100C102JW1000X
100C102JW1000X
    ATC
    贴片电容(MLCC) 2325 1nF ±5% 1KV P90
100C102JW1000X 数据手册
RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100C Series Porcelain Superchip® Multilayer Capacitors FEATURES • • • • • • • • • GENERAL DESCRIPTION KYOCERA AVX, the industry leader, offers new improved ESR/ ESL performance for the 100C Series RF Capacitors. This high Q multilayer capacitor is ultra-stable under high RF current and voltage applications. High density Porcelain construction provides a rugged, hermetic package. Case C Size (.250" x .250") Capacitance Range 1pF to 2700pF Extended WVDC up to 3600 VDC Low ESR/ESL High Q Low Noise Ultra-Stable Performance High Self-Resonance Established Reliability (QPL) PACKAGING OPTIONS Tape & Reel KYOCERA AVX offers an encapsulation option for applications requiring extended protection against arc-over and corona. ELECTRICAL SPECIFICATIONS FUNCTIONAL APPLICATIONS • Bypass • Coupling • Tuning • Impedance Matching • DC Blocking CIRCUIT APPLICATIONS • VHF/UHF RF Power Amplifiers • Antenna Tuning • Plasma Chambers • Medical (MRI coils) ENVIRONMENTAL CHARACTERISTICS Thermal Shock MIL-STD-202, Method 107, Condition A Moisture Resistance MIL-STD-202, Method 106 Low Voltage Humidity MIL-STD-202, Method 103, Condition A, with 1.5 Volts DC applied while subjected to an environment of 85°C with 85% relative humidity for 240 hours min. Life Test Termination Styles Tray (180 pcs) MIL-STD-202, Method 108, for 2000 hours, at 125°C. Voltage applied. 200% of WVDC for capacitors rated at 500 volts DC or less. 120% of WVDC for capacitors rated at 1250 volts DC or less. 100% of WVDC for capacitors rated above 1250 volts DC. Temperature Coefficient (TCC) +90 ±30 PPM/°C (-55°C to +125°C) Insulation Resistance (IR) 1 pF to 2700 pF: 105 Megohms min. @ +25°C at rated WVDC. 104 Megohms min. @ +125°C at rated WVDC. Max. test voltage is 500 VDC. Working Voltage (WVDC) See Capacitance Values Table Dielectric Withstanding Voltage (DWV) 250% of WVDC for capacitors rated at 500 volts DC or less for 5 seconds. 150% of WVDC for capacitors rated at 1250 volts DC or less for 5 seconds. 120% of WVDC for capacitors rated above 1250 Volts DC for 5 seconds Retrace Less than ±(0.02% or 0.02 pF), whichever is greater. Aging Effects None Piezoelectric Effects None Capacitance Drift ±(0.02% or 0.02 pF), whichever is greater. Operating Temperature Range From -55°C to +125°C (No derating of working voltage) Available in various surface mount and leaded styles. See Mechanical Configurations Terminations for chips and pellets withstand a pull of 10 lbs. min., 20 lbs. typical, for 5 seconds in direction Terminal Strength perpendicular to the termination surface of the capacitor. Test per MIL-STD-202, method 211. 462 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 032421 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100C Series Porcelain Superchip® Multilayer Capacitors 3600 F, G, J, K, M RATED WVDC STD. EXT. 3600 F, G, J, K, M 2500 3000 CAP. CODE 301 331 361 391 431 471 511 561 621 681 751 821 911 102 112 122 152 182 222 242 272 CAP. (pF) 300 330 360 390 430 470 510 560 620 680 750 820 910 1000 1100 1200 1500 1800 2200 2400 2700 TOL. RATED WVDC STD. EXT. 1500 2000 1000 1500 500 800 300 500 VOLTAGE TOL. F, G, J, K, M EXTENDED 2500 CAP. (pF) 39 43 47 51 56 62 68 75 82 91 100 110 120 130 150 160 180 200 220 240 270 VOLTAGE B, C, D CAP. CODE 390 430 470 510 560 620 680 750 820 910 101 111 121 131 151 161 181 201 221 241 271 EXTENDED 3600 RATED WVDC STD. EXT. TOL. VOLTAGE 2500 CAP. (pF) 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 16 18 20 22 24 27 30 33 36 EXTENDED B, C, D CAP. CODE 5R1 5R6 6R2 6R8 7R5 8R2 9R1 100 110 120 130 150 160 180 200 220 240 270 300 330 360 EXTENDED VOLTAGE RATED WVDC STD. EXT. EXTENDED VOLTAGE TOL. EXTENDED VOLTAGE CAP. (pF) 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 EXTENDED VOLTAGE CAP. CODE 1R0 1R1 1R2 1R3 1R4 1R5 1R6 1R7 1R8 1R9 2R0 2R1 2R2 2R4 2R7 3R0 3R3 3R6 3R9 4R3 4R7 VRMS = 0.707 x WVDC • SPECIAL VALUES, TOLERANCES, HIGHER WVDC AND MATCHING AVAILABLE. • ENCAPSULATION OPTION AVAILABLE . PLEASE CONSULT FACTORY. HOW TO ORDER 100 C 100 J W 2500 X T Series Packaging Case Size T = Tape and Reel, 500 pc. qty. Please see last column of mechanical configuration table for other options. See mechanical dimensions below Capacitance Laser Marking (Optional) EIA Capacitance Code in pF. First two digits = significant figures or “R” for decimal place. Third digit = number of zeros or after “R” significant figures WVDC Capacitance Tolerance Code Please see 2nd Column Mechanical Configuration Table Code Tol. B C D ±0.1 pF ±0.25 pF ±0.5 pF F G J K M ±1% ±2% ±5% ±10% ±20% Termination Style Code The above part number refers to a 100 C Series (case size C) 10 pF capacitor, J tolerance (±5%), 2500 WVDC, with W termination (Tin/Lead, Solder Plated over Nickel Barrier), laser marking and 500 pc T&R packaging. The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – 463 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100C Series Porcelain Superchip® Multilayer Capacitors MECHANICAL CONFIGURATIONS ATC ATC SERIES TERM. & CASE CODE SIZE 100C W CASE SIZE & TYPE OUTLINES W/T IS A TERMINATION SURFACE C Y L C 100C P T T Y L T Y L T C 100C MS TL LL WL W Microstrip L T C 100C WL W L Axial Ribbon C 100C T LL AW L C VA LL L T LL RW T Radial Wire 464 N/A TL L W Pkg. Type Pkg Code Tin/Lead, Solder Plated over Nickel Barrier Termination T&R, 250 or 500 pcs Tray, 36 or 180 pcs T250 or T J36 or J180 Heavy Tin/Lead Coated, over Nickel Barrier Termination T&R, 250 or 500 pcs Tray, 36 or 180 pcs T250 or T J36 or J180 RoHS Compliant Tin Plated over Nickel Barrier Termination T&R, 250 or 500 pcs Tray, 36 or 180 pcs T250 or T J36 or J180 Tray, 24 or 60 pcs J24 or J60 Tray, 24 or 60 pcs J24 or J60 Silver-plated Copper Leads LL = 2.25 (57.15) min. Dia. = .032 ±.002 (0.81 ±0.05 Box, 21 pcs B21 Silver Leads LL = .500 (12.7) min. WL = ** See below TL = .004 ±.001 (.102 ±.025) Box, 24 pcs B24 Silver-plated Copper Leads LL = 1.0 (25.4) min. Tray, 16 pcs Dia. = .032 ±.002 (0.81 ±0.05) J16 High Purity Silver Leads LL = .500 (12.7) min. WL = .240 ±.005 (6.10 ±.127 TL = .004 ±.001 (.102 ±.025) Leads are Attached with High Temperature Solder. .165(4.19) max. for capacitance values >680pF WL W Vertical Axial Ribbon .145(3.68) max. for capacitance values ≤680pF .245 ±.025 (6.22 ±0.64) T C 100C • W Axial Wire 100C .250 ±.015 (6.35 ±0.38) TL LL AR .230+.020 -.010 (5.84+0.51-0.25 W Solderable Nickel Barrier .040 (1.02) max. .230+.025 -.010 (5.84+0.64-0.25) W Pellet C 100C .230+.020 -.010 (5.84+0.51-0.25) W Solder Plate BODY DIMENSIONS LEAD AND TERMINATION INCHES (MM) DIMENSIONS AND MATERIALS LENGTH WIDTH THICKNESS OVERLAP MATERIALS (L) (W) (T) (Y) The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100C Series Porcelain Superchip® Multilayer Capacitors NON-MAGNETIC MECHANICAL CONFIGURATIONS ATC ATC SERIES TERM. & CASE CODE SIZE OUTLINES W/T IS A TERMINATION SURFACE CASE SIZE & TYPE C 100C WN Y L C 100C PN Non-Mag Pellet TN T Y L T Y Non-Mag Solderable Nickel Barrier .230+.025 -.010 (5.84+0.64-0.25) W L T C 100C .230+.035-.010 (5.84+0.89-0.25) W C 100C .230+.025 -.010 (5.84+0.64-0.25) W Non-Mag Solder Plate WL Non-Mag Microstrip .250 ±.015 (6.35 ±0.38) TL LL MN BODY DIMENSIONS LEAD AND TERMINATION INCHES (MM) DIMENSIONS AND MATERIALS LENGTH WIDTH THICKNESS OVERLAP MATERIALS (L) (W) (T) (Y) .165(4.19) max. for capacitance values >680pF .040 (1.02) max. .245 ±.025 (6.22 ±0.64) W L .145(3.68) max. for capacitance values ≤680pF T Pkg. Type Pkg Code Tin/Lead, Solder Plated over Non-Magnetic Barrier Termination T&R, 250 or 500 pcs Tray, 36 or 180 pcs T250 or T J36 or J180 Heavy Tin/Lead Coated, over Non-Magnetic Barrier Termination T&R, 250 or 500 pcs Tray, 36 or 180 pcs T250 or T J36 or J180 RoHS Compliant Tin Plated over Non-Magnetic Barrier Termination T&R, 250 or 500 pcs Tray, 36 or 180 pcs T250 or T J36 or J180 High Purity Silver Leads LL = .500 (12.7) min. WL = .240 ±.005 (6.10 ±.127) TL = .004 ±.001(.102 ±.025) Leads are Attached with High Temperature Solder. Tray, 24 or 60 pcs J24 or J60 SUGGESTED MOUNTING PAD DIMENSIONS L W 391k 1k 39 T T L W Case C Vertical Mount Cap Value Pad Size Normal High Density Normal > 680 pF High Density < 680 pF Horizontal Electrode Orientation Vertical Electrode Orientation B A A Min. B Min. C Min. D Min. .150 .130 .185 .165 .050 .030 .050 .030 .200 .200 .200 .200 .300 .260 .300 .260 .200 .200 .300 .260 B C Horizontal Mount Normal All Values High Density .280 .260 .050 .030 D The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 062821 – rf microwave products – 465 RF/Microwave Capacitors RF/Microwave Multilayer Capacitors (MLC) 100C Series Porcelain Superchip® Multilayer Capacitors PERFORMANCE DATA ESR VS CAPACITANCE AVX SERIES 100, CASE C 1 ESR (Ohms) 0.1 Q VS CAPACITANCE AVX SERIES 100, CASE C 100000 500 MHz 10000 150 MHz 1000 Q 30 MHz 30 MHz 0.01 150 MHz 100 500 MHz (Typical) 0.001 1 10 100 1000 (Typical) 10 10000 1 10 100 CAPACITANCE (pF) SERIES RESONANCE VS CAPACITANCE AVX SERIES 100, CASE C CURRENT RATING VS CAPACITANCE AVX SERIES 100, CASE C 100 1000 100 The current rating is based on a 65°C mounting surface and a device thermal resistance of 15°C/W. A power dissipation of 4W will result in a case temperature of 125°C. 10 150 MHz 500 MHz 30 MHz 10 MHz 1 Dotted line = Power dissipation limited Solid line = Voltage limited (Vrms) (Typical) 10 1 10 100 1000 0.1 10000 10 1 1.5 % CHANGE IN CAPACITANCE 100 CAPACITANCE (pF) CAPACITANCE (pF) CAPACITANCE CHANGE VS TEMPERATURE AVX SERIES 100, CASE C TC= +90 ± 30 PPM/°C 1 0.5 0 -0.5 -1 -55 -35 -15 5 25 45 65 85 105 125 TEMPERATURE (Degrees C) 466 10000 CAPACITANCE (pF) RMS CURRENT (Amps) FREQUENCY (MHz) 10000 1000 The Important Information/Disclaimer is incorporated in the catalog where these specifications came from or available online at www.avx.com/disclaimer/ by reference and should be reviewed in full before placing any order. 032421 – rf microwave products – 1000 10000
100C102JW1000X 价格&库存
很抱歉,暂时无法提供与“100C102JW1000X”相匹配的价格&库存,您可以联系我们找货
