Integrated in
OVP&OCP products
provider
WTD3201-XXB
Bidirectional Ultralow Capacitance TVS ARRAY
WTD3201-03B,WTD3201-05B,WTE3201-08B,WTD3201-12B,
WTD3201-15B,WTD3201-24B
The WTD3201-XXB is ultra low capacitance transient voltage suppressor arrays, designed to protect applications such
as portable electronics and SMART phones. This series is available in both unidirectional and bidirectional configurations
and is rated at 300 Watts for an 8/20μs waveform.
The WTD3201-XXB meets IEC 61000-4-2 (ESD) and IEC 61000-4-4 (EFT) requirements. At higher operating
frequencies or faster edge rates, insertion loss and signal integrity are a major concern. This series offers an ultra low
capacitance and low leakage current in a miniature SOD-323 package.
Features
300 Watts Peak Pulse Power per Line (8 x 20 us Waveform)
Replacement for MLV (0805)
Protects One Power or I/O Port
Low Clamping Voltage
Available in Multiple Voltages:3.3V,5.0V,8.0V,12V,15V,24V
Ultra Low Capacitance: 1pF (Typical)
Response Time is < 1 ns
Meets MSL 1 Requirements
Solid-state silicon avalanche technology
ROHS compliant
WeiPan technology
SOD-323
Main applications
1
Hand−Held Portable Applications
Networking and Telecom(Ethernet 10/100/1000 Base T)
USB Interface
Automotive Electronics
Serial and Parallel Ports
Notebooks, Desktops, Servers
2
Protection solution to meet
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
IEC61000-4-5 (Surge) :Refer to next page
Circuit and Pin Schematic
Ordering Information
Device
Qty per Reel
Reel Size
WPExxxD3ULA
3000
7 Inch
“xxx” =Working Peak Reverse Voltage
Revision: A2.1
Integrated in
OVP&OCP products
provider
WPExxxD3ULA
Maximum ratings (Tamb=25℃ Unless Otherwise Specified)
Parameter
Peak Pulse Power (tp=8/20μs waveform)
ESD Rating per IEC61000-4-2:
Symbol
Value
Unit
PPPP
300
Watts
Contact
30
Air
30
KV
Lead Soldering Temperature
TL
260 (10 sec.)
Operating Temperature Range
TJ
-55 ~ 150
TSTG
-55 ~ 150
TL
260
Storage Temperature Range
Lead Solder Temperature − Maximum (10 Second Duration)
Maximum ratings are those values beyond which device damage can occur. Maximum ratings applied to the device are individual stress limit values (not
normal operating conditions) and are not valid simultaneously. If these limits are exceeded, device functional operation is not implied, damage may occur
and reliability may be affected.
*Other voltages may be available upon request.
1. Non-repetitive current pulse, per Figure 1.
Electrical characteristics ( Tamb=25℃ Unless Otherwise Specified)
IR @
VBR @ 1 mA
VC1
VC2
Ipp@8/20us
Capacitance
VRWM
(Volts)
@1A
@ Ipp(Max)
(Amps)
@ VR = 0 V, 1 MHz (pF)
(V)
(uA)
Min
(V)
(V)
Max.
Typ
Max.
(W)
WTD3201-03B
3.3
2
4
7
18
18
0.9
1.5
300
WTD3201-05B
5
1
6
9.8
19
16
0.9
1.5
300
WTD3201-08B
8
1
8.5
13
18
10
0.9
1.5
230
WTD3201-12B
12
1
13.3
18
27
8
0.9
1.5
230
WTD3201-15B
15
1
16.7
23
30
5
0.9
1.5
200
WTD3201-24B
24
1
26.7
35
48
3
0.9
1.5
180
VRWM
Device
PPK
Junction capacitance is measured in VR=0V,F=1MHz
I
Symbol
VRWM
IPP
Parameter
VBR
Breakdown Voltage @ IT
VC
Clamping Voltage @ IPP
IT
Test Current
IRM
Leakage current at VRWM
IPP
Peak pulse current
CO
Off-state Capacitance
CJ
Junction Capacitance
VC
VBR VRWM
IT
IR
IR
IT
IPP
Revision: A2.1
VRWM
VBR
VC
V
Integrated in
OVP&OCP products
provider
WPExxxD3ULA
10
110
100
90
80
70
60
50
40
30
Waveform
Parameters:
tr=8us
td=20us
Peak Pulse Power-PPK(KW)
PP
Typical electrical characterist applications
td=IPP/2
10
15
1
0.1
0.01
0.1
30
Time (us)
10
100
1000
Pulse Duration-tp(us)
Non-Repetitive Peak Pulse Power vs. Pulse Time
Pulse Waveform
1 -0.7540 dB
900MHZ
110
100
90
80
70
60
50
40
30
2 -1.9718 dB
1.7GHZ
Insertion Loss (dB)
% of Rated Power or Ipp
1
-6
3 -2.8512 dB
2.5GHZ
3
2
4
-12
-18
-24
-30
-36
50
75
100
125
150
Ambient Temperature-TA
Power Derating Curve
-42
1
MHZ
10
MHZ
Insertion Loss S21
Revision: A2.1
1
GHZ
3
GHZ
4 -4.3316 dB
2.7GHZ
Integrated in
OVP&OCP products
provider
WPExxxD3ULA
Package Information
SOD-323 Package Outline Drawing
MILLIMETERS
NOM
SYM
MIN
A
0.800
1.100
A1
0.800
0.900
A2
0.000
0.100
b
0.250
0.400
c
0.080
0.177
D1
1.600
1.700
1.800
D
2.300
2.800
E
1.150
1.400
L
MAX
0.475REF
L1
0.100
0.500
Θ
0°
8°
Suggested Land Pattern
SOD-123
Unit:mm
SOD-323 Reel Dim
E
P0
K
P2
D
W
F
D1
A0
T
B0
B1
K0
P1
Package
Pocket Size
Tape
B0×A0×K0(mm)
Width
Chip Size
Reel Diameter
Quantity Per Reel
P0
P1
4mm
4mm
SOD-323
2.60×1.40×1.05
3.30×1.50×1.25
8mm
178mm(7")
3000
D0
D1
E
F
K
T
W
1.5mm
0.5mm
1.75mm
3.5mm
0.95mm
0.2mm
8mm
Revision: A2.1
很抱歉,暂时无法提供与“WTD3201-24B”相匹配的价格&库存,您可以联系我们找货
