HV series
HV Series
Features
SMD
◆ Long life of 2000 hrs at 105℃
◆ Reflow soldering is available
◆ Available for high density mounting
◆ For detail specifications, please refer to Engineering Bulletin No. E131
◆ RoHS Compliant
Specifications
Item
Operating Temperature Range
Rated Voltage Range
Capacitance Range
Capacitance Tolerance
Performance Characteristics
-55 +105℃
6.3~50 VDC
0.1 to 1500μF
±20%(120Hz,+20℃)
I≦0.01 CV or 3 (μA)
After 2 minutes, whichever is greater measured with rated working voltage applied
Leakage Current (+20℃,max.)
Dissipation Factor
(tanδ,at 20℃,120Hz)
Working voltage(VDC)
6.3
10
16
25
35
50
φ4~6.3
30
24
14
14
φ8~10
35
26
24
18
14
14
D.F.(%)max
Impedance ratio max
Rated voltage(VDC)
Z-25℃ Z+20℃
Z-40℃ Z+20℃
Low Temperature Characteristics
(at 120Hz)
Load Life
Shelf Life
6.3
6
12
10
4
10
16
4
8
25
3
6
35
2
4
50
2
4
Test conditions
Duration time
:2000 Hrs
Ambient temperature
:+105℃
Applied voltage
:Rated DC working voltage
After test requirement at +20℃:
Capacitance change
:Within ±30% of the initial value
Dissipation factor
:Not more than 300% of specified value
Leakage current
:Not more than the specified value
Test conditions
Duration time
:1000 Hrs
Ambient temperature
:+105℃
Applied voltage
:None
After test requirement at +20℃ : Same limits as Load life.
Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes.
The capacitors shall be kept on the hot plate maintained at 250℃for 30 seconds. After removing form the
hot plate and restored at room temperature, they meet the characteristic requirements listed under.
Resistance to soldering heat
Leakage current
Capacitance change
Less than specified value
Within ±10% of initial value
tanδ
Multiplier for Ripple Current vs. Frequency
CAP(μF) Frequency(Hz)
0.1≦CAP≦100μF
100<CAP≦1500μF
60(50)
0.8
0.8
120
1.0
1.0
500
1.20
1.10
1K
1.30
1.15
≧10K
1.50
1.20
Diagram of Dimensions:(unit:mm)
φD
4
5
6.3
6.3
8
8
10
Cathode
59
L
A
B
C
5.5 4.3 4.3 4.9
5.5 5.3 5.3 5.9
5.5 6.6 6.6 7.2
7.7 6.6 6.6 7.2
6.5 8.3 8.3 9.0
10.5 8.3 8.3 9.0
10.5 10.3 10.3 11.0
W
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.5~0.8
0.7~1.1
0.7~1.1
P
1.0
1.4
2.2
2.2
2.3
3.1
4.5
HV Series
Case Size
φDxL(mm)
WV (SV)
Cap(μF)
0.1
0.22
0.33
0.47
1
2.2
3.3
4.7
10
Size
6.3
(8)
Ripple
Size
10
(13)
Ripple
Size
16
(20)
Ripple
22
4X5.5
23
4X5.5
25
33
4X5.5
28
4X5.5
34
4X5.5
5X5.5
5X5.5
6.3X5.5
6.3X5.5
8X6.5
6.3X7.7
8X6.5
6.3X7.7
8X10.5
37
42
46
57
70
90
90
130
140
170
5X5.5
40
6.3X5.5
8X6.5
6.3X5.5
8X6.5
6.3X7.7
8X6.5
55
60
90
110
140
160
4X5.5
4X5.5
5X5.5
5X5.5
6.3X5.5
5X5.5
6.3X5.5
6.3X7.7
8X6.5
6.3X7.7
8X6.5
6.3X7.7
8X10.5
8X10.5
195
8X10.5
250
470
8X10.5
210
560
680
1000
1200
1500
8X10.5
10X10.5
10X10.5
10X10.5
10X10.5
310
370
480
500
520
8X10.5
10X10.5
10X10.5
10X10.5
10X10.5
350
420
450
480
530
8X10.5
10X10.5
10X10.5
10X10.5
370
420
480
540
47
100
150
220
330
Size
25
(32)
35
(44)
Ripple
Size
Ripple
4X5.5
4X5.5
12
22
5X5.5
38
6.3X5.5
48
6.3X7.7
8X6.5
6.3X7.7
8X10.5
56
60
110
160
4X5.5
4X5.5
5X5.5
6.3X5.5
6.3X7.7
8X6.5
6.3X7.7
8X6.5
6.3X7.7
8X10.5
14
24
40
46
47
50
60
65
130
180
50
(63)
Size
4X5.5
4X5.5
4X5.5
4X5.5
4X5.5
4X5.5
4X5.5
4X5.5
6.3X5.5
6.3X7.7
8X6.5
6.3X7.7
8X10.5
6.3X7.7
8X10.5
Ripple
1.0
2.0
3.0
4.0
8.4
11
13
18
28
50
55
95
135
115
155
10X10.5
315
35
36
40
45
56
58
62
125
140
170
185
8X10.5
175
8X10.5
190
10X10.5
330
8X10.5
10X10.5
180
190
8X10.5
10X10.5
250
280
10X10.5
350
8X10.5
290
10X10.5
360
10X10.5
440
Ripple Current ( mA, rms ) at 105℃
60
很抱歉,暂时无法提供与“HV101M035E077R”相匹配的价格&库存,您可以联系我们找货
