SLIDE SWITCHES (1 mm PITCH)
RoHS compliant
CVS
INTERNAL STRUCTURE
③
①
②
⑦
⑤
④
⑥
Part name
Material
Flammability
■ FEATURES
①
Cover
Stainless steel, Gold-plated
● RoHS compliant
● Lowest profile design of 1.45 mm
● Fine pitch of 1 mm
● Easy motion with knob height of 0.2 mm
②
Slider
Polyamide
③
Housing
④
Slider contact
⑤
Fixed contact
⑥
Terminal pin
⑦
Earth terminal
UL94V-0
Polyphenylenesulphide
Copper alloy, Gold-plated
■ PART NUMBER DESIGNATION
C V S - 0 4 T B - 1
Taping
Series name
1:500 pcs./reel
Blank:2000 pcs./reel
No. of bits
01:1 bit
02:2 bits
03:3 bits
Shape of terminal
04:4 bits
08:8 bits
B:Gull wing
C:Through hole
Form of packaging
T :Taping (Reel)
Blank : Bulk in plastic bag (01C : Plastic bag only)
■ LIST OF PART NUMBERS
No. of bits Form of packaging Shape of terminals
Taping
1
Taping
Plastic bag
Taping
2
Taping
Plastic bag
Taping
3
Taping
Plastic bag
(Gull wing)
(Through hole) Pieces in package
CVS-01TB-1
CVS-01TB
CVS-01B
CVS-01C
CVS-02TB-1
CVS-02TB
CVS-02B
CVS-03TB-1
CVS-03TB
CVS-03B
500 pcs./reel
2000 pcs./reel
Taping
4
Taping
100 pcs./pack
Plastic bag
500 pcs./reel
Taping
2000 pcs./reel
100 pcs./pack
500 pcs./reel
2000 pcs./reel
100 pcs./pack
8
Taping
Plastic bag
(Gull wing)
CVS-04TB-1
CVS-04TB
CVS-04B
CVS-08TB-1
CVS-08TB
CVS-08B
500 pcs./reel
2000 pcs./reel
100 pcs./pack
500 pcs./reel
2000 pcs./reel
100 pcs./pack
CVS
■ STANDARD SPECIFICATIONS
■ ELECTRICAL CHARACTERISTICS
Operating temp. range
Contact rating
Non-switching
Switching
Minimum
− 40 ~ 85 °C
Storage temp. range
Sealing
Net weight
Non-washable
Contact resistance
Approx. 0.028g (CVS-01B)
Approx. 0.031g (CVS-01C)
Approx. 0.041g (CVS-02B)
Approx. 0.054g (CVS-03B)
Approx. 0.067g (CVS-04B)
Approx. 0.13 g (CVS-08B)
Insulation resistance
Dielectric strength
■ MECHANICAL CHARACTERISTICS
Operating force
Stop strength
Solderability
Soldering heat
DC50 V 100 mA
DC6 V, 100 mA DC24 V, 25 mA
DC20 mV 1 μA
200 mΩ maximum
100 MΩ (DC100 V) minimum
AC250 V, 60 s
■ ENVIRONMENTAL CHARACTERISTICS
3 N {0.306 kgf} maximum
Vibration
6 N {0.61 kgf}, 60 s
Shock
490 m/s2, 11 ms
6 directions for 3 times each
Load life
Continuous load 1000 cycles,
DC6 ± 0.5 V, 100 ± 10 mA
Humidity
−10 ~ 65 °C,
Relative humidty 0 ~ 96 %,
24 h for 10 cycles
245 ± 3 °C, 2 ~ 3 s
Reflow:255 °C (Peak temperature)
(Please refer to the profile below)
Manual soldering:350 ± 10 °C, 3 ~ 4 s
(Amplitude) 1.5 mm or
(Acceleration) 98 m/s2,
10-500 Hz, 3 directions for 10 cycles each
Shear (Adhesion)
5 N {0.51 kgf} 10 s
High temp. exposure
85 °C, 96 h
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
Low temp. exposure
− 40 °C, 96 h
Pull-off strength
Thermal shock
5 N {0.51 kgf} 10 s
{ } : Reference only
Reflow profile for soldering heat evaluation〉
Temperature
250
200
150
100
50
Peak : 250
+5
Over 230 ℃
180 ℃
150 ℃
Pre Heating Zone
90 ± 30 s
30 ± 10 s
Heating time
Reflow : two times maximum
Soldering Zone
− 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles
CVS
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
Stroke 0.6
Production date code
0.3 min.
4.7
6.1
4.7
0.15 +0.1
–0.05
1.45
0.1 –0.1
1.2
2
2 1.35
2
6.5
Stroke 0.6
0.15 +0.1
–0.05
● CVS-01C
0.3 min.
● CVS-01B
0.5 +0.1
–0.05
Schematic
Schematic
0.5 +0.1
–0.05
0.3 min.
● CVS- □□ B
Part number
0.3 min.
6.1
4.7
Stroke 0.6
0.15 +0.1
–0.05
No. of bits. L dimension
CVS-02
2
3
CVS-03
3
4
CVS-04
4
5
CVS-08
8
9
1.45
L
Schematic
1
0.15
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
● CVS-02B
● CVS-03B
1
1
0.7
2.2
0.7
3.2
0.7
4.7
0.7
0.7
1.2
0.5
0.7
1.2
4.7
0.7
1.2
0.7
3.6
1.2
1.4
3.6
0.7
0.7
0.5
0.7
0.7
1.2
1.2
4.7
1N (N=1~3) = 3
1
0.5
1.2
0.7
● CVS-04B
3.6
● CVS-01B
(Unit : mm)
0.7
0.7
0.5
● CVS-01C
0.7
1.2
6.5
4.7
1.2
1N (N=1~7) = 7
0.7
4.2
■ SIZE OF P.C.B. PROCESSING
● CVS-08B
8.2
0.7
0.7
0.15
3.6
0.1 –0.1
0.35 +0.1
–0.05
1
2 – φ 0.7 hole
0.7
(Unit : mm)
CVS
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 2000 pcs. or 500 pcs. per reel. Orders
will be accepted for units of 2000 pcs., i.e., 2000, 4000, 6000 pcs.,
etc. or for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc.
● Taping version is boxed with two reels.
Maximum number of consecutive missing pieces = 2
Leader length and reel dimension are shown in the
diagrams below:
●Embossed tape dimensions
●Reel dimensions
Empty
End
φ 21±0.8
Head
40 mm min.
20 pitches min.
Leader
400 mm min.
Direction of feed
φ 50 min. (2000 pcs/reel)
φ 80±1 (500 pcs/reel)
17.4±1
2±0.5
φ 13±0.2
φ 254±2 (2000pcs./reel)
φ 182±1 (500pcs./reel)
4 ± 0.1
2 ± 0.1
Direction of feed
0.3 ± 0.1 Installation
example
(CVS-02B)
Direction of feed
2
4 ± 0.1
2 ± 0.1
Direction of feed
2
example
(CVS-03B)
2
8 ± 0.1
1.75 ± 0.1
4 ± 0.1
φ 1.5 +0.1
0.3 ± 0.1
2 ± 0.1
(CVS-04B)
Installation example
2
● The smallest unit of bulk pack in a plastic bag is 10 pcs.
per pack.
Orders will be accepted for unit of minimum 10 pcs., i.e.,
10, 20, 30 pcs., etc.
ON
12345678
ON
1234
Direction of feed
7.5 ± 0.1
2 ± 0.1
7.5 ± 0.1
4 ± 0.1
16
8 ± 0.1
φ 1.5 +0.1
1.75 ± 0.1
● 8 bits
Direction of feed
0.3 ± 0.1
(CVS-08B)
16
● 4 bits
8 ± 0.1
φ 1.5 +0.1
7.5 ± 0.1
8 ± 0.1
φ 1.5 +0.1
7.5 ± 0.1
example
(CVS-01B)
16
7.5 ± 0.1
2 ± 0.1
16
8 ± 0.1
4 ± 0.1
φ 1.5 +0.1
● 3 bits
1.75 ± 0.1
● 2 bits
1.75 ± 0.1
● 1 bit
21.4±1 (2000pcs./reel)
20.4±1 (500pcs./reel)
1.75 ± 0.1
Filled
16
Empty
(Unit: mm)
(Conforms to JIS C 0806-3)
(In accordance with EIAJ ET-7200A)
2
● Boxing of bulk in a plastic bag is performed with 100
pcs. (standard 500 pcs.) per box.
很抱歉,暂时无法提供与“CVS-08TB”相匹配的价格&库存,您可以联系我们找货
