SIK A CO.,LIMITED
B T134 Series
4A TRIACs
DESCRIPTION:
B T134 series triacs with low holding and
latching current are especially recommended
for use on middle and small resistance type
power load.
T 2(2)
MAIN FEATURES
T 1(1)
G (3)
Symbol
Value
Unit
IT(RMS)
4
A
VDRM /VRRM
600
V
ABSOLUTE MAXIMUM RATINGS
Parameter
Symbol
Value
Unit
Tstg
-40 - 150
Tj
-40 - 125
Repetitive peak off-state voltage(Tj =25℃)
VDRM
600
V
Repetitive peak reverse voltage(Tj =25℃)
VRRM
600
V
Non repetitive surge peak Off-state voltage
VDSM
VDRM + 100
V
Non repetitive peak reverse voltage
VRSM
VRRM + 100
V
IT(RMS)
4
A
Storage junction temperature range
Operating junction temperature range
RMS on-state current
TEL:+86-0755-89519740
SOT-223
(TC=75℃)
-1/5-
www.sika-wen.com
B T134
Series
SIK A CO.,LIMITED
Non repetitive surge peak on-state current
(full cycle, F=50Hz)
I2t value for fusing (tp =10ms)
Critical rate of rise of on-state
current (IG =2×IGT)
Ⅰ-Ⅱ-Ⅲ
Ⅳ
Peak gate current
Average gate power dissipation
Peak gate power
ITSM
25
A
I 2t
3.1
A2s
dI/dt
50
10
A/μs
IGM
2
A
PG(AV)
0.5
W
PGM
5
W
ELECTRICAL CHARACTERISTICS (Tj=25℃ unless otherwise specified)
Value
Symbol
Test Condition
Quadrant
Unit
E
IGT
Ⅰ-Ⅱ-Ⅲ
VD=12V RL=33Ω
Ⅳ
VGT
VGD
VD=VDRM Tj=125℃
RL=3.3KΩ
MAX
5
mA
10
ALL
MAX
1.3
V
ALL
MIN
0.2
V
Ⅰ-Ⅲ-Ⅳ
MAX
10
mA
IL
IG=1.2IGT
IH
IT=100mA
MAX
10
mA
VD=2/3VDRM Gate Open Tj=125℃
MIN
50
V/ μs
(dI/dt)c=1.1A/ms Tj=125℃
MIN
1
V/ μs
Value(MAX)
Unit
Tj=25℃
1.7
V
Tj=25℃
5
μA
Tj=125℃
0.5
mA
dV/dt
(dV/dt)c
Ⅱ
15
STATIC CHARACTERISTICS
Symbol
VTM
IDRM
IRRM
Parameter
ITM=5A tp=380μs
VD=VDRM VR=VRRM
-2/5-
www.sika-wen.com
B T134
Series
SIK A CO.,LIMITED
THERMAL RESISTANCES
Symbol
Rth(j-c)
Parameter
junction to case(AC)
Value
Unit
4.5
℃/W
SOT-223
ORDERING INFORMATION
B
T
134
W
600
E
SIKA CO.,LIMITED
600
W:SOT-223
PACKAGE MECHANICAL DATA
-3/5-
www.sika-wen.com
Series
B T134
FIG.1: Maximum power dissipation versus RMS
on-state current
FIG.2: RMS on-state current versus case
temperature
P(w)
6.6
IT(RMS) (A)
6
5.5
5
4.4
4
3.3
3
2.2
2
1.1
α=180°
SOT-223/
1
IT(RMS) (A)
2
3
4
5
FIG.3: Surge peak on-state current versus
number of cycles
28
SIK A CO.,LIMITED
Tc (℃)
50
75
100
125
FIG.4: On-state characteristics (maximum
values)
ITSM (A)
30
ITM (A)
t=20ms
One cycle
24
Tj=Tjmax
10
12
1
8
Tj=25℃
4
10
Number of cycles
100
1000
FIG.5: Non-repetitive surge peak on-state current
for a sinusoidal pulse with width tp
很抱歉,暂时无法提供与“BT134W-600E”相匹配的价格&库存,您可以联系我们找货
