P6KE6.8A(CA)-P6KE600A(CA)
AXIAL LEADED TRANSIENT VOLTAGE SUPPRESSOR DIODE
VOLTAGE RANGE: 6.8 - 600V
POWER: 600Wa t t s
Features
Glass Passivated Die Construction
Uni- and Bi-Directional Versions Available
Excellent Clamping Capability
Fast Response Time
Plastic Case Material has UL Flammability
Classification Rating 94V-O
B
A
A
C
D
Mechanical Data
· Case : DO-15 Molded plastic
· Epoxy : UL94V-O rate flame retardant
· Lead : Axial lead solderable per MIL-STD-202,
Method 208 guaranteed
· Polarity : Color band denotes cathode end
· Mounting position : Any
· Weight : 0.465 gram
DO-15
Dim
Min
A
25.40
B
5.50
7.62
C
0.686
0.889
2.60
3.60
D
Max
All Dimensions in mm
Maximum Ratings and Electrical Characteristics
@TA=25°C unless otherwise specified
Characteristic
Symbol
Value
Unit
Peak Pulse Power Dissipation at TA = 25°C (Note 1, 2, 5) Figure 3
PPPM
600 Minimum
W
Peak Forward Surge Current (Note 3)
IFSM
100
A
Peak Pulse Current on 10/1000µS Waveform (Note 1) Figure 1
IPPM
See Table 1
A
Steady State Power Dissipation (Note 2, 4)
PM(AV)
5.0
W
Operating and Storage Temperature Range
Tj, TSTG
-65 to +175
°C
Note:
1. Non-repetitive current pulse, per Figure 1 and derated above TA = 25°C per Figure 4.
2. Mounted on 40mm2 copper pad.
3. 8.3ms single half sine-wave duty cycle = 4 pulses per minutes maximum.
4. Lead temperature at 75°C = TL .
5. Peak pulse power waveform is 10/1000µS.
1 of 5
www.sunmate.tw
TYPE
(UNI)
(BI)
Reverse
Stand-Off
Voltage
Breakdown
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
VRWM (V)
VBR MIN(V)
VBR MAX(V)
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
IT (mA)
VC(V)
IPP(A)
IR(uA)
Test
P6KE6.8
P6KE6.8C
5.50
6.12
7.48
10.0
10.8
55.6
1000.0
P6KE6.8A
P6KE6.8CA
5.80
6.45
7.25
10.0
10.5
57.1
1000.0
P6KE7.5
P6KE7.5C
6.05
6.75
8.25
10.0
11.7
51.3
500.0
P6KE7.5A
P6KE7.5CA
6.40
7.13
7.88
10.0
11.3
53.1
500.0
P6KE8.2
P6KE8.2C
6.63
7.38
9.02
10.0
12.5
48.0
200.0
P6KE8.2A
P6KE8.2CA
7.02
7.79
8.61
10.0
12.1
49.6
200.0
P6KE9.1
P6KE9.1C
7.37
8.19
10.0
1.0
13.8
43.5
50.0
P6KE9.1A
P6KE9.1CA
7.78
8.65
9.55
1.0
13.4
44.8
50.0
P6KE10
P6KE10C
8.10
9.00
11.0
1.0
15.0
40.0
10.0
P6KE10A
P6KE10CA
8.55
9.50
10.5
1.0
14.5
41.4
10.0
P6KE11
P6KE11C
8.92
9.90
12.1
1.0
16.2
37.0
5.0
P6KE11A
P6KE11CA
9.40
10.5
11.6
1.0
15.6
38.5
5.0
P6KE12
P6KE12C
9.72
10.8
13.2
1.0
17.3
34.7
5.0
P6KE12A
P6KE12CA
10.2
11.4
12.6
1.0
16.7
35.9
5.0
P6KE13
P6KE13C
10.5
11.7
14.3
1.0
19.0
31.6
5.0
P6KE13A
P6KE13CA
11.1
12.4
13.7
1.0
18.2
33.0
5.0
P6KE15
P6KE15C
12.1
13.5
16.5
1.0
22.0
27.3
5.0
P6KE15A
P6KE15CA
12.8
14.3
15.8
1.0
21.2
28.3
5.0
P6KE16
P6KE16C
12.9
14.4
17.6
1.0
23.5
25.5
5.0
P6KE16A
P6KE16CA
13.6
15.2
16.8
1.0
22.5
26.7
5.0
P6KE18
P6KE18C
14.5
16.2
19.8
1.0
26.5
22.6
5.0
P6KE18A
P6KE18CA
15.3
17.1
18.9
1.0
25.2
23.8
5.0
P6KE20
P6KE20C
16.2
18.0
22.0
1.0
29.1
20.6
5.0
P6KE20A
P6KE20CA
17.1
19.0
21.0
1.0
27.7
21.7
5.0
P6KE22
P6KE22C
17.8
19.8
24.2
1.0
31.9
18.8
5.0
P6KE22A
P6KE22CA
18.8
20.9
23.1
1.0
30.6
19.6
5.0
P6KE24
P6KE24C
19.4
21.6
26.4
1.0
34.7
17.3
5.0
P6KE24A
P6KE24CA
20.5
22.8
25.2
1.0
33.2
18.1
5.0
P6KE27
P6KE27C
21.8
24.3
29.7
1.0
39.1
15.3
5.0
P6KE27A
P6KE27CA
23.1
25.7
28.4
1.0
37.5
16.0
5.0
P6KE30
P6KE30C
24.3
27.0
33.0
1.0
43.5
13.8
5.0
P6KE30A
P6KE30CA
25.6
28.5
31.5
1.0
41.4
14.5
5.0
P6KE33
P6KE33C
26.8
29.7
36.3
1.0
47.7
12.6
5.0
P6KE33A
P6KE33CA
28.2
31.4
34.7
1.0
45.7
13.1
5.0
P6KE36
P6KE36C
29.1
32.4
39.6
1.0
52.0
11.5
5.0
P6KE36A
P6KE36CA
30.8
34.2
37.8
1.0
49.9
12.0
5.0
2 of 5
www.sunmate.tw
TYPE
(UNI)
(BI)
Reverse
Stand-Off
Voltage
Breakdown
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
VRWM (V)
VBR MIN(V)
VBR MAX(V)
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
IT (mA)
VC(V)
IPP(A)
IR(uA)
Test
P6KE39
P6KE39C
31.6
35.1
42.9
1.0
56.4
10.6
5.0
P6KE39A
P6KE39CA
33.3
37.1
41.0
1.0
53.9
11.1
5.0
P6KE43
P6KE43C
34.8
38.7
47.3
1.0
61.9
9.7
5.0
P6KE43A
P6KE43CA
36.8
40.9
45.2
1.0
59.3
10.1
5.0
P6KE47
P6KE47C
38.1
42.3
51.7
1.0
67.8
8.8
5.0
P6KE47A
P6KE47CA
40.2
44.7
49.4
1.0
64.8
9.3
5.0
P6KE51
P6KE51C
41.3
45.9
56.1
1.0
73.5
8.2
5.0
P6KE51A
P6KE51CA
43.6
48.5
53.6
1.0
70.1
8.6
5.0
P6KE56
P6KE56C
45.4
50.4
61.6
1.0
80.5
7.5
5.0
P6KE56A
P6KE56CA
47.8
53.2
58.8
1.0
77.0
7.8
5.0
P6KE62
P6KE62C
50.2
55.8
68.2
1.0
89.0
6.7
5.0
P6KE62A
P6KE62CA
53.0
58.9
65.1
1.0
85.0
7.1
5.0
P6KE68
P6KE68C
55.1
61.2
74.8
1.0
98.0
6.1
5.0
P6KE68A
P6KE68CA
58.1
64.6
71.4
1.0
92.0
6.5
5.0
P6KE75
P6KE75C
60.7
67.5
82.5
1.0
108
5.6
5.0
P6KE75A
P6KE75CA
64.1
71.3
78.8
1.0
103
5.8
5.0
P6KE82
P6KE82C
66.4
73.8
90.2
1.0
118
5.1
5.0
P6KE82A
P6KE82CA
70.1
77.9
86.1
1.0
113
5.3
5.0
P6KE91
P6KE91C
73.7
81.9
100
1.0
131
4.6
5.0
P6KE91A
P6KE91CA
77.8
86.5
95.5
1.0
125
4.8
5.0
P6KE100
P6KE100C
81.0
90.0
110
1.0
144
4.2
5.0
P6KE100A
P6KE100CA
85.5
95.0
105
1.0
137
4.4
5.0
P6KE110
P6KE110C
89.2
99.0
121
1.0
158
3.8
5.0
P6KE110A
P6KE110CA
94.0
105
116
1.0
152
3.9
5.0
P6KE120
P6KE120C
97.2
108
132
1.0
173
3.5
5.0
P6KE120A
P6KE120CA
102
114
126
1.0
165
3.6
5.0
P6KE130
P6KE130C
105
117
143
1.0
187
3.2
5.0
P6KE130A
P6KE130CA
111
124
137
1.0
179
3.4
5.0
P6KE150
P6KE150C
121
135
165
1.0
215
2.8
5.0
P6KE150A
P6KE150CA
128
143
158
1.0
207
2.9
5.0
P6KE160
P6KE160C
130
144
176
1.0
230
2.6
5.0
P6KE160A
P6KE160CA
136
152
168
1.0
219
2.7
5.0
P6KE170
P6KE170C
138
153
187
1.0
244
2.5
5.0
P6KE170A
P6KE170CA
145
162
179
1.0
234
2.6
5.0
P6KE180
P6KE180C
146
162
198
1.0
258
2.3
5.0
P6KE180A
P6KE180CA
154
171
189
1.0
246
2.4
5.0
3 of 5
www.sunmate.tw
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
IT (mA)
VC(V)
IPP(A)
IR(uA)
287
2.1
5.0
1.0
274
2.2
5.0
242
1.0
344
1.7
5.0
209
231
1.0
328
1.8
5.0
202
225
275
1.0
360
1.7
5.0
P6KE250CA
214
237
263
1.0
344
1.7
5.0
P6KE300
P6KE300C
243
270
330
1.0
430
1.4
5.0
P6KE300A
P6KE300CA
256
285
315
1.0
414
1.4
5.0
P6KE350
P6KE350C
284
315
385
1.0
504
1.2
5.0
P6KE350A
P6KE350CA
300
333
368
1.0
482
1.2
5.0
P6KE400
P6KE400C
324
360
440
1.0
574
1.0
5.0
P6KE400A
P6KE400CA
342
380
420
1.0
548
1.1
5.0
P6KE440
P6KE440C
356
396
484
1.0
631
0.95
5.0
P6KE440A
P6KE440CA
376
418
462
1.0
602
1.0
5.0
P6KE480
P6KE480C
389
432
528
1.0
686
0.88
5.0
P6KE480A
P6KE480CA
408
456
504
1.0
658
0.9
5.0
P6KE510
P6KE510C
413
459
561
1.0
729
0.82
5.0
P6KE510A
P6KE510CA
434
485
535
1.0
698
0.9
5.0
P6KE530
P6KE530C
457
477
583
1.0
798
0.76
5.0
P6KE530A
P6KE540
P6KE530CA
P6KE540C
451
437
503.5
486
556.5
594
1.0
1.0
725
772
0.8
0.78
5.0
P6KE540A
P6KE540CA
460
513
567
1.0
740
0.8
5.0
P6KE550
P6KE550C
470
495
605
1.0
836
0.76
P6KE550A
P6KE550CA
468
522.50
577.50
1.0
760
0.8
5.0
5.0
P6KE600
P6KE600C
490
540
660
1.0
911
0.71
5.0
P6KE600A
P6KE600CA
512
570
630
1.0
828
0.75
5.0
Reverse
Stand-Off
Voltage
Breakdown
Voltage
Min. @IT
Breakdown
Voltage
Max. @ IT
(BI)
VRWM (V)
VBR MIN(V)
VBR MAX(V)
P6KE200
P6KE200C
162
180
220
1.0
P6KE200A
P6KE200CA
171
190
210
P6KE220
P6KE220C
175
198
P6KE220A
P6KE220CA
185
P6KE250
P6KE250C
P6KE250A
TYPE
(UNI)
4 of 5
Test
5.0
www.sunmate.tw
Tj = 25°C
f = 1.0 MHz
Vsig = 50mV p-p
tr = 10ms
100
Peak Value Ipp
Cj, CAPACITANCE (pF)
IP, PEAK PULSE CURRENT (%pp)
10,000
Half Value Ipp/2
50
tp
Measured at
Zero Bias
1000
10 X 1000 Waveform
as defined by R.E.A.
2
Measured at
Stand-off Voltage
100
10
1
3
10
100
1000
VRWM, REVERSE STANDOFF VOLTAGE (V)
t, TIME (ms)
Fig. 1 Pulse Waveform
Fig. 2 Typical Junction Capacitance
PP, PEAK PULSE POWER (kW)
100
IMPULSE
10
1.0
TC = 25°C
0.1
0.1
1.0
10
1000
100
10000
100
Pd , STEADY STATE POWER DISSIPATION (W)
PK PULSE DERATING (% PK PWR OR CURRENT)
Tp, PULSE WIDTH (µs)
Fig. 3 Pulse Rating Curve
75
50
25
10 X 1000 Waveform
as defined by REA
50
75
100 125 150 175
5.0
Single Phase
Half-Wave 60Hz
Resistive or
Inductive Load
3.75
2.5
L = 9.5 mm
1.25
40 x 40 x 1 mm Cu
TA, AMBIENT TEMPERATURE (°C)
Fig. 4 Pulse Derating Curve
25
50
75
100
125
150
175
200
TL , LEAD TEMPERATURE (°C)
Fig. 5, Steady State Power Derating
5 of 5
www.sunmate.tw
很抱歉,暂时无法提供与“P6KE16CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.23800
- 20+0.21700
- 100+0.19600
- 500+0.17500
- 1000+0.16520
- 2000+0.15820
