F3 16A 115C
F3 16A 115C
    SUP(美隆)
    FUSE_8.3X3.4MM_TM
    一次性保险丝(熔断) FUSE_8.3X3.4MM_TM 300V 16A
F3 16A 115C 数据手册
A Series Ir : 1 A 温度保险丝 Thermal-link 尺寸 Dimensions (mm) 关键特性 Key Features ● ● ● ● ● 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 应用领域 Applications ● ● ● ● ● ● 灯具 Lamps 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 变压器 Transformers 电机 Motors 电池 Batteries 特殊定制 Customization ● ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 引线材质可选镀锡铜线或CP线 Tinned Copper Wires or CP Wires 包装信息 ● ● ● ● ● ● L1 W T d F 4.2±0.5 70±2 5.1±0.5 2.3±0.2 Φ0.50±0.05 3.2±0.5 技术参数 Specifications 型号 额定 熔断 Model 动作 温度 温度 Fusing Temp. Tf 保持 温度 Th 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur (°C) (°C) (°C) (°C) (A) (V) A0 76 73±2 53 200 1 AC 300 A1 86 81±2 61 200 1 A2 102 99±2 79 200 1 A3 115 111±2 91 200 1 A4 A5 A6 A7 A8 125 130 133 135 136 120±2 125±2 130±2 130±2 131±2 100 106 112 112 112 200 200 200 200 200 Agency Information 1 1 1 UL :E504471 CUL: E504471 CCC:2019180205010143 TUV: R50442306 140 136±2 121 200 1 A9 145 140±2 121 200 1 150 145±2 126 200 AC 300 ● ● DC 60 ● ● AC 300 ● ● ● ● ● ● ● ● ● ● ● ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● ● AC 300 ● ● ● DC 60 ● ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● AC300 ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● ● ● ● ● ● ● ● ● 1 A22 A10 UL CUL TUV CCC 1 Packaging Information 产品包装数量 Q’TY: 40 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 L 1 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● A11 160 156±2 135 200 1 AC 300 ● ● A25 185 182±3 150 250 1 AC 300 ● ● A20 205 198±3 160 250 1 AC 300 ● ● www.SUPfuse.com SUP@SUPfuse.com Thermal-link Thermal-link SUP A2 102 0C 1A 300V~ A01 GP B Series Ir : 2 A 温度保险丝 Thermal-link 尺寸 Dimensions (mm) 关键特性 Key Features ● ● ● ● ● 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 应用领域 Applications ● ● ● ● ● ● 灯具 Lamps 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 变压器 Transformers 电机 Motors 电池 Batteries 特殊定制 Customization ● ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 引线材质可选镀锡铜线或CP线 Tinned Copper Wires or CP Wires 包装信息 ● ● ● ● ● ● L1 W T d F 5.8±0.5 70±2 5.8±0.5 2.3±0.2 Φ 0.54±0.05 3.7±0.5 技术参数 Specifications 型号 额定 熔断 Model 动作 温度 温度 Fusing Temp. Tf 保持 温度 Th 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur (°C) (°C) (°C) (°C) (A) (V) B0 76 73±2 53 200 2 AC 300 B1 86 81±2 61 200 2 B2 102 99±2 79 200 2 B3 115 111±2 91 200 2 B4 B5 B6 B7 B8 125 130 133 135 136 120±2 125±2 130±2 130±2 131±2 100 106 112 112 112 200 200 200 200 200 Agency Information 2 2 2 UL :E504471 CUL: E504471 CCC:2019180205010143 TUV: R50442306 140 136±2 121 200 2 B9 145 140±2 121 200 2 150 145±2 126 200 AC 300 ● ● DC 60 ● ● AC 300 ● ● ● ● ● ● ● ● ● ● ● ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● ● AC 300 ● ● ● DC 60 ● ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● AC300 ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● ● ● ● ● ● ● ● ● 2 B22 B10 UL CUL TUV CCC 2 Packaging Information 产品包装数量 Q’TY: 40 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 L 2 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● B11 160 156±2 135 200 2 AC 300 ● ● B25 185 182±3 150 250 2 AC 300 ● ● B20 205 198±3 160 250 2 AC 300 ● ● www.SUPfuse.com SUP@SUPfuse.com Thermal-link Thermal-link SUP B5 130 0C 2A 300V~ A01 GP C Series Ir : 3 A 温度保险丝 Thermal-link 尺寸 Dimensions (mm) 关键特性 Key Features ● ● ● ● ● 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 应用领域 Applications ● ● ● ● ● ● 灯具 Lamps 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 变压器 Transformers 电机 Motors 电池 Batteries 特殊定制 Customization ● ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 引线材质可选镀锡铜线或CP线 Tinned Copper Wires or CP Wires 包装信息 ● ● L1 W T d F 5.8±0.5 70±2 5.8±0.5 2.3±0.2 Φ 0.54±0.05 3.7±0.5 技术参数 Specifications 型号 额定 熔断 Model 动作 温度 温度 Fusing Temp. Tf 保持 温度 Th 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur (°C) (°C) (°C) (°C) (A) (V) C0 76 73±2 53 200 3 AC 300 C1 86 81±2 61 200 3 C2 102 99±2 79 200 3 C3 115 111±2 91 200 3 C4 C5 C6 C7 C8 125 130 133 135 136 120±2 125±2 130±2 130±2 131±2 100 106 112 112 112 200 200 200 200 200 Agency Information 3 3 3 UL :E504471 ● CUL: E504471 ● CCC:2019180205010143 ● TUV: R50442306 :on going 140 136±2 121 200 3 C9 145 140±2 121 200 3 150 145±2 126 200 AC 300 ● ● DC 60 ● ● AC 300 ● ● ● ● ● ● ● ● ● ● ● ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● ● AC 300 ● ● ● DC 60 ● ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● AC300 ● ● AC 300 ● ● DC 60 ● ● AC 300 ● ● DC 60 ● ● ● ● ● ● ● ● ● ● 3 C22 C10 UL CUL TUV CCC 3 Packaging Information 产品包装数量 Q’TY: 40 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 L 3 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● C11 160 156±2 135 200 3 AC 300 ● ● C25 185 182±3 150 250 3 AC 300 ● ● C20 205 198±3 160 250 3 AC 300 ● ● www.SUPfuse.com SUP@SUPfuse.com Thermal-link Thermal-link SUP C5 130 0C 3A 300V~ A01 GP D Series Ir : 5 A 温度保险丝 Thermal-link Thermal-link Thermal-link SUP D2 102 0C 5A 300V~ A01 GP 尺寸 Dimensions (mm) 关键特性 Key Features ● ● ● ● ● 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant L L1 W T d F 7.0±0.5 50±2 6.6±0.5 2.7±0.3 Φ0.80±0.05 4.0±0.5 技术参数 Specifications 型号 额定 熔断 保持 极限 额定 Model 动作 温度 温度 温度 电流 Tm Ir 温度 Fusing Th Tf Temp. 额定 电压 Ur 标称 放电 电流 In 最大 放电 电流 Imax 8/20 μs 8/20 μs (15 Times) (1 Time) (°C) (°C) (°C) (°C) D2 102 99±2 77 D3 115 113±2 D4 125 120±2 UL CUL TUV CCC (A) (V) (kA) (kA) 200 5 AC 300 3 6 ● ● ● ● ● 89 200 5 AC 300 3 6 ● ● ● ● ● 98 200 5 AC 300 3 6 ● ● ● 130 125±2 103 200 5 AC 300 3 6 ● ● ● 133 130±2 108 200 5 AC 300 3 6 ● ● D7 135 130±2 108 200 5 AC 300 3 6 ● ● ● ● ● D8 136 131±2 108 200 5 AC 300 3 6 ● ● ● ● ● D10 150 145±2 123 200 5 AC 300 3 6 ● ● ● 应用领域 Applications ● ● ● ● ● 开关电源 Switched-mode Power Supply 防雷插座 Power Strips 灯具 Lamps 家用电器 Home Electrical Appliances 电池 Batteries 特殊定制 Customization ● ● ● ● 其它温度可定制 Other Temp. Can be Customized D5 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated D6 引线材质可选镀锡铜线或CP线 Tinned Copper Wires or CP Wires 包装信息 ● ● 产品包装数量 Q’TY: 50 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 ● ● ● ● Packaging Information ● Agency Information UL:E504471 CUL:E504471 CCC:2019180205010154 TUV:R50442308 www.SUPfuse.com SUP@SUPfuse.com E Series Ir : 10 A 温度保险丝 Thermal-link Thermal-link Thermal-link SUP E8 136 0C 10A 300V~ A01 GP 尺寸 Dimensions (mm) ● ● ● ● ● L L1 W T d F 7.5±0.5 45±2 8.3±0.5 3.4±0.2 Φ1.05±0.05 5.2±0.5 关键特性 Key Features 技术参数 Specifications 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 型号 额定 熔断 保持 极限 Model 动作 温度 温度 温度 Tm 温度 Fusing Th Temp. Tf 额定 电流 Ir 额定 电压 Ur 标称 放电 电流 In 最大 放电 电流 Imax 8/20 μs 8/20 μs (15 Times) (1 Time) (°C) (°C) (°C) (°C) (A) (Vac) (kA) (kA) UL CUL TUV CCC E2 102 99±2 72 200 10 300 5 10 ● ● ● ● ● E3 115 113±2 85 200 10 300 5 10 ● ● ● ● ● E4 125 121±2 95 200 10 300 5 10 ● ● ● E5 130 125±2 100 200 10 300 5 10 ● ● ● E6 133 130±2 106 200 10 300 5 10 ● ● E7 135 130±2 106 200 10 300 5 10 ● ● ● ● ● E8 136 131±2 106 200 10 300 5 10 ● ● ● ● ● E10 150 145±2 118 200 10 300 5 10 ● ● ● 应用领域 Applications ● ● ● ● ● 电涌保护器 SPD 防雷插座 Power Strips 灯具 Lamps 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 包装信息 ● ● ● ● ● ● Packaging Information 产品包装数量 Q’TY: 20 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 ● Agency Information UL:E504471 CUL:E504471 CCC:2019180205010154 TUV:R50442308 www.SUPfuse.com SUP@SUPfuse.com F Series Ir : 16 A 温度保险丝 Thermal-link Thermal-link Thermal-link SUP F3 115 0C 16A 300V~ A01 GP 尺寸 Dimensions (mm) ● ● ● ● ● L L1 W T d F 7.5±0.5 45±2 8.3±0.5 3.4±0.2 Φ1.05±0.05 5.2±0.5 关键特性 Key Features 技术参数 Specifications 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 型号 额定 熔断 保持 极限 Model 动作 温度 温度 温度 温度 Fusing Th Tm Tf Temp. 额定 电流 Ir 额定 电压 Ur 标称 放电 电流 In 最大 放电 电流 Imax 8/20 μs 8/20 μs (15 Times) (1 Time) (°C) (°C) (°C) (°C) (A) (Vac) (kA) (kA) F2 102 99±2 72 200 16 300 6 12 ● ● ● ● ● F3 115 113±2 85 200 16 300 6 12 ● ● ● ● ● F4 125 121±2 95 200 16 300 6 12 ● ● ● F5 130 125±2 100 200 16 300 6 12 ● ● ● F6 133 130±2 106 200 16 300 6 12 ● ● F7 135 130±2 106 200 16 300 6 12 ● ● ● ● ● F8 136 131±2 106 200 16 300 6 12 ● ● ● ● ● F10 150 145±2 118 200 16 300 6 12 ● ● ● UL CUL TUV CCC 应用领域 Applications ● ● ● ● ● 电涌保护器 SPD 防雷插座 Power Strips 灯具 Lamps 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 包装信息 ● ● ● ● ● ● Packaging Information 产品包装数量 Q’TY: 20 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 ● Agency Information UL:E504471 CUL:E504471 CCC:2019180205010154 TUV:R50442308 www.SUPfuse.com SUP@SUPfuse.com L Series Ir : 20 A 温度保险丝 Thermal-link Thermal-link Thermal-link SUP L3 115 0C 20A 300V~ A01 GP 尺寸 Dimensions (mm) 关键特性 Key Features ● ● ● ● ● 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant L L1 W T d F 13±0.5 45±2 11.5±0.5 4.9±0.5 Φ1.7±0.05 7.2±0.5 技术参数 Specifications 型号 Model 额定 动作 温度 Tf 熔断 保持 温度 温度 Fusing Th Temp. 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur 标称 放电 电流 In 最大 放电 电流 Imax (15 Times) 8/20 μs 8/20 μs (1 Time) (°C) (°C) (°C) (°C) (A) (Vac) (kA) (kA) L2 102 99±2 65 165 20 300 10 20 L3 115 113±2 78 165 20 300 12 25 ● ● L4 125 122±2 90 165 20 300 12 25 ● ● L5 130 126±2 96 165 20 300 12 25 L8 136 132±2 102 165 20 300 12 25 L10 150 145±2 116 165 20 300 12 25 CCC ● 应用领域 Applications ● ● ● ● ● 电涌保护器 SPD 防雷插座 Power Strips 灯具 Lamps 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 包装信息 ● ● Packaging Information 产品包装数量 Q’TY: 9 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 Agency Information :on going www.SUPfuse.com SUP@SUPfuse.com ● ● ● ● G Series Ir : 25 A 温度保险丝 Thermal-link Thermal-link Thermal-link SUP G3 115 0C 25A 300V~ A01 GP 尺寸 Dimensions (mm) 关键特性 Key Features ● ● ● ● ● 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant L L1 W T d F 13±0.5 45±2 11.5±0.5 4.9±0.5 Φ1.7±0.05 7.2±0.5 技术参数 Specifications 型号 Model 额定 动作 温度 Tf 熔断 保持 温度 温度 Fusing Th Temp. 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur 标称 放电 电流 In 最大 放电 电流 Imax (15 Times) 8/20 μs 8/20 μs (1 Time) (°C) (°C) (°C) (°C) (A) (Vac) (kA) (kA) G2 102 99±2 65 165 25 300 12 25 G3 115 113±2 78 165 25 300 15 30 ● ● G4 125 122±2 90 165 25 300 15 30 ● ● G5 130 126±2 96 165 25 300 15 30 G8 136 132±2 102 165 25 300 15 30 G10 150 145±2 116 165 25 300 15 30 CCC ● 应用领域 Applications ● ● ● ● ● 电涌保护器 SPD 防雷插座 Power Strips 灯具 Lamps 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 包装信息 ● ● Packaging Information 产品包装数量 Q’TY: 9 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 Agency Information :on going www.SUPfuse.com SUP@SUPfuse.com ● ● ● ● H Series Ir : 30 A 温度保险丝 Thermal-link Thermal-link Thermal-link SUP H2 102 0C 30A 300V~ A01 GP 尺寸 Dimensions (mm) 关键特性 Key Features ● ● ● ● ● 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant L L1 W T d F 13±0.5 45±2 11.5±0.5 4.9±0.5 Φ2.0±0.05 7.2±0.5 技术参数 Specifications 型号 Model 额定 动作 温度 Tf 熔断 保持 温度 温度 Fusing Th Temp. 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur 标称 放电 电流 In 最大 放电 电流 Imax (15 Times) 8/20 μs 8/20 μs (1 Time) (°C) (°C) (°C) (°C) (A) (Vac) (kA) (kA) H2 102 99±2 65 165 30 300 15 30 H3 115 113±2 78 165 30 300 20 40 ● ● H4 125 122±2 90 165 30 300 20 40 ● ● H5 130 126±2 96 165 30 300 20 40 H8 136 132±2 102 165 30 300 20 40 H10 150 145±2 116 165 30 300 20 40 CCC ● 应用领域 Applications ● ● ● ● ● 电涌保护器 SPD 防雷插座 Power Strips 灯具 Lamps 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 包装信息 ● ● Packaging Information 产品包装数量 Q’TY: 9 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 Agency Information :on going www.SUPfuse.com SUP@SUPfuse.com ● ● ● ● M Series Ir : 40 A 温度保险丝 Thermal-link Thermal-link Thermal-link SUP M3 115 0C 40A 300V~ B02 GP 尺寸 Dimensions (mm) 关键特性 Key Features ● ● ● ● ● 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant L L1 W T d F 15.5±1.0 50±2 13.8±1.0 5.7±0.8 Φ2.2±0.05 9.0±0.5 技术参数 Specifications 型号 Model 额定 熔断温度 保持 动作 Fusing 温度 Temp. Th 温度 Tf 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur 标称 放电 电流 In 最大 放电 电流 Imax (15 Times) 8/20 μs 8/20 μs (1 Time) (°C) (°C) (°C) (°C) (A) (Vac) (kA) (kA) M2 102 99±2 61 165 40 300 20 40 ● M3 115 113±2 75 165 40 300 25 50 ● M4 125 122±2 85 165 40 300 25 50 ● M5 130 126±2 90 165 40 300 25 50 ● M8 136 132±2 95 165 40 300 25 50 ● M10 150 145±2 110 165 40 300 25 50 ● 应用领域 Applications ● ● ● ● ● 电涌保护器 SPD 防雷插座 Power Strips 电池 Batteries 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 包装信息 ● ● Packaging Information 产品包装数量 Q’TY: 9 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) www.SUPfuse.com SUP@SUPfuse.com K Series Ir : 50 A 温度保险丝 Thermal-link Thermal-link Thermal-link SUP K3 115 0C 50A 300V~ A01 GP 尺寸 Dimensions (mm) 关键特性 Key Features ● ● ● ● ● 外壳激光打标 Shell Laser marking 阻燃性外壳 Flame retardant shell 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant L L1 W T d F 15.5±1.0 50±2 13.8±1.0 5.7±0.8 Φ2.2±0.05 9.0±0.5 技术参数 Specifications 型号 Model 额定 熔断温度 保持 动作 Fusing 温度 Temp. Th 温度 Tf 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur 标称 放电 电流 In 最大 放电 电流 Imax (15 Times) 8/20 μs 8/20 μs (1 Time) (°C) (°C) (°C) (°C) (A) (Vac) (kA) (kA) K2 102 99±2 61 165 50 300 25 50 ● K3 115 113±2 75 165 50 300 30 60 ● K4 125 122±2 85 165 50 300 30 60 ● K5 130 126±2 90 165 50 300 30 60 ● K8 136 132±2 95 165 50 300 30 60 ● K10 150 145±2 110 165 50 300 30 60 ● 应用领域 Applications ● ● ● ● ● 电涌保护器 SPD 防雷插座 Power Strips 电池 Batteries 开关电源 Switched-mode Power Supply 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可采用绝缘线 Lead Wires Can be Insulated 包装信息 ● ● Packaging Information 产品包装数量 Q’TY: 9 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) www.SUPfuse.com SUP@SUPfuse.com Thermal-link 尺寸 Dimensions (mm) L 21±1 ● ● ● ● ● ● ● L2 技术参数 Specifications 陶瓷外壳 Ceramic Case 预制安装孔 Make a Mounting Hole 引线为阻燃性绝缘线 Lead Wire is Flame Retardant Insulated 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 型号Model 额定 动作 温度 Tf 电热器具 Electric Heating Apparatus 家用电器 Home Electrical Appliances L3 W T d d1 d2 13.5±1.0 78±2 5.0±1.0 12±1 5.0±0.5 Φ5.5±1.0 Φ1.6±0.1 关键特性 Key Features 应用领域 Applications ● L1 Φ1.3±0.1 熔断温度 Fusing Temp. 保持 温度 Th 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur (°C) (°C) (°C) (°C) (A) (V) CCC EK2 102 99±2 72 200 10 AC 250 ● ● EK3 115 113±2 85 200 10 AC 250 ● ● EK4 125 121±2 95 200 10 AC 250 EK5 130 125±2 100 200 10 AC 250 EK6 133 130±2 107 200 10 AC 250 ● EK7 135 130±2 108 200 10 AC 250 ● EK8 136 131±2 108 200 10 AC 250 ● EK9 145 140±2 115 200 10 AC 250 ● EK10 150 145±2 120 200 10 AC 250 ● ● EK11 160 156±2 133 200 10 AC 250 ● ● EK12 200 197±2 160 380 10 AC 250 ● ● EK13 221 218±2 186 380 10 AC 250 ● ● EK16 230 225±3 190 380 10 AC 250 ● ● EK17 240 235±3 210 380 10 AC250 ● ● ● ● ● 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可带插拔端子 Lead Wires Can Make a Pluggable Terminals 包装信息 ● ● Packaging Information 产品包装数量 Q’TY: 3 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 :on going Agency Information www.SUPfuse.com SUP@SUPfuse.com Thermal-link EK Series Ir : 10 A 温度保险丝 Thermal-link Thermal-link 尺寸 Dimensions (mm) L 21±1 ● ● ● ● ● ● ● L2 技术参数 Specifications 陶瓷外壳 Ceramic Case 预制安装孔 Make a Mounting Hole 引线为阻燃性绝缘线 Lead Wire is Flame Retardant Insulated 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 型号Model 额定 动作 温度 Tf 电热器具 Electric Heating Apparatus 家用电器 Home Electrical Appliances L3 W T d d1 d2 13.5±1.0 78±2 5.0±1.0 12±1 5.0±0.5 Φ5.5±1.0 Φ1.6±0.1 关键特性 Key Features 应用领域 Applications ● L1 Φ1.3±0.1 熔断温度 Fusing Temp. 保持 温度 Th 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur (°C) (°C) (°C) (°C) (A) (V) CCC FK2 102 99±2 72 200 16 AC 250 ● ● FK3 115 113±2 85 200 16 AC 250 ● ● FK4 125 121±2 95 200 16 AC 250 FK5 130 125±2 100 200 16 AC 250 FK6 133 130±2 107 200 16 AC 250 ● FK7 135 130±2 108 200 16 AC 250 ● FK8 136 131±2 108 200 16 AC 250 ● FK9 145 140±2 115 200 16 AC 250 ● FK10 150 145±2 120 200 16 AC 250 ● ● FK11 160 156±2 133 200 16 AC 250 ● ● FK12 200 197±2 160 380 16 AC 250 ● ● FK13 221 218±2 186 380 16 AC 250 ● ● FK16 230 225±3 190 380 16 AC 250 ● ● FK17 240 235±3 210 380 16 AC250 ● ● ● ● ● 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可带插拔端子 Lead Wires Can Make a Pluggable Terminals 包装信息 ● ● Packaging Information 产品包装数量 Q’TY: 3 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 :on going Agency Information www.SUPfuse.com SUP@SUPfuse.com Thermal-link FK Series Ir : 16 A 温度保险丝 Thermal-link Thermal-link 尺寸 Dimensions (mm) L L1 21±1 ● ● ● ● ● ● 技术参数 Specifications 陶瓷外壳 Ceramic Case 预制安装孔 Make a Mounting Hole 引线为阻燃性绝缘线 Lead Wire is Flame Retardant Insulated 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 型号Model ● 电热器具 Electric Heating Apparatus 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可带插拔端子 Lead Wires Can Make a Pluggable Terminals 包装信息 ● ● Packaging Information 产品包装数量 Q’TY: 3 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) L3 W T d d1 13.5±1.0 78±2 5.0±1.0 12±1 5.0±0.5 Φ5.5±1.0 Φ1.7±0.1 关键特性 Key Features 应用领域 Applications ● L2 d2 Φ1.4±0.1 额定 动作 温度 Tf 熔断温度 Fusing Temp. 保持 温度 Th 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur (°C) (°C) (°C) (°C) (A) (V) LK5 130 125±2 100 200 20 AC 250 ● LK6 133 130±2 107 200 20 AC 250 ● LK7 135 130±2 108 200 20 AC 250 ● LK8 136 131±2 108 200 20 AC 250 ● LK9 145 140±2 115 200 20 AC 250 ● LK10 150 145±2 120 200 20 AC 250 ● LK11 160 156±2 133 200 20 AC 250 ● LK12 200 197±2 160 380 20 AC 250 ● LK13 221 218±2 186 380 20 AC 250 ● LK16 230 225±3 190 380 20 AC 250 ● LK17 240 235±3 210 380 20 AC250 ● LK18 184 181±3 145 380 20 AC250 ● LK19 192 187±3 150 380 20 AC250 ● LK20 205 200±3 160 380 20 AC250 ● LK21 216 210±3 175 380 20 AC250 ● www.SUPfuse.com SUP@SUPfuse.com Thermal-link LK Series Ir : 20 A 温度保险丝 Thermal-link Thermal-link 尺寸 Dimensions (mm) ● ● ● ● ● ● 技术参数 Specifications 陶瓷外壳 Ceramic Case 引线为阻燃性绝缘线 Lead Wire is Flame Retardant Insulated 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 型号Model 额定 动作 温度 Tf 电热器具 Electric Heating Apparatus 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可带插拔端子 Lead Wires Can Make a Pluggable Terminals 包装信息 ● ● L1 70±3 关键特性 Key Features 应用领域 Applications ● L 13±1 D 5.0±1.0 Φ9±1 d1 d2 Φ1.6±0.1 Φ1.3±0.1 熔断温度 Fusing Temp. 保持 温度 Th 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur (°C) (°C) (°C) (°C) (A) (V) CCC EY2 102 99±2 72 200 10 AC 250 ● EY3 115 113±2 85 200 10 AC 250 ● EY4 125 121±2 95 200 10 AC 250 ● EY5 130 125±2 100 200 10 AC 250 ● EY6 133 130±2 107 200 10 AC 250 ● EY7 135 130±2 108 200 10 AC 250 ● EY8 136 131±2 108 200 10 AC 250 ● EY9 145 140±2 115 200 10 AC 250 ● EY10 150 145±2 120 200 10 AC 250 ● EY11 160 156±2 133 200 10 AC 250 ● EY12 200 197±2 160 250 10 AC 250 ● EY18 120 115±2 90 250 10 AC 250 ● ● EY15 95 91±2 60 200 10 AC 250 ● ● ● Packaging Information 产品包装数量 Q’TY: 3 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 L2 Agency Information :on going www.SUPfuse.com SUP@SUPfuse.com Thermal-link EY Series Ir : 10 A 温度保险丝 Thermal-link Thermal-link 尺寸 Dimensions (mm) L 13±1 ● ● ● ● ● 关键特性 Key Features 技术参数 Specifications 陶瓷外壳 Ceramic Case 引线为阻燃性绝缘线 Lead Wire is Flame Retardant Insulated 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 环保型产品 RoHS & REACH Compliant 型号Model 额定 动作 温度 Tf 应用领域 Applications ● ● 电热器具 Electric Heating Apparatus 家用电器 Home Electrical Appliances 特殊定制 Customization ● ● ● 其它温度可定制 Other Temp. Can be Customized 引线长度可定制 The Length of Lead Wires Can be Customized as Required. 引线可带插拔端子 Lead Wires Can Make a Pluggable Terminals 包装信息 ● ● L1 70±3 Packaging Information 产品包装数量 Q’TY: 3 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 220 (mm) 安规认证 Agency Information L2 5.0±1.0 D Φ9±1 d1 Φ1.6±0.1 d2 Φ1.3±0.1 熔断温度 Fusing Temp. 保持 温度 Th 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur (°C) (°C) (°C) (°C) (A) (V) CCC FY2 102 99±2 72 200 16 AC 250 ● FY3 115 113±2 85 200 16 AC 250 ● FY4 125 121±2 95 200 16 AC 250 ● FY5 130 125±2 100 200 16 AC 250 ● FY6 133 130±2 107 200 16 AC 250 ● FY7 135 130±2 108 200 16 AC 250 ● FY8 136 131±2 108 200 16 AC 250 ● FY9 145 140±2 115 200 16 AC 250 ● FY10 150 145±2 120 200 16 AC 250 ● FY11 160 156±2 133 200 16 AC 250 ● FY12 200 197±2 160 250 16 AC 250 ● FY18 120 115±2 90 250 16 AC 250 ● ● FY15 95 91±2 60 200 16 AC 250 ● ● ● :on going www.SUPfuse.com SUP@SUPfuse.com Thermal-link FY Series Ir : 16 A 温度保险丝 Thermal-link LT Series Ir : 200 A Thermal-link Thermal-link 温度保险丝 Thermal-link SUP LT4 125°C 200A 100Vdc B03 GP 尺寸 Dimensions (mm) L L1 W W1 W2 W3 D T T1 20.0±0.5 35.6±0.5 35.0±0.5 8.5±0.5 32.5±0.5 42.5±2 3.3 13.5±0.5 1.50±0.05 关键特性 Key Features ● ● ● ● ● 额定电流 200 A Rated Current 200 A 一次性动作而不可复位 Non-resettable 动作温度精确 High Accuracy of Function Temp. 大通流容量 High Surge Capacity 引脚带安装孔 Pins with Mounting Holes 应用领域 Applications ● ● ● 其它温度可定制 Other Temp. Can be Customized 接线电极形状可以定制 The Shape of Connecting Leads Can be customized as Required. 包装信息 ● ● 型号 Model 额定 动作 温度 Tf 熔断 温度 Fusing Temp. 保持 温度 Th 极限 温度 Tm 额定 电流 Ir 额定 电压 Ur (°C) (°C) (°C) (°C) (A) (V) LT2 102 99±2 61 180 200 DC 100 ● LT3 115 112±2 74 180 200 DC 100 ● LT4 125 122±2 84 180 200 DC 100 ● LT5 130 126±2 88 180 200 DC 100 ● LT8 136 132±2 94 180 200 DC 100 ● LT10 150 146±2 108 180 200 DC 100 ● LT11 160 156±2 123 180 200 DC 100 ● 电池 Batteries 汽车电子Automobile Electronic 特殊定制 Customization ● 技术参数 Specifications Packaging Information 产品包装数量 Q’TY: 1.5 kPCS/箱 Carton 外箱尺寸 Carton Size: 440 × 300 × 260 (mm) www.SUPfuse.com SUP@SUPfuse.com
F3 16A 115C 价格&库存
很抱歉,暂时无法提供与“F3 16A 115C”相匹配的价格&库存,您可以联系我们找货
