2EZ3.6D5 -2EZ200D5
AXIAL LEADED SILICON ZENER DIODES
VOLTAGE RANGE: 3.6 - 200V
POWER: 2.0Wa t t s
Features
! Complete Voltage Range 3.6 to 200 Volts
! High peak reverse power dissipation
! High reliability
B
A
A
! Low leakage current
C
Mechanical Data
D
! Case : DO-41 Molded plastic
! Epoxy : UL94V-O rate flame retardant
! Lead : Axial lead solderable per MIL-STD-202,
method 208 guaranteed
! Polarity : Color band denotes cathode end
! Mounting position : Any
DO-41
! Weight : 0.339 gram
Dim
Min
Max
A
25.40
¾
B
4.06
5.21
C
0.71
0.864
D
2.00
2.72
All Dimensions in mm
Maximum Ratings and Electrical Characteristics
@ TA = 25°C unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load.
Rating
Symbol
Value
Unit
DC Power Dissipation at TL = 75 °C (Note1)
PD
2.0
Watts
Maximum Forward Voltage at IF = 200 mA
VF
1.2
Volts
60
K/W
Maximum Thermal Resistance Junction to Ambient Air (Note2)
RθJA
Junction Temperature Range
TJ
- 55 to + 175
°C
Storage Temperature Range
Ts
- 55 to + 175
°C
Note :
(1) TL = Lead temperature at 3/8 " (9.5mm) from body
(2) Valid provided that leads are kept at ambient temperature at a distance of 10 mm from case.
PD, MAXIMUM DISSIPATION
(WATTS)
Fig. 1 POWER TEMPERATURE DERATING CURVE
2.5
L = 3/8" (9.5mm)
2.0
1.5
1.0
0.5
50
75
100
125
150
175
TL, LEAD TEMPERATURE (° C)
1 of 2
www.sunmate.tw
TYPE
2EZ3.6D5
2EZ3.9D5
2EZ4.3D5
2EZ4.7D5
2EZ5.1D5
2EZ5.6D5
2EZ6.2D5
2EZ6.8D5
2EZ7.5D5
2EZ8.2D5
2EZ9.1D5
2EZ10D5
2EZ11D5
2EZ12D5
2EZ13D5
2EZ14D5
2EZ15D5
2EZ16D5
2EZ17D5
2EZ18D5
2EZ19D5
2EZ20D5
2EZ22D5
2EZ24D5
2EZ27D5
2EZ30D5
2EZ33D5
2EZ36D5
2EZ39D5
2EZ43D5
2EZ47D5
2EZ51D5
2EZ56D5
2EZ62D5
2EZ68D5
2EZ75D5
2EZ82D5
2EZ91D5
2EZ100D5
2EZ110D5
2EZ120D5
2EZ130D5
2EZ140D5
2EZ150D5
2EZ160D5
2EZ170D5
2EZ180D5
2EZ190D5
2EZ200D5
Nominal Zener
Voltage
VZ @ IZT
IZT
(V)
(mA)
3.6
139
3.9
128
4.3
116
4.7
106
5.1
98.0
5.6
89.5
6.2
80.5
6.8
73.5
7.5
66.5
8.2
61.0
9.1
55.0
10
50.0
11
45.5
12
41.5
13
38.5
14
35.7
15
33.4
16
31.2
17
29.4
18
27.8
19
26.3
22
22.8
24
20.8
27
18.5
30
16.6
33
15.1
36
13.9
39
12.8
43
11.6
47
10.6
51
9.8
56
9.0
62
8.1
68
7.4
75
6.7
82
6.1
91
5.5
100
5.0
110
4.5
120
4.2
130
3.8
140
3.6
150
3.3
160
3.1
170
2.9
180
2.8
190
2.6
200
2.5
ZZT @ IZT
(Ω)
5.0
5.0
4.5
4.5
3.5
2.5
1.5
2.0
2.0
2.3
2.5
3.5
4.0
4.5
5.0
5.5
7.0
8.0
9.0
10
11
11
12
13
18
25
30
35
40
48
55
60
75
90
100
125
175
250
325
400
500
575
650
675
725
825
900
Maximum Zener
Impedance
ZZK @ IZK
(Ω)
400
400
400
550
600
500
700
700
700
700
700
700
700
700
700
700
700
700
750
750
750
750
750
750
750
1000
1000
1000
1000
1500
1500
1500
2000
2000
2000
2000
3000
3000
3000
4000
4500
5000
5500
6000
6500
7000
7000
8000
8000
IZK
(mA)
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
0.5
0.5
0.5
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
Maximum Reverse
Leakage Current
IR @ VR
(V)
(µ A)
80
1.0
30
1.0
5.0
1.0
5.0
1.0
5.0
2.0
5.0
3.0
5.0
4.0
50
5.0
50
6.0
50
7.0
50
7.6
50
8.4
1.0
9.1
0.5
9.9
0.5
10.6
0.5
11.4
0.5
12.2
0.5
13.0
0.5
13.7
0.5
14.4
0.5
15.2
0.5
16.7
0.5
18.2
0.5
20.6
0.5
22.5
0.5
25.1
0.5
27.4
0.5
29.7
0.5
32.7
0.5
35.8
0.5
38.8
0.5
42.6
0.5
47.1
0.5
51.7
0.5
56.0
0.5
62.2
0.5
69.2
0.5
76.0
0.5
83.6
0.5
91.2
0.5
98.8
0.5
106.4
0.5
114.0
0.5
121.6
0.5
130.4
0.5
136.8
0.5
144.8
0.5
152.0
Maximum DC
Zener Current
IZM
(mA)
504
468
434
386
356
324
292
266
242
220
200
182
166
152
138
130
122
114
107
100
95
90
82
76
68
60
55
50
47
43
39
36
32
29
27
24
22
17
15
14
13
12
11
11
10
10
9.0
Note :
( 1 ) Suffix " 5 " indicates ± 5.0% tolerance, suffix " 10 " indicates ± 10.0% tolerance.
2 of 2
www.sunmate.tw
很抱歉,暂时无法提供与“2EZ8.2D5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15188
- 10+0.14625
- 100+0.13275
- 500+0.12600
