MKDV8GIL-AS
MKDV8GIL-AS
    MK(米客方德)
    LGA8_6X8MM
    存储器类型:Non-Volatile 存储器构架(格式):FLASH 技术:NAND Flash 存储器容量:8Gb 时钟频率:50MHz 存储器接口类型:SD2.0 SD NAND,8Gbit(1G...
MKDV8GIL-AS 数据手册
Embedded Tailor™ SD Flash MKDVXXIL Industrial Grade Specification Ver.1.3 Sep.2019 -1- Tailor™ SD Rev. 1.0 1.2 1.3 Description Original version Operating Temperature SPI Mode Pin Assignment M K Fo un de rC on fid en tia l Revision History Date 2018/4/20 2019/2/15 2019/9/27 -2- Tailor™ SD CONTENTS 1. Introduction .............................................................................................................................................................. - 1 2. Product List ............................................................................................................................................................. - 1 3. Features........................................................................................................................................................................1 tia l 4. Physical Characteristics .............................................................................................................................................2 4.1. Temperature ......................................................................................................................................................2 en 5. Pin Assignments(SD Mode& SPI Mode)................................................................................................................. 2 6. Usage ............................................................................................................................................................................3 fid 6.1 SD Bus Mode protocol .....................................................................................................................................3 6.2. Card Initialize ....................................................................................................................................................5 on 6.3 DC Characteristics ...........................................................................................................................................7 rC 7. Internal Information .....................................................................................................................................................8 7.1 Registers ............................................................................................................................................................8 de 7.1.1 OCR Register .................................................................................................................................................9 7.1.2. CID Register ................................................................................................................................................10 un 7.2.3. CSD Register ..............................................................................................................................................11 7.1.4. RCA Register ..............................................................................................................................................12 Fo 7.1.5. DSR Register ..............................................................................................................................................12 8. Power Scheme ..........................................................................................................................................................13 K 8.1. Power Up.........................................................................................................................................................13 M 8.2 Power Up Time ................................................................................................................................................13 8.2.1 Power On or Power Cycle ..........................................................................................................................14 8.2.2 Power Supply Ramp Up .............................................................................................................................14 8.2.3 Power Supply Ramp Up .............................................................................................................................14 9. Package Dimensions ................................................................................................................................................15 10. Reference Design ...................................................................................................................................................16 -3- Tailor™ SD 1. Introduction MK Founder Tailor™ SD is an embedded storage solution designed in a LGA package form. The operation of SD is similar to an SD card which is an commercial standard. Tailor™ SD consists of NAND flash and a high performance controller. 3.3V supply voltage is required for the NAND area (VCC). Tailor™ SD is fully compliant with SD2.0 interface, which allows most of general CPU to utilize. Tailor™ SD has high performance at a competitive cost, high quality and low power consumption. 1Gb 2Gb 4Gb 8Gb de rC 3. Features LGA-8 LGA-8 LGA-8 LGA-8 on MKDV1GIL MKDV2GIL MKDV4GIL MKDV8GIL Package en Capacity fid Part No. tia l 2. Product List Support up to 50Mhz clock frequency  SD-protocol compatible  Supports SPI Mode  Built-in HW ECC Engine and highly reliable NAND management mechanism  Write speed up to class 6  Smaller package LGA-8 M K Fo un  -1- Size 6x8mm 6x8mm 6x8mm 6x8mm Tailor™ SD 4. Physical Characteristics 4.1. Temperature 1) Operation Conditions Temperature Range: Ta = -45 to 85 degrees centigrade 2) Storage Conditions Temperature Range: Tstg = −65 to 150 degrees centigrade 5. Pin Assignments(SD Mode& SPI Mode) TOP VIEW a. Type Key: S=power supply; I= input; O=output using push-pull drivers; PP=I/O using push-pull drivers. b. The extended DAT lines (DAT1-DAT3) are input on power up. They start to operate as DAT lines after the SET_BUS_WIDTH Type Key: S=power supply; I=input; O=output using push-pull drivers; PP=I/O using push-pull drivers. c. At power up this line has a 50 kilohm pull-up enabled in the card. This resistor serves two functions: Card detection and Mode Selection. For Mode Selection, the host can drive the line high or let it be pulled high to select SD mode. If the host wants to select SPI mode it should drive the line low. For Card detection, the host detects that the line is pulled high. This pull-up should be disconnected by the user, during regular data transfer, with SET_CLR_CARD_DETECT (ACMD42) command. 2 Tailor™ SD 6. Usage 6.1 SD Bus Mode protocol The SD bus allows the dynamic configuration of the number of data line from 1 to 4 Bi-directional data signal. After power up by default, the SD card will use only DAT0. After initialization, host can change the bus width. tia l Multiplied SD cards connections are available to the host. Common VDD, VSS and CLK signal connections are available in the multiple connections. However, Command, Respond and Data lined (DAT0-DAT3) shall be divided for each device from host. fid en This feature allows easy trade off between hardware cost and system performance. Communication over the SD bus is based on command and data bit stream initiated by a start bit and terminated by stop bit. on Command: Commands are transferred serially on the CMD line. A command is a token to starts an operation from host to the device. Commands are sent to an addressed single card (addressed Command) or to all connected cards (Broad cast command). de rC Response:Responses are transferred serially on the CMD line. A response is a token to answer to a previous received command. Responses are sent from an addressed single card or from all connected cards. Data:Data can be transfer from the card to the host or vice versa. Data is transferred via the data M K Fo un lines. 3 Tailor™ SD Host card Clock signal Bi-directional Command/ Response Signal 4 Bi-directional data signal Power supply GND M K Fo un de CLK CMD DAT0 - DAT3 VDD VSS rC on fid en tia l Tailor™ SD (A) 4 Tailor™ SD 6.2. Card Initialize To initialize the Tailor™ SD, follow the following procedure is recommended example. 1) Supply Voltage for initialization. Host System can apply the Operating Voltage from initialization to the card. Apply more than 74 cycles of Dummy-clock to the SD card. 2) Select operation mode (SD mode or SPI mode) tia l In case of SPI mode operation, host should drive 1 pin (CD/DAT3) of SD Card I/F to “Low” level. Then, issue CMD0. In case of SD mode operation, host should drive or detect 1 pin of SD Card I/F (Pull up register of 1 pin is pull up en to “High” normally). fid Card maintain selected operation mode except re-issue of CMD0 or power on below is SD mode initialization procedure. on 3) Send the ACMD41 with Arg = 0 and identify the operating voltage range of the Card. 4) Apply the indicated operating voltage to the card. rC Reissue ACMD41 with apply voltage storing and repeat ACMD41 until the busy bit is cleared. (Bit 31 Busy = 1) If response time out occurred, host can recognize not SD Card. de 5) Issue the CMD2 and get the Card ID (CID). Issue the CMD3 and get the RCA. (RCA value is randomly changed by access, not equal zero) un 6) Issue the CMD7 and move to the transfer state. If necessary, Host may issue the ACMD42 and disabled the pull up resistor for Card detect. Fo 7) Issue the ACMD13 and poll the Card status as SD Memory Card. Check SD_CARD_TYPE value. If significant 8 bits are “all zero”, that means SD Card. If it is not, stop initialization. K 8) Issue CMD7 and move to standby state. Issue CMD9 and get CSD. M Issue CMD10 and get CID. 9) Back to the Transfer state with CMD7. Issue ACMD6 and choose the appropriate bus-width. Then the Host can access the Data between the SD card as a storage device. 5 Tailor™ SD Power-on CMD0 No Response CMD8 Card returns response Ver2.00 or later SD Memory Card Ver2.00 or later SD Memory Card (voltage mismatch) Or Ver1.X SD Memory Card Or not SD Memory Card Valid Response ? Card with compatible Voltage range Card returns busy Cards with non compatible voltage range(card goes to ‘ina’ state) or timeout (no response or busy) occurs Card returns ready Card is ready ? Card returns ready Fo un de rC CCS=0 Ver2.00 or later Standard Capacity SD Memory Card K No Other SD Card (SD IO or Others) 6 Ver2.00 or later High Capacity SD Memory Card CMD2 Get CID CMD3 Get RCA CMD7 Choose card with RCA ACMD42 Disable the Pull-up Resister (If necessary) ACMD3 Get SD status Memory Card ? Yes CMD7 Idle state with RCA=0000 CMD9 Get CSD CMD10 Get CID CMD7 Choose card with RCA ACMD6 Choose Data Bus Width Transfer mode SD card Initialize Procedure Unusable Card CCS=1 on CCS in ready ? Not SD Memory Card Ver1.X Standard Capacity SD Memory Card Cards with non compatible voltage range or time out ( no response or busy ) occurs fid Unusable Card If host supports high capacity, HCS is set to 1 ACMD41 with HCS=0 or 1 en Card is ready ? M Unusable Card Compatible voltage range and check pattern is correct l Card returns busy tia ACMD41 with HCS=0 No Response Non-compatible voltage range or check pattern is not correct Data Access Enable Tailor™ SD 6.3 DC Characteristics - Operation Write Current (*) Read Input Voltage Setup Time ICC2 - - - Vrs 0.05 30 (8Gb) 28(8Gb) 250 mA mA fid Signal Capacitance Min. Max. uA uA Unit 10 100 kΩ ─ 40 pF ─ 10 pF 10 90 kΩ ─ 5 uF M K CC Note on rC 10 de CCAR D RDAT3 Fo Total bus capacitance for each signal line Card capacitance for signal pin Pull up Resistance inside card ( pin1 ) Capacity Conneted to Power line Symbol RCMD RDAT CL -10 10 un Item Pull up Resistance Peak Voltage and Leak Current Min. Max. Unit VDD+0.3 -0.3 V -10 3.3V / 25MHz, 50MHz ms From 0V to VDD min *) Peak Current: RMS value over a 10usec period Item Symbol Peak voltage on all lines Input Leakage Current for all pins Output Leakage Current for all outputs IOH = -2mA , VDD=VDD min IOL = 2mA , VDD=VDD min VDD = 3.6V , Clock 25MHz VDD = 3.3V, Clock STOP, Ta=25℃ l ICC1 Note tia Standby Current Unit V V V V V en Item Symbol VDD Supply Voltage VIH High Level Input VIL Voltage Low Level High Level VOH Output VOL Voltage Low Level DC Characteristics MIN. MAX. 2.7 3.6 VDD+0.3 VDD×0.625 VSS-0.3 VDD×0.25 - VDD×0.75 - VDD×0.125 - 0.25(8Gb) 7 Note 1 card CHOST+CBUS≦30pF Tailor™ SD 7. Internal Information 7.1 Registers The Tailor™ SD has six registers and SD Status information: OCR, CID, CSD, RCA, DSR, SCR and SD Status. DSR IS NOT SUPPORTED in this card. There are two types of register groups. Description on fid en Operation Conditions (VDU Voltage Profile and Busy Status Card Identification information Information) Card specific information Relative Card Address Not Implemented (Programmable Card Driver): Driver Stage Register SD Memory Card‟s special features Status bits and Card features M K Fo un de rC Resister Bit Width Name OCR 32 CID 128 CSD 128 RCA 16 DSR 16 SCR 64 SD Status 512 tia SD card Registers l MMC compatible registers: OCR, CID, CSD, RCA, DSR, and SCR SD card Specific: SD Status 8 Tailor™ SD 7.1.1 OCR Register This 32-bit register describes operating voltage range and status bit in the power supply. OCR register definition OCR bit positio 31 n 30 VDD voltage window 1Gb Card power up status bit(busy) Card Capacity Status Initial 2GbValue4Gb 8Gb “0” = busy “1” = “0”= SD Memory ready Card All „0‟Memory “1”= SDHC 0 Card 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 All „0‟ M K Fo un de rC on fid en tia l 29-25 reserved 24 Switching to 1.8V Accepted(S18A) 23 3.6 - 3.5 22 3.5 - 3.4 21 3.4 - 3.3 20 3.3 - 3.2 19 3.2 - 3.1 18 3.1 - 3.0 17 3.0 - 2.9 16 2.9 - 2.8 15 2.8 - 2.7 14 Reserved 13 Reserved 12 Reserved 11 Reserved 10 Reserved 9 Reserved 8 Reserved 7 Reserved for Low Voltage Range 6 Reserved 5 Reserved 4 Reserved 3-0 reserved bit 23-4: Describes the SD Card Voltage bit 31 indicates the card power up status. Value “1” is set after power up and initialization procedure has been completed. 9 Tailor™ SD 7.1.2. CID Register The CID (Card Identification) register is 128-bit width. It contains the card identification information. (Refer Appendix 3. for the detail) The Value of CID Register is vender specific. Table 11: CID Register CID-slice 1Gb 8Gb -- M K Fo un de rC on fid en tia Width l Initial Value 2Gb 4Gb MID 8 [127:120] TB OID 16 [119:104] TBD D TBD TBD PNM 40 [103:64] TBD PRV 8 [63:56] TB PSN 32 [55:24] (a) (ProductDserial number) 4 [23:20] All “0b” MDT 12 [19:8] (a) (Manufacture date) CRC 7 [7:1] (b) (CRC) 1 [0:0] 1b (a): Depends on the SD Card. Controlled by Production Lot. (b) Depends on the CID Register Field 10 Tailor™ SD 7.2.3. CSD Register CSD is Card-Specific Data register provides information on 128bit width. Some field of this register can writable by PROGRAM_CSD (CMD27). M K Fo un de rC on fid en tia l CSD Register Initial Value Cell CSD Field Width 1Gb 2Gb 4Gb 8Gb Type Slice CSD_STRUCTURE 2 R [127:126] 01b 6 R [125:120] All “0b” TAAC 8 R [119:112] 0_0001_110b (1ms) NSAC 8 R [111:104] 00000000 TRAN_SPEED 8 R [103:96] 0_0110_010b b CCC 12 R [95:84] 0101_1011_0101 READ_BL_LEN 4 R [83:80] 1001b b READ_BL_PARTIAL 1 R [79:79] 0b WRITE_BLK_MISALIG 1 R [78:78] 0b READ_BLK_MISALIGN 1 R [77:77] 0b N DSR_IMP 1 R [76:76] 0b 6 R [75:70] All “0b” C_SIZE 22 R [69:48] TBD TBD TBD -1 R [47:47] 0b ERASE_BLK_EN 1 R [46:46] 1b SECTOR_SIZE 7 R [45:39] 11_1111_1 WP_GRP_SIZE 7 R [38:32] 000_0000 b WP_GRP_ENABLE 1 R [31:31] 0b b 2 R [30:29] 00b R2W_FACTOR 3 R [28:26] 010b WRITE_BL_LEN 4 R [25:22] 1001b WRITE_BL_PARTIAL 1 R [21:21] 0b 2 R [20:16] All “0b” FILE_FORMAT_GRP 1 R [15:15] 0b R/W(1 [14:14] COPY 1 0b ) (1 R/W [13:13] 0b PERM_WRITE_PROTE 1 ) 1 R/W [12:12] 0b TMP_WRITE_PROTEC CT FILE_FORMAT 2 R [11:10] 00b T 2 R [9:8] All “0b” CRC 7 R/W [7:1] (CRC) 1 [0:0] 1b (1) Cell Type: R: Read Only, R/W: Writable and Readable, R/W : One-time Writable / Readable Note: Erase of one data block is not allowed in this card. This information is indicated by “ERASE_BLK_EN”. Host System should refer this value before one data block size erase. 11 Tailor™ SD 7.1.4. RCA Register The writable 16bit relative card address register carries the card address in SD Card mode. 7.1.5. DSR Register M K Fo un de rC on fid en tia l This register is not implemented on this car 12 Tailor™ SD 8. Power Scheme on fid en tia l 8.1. Power Up rC 'Power up time' is defined as voltage rising time from 0 volt to VDD min. de 'Supply ramp up time' provides the time that the power is built up to the operating level (Host Supply Voltage) and the time to wait until the Tailor™ SD can accept the first command, Fo un The host shall supply power to the card so that the voltage is reached to Vdd_min within 250ms and start to supply at least 74 SD clocks to the Tailor™ SD with keeping CMD line to high. K 8.2 Power Up Time M Host needs to keep power line level less than 0.5V and more than 1ms before power ramp up. 13 Tailor™ SD 8.2.1 Power On or Power Cycle Followings are requirements for Power on and Power cycle to assure a reliable Tailor™ SD hard reset. (1) Voltage level shall be below 0.5V tia l (2) Duration shall be at least 1ms. en 8.2.2 Power Supply Ramp Up on fid The power ramp up time is defined from 0.5V threshold level up to the operating supply voltage which is stable between VDD(min.) and VDD(max.) and host can supply SDCLK. Followings are recommendation of Power ramp up: rC (1) Voltage of power ramp up should be monotonic as much as possible. (2) The minimum ramp up time should be 0.1ms. un de (3) The maximum ramp up time should be 35ms for 2.7-3.6V power supply. Fo 8.2.3 Power Supply Ramp Up K When the host shuts down the power, the VDD shall be lowered to less than 0.5Volt for a minimum period of 1ms. During power down, DAT, CMD, and CLK should be disconnected or driven to logical 0 by the host to avoid a situation that the operating current is drawn through the signal lines. M If the host needs to change the operating voltage, a power cycle is required. Power cycle means the power is turned off and supplied again. Power cycle is also needed for accessing cards that are already in Inactive State. To create a power cycle the host shall follow the power down description before power up the card (i.e. the VDD shall be once lowered to less than 0.5Volt for a minimum period of 1ms). 14 Tailor™ SD 9. Package Dimensions Package Outline Drawing Information for LGA LGA (8 x 6 x 0.8mm) Dimension Table 15 Tailor™ SD on fid en tia l 10. Reference Design rC RDAT and RCMD (10K~100 kΩ) are pull-up resistors protecting the CMD and the DAT lines against bus floating when Tailor™ SD is in a high-impedance mode. M K Fo un Rclk reference 0~120 Ω de The host shall pull-up all DAT0-3 lines by RDAT, even if the host uses the Tailor™ SD as 1 bit mode-only in SD mode. It is recommended to have 2.2uF capacitance on VDD. 16
MKDV8GIL-AS 价格&库存
很抱歉,暂时无法提供与“MKDV8GIL-AS”相匹配的价格&库存,您可以联系我们找货
