TPSLVU2.8-8-TP
TPSLVU2.8-8-TP
    TECHPUBLIC(台舟电子)
    SOP8
    Array VRWM=2.8V IR=1uA CJ=2pF
TPSLVU2.8-8-TP 数据手册
SLVU2.8-8-TP EPD TVS Array For ESD and Latch Up Protection WWW.SOT23.COM.TW Mechanical Characteristics Features 400W peak pulse power(8/20µs) Protects four line pairs(eight lines) High peak pulse currentl Comprehensive pin out for easy board layout Low capacitance Low leakage current Low operating and clamping voltages Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±25kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 2 3A (8/20µs)  RoHS Compliant         BL CH PU Applications SLVU2.8-8-TP TE Ordering Information Part Number Package: SO-8 Lead Finish: Matte Tin Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below IC       Qty per Reel Reel Size 2500 13Inch 10/100 Ethernet WAN/LAN Equipment Switching Systems DSLAMs Desktops, Severs, &Notebooks Instrumentation Base Stations Analog Inputs         Dimensions and Pin Configuration Each Line 8 7 6 5 1 2 3 4 SLVU2.8-8-TP EPD TVS Array For ESD and Latch Up Protection WWW.SOT23.COM.TW Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Ppk 400 W 23 A IC Peak Pulse Power(8/20µs) Peak Pulse Current(8/20µs) IPP ESD per IEC 61000−4−2 (Air) VESD BL ESD per IEC 61000−4−2 (Contact) Operating Temperature Range PU Storage Temperature Range ±30 ±25 kV TJ −55 to +125 °C Tstg −55 to +150 °C Parameter CH Electrical Characteristics (TA=25°C unless otherwise specified) Symbol Typ VRWM TE Reverse Working Voltage Min Max Unit 2.8 V Test Condition Pouch-Through Voltage VPT 3.0 V IPT = 2µA Snap-Back Voltage VSB 2.8 V ISB = 50mA 1.0 µA VRWM = 2.8V(Each Line) Reverse Leakage Current IR Clamping Voltage VC 6.0 V IPP = 1A (8 x 20µs pulse) (Each Line) Clamping Voltage VC 8.0 V IPP = 5A (8 x 20µs pulse) (Each Line) Clamping Voltage VC 10 V IPP = 10A (8 x 20µs pulse) (Each Line) Clamping Voltage VC 17 V IPP = 23A (8 x 20µs pulse) (Each Line) Junction Capacitance CJ pF VR = 0V, f = 1MHz(Each Line) 0.1 2 SLVU2.8-8-TP EPD TVS Array For ESD and Latch Up Protection WWW.SOT23.COM.TW PROTECTION PRODUCTS TE CH PU BL IC Typical charateristics 8 X 20μs Pulse Waveform SLVU2.8-8-TP EPD TVS Array For ESD and Latch Up Protection WWW.SOT23.COM.TW A e N h D 2 0.25 ccc C 2X N/2 TIPS e/2 DETAIL B D aaa C CH A2 A C A1 01 A SEE DETAIL A DIM A A1 A2 b c D E1 E e h L L1 N 01 aaa bbb ccc DIMENSIONS INCHES MILLIMETERS MIN NOM MAX MIN NOM MAX .069 .053 .010 .004 .065 .049 .020 .012 .010 .007 .189 .193 .197 .150 .154 .157 .236 BSC .050 BSC .010 .020 .016 .028 .041 (.041) 8 8° 0° .004 .010 .008 1.75 1.35 0.25 0.10 1.65 1.25 0.51 0.31 0.25 0.17 4.80 4.90 5.00 3.80 3.90 4.00 6.00 BSC 1.27 BSC 0.25 0.50 0.40 0.72 1.04 (1.04) 8 8° 0° 0.10 0.25 0.20 SIDE VIEW C A-B D TE bxN bbb L (L1) PU 1 c GAGE PLANE BL E1 E SEATING PLANE h H 2X E/2 IC Outline Drawing - SOP-8 Land Pattern - SOP-8 WWW.TECHPUBLIC.COM.TW
TPSLVU2.8-8-TP 价格&库存
很抱歉,暂时无法提供与“TPSLVU2.8-8-TP”相匹配的价格&库存,您可以联系我们找货
