BZX84 Series
Zener Diodes
◇ Planar Die construction
◇ 350mW Power Dissipation
◇ Zener Voltages from 2.4V 51V
◇ RoHS compliant / Green EMC
MAXIMUM RATINGS (Ta = 25 ℃)
Symbol
VF
P(AV)
TJ, Tstg
Parameter
Value
Units
Maximum Forward Voltage @ IF=10mA
0.9
V
Power Dissipation
350
mW
-55 to 150
Operating And StorageTemperature
IFSM
Peak Forward Surge Surge Current
Tstg
Storage Temperature Rance
Rj
2.0
A
-55 to 150
357
℃/W
Thermal Resistance Junction to Ambient
ELECTRICAL CHARACTERISTICS (Ta = 25 ℃ unless otherwise noted)
Max.Reverse
Nominal Zener Voltage
Part Number
Max. Zener Impedance
Leakage
Marking
Current
Vz(V) @ IZT
ZZT @ IZT
ZZK @ IZK
IR @ VR
Nom.
Min.
Max.
Ohm
mA
Ohm
mA
µA
V
BZX84C2V4
W1/Z11
2.4
2.28
2.52
100
5
600
1
50
1.0
BZX84C2V7
W2/Z12
2.7
2.5
2.9
100
5
600
1
BZX84C3V0
W3/Z13
3
2.8
3.2
95
5
600
1
10
1.0
BZX84C3V3
W4/Z14
3.3
3.1
3.5
95
5
600
1
5
1.0
BZX84C3V6
W5/Z15
3.6
3.4
3.8
90
5
600
1
5
1.0
BZX84C3V9
W6/Z16
3.9
3.7
4.1
90
5
600
1
3
1.0
BZX84C4V3
W7/Z17
4.3
4
4.6
90
5
600
1
3
1.0
1
BZX84 Series
Zener Diodes
BZX84C4V7
W8/Z1
4.7
4.4
5
80
5
500
1
3
2.0
BZX84C5V1
W9/Z2
5.1
4.8
5.4
60
5
480
1
2
2.0
BZX84C5V6
WA/Z3
5.6
5.2
6
40
5
400
1
1
2.0
BZX84C6V2
WB/Z4
6.2
5.8
6.6
10
5
150
1
3
4.0
BZX84C6V8
WC/Z5
6.8
6.4
7.2
15
5
80
1
2
4.0
BZX84C7V5
WD/Z6
7.5
7
7.9
15
5
80
1
1
5.0
BZX84C8V2
WE/Z7
8.2
7.7
8.7
15
5
80
1
0.7
5.0
BZX84C9V1
WF/Z8
9.1
8.5
9.6
15
5
100
1
0.5
6.0
BZX84C10
WG/Z9
10
9.4
10.6
150
1
0.2
7.0
BZX84C11
WH/Y1
11
10.4
11.6
150
1
0.1
8.0
BZX84C12
WI/Y2
12
11.4
12.7
25
5
150
1
0.1
8.0
BZX84C13
WK/Y3
13
12.4
14.1
30
5
170
1
0.1
8.0
BZX84C15
WL/Y4
15
13.8
15.6
30
5
200
1
0.1
10.5
BZX84C16
WM /Y5
16
15.3
17.1
40
5
200
1
0.1
11.2
BZX84C18
WN/Y6
18
16.8
19.1
45
5
225
1
0.1
12.6
BZX84C20
WO/Y7
21.2
55
5
225
1
0.1
14.0
BZX84C22
WP/Y8
22
20.8
23.3
55
5
250
1
0.1
15.4
BZX84C24
WR/Y9
24
22.8
25.6
70
5
250
1
0.1
16.8
BZX84C27
WS/Y10
27
25.1
28.9
80
2
300
1
0.1
18.9
BZX84C30
WT /Y11
30
28
32
80
2
300
1
0.1
21.0
BZX84C33
WU/Y12
33
31
35
80
2
325
1
0.1
23.1
BZX84C36
WW/Y13
36
34
38
90
2
350
1
0.1
25.2
BZX84C39
WX/Y14
39
37
41
130
2
350
1
0.1
27.3
BZX84C43
WY/Y15
43
45.15
150
5
375
1
0.1
30.10
49.35
170
5
375
1
0.1
32.90
0.1
35.70
BZX84C47
WZ/Y16
47
40.85
44.65
BZX84C51
XA/Y17
51
48.45
53.55
100
5
400
1
BZX84C62
Y19
62
58.0
66.0
215
2
450
0.5
2
0.05
43.40
BZX84 Series
Zener Diodes
Max.Reverse
Part Number
Leakage
Marking
Current
Vz(V) @ IZT
ZZT @ IZT
ZZK @ IZK
IR @ VR
Nom.
Min.
Max.
Ohm
mA
Ohm
mA
µA
V
BZX84B4V3
W7
4.3
4.21
4.39
90
5
600
1
3.0
1.0
BZX84B4V7
W8/Z1
4.7
4.61
4.79
80
5
500
1
3.0
2.0
BZX84B5V1
W9/2Z2
5.1
5.00
5.20
60
5
480
1
2.0
2.0
BZX84B5V6
WA/2Z3
5.6
5.49
5.71
40
5
400
1
1.0
2.0
BZX84B6V2
WB/2Z4
6.2
6.08
6.32
10
5
150
1
3.0
4.0
BZX84B6V8
WC/2Z5
6.8
6.66
6.94
15
5
80
1
2.0
4.0
BZX84B7V5
WD/2Z6
7.5
7.35
7.65
15
5
80
1
1.0
5.0
BZX84B8V2
WE/2Z7
8.2
8.04
8.36
15
5
80
1
0.7
5.0
BZX84B9V1
WF/2Z8
9.1
8.92
9.28
15
5
100
1
0.5
6.0
BZX84B10
WG/2Z9
10
9.80
10.20
150
1
0.2
7.0
BZX84B11
WH/2Y1
11
10.78
11.22
150
1
0.1
8.0
BZX84B12
WI/2Y2
12
11.76
12.24
25
5
150
1
0.1
8.0
BZX84B13
WK/2Y3
13
12.74
13.26
30
5
170
1
0.1
8.0
BZX84B15
WL/2Y4
15
14.70
15.30
30
5
200
1
0.1
10.5
BZX84B16
WM /2Y5
16
15.68
16.32
40
5
200
1
0.1
11.2
BZX84B18
WN/2Y6
18
17.64
18.36
45
5
225
1
0.1
12.6
BZX84B20
WO/2Y7
20.40
55
5
225
1
0.1
14.0
BZX84B22
WP/Y8
22
21.56
22.44
55
5
250
1
0.1
15.4
BZX84B24
WR/Y9
24
23.52
24.48
70
5
250
1
0.1
16.8
BZX84B27
WS/Y10
27
26.46
27.54
80
5
300
1
0.1
18.9
BZX84B30
WT /Y11
30
29.40
30.60
80
5
300
1
0.1
21.0
BZX84B33
WU/Y12
33
32.34
33.66
80
5
325
1
0.1
23.1
BZX84B36
WW/Y13
36
35.28
36.72
90
5
350
1
0.1
25.2
BZX84B39
WX/Y14
39
38.22
39.78
130
5
350
1
0.1
27.3
BZX84B43
WY
43
42.14
43.86
150
5
375
1
0.1
30.1
3
BZX84 Series
Zener Diodes
BZX84B47
WZ
47
46.06
47.94
170
5
375
1
0.1
32.9
BZX84B51
XA
51
49.98
52.02
100
5
750
1
0.1
38.0
ORDERING INFORMATION
Package
Device
BZX84C2V4BZX84B51
SOT23
Shipping
Tape & Reel
3000pcs /7” Reel
PACKAGE DIMENSIONS
4
Tape
wide
Emboss
pitch
Tape
specification
8mm
4mm
Conductive
Notes
很抱歉,暂时无法提供与“BZX84C3V9”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.09280
- 50+0.08584
- 200+0.08004
- 600+0.07424
- 1500+0.06960
- 3000+0.06670
