Thick Film Chip Resistors
Description:
The resistors are constructed in a high grade ceramic body (aluminum oxide).
Internal metal electrodes are added at each end and connected by a resistive paste
that is applied to the top surface of the substrate. The composition of the paste is
adjusted to give the approximate resistance required and the value is trimmed to
within tolerance by laser cutting of this resistive layer.
The resistive layer is covered with a protective coat. Finally, the two external
end terminations are added. For ease of soldering the outer layer of these end
terminations is a Tin (lead free) alloy.
Features:
High reliability and stability
Reduced size of final equipment
Lower assembly costs
Higher component and equipment reliability
Application:
Quick Reference Data
• Consumer electrical equipment
• EDP, Computer application
• Telecom application
Item
General Specification
Series No.
MCWR12
MCWR08
MCWR06
MCWR04
Size code
1206(3216)
0805(2012)
0603(1608)
0402(1005)
Resistance Range
1Ω to10MΩ 1% tolerance
Resistance Tolerance
1%
E96/E24
TCR (ppm/°C)
10MΩ ≥R >10
R≤10Ω
≤ ± 100
-200 to +400
Max. dissipation
@ Tamb=70°C
1/4 W
1/8 W
1/10 W
1/16 W
Max. Operation
Voltage (DC or RMS)
200V
150V
75V
50V
Max. Overload
Voltage (DC or RMS)
400V
300V
150V
100V
Climatic category
55/155/56
Note :
1. Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by
RCWV = Rated Power × Resistance Value or Max. RCWV listed above, whichever is lower.
2. The resistance of Jumper is defined
很抱歉,暂时无法提供与“MCWR12W1R80FTL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10865
- 200+0.10141
- 600+0.09416
- 2000+0.08692
- 5000+0.07968
- 10000+0.07461
