WPE0791ZP4
Integrated in
OVP&OCP products
provider
1-Line High Power TVS Diode
Description
Mechanical Characteristics
The WPE0791ZP4 is a high power TVS, utilizing
leading monolithic silicon technology to provide fast
response time and low ESD clamping voltage, making
this device an ideal solution for protecting voltage
sensitive lines. The WPE0791ZP4 complies with the IEC
61000-4-2 (ESD) with ±30kV air and ±30kV contact
discharge. It is assem-bled into a 3-pin DFN2020-3
lead-free package. Each device will protect one line.
The combination of small size, and high surge
capability makes them ideal for use in applications such
as cellular phones, LCD displays, USB, and multi
media card interfaces.
Package: DFN2020-3
Case Material: “Green” Molding Compound
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Features
Dimensions and Pin Configuration
6000W peak pulse power (8/20µs)
Low leakage: nA level
Operating voltage: 7V
Ultra low clamping voltage
One power line protects
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-5 (Lightning) 275A (8/20μs)
RoHS Compliant
Applications
Power Management
Industrial Application
Power Supply Protection
3
1, 2
Transparent top view
Circuit Diagram
Pin Schematic
Ordering Information
Part Number
Packaging
WPE0791ZP4 3000/Tape & Reel
Rev.E_Aug,2017
Reel Size
7 inch
-1-
www.wpmtek.com
WPE0791ZP4
Integrated in
OVP&OCP products
provider
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
6000
W
Peak Pulse Current (8/20µs)
IPP
275
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
±30
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Reverse Working Voltage
Breakdown Voltage
Symbol
Min
Typ
VRWM
VBR
Max
Unit
7
V
7.5
Test Condition
V
IT = 1mA
Reverse Leakage Current
IR
1.0
µA
VRWM = 7V
Clamping Voltage
VC
10
V
IPP = 20A (8 x 20µs pulse)
Clamping Voltage
VC
22
V
IPP = 275A (8 x 20µs pulse)
Junction Capacitance
CJ
1000
pF
VR = 0V, f = 1MHz
Rev.E_Aug,2017
-2-
www.wpmtek.com
WPE0791ZP4
Integrated in
OVP&OCP products
provider
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Novction Capacitance vs. Reverse Voltage
Peak Pulse Power vs. Pulse Time
Clamping Voltage vs. Peak Pulse Current
Power Derating Curve
Note:Data is taken with a 10x attenuator
ESD Clamping Voltage
8 X 20μs Pulse Waveform
Rev.E_Aug,2017
8 kV Contact per IEC61000−4−2
-3-
www.wpmtek.com
WPE0791ZP4
Integrated in
OVP&OCP products
provider
DFN2020-3 Package Outline Drawing
MILLIMETERS
MIN
NOM
MAX
Suggested Land Pattern
A
0.55
0.60
0.65
A1
A3
b
D
E
0.00
0.05
0.25
1.90
1.90
0.02
0.10REF.
D2
0.95
1.15
E2
1.40
1.60
e
1.20
H
0.20
K
0.20
L
0.35
0.45
R
0.13
0.35
2.10
2.10
1.40
0.30
0.40
Unit:mm
Contact information
WPMTEK Incorporated Limited
Room 206-207,2nd Floor,Block 3,Minxing lndustry Park,Minzhi
Longhua New District,Shenzhen
TEL:86755-29308003
FAX:86755-23739900
wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability
arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special,
consequential or incidental damages.
Rev.E_Aug,2017
-4-
www.wpmtek.com
很抱歉,暂时无法提供与“WPE0791ZP4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.39000
- 100+0.36400
- 300+0.33800
- 500+0.31200
- 2000+0.29900
- 5000+0.29120
- 国内价格
- 5+0.68634
- 50+0.55242
- 150+0.48546
- 500+0.43524
- 3000+0.37498
- 6000+0.35489
