 V
VDS = 44 V
6
Coss
4000
4
C
rss
2000
2
100
QG (nC)
150
1
10
VDS (V)
102
VGS = 0 V ; f = 1 M H z
Fig 14. Gate-source voltage as a function of gate
charge; typical values
Fig 15. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
003aaa736
150
IS
(A)
100
Tj = 25 °C
50
Tj = 175 °C
0.3
0.6
0.9
VSD (V)
1.2
VGS = 0 V
Fig 16. Source current as a function of source-drain voltage; typical values
BUK7610-55AL_2
Product data sheet
9 of 13
BUK7610-55AL
Nexperia
7. Package outline
SOT404
Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped)
A
A1
E
mounting
base
D1
D
HD
2
Lp
1
3
c
b
e
e
Q
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
c
D
max.
D1
E
e
Lp
HD
Q
mm
4.50
4.10
1.40
1.27
0.85
0.60
0.64
0.46
11
1.60
1.20
10.30
9.70
2.54
2.90
2.10
15.80
14.80
2.60
2.20
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-02-11
06-03-16
SOT404
Fig 17. Package outline SOT404 (D2PAK)
BUK7610-55AL_2
Product data sheet
10 of 13
BUK7610-55AL
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK7610-55AL_2
20080109
Product data sheet
BUK75_7610_55AL_1
Modifications:
BUK75_7610_55AL_1
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Typical thermal resistance (j-mb) figure added in Table 5.
20041022
Product data sheet
BUK7610-55AL_2
Product data sheet
11 of 13
BUK7610-55AL
Nexperia
9. Legal information
9.1
Data sheet status
Document status[1][2]
Product status[3]
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
Definition
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected to
result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore
such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
BUK7610-55AL_2
Product data sheet
12 of 13
Nexperia
BUK7610-55AL
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
11
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11
Legal information. . . . . . . . . . . . . . . . . . . . . . . 12
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Contact information. . . . . . . . . . . . . . . . . . . . . 12
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 09 January 2008
很抱歉,暂时无法提供与“BUK7610-55AL,118”相匹配的价格&库存,您可以联系我们找货
