WST2088
N-Ch MOSFET
Product Summery
General Description
The WST2088 is the highest performance trench
N-ch MOSFETs with extreme high cell density ,
which provide excellent RDSON and gate
charge for most of the small power switching
and load switch applications.
BVDSS
RDSON
ID
20V
8mΩ
8.8A
Applications
The WST2088 meet the RoHS and Green
Product requirement with full function
reliability approved.
● Power switching application
● Hard Switched and High Frequency Circuits
● Uninterruptible Power Supply
Features
SOT-23-3L Pin Configuration
z Advanced high cell density Trench technology
z Super Low Gate Charge
z Excellent Cdv/dt effect decline
z Green Device Available
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
V
VGS
Gate-Source Voltage
±12
V
ID@Tc=25℃
Continuous Drain Current, VGS @ 4.5V
8.8
A
ID@Tc=70℃
6.2
A
IDP
Pulsed Drain Current
40
A
PD@TA=25℃
Total Power Dissipation
1.5
W
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Rthj-a
Rthj-c
www.winsok.tw
Parameter
Typ.
Maximum Thermal Resistance, Junction-ambient
Maximum Thermal Resistance, Junction-case
Page 1
Max.
25
8
Unit
℃/W
℃/W
Rev:1.0 May.2019
WST2088
N-Ch MOSFET
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
BVDSS
Parameter
Drain-Source Breakdown Voltage
△BVDSS/△TJ BVDSS Temperature Coefficient
RDS(ON)
Static Drain-Source On-Resistance2
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
V
Reference to 25℃ , ID=1mA
0.018
V/℃
8
13
VGS=2.5V , ID=5A
10
19
VGS=4.5V , ID=6A
mΩ
VGS=VDS , ID =250uA
0.5
1.3
IDSS
Drain-Source Leakage Current
VDS=16V , VGS=0V.
10
uA
IGSS
Gate-Source Leakage Current
VGS=±12V , VDS=0V
±100
nA
Qg
Total Gate Charge
16
Qgs
Gate-Source Charge
3
Qgd
Gate-Drain Charge
4.5
Turn-On Delay Time
10
VGS(th)
Td(on)
Tr
Td(off)
Tf
Ciss
Gate Threshold Voltage
VDS=15V , VGS=4.5V , ID=6A
Rise Time
VDS=10V , VGS=4.5V ,
13
Turn-Off Delay Time
RG=3.3Ω ID=1A
28
7
Fall Time
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS=15V , VGS=0V , f=1MHz
nC
ns
1400
170
135
Min.
Typ.
Max.
Unit
1.2
V
8.5
nS
2.5
nC
Input Capacitance
V
pF
Diode Characteristics
Symbol
Parameter
VSD
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
Conditions
VGS=0V , IS=1A
IF=1A , VGS=0V,
dI/dt=100A/µs
Notes:
1.Pulse width limited by Max. junction temperature.
2.Pulse test
3.Surface mounted on 1 in2 copper pad of FR4 board, t
很抱歉,暂时无法提供与“WST2088”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.67680
- 10+0.63450
- 50+0.57105
- 150+0.52875
- 300+0.49914
- 500+0.48645
