SM712
Asymmetrical TVS Diode
www.sot23.com.tw
Features
Mechanical Characteristics
150W peak pulse power(8/20µs)
Ultra low leakage:nA level
Operating voltage:7V or 12V
Low clamping voltage
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
– IEC61000-4-5 (Lightning) 7A (8/20µs)
RoHS Compliant
3000
7”
CH
PU
Reel Size
Circuit Diagram
TE
SM712
Qty per Reel
Wireless System
Networks
Portable Instrumentation
RS485 Ports
BL
IC
Applications
Ordering Information
Part Number
Package: SOT-23
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
UL Flammability Classification Rating 94V-0
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Pin Configuration
SM712
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power(8/20µs)
Ppk
150
W
Peak Pulse Current(8/20µs)
IPP
7
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
IC
Storage Temperature Range
kV
±30
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
Pin 3to 1 and 3
to 2(7V TVS)
Pin 1 to 3 and 2
to 3(12V TVS)
Symbol Min
Reverse Working Voltage
Min
Typ
13.3
Max
7
12
VRWM
VBR
Max
Unit
V
V
7.5
Test Condition
I T = 1mA
CH
Breakdown Voltage
Typ
PU
Parameter
0.5
VC
19
11
V
IPP = 1A (8 x 20µs pulse)
VC
25
15
V
IPP = 7A (8 x 20µs pulse)
Junction Capacitance
CJ
75
75
pF
VR=0, f=1MHz
CJ
pF
VR=VRWM, f=1MHz
Clamping Voltage
Clamping Voltage
IR
0.01
TE
Reverse Leakage Current
45
0.01
45
0.5
µA
VR = VRWM
SM712
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
120
60
40
td=t IPP/2
10
15
30
Fig3.
Power Derating Curve
CH
TE
% of Rated Power
110
100
90
80
70
60
50
40
30
50
10%
PU
t - Time ( s)
75
100
125
Ambient Temperature –TA (ºC)
150
IC
80
90%
BL
IPP - Peak Pulse Current - % of IPP
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
Percent of Peak Pulse Current %
tr
tr = 0.7~1ns
30ns
60ns
Time (ns)
SM712
www.sot23.com.tw
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
C
c
IC
E1
GAUGE
PLANE
SEATING
PLANE
E
L
L1
DETAIL A
1
2
C A B
A2
A
3X
aaa C
PU
bbb
BL
bxN
e
SEATING PLANE
A1
TE
CH
C
SIDE VIEW
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
E
E1
C
C
E
E1
G
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
SEE DETAIL A
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.30
0.51
0.08
0.18
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
很抱歉,暂时无法提供与“SM712”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.18083
- 50+0.16478
- 500+0.14873
- 1000+0.13268
- 2500+0.12519
- 5000+0.11877
