东莞市汉博电子科技有限公司
Dongguan Hanbo Electronic Technology Co., Ltd
承
认
书
SPECIFICATION FOR APPROVAL
客
户Customer:
产品名称Project:
轻触开关
规格型号Part No:
TS-KG07U
贵公司承认印 Approal slgnatures
料 号/Part No.
签
章/Signatures
日期 Date:
Thank you for your support
网址:http://www.hanbodianzi.com
alibaba:https://hanbodianzii.1688.com/
电话/TEL:17818537717 黄达
拟制/Drawn
潘伟垦
审核/Check
丁熊钊
批准/Approved
李国栋
TEL:17818910097 林振强
传真/FAX:0769-82866750
邮箱:hanbodianz@foxmail.com
企业客服QQ: 578882810 黄生
2293580177 林生
东莞市汉博电子科技有限公司
PART NAME;
TOLERANCE;
30~ 以上 ±0.30
10~30
±0.20
5~10
~5
±0.15
±0.10
ANGLE
DWN
CHKD
APVD
±2°
CUSTOMER COPY
SCALE 1;1
3*6*2.5贴片式红头包脚
TS-KG07U
潘伟垦
2013/06/30
丁熊钊
李国栋
UNIT: mm
SHEET:1OF1
东莞市汉博电子科技有限公司
Page
1/6
PARTNO.
TS-KG07U
SPECIFICATION
1、General Charactenstics 一般特性:
1.1 适用范围
APPLICATION
此规格书适用于机械式轻触开关的相关要求
This specification is applied to the requirements for TACTILE SWITCH (MECHANICAL CONTACT)
1.2 工作温度范围
Operating Temperature Range
-20℃~80℃(在标准大气压、标准湿度条件下)
-20℃~80℃(Normal humidity, normal air pressure)
1.3 Operating Relative Humidiy.≤85%RH
相对湿度≤85%RH
1.4 TeStConditions Unless otherwise specofoed the atmospheric conditions for making measurements
and tets are asfollows:
实验条件:诺没有特别说明,测试大气条件如下:
Ambient Temperature:5-35°C,Relative umidity:45-85%
环境温度:5-35°C 相对温度:45-/85%
大气压力:86-106Kpa(860-1060mbar)
2.Appearance;The switch shall have good fimishing,and no rust crackorplating defects.
外观:产品外观良好,无锈腐、裂纹和镀层缺陷
2.1 Stucture Dimensions:Refer to individual product drawing.
结构及尺寸:参加产品图纸
3.Ratings 额定负荷
DC12V 50mA
4.Electrical Characteristics 电气特性
4.1
100mΩ Max.
接触电阻
Contact
Resistance
4.2
4.3
绝缘电阻
Insulation
esistance
抗电强度
Dielectric
Voltage
100mΩ Min.
Nodielectricbreakdown
shall occur.
无击穿现象发生。
在以5V 10mA 的直流电源或不低于1KHz
的交流电源的电路中以一个等于2倍按力
的静负荷施加于手柄中心
Applying a static load of 2 times
operating force to the center of
thestem,measurements shall be made
by 5V DC 10mA or more than 1KHZ AC
small-current contact resistance
meter
measurement shall be made following
application of 100V DC potential
across teminals,and across teminals
and cover,for one minute
在端子之间施加DC 100V/1min的条件下
测量端子之间底座、盖板的电阻值
250VAC (50-60HZ,cutoff current2mA)
isapplied between non-connected
teminals and between terminals and
themeta1frame for 60±5S
在相互绝缘的所有接线端子之间250V
(50-60Hz)交流电,持续时间60±5S
Page
东莞市汉博电子科技有限公司
PARTNO.
2/6
TS-KG07U
SPECIFICATION
No.
Item项目
Cniteria 标准
After test,
Test Method 实验方法
Switch shall bemeasured after following test:
Contact resistance:200 mΩMax
(1)Mounting Method:Normal
Nofunctional defective occur
(2)Acceleration:490m/s(50G)
Shall be free from mechanical
(3)Duration:11ms
abnormalities.
(4)Test Direction:6directions
Mechanical
Shock
冲击
5.6
实验后:
接触电阻:200 mΩMax.
无功能性不良。
表面无变形且操作无异常
(5)Number of shocks:3times per direction
(18times intotal)试件在下述参数条件下
进行试验:
(1)安装方法:常规方法
(2)加速度:490m/s2(50G)
(3)时间:11ms
(4)试验方向:图示6方向
(5)冲击速度:每个方向3次(总共18次)
The switch is tested under the following parameters:
(1) Equipment: automatic welding machine
(2) Solder: General
(3) Flux: a colorless transparent solution of 25% rosin and 75% methanol
(4) Welding temperature: 260 ± 5 ° C
(5) Immersion time: 3 ± 1s
(6) Immersion depth: the terminal shall be immersed in the root of the switch
5.7
SolderAbility
可焊性
More than 90% of immersed
part shall
becovered with solder.
超过90%的浸锡面积被焊料
所覆盖。
开关在下述参数条件下进行试验:
(1)设备:自动焊接机
(2)焊料:常规
(3)焊剂:焊剂质量百分比为25%松香为75%
甲醇的无色透明溶液。
(4)焊接温度:260±5°C
(5)浸渍时间:3±1S
(6)浸渍深度:接线端应浸到开关根部处
东莞市汉博电子科技有限公司
Page
3/6
PARTNO.
TS-KG07U
SPECIFICATION
5.Mechanical Characteristics 机械特性
No.
5.1
Item 项目
Criteria 标准
160±30gf
Operating
Force
操作力
5.2
Return
Force
回弹力
5.3
90 gfMin
Terminal
Strength
端子强度
0.16±0.05mm
Shall be free from
terminallooseness
damageandins u1ator
breakage.Nofunctiona1
defective occur
端子无松动,损坏及绝缘层的
开关垂直于操作方向放置,以一个等于2倍按力的静负荷施
A force of 0.5N is applied to the terminal 10 ± 1s
along the axial direction (the force direction is
to leave the switch outward), and the measurement
is conducted once for each terminal.
以0.5N作用力沿轴向逐渐施加于接线端末10±1S(作用力
方向为离开开关向外指向),每个接线端子测量一次。
破裂。无功能性不良
Contact resistance: 200m Ω max
There was no dysfunction.
Vibration
Proof
振动
The switch is placed perpendicular to the operation
direction, and a static load equal to 2 times of
the pressing force is applied to the top center of
the switch driver, and the distance of the top
moving is measured.
加在开关驱动件顶端中心,测量顶端移动的距离。
After the experiment:
5.5
At the end of the operating element, the static
load is applied evenly along the operation
direction, so that the operating element is
transferred to the action position
在操作元件末端沿操作方向均匀施加静载荷,使操作元件
转换到动作位置 .
load is evenly reduced along the operation
direction, so that the operating element can be
transferred from the action position to the free
position
在操作元件末端沿操作方向均匀减少静载荷,使操作元件
从动作位置.转换到自由位置
Operation
Position
操作位置
5.4
Test Method 实验方法
The surface and structure
The switch can be installed firmly on the test
equipment and tested under the following
parameters:
(1) Vibration frequency 10-55hz
(2) The amplitude is 1.55mm
have no obvious deformation
(3) Vibration change rate: 10-55-10hz, about 1
minute
实验后:
(4) Frequency conversion method: logarithmic or
linear
接触电阻:200m Ω Max.
无功能性不良。
表面及结构无明显变形
(5) Vibration direction: three mutually
perpendicular directions, one of which should be
the direction of actuator movement.
(6) Time: 2 hours in each direction (6 hours in
total)
开关才有常规的安装方法牢固地安装在试验设备上,并在
下述参数条件下进行试验:
(1)振频10-55Hz
(2)振幅1.55mm
(3)振动变化速率:10-55-10Hz 大约1分钟
(4)变频方法:对数或线性型式
(5)振动方向:三个相互垂直的方向,其中一个方向应
是促动元件运动的方向。
(6)时间:每个方向2个小时(共6小时)
东莞市汉博电子科技有限公司
Page
4/6
PARTNO.
TS-KG07U
SPECIFICATION
No.
Item项目
SolderHeat
Resistance
耐焊接热
Cniteria 标准
Test Method 实验方法
Please practice according to below
condition:
(1)preheat:150°C 90-120s
NO abnormalities shll be
(2)Soldering heat:260°C Max 10S
observed in appearance and
opertion.
occur
无外观及功能损坏
无功能性不良。
(3)Immersion depth:Up tothe surface
of the board
焊接方法:
(1)预热:150°C 90-120秒
5.8
(2)最高焊接温度:260°C Max5s
(3) 浸入深度:PCB表面
260℃ max. 3sec max.
peak temperature
230℃
180℃
150℃
室温
time 时间(秒)
pre-heating 预热
time inside soldering equipment 炉内通过时间
(2) Solder: General
5.9
Resistance
to Flux
抗焊剂能力
Flux shall not be sisen up (5) Immersion time: 3 ± 1s
to contact,
The switch shall be free
开关在下述参数条件下进行试验:
from abnormalities in
(1)设备:自动焊接机
operation
焊剂不得上升进入开关内部, (2)焊料:常规
影响接触转换
试件在操作过程中不应发生 甲醇的无色透明溶液。
变形
(4)焊接温度:260±5°C
(5)浸渍时间:3±1S
(6)浸渍深度:接线端应浸到开关根部处
东莞市汉博电子科技有限公司
Page
5/6
PARTNO.
TS-KG07U
SPECIFICATION
6.Durability characteristics
No.
Item 项目
Cnteria 标准
Test Method实验方法
100,000cycles of operation shall be
performed
Contact resistance: 500M Ω max continuouly at a rate of 60cycles
Insulation resistance: 100M Ω min per minute without load.
The operating force variation
在加载按力1.5倍的负载条件下,行程高度
was within ± 30%.
Mechanical
Life
机械寿命
6.1
在2MM,速度为60次/分,在寿命试验设备
The appearance and structure of the
上连续转换100,000次
switch shall be free from damage
Electronics
Life
电气寿命
6.2
Under the following load conditions,
实验后:
接触电阻:500mΩMax.
the speed is 60 times / min, and the
绝缘电阻:100MΩMin.
操作力哀变应在±30%以内。continuous conversion is 100000 times
on the life test equipment
无功能性不良。
开关外观及结构应无损坏
DC6V 50mA
在带以下负荷的条件下,速度为60次/分
在寿命试验设备上连续转换100,000次
DC6V 50mA
7、
极限电气性能:
ENVIRONMENTAL SPECIFICATION
NO.
7.1
7.2
项目
ITEM
试验条件
TEST CONDITIONS
要求
REQUIREMENTS
样品应按照以下实验条件进行测试,实验后样品应放
在常温及标准湿度的环境中1小时后做性能测试:
Following the test set forth below the sample
低温测试
shall be left in normal temperature and
Resistance to humidity conditions for 1 h before measurements
low temperature are made:
(1) 温度:-30±2℃
Temperature : -30±2℃
(2) 时间:96h
接触电阻:≤500mΩ
Time: 96h
Contact resistance: ≤
500mΩ
项目3,4
Item 3,4
高温测试
Heat resistance
are made:
(1) 温度:80±2℃
temperature:80±2℃
(2) 时间:96h
time: 96h
东莞市汉博电子科技有限公司
Page
6/6
PARTNO.
TS-KG07U
SPECIFICATION
温度转换
7.3
Change of
temperature
根据下面的测试要求进行5次循环的温度周期性测试,
实验后样品应放在常温及标准湿度的环境中1小时后做
性能测试。测试期间样品应保持干燥.
After 5 cycles of following conditions, the
sample shall be allowed to stand under normal
temperature and humidity conditions for 1 h.
and measurements shall be made. During the test
water drops shall be removed.
+65±2℃
-10±2℃
2(hour)
1(hour)
2(hour)
1(hour)
1 cycle
接触电阻:≤500mΩ
500mΩ
项目3,4
Item 3,4
7.4
7.5
湿温测试
Moisture
resistance
are made:
(1) 温度:60±2℃
temperature: 60±2℃
(2) 相对湿度:90%~95%
relative humidity:90% to 95%
(3) 时间:96h
time: 96h
在以下设定条件下进行测量:
The switch shall be checked after following
test:
(1)温度:35℃±2℃
temperature: 35℃±2℃
盐雾试验
(2)盐溶液浓度:5±1%(质量百分比)
Salt Mist
salt solution : 5±1%(solids by
(铁材质不做盐雾
mass)
要求)
(3)时间:24h
Time: 24h
实验后的盐沉积物后水冲掉
After test, salt deposit shall be removed by
running water.
金属件上没有腐蚀斑点
No remarkable corrosion
shall be recognized in
metal part.
很抱歉,暂时无法提供与“TS-KG07U”相匹配的价格&库存,您可以联系我们找货
