SMBJ5.0A(CA) - SMBJ440A(CA)
SURFACE MOUNT TRANSIENT VOLTAGE SUPPRESSOR DIODE
VOLTAGE RANGE: 5.0 - 440 V
POWER: 600Wa t t s
Features
! Glass Passivated Die Construction
! Uni- and Bi-Directional Versions Available
! Excellent Clamping Capability
! Fast Response Time
! Plastic Material: UL Flammability
Classification Rating 94V-0
B
SMB(DO-214AA)
Mechanical Data
A
Case: SMB/DO-214AA, Molded Plastic
Terminals: Solder Plated, Solderable
per MIL-STD-750, Method 2026
Polarity: Cathode Band or Cathode Notch
Marking: Type Number
Weight: 0.093 grams (approx.)
C
D
J
H
Maximum Ratings
Min
A
3.30
Max
3.94
B
4.06
4.70
C
1.91
2.21
D
0.15
0.31
E
5.00
5.59
G
0.10
0.20
H
0.76
1.52
J
2.00
2.62
All Dimensions in mm
@ TA = 25°C unless otherwise specified
Characteristic
Peak Pulse Power Dissipation
(Non repetitive current pulse derated above TA = 25°C)
(Note 1)
Peak Forward Surge Current, 8.3ms Single Half Sine
Wave Superimposed on Rated Load (JEDEC Method)
(Notes 1, 2, & 3)
Instantaneous Forward Voltage @ IPP = 35A V BR
很抱歉,暂时无法提供与“SMBJ250CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.49815
- 10+0.47970
- 100+0.43542
- 500+0.41328
