◆Features
·Power rating up to 15 W
·Excellent long-term stability
·Ideal for mounting on DCB/IMS substrate
·RoHS compliant
·AEC-Q200 qualified
◆Applications
·Current sensor for power hybrid applications
·Frequency converters
·Power modules
·Automatic control power supply
·High current applications for the automotive market
◆Technical Date
Resistance
m0hm
0.1 to 5
Tolerance
1、2、5
Power P70℃
W
3~15
Recommended applicable temperature range
-65℃ to +170℃
◆Ordering Code
ASR
M
3
1
F
Product
Material
Dimension
R Value
R Tolerance
M:Manganin
3:2512
Unit:mΩ
J:± 5%
K:Kamar
5:3920
G:± 2%
S:CuMn7Sn
7:5930
F:± 1%
Type
F:FeCrAl
◆Physical Dimensions
Type
Size
W/mm
A/mm
C/mm
H/mm
l
w
a
ASR-S/M/K/F-3
2512
6.3±0.2
1.2±0.2
3.1±0.3
0.5±0.1
7
3.4
1.8
ASR-S/M/K/F-5
3920
10±0.2
2.2±0.2
5.1±0.4
0.5±0.1
11
6.2
2.7
ASR-S/M/K/F-7
5930
15±0.3
4.2±0.3
7.6±0.4
0.5±0.1
16
8.75
5.2
深圳市业展电子有限公司
Tel:0755-29500756 E-mail:business@yezhan.com.cn
1
◆ Electrical Features
Type
Resistance/mΩ
D1 /mm
D2 /mm
ASR-S-3
0.2
1.40
1.40
P70℃ /W
6
TCR /ppm/℃
175
0.3
1.50
1.50
6
175
0.5
0.88
0.88
6
115
1
0.50
0.50
5
100
2
0.65
0.65
5
50
3
0.43
0.43
4
50
4
0.3
0.3
3
50
2
0.7
0.7
5
50
3
0.47
0.47
4
50
4
0.35
0.35
3
50
5
0.28
0.28
3
50
0.2
1.66
1.66
12
200
0.3
1.37
1.37
10
150
0.5
0.83
0.83
9
70
1
0.40
0.40
7
50
1
1.16
1.16
8
50
2
0.56
0.56
6
50
3
0.37
0.37
5
50
4
0.28
0.28
5
50
1
1.28
1.28
8
50
2
0.64
0.64
6
50
3
0.43
0.43
5
50
4
0.32
0.32
5
50
0.1
2.0
2.0
15
200
0.2
1.50
1.50
15
100
0.3
0.98
0.98
10
100
0.5
0.60
0.60
10
75
0.75
0.41
0.41
10
75
1
0.86
0.86
9
50
2
0.40
0.40
7
50
3
0.29
0.29
7
50
1
0.96
0.96
9
50
2
0.48
0.48
7
50
3
0.32
0.32
7
50
ASR-M-3
ASR-K-3
ASR-F-3
ASR-M-5
ASR-K-5
ASR-F-5
ASR-S-7
ASR-M-7
ASR-K-7
ASR-F-7
深圳市业展电子有限公司
2
Power derating curve at 70
P (W)
6
4
2
60
80
100
120
140
160
Terminal Temperature
180
o
T[ C]
Stability < 1.0% (in covered condition)
Performance Date
Iterms
Additional Requirements
Reference
JESD22
Temperature
1000 Cycles(-55℃ to +125℃)
Cycling
Measurement at 24± 2hours after test conclusion
High Temperature
1000hrs.@T=125℃.Unpowered.
MIL-STD-202
Exposure
Method 108
1000hrs 85℃/85%RH。Note: Specified conditions:
Biased Humidity
10% of operating power.
Operational Life
Limits
Method
± 0.5%
JA-104
MIL-STD-202
Method 103
Condition D Steady State TA=125℃ at rated power.
MIL-STD-202
Method 108
± 0.5%
± 0.5%
± 1%
95%
Solderability
245℃± 5℃,5s+0.5s/-0
J-STD-002C
Coverage
Min
Resistance to
260℃± 5℃,10s± 1s
MIL-STD-202
Soldering Heat
Method 210
Short Time
5× Rated power for 5 s
MIL-STD-202
Overload
Method 301
深圳市业展电子有限公司
3
± 0.5%
± 0.5%
Marking
R001 1%
R001:1mΩ
1%:Tolerance
包装 Packaging
Embossed plastic Tape Specifications
(Unit:mm)
Size
A
B
W
E
F
P0
P1
P2
D0
T
Quantity
2512
4.3
7.6
16
1.55
7.5
3.85
7.7
7.7
1.50
1.7
1000
3920
6
11
24
1.55
11.2
6
12
12
1.50
2.0
2500
5930
8.6
16
24
1.55
10.8
6
12
12
1.50
2.4
2000
深圳市业展电子有限公司
Size
2512
3920
5930
φA
330
330
330
φB
99.5
99.5
99.5
φC
13
13
13
W
16.5
24.5
24.5
T
21
29
29
4
很抱歉,暂时无法提供与“ASR-K-5-1F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.26560
- 20+1.14695
- 100+1.02830
- 500+0.90965
- 1000+0.85428
- 2000+0.81473
