PSOT05LC
TVS Diode Array
www.sot23.com.tw
Features
300 Watts peak pulse power (tp = 8/20μs)
Transient protection for high speed data lines to
IEC 61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC 61000-4-4 (EFT) 40A (5/50ns)
Working voltages : 5V
Protects two unidirectional line
Low operating and clamping voltages
Solid-state silicon avalanche technology
Mechanical Characteristics
Package: SOT23
Lead Finish: Matte Tin
UL Flammability Classification Rating 94V-0
Pb-Free, Halogen Free, RoHS/WEEE Compliant
Shipping Qty : 3000pcs/7Inch Tape & Reel
IC
CH
PU
USB Power & Data Line Protection
Monitors and Flat Panel Displays
I²C Bus Protection
Portable Instrumentation
Set Top Box
Dimensions and Pin Configuration
TE
BL
Applications
1
3
(N.C.)
2
PSOT05LC
TVS Diode Array
www.sot23.com.tw
Absolute Maximum Ratings (Tamb=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Ppk
300
W
Peak Pulse Power(8/20µs)
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
−55 to +125
°C
Tstg
−55 to +150
°C
BL
Storage Temperature Range
kV
TJ
IC
Operating Temperature Range
±30
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Reverse Working Voltage
Breakdown Voltage
Min
VRWM
VBR
Typ
Max
PU
Parameter
5
6
Unit
Test Condition
V
V
IT = 1mA
1.0
uA
VRWM = 5V
IR
Clamping Voltage
VC
9.8
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
11
V
IPP = 5A (8 x 20µs pulse)
IPP
17
A
tp = 8/20µs
CJ
5
pF
VR = 0V, f = 1MHz, Pin 1 to Pin 2
Junction Capacitance
TE
Peak Pulse Current
CH
Reverse Leakage Current
PSOT05LC
TVS Diode Array
www.sot23.com.tw
CH
PU
BL
IC
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
TE
% Of Rated Power
FIGURE 3
PSOT05LC
TVS Diode Array
www.sot23.com.tw
Outline Drawing - SOT23
D
A
DIM
e1
H
3
B
E1
GAUGE
PLANE
SEATING
PLANE
E
c
0.25
L
L1
IC
C
DETAIL A
1
2
bxN
bbb
C A B
A2
A
3X
BL
e
aaa C
TE
CH
C
PU
A1
SEE DETAIL A
SIDE VIEW
SEATING PLANE
Land Pattern - SOT23
X
Y
DIM
Z
G
Y
E
E1
C
C
E
E1
G
X
Y
Z
DIMENSIONS
INCHES
MILLIMETERS
(.087)
.037
.075
.031
.039
.055
.141
(2.20)
0.95
1.90
0.80
1.00
1.40
3.60
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
N
aaa
bbb
DIMENSIONS
INCHES
MILLIMETERS
MIN NOM MAX MIN NOM MAX
.035
.000
.035
.012
.003
.110
.082
.047
.015
0°
.037
.114
.093
.051
.075
.037
.020
.022
3
.004
.008
.044
.004
.040
.020
.007
.120
.104
.055
.024
8°
0.89
1.12
0.01
0.10
0.88 0.95 1.02
0.30
0.51
0.08
0.18
2.80 2.90 3.04
2.10 2.37 2.64
1.20 1.30 1.40
1.90 BSC
0.95 BSC
0.40 0.50 0.60
(0.55)
3
0°
8°
0.10
0.20
很抱歉,暂时无法提供与“PSOT05LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.25309
- 30+0.24412
- 100+0.22617
- 500+0.20822
- 1000+0.19925
