MULTILAYER CERAMIC CHIP CAPACITORS
RoHS
Compliant
(High Reliability)
?FEATURES
1. Small size and large capacitance, high ripple current.
2. Temperature characteristic is Y5U in EIA code.
3. Superior humidity characteristic and long life.
4. Excellent noise absorption.
?APPLICATIONS
1. Smoothing circuit of small size DC-DC converter.
2. On-board power supply.
3. Noise suppressor for various kinds of equipments.
4. By-pass or decoupling circuits.
?CONSTRUCTION
Ceramic Dielectric
Termination
Tin Plating
(21, 31, 32, 43size : For flow or reflow soldering)
(55, 76size : For reflow soldering only)
Silver (THC Series only)
(All sizes : For reflow soldering only)
Internal Electrode
?RATINGS
1.
2.
3.
4.
5.
6.
Category Temperature Range
Rated Voltage Range
Rated Capacitance Range
Rated Capacitance Tolerance
Temperature Characteristics
Rated Ripple Current
-55 to +125C
25, 50, 100, 200Vdc
0.047 to 47MF
M (P20%) , Z (P80
20%)
E (JIS) Y5U (EIA)
See No.5 on the following table
?SPECIFICATIONS
No.
Items
Specification
Test Condition
1
Withstand Voltage
No abnormality.
250% of rated voltage shall be applied for 5 seconds.
2
Insulation Resistance
1000/CR(MO) or 10000(MO)
whichever is less.
Rated voltage shall be applied for 60P5 seconds at
temperature 20P2C.
3
Rated Capacitance
Within specified tolerance.
Temperature
Frequency
Voltage
: 20P2C
: 1P0.1kHz
: 1P0.2Vrms
4
Dissipation Factor
5.0% maximum.
Temperature
Frequency
Voltage
: 20P2C
: 1P0.1kHz
: 1P0.2Vrms
5
Size code 21 31 32 43 55 76
Arms
0.2 0.3 0.5 1.0 2.0 3.0
(1/4)
10kHzK1MHz (sine curve)
Ripple voltage Vp shall be less than
the rated voltage.
CAT. No. E1002P
?SPECIFICATIONS
No.
6
Items
Adhesion
Specification
Test Condition
No visible damage.
Substrate
5N (0.51kgf)
for 10P1 seconds
Capacitor
7
Bend strength of the face plating Appearance : No visible damage.
DC/C : P15%
The substrate shall be bend by 1mm at a rate of 1mm/s
for 5 seconds.
Press
Press bar
Capacitor
Substrate
1.0mm
45P2mm
8
Solderability
Min. 75% of surface of the termination
shall be covered with new solder
9
Resistance to Soldering Heat
DC/C : P15%
D.F. : To meet the initial specification.
I.R. : To meet the initial specification.
10
Temperature Cycle
DC/C : P15%
45P2mm
Solder
Solder Temperature
Dipping Time
Support
Pb Free
Eutectic
245P5C
235P5C
2P0.5sec.
Solder Temperature : 260P5C
Dipping Time
: 2P0.5 seconds
Step
1
2
3
4
Temperature (C)
Min. Category temperature P3
Room temperature
Max. Category temperature P3
Room temperature
(min.)
30P3
3 max.
30P3
3 max.
THC series : 5 cycles
TMC series : 100 cycles
11
Humidity Load Life
Appearance : No abnormality.
DC/C : P20%
D.F. : 7% maximum
I.R. : 50/CR(MO) or 1000(MO)
whichever is less.
Temperature : 40P2C
Humidity
: 90 to 95%RH
Voltage
: Rated voltage
Time
: 500P24
0 hours
12
Endurance
DC/C : P20%
D.F. : 7% maximum
I.R. : 100/CR(MO) or 1000(MO)
whichever is less.
Temperature : 85P2C
Voltage
: 200% of rated voltage.
hours
Time
: 1000P48
Temperature : 125P3C
Voltage
: Rated voltage
Time
: 1000P48
0 hours
*CR : Rated Capacitance(MF)
(2/4)
CAT. No. E1002P
?STANDARD RATINGS
Dimensions(mm)
Rated Capacitance
(mF)
L
0.33
0.47
0.68
1.0
1.5
2.2
3.3
4.7
6.8
10
15
22
33
47
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
3.3
4.7
6.8
10
15
22
0.047
0.068
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
3.3
4.7
6.8
0.047
0.068
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
2.2
25
50
100
200
W
Tmax.
a
2.0P0.2
1.25P0.2
1.25
0.3P0.2
0.2
3.2P0.2
1.6P0.2
1.6
0.5P0.3
0.3
3.2P0.2
2.5P0.2
2.0
0.6P0.3
0.5
4.5P0.3
3.2P0.2
2.2
0.6P0.3
1.0
0.8P0.5
2.0
0.8P0.5
3.0
5.7P0.4
5.0P0.4
7.5P0.5
6.3P0.5
3.0
2.2
3.0
3.0
2.0P0.2
1.25P0.2
1.25
0.3P0.2
0.2
3.2P0.2
1.6P0.2
1.6
0.5P0.3
0.3
3.2P0.2
2.5P0.2
0.6P0.3
0.5
0.6P0.3
1.0
4.5P0.3
3.2P0.2
5.7P0.4
5.0P0.4
2.0
2.5
2.2
3.0
2.2
0.8P0.5
2.0
7.5P0.5
6.3P0.5
3.0
2.5
0.8P0.5
3.0
2.0P0.2
1.25P0.2
1.25
0.3P0.2
0.2
3.2P0.2
1.6P0.2
1.6
0.5P0.3
0.3
3.2P0.2
2.5P0.2
0.6P0.3
0.5
2.0
2.5
4.5P0.3
3.2P0.2
2.2
5.7P0.4
5.0P0.4
7.5P0.5
6.3P0.5
3.0
2.2
3.0
3.0
3.2P0.2
1.6P0.2
1.6
3.2P0.2
2.5P0.2
4.5P0.3
3.2P0.2
5.7P0.4
5.0P0.4
7.5P0.5
6.3P0.5
2.0
2.5
2.2
3.0
2.2
3.0
2.5
3.0
0.6P0.3
1.0
0.8P0.5
2.0
0.8P0.5
3.0
0.5P0.3
0.3
0.6P0.3
0.5
0.6P0.3
1.0
0.8P0.5
2.0
0.8P0.5
3.0
?PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
Maximum ripple current
(Arms)
9
10
11
12
13
14
15
Part Number
Previous Part Number
KHC250E334M21N0T00
KHC250E474M21N0T00
KHC250E684M21N0T00
KHC250E105M31N0T00
KHC250E155M31N0T00
KHC250E225M31N0T00
KHC250E335M32N0T00
KHC250E475M32N0T00
KHC250E685M43N0T00
KHC250E106M43N0T00
KHC250E156M43N0T00
KHC250E226M55N0T00
KHC250E336M55N0T00
KHC250E476M76N0T00
KHC500E104M21N0T00
KHC500E154M21N0T00
KHC500E224M21N0T00
KHC500E334M31N0T00
KHC500E474M31N0T00
KHC500E684M31N0T00
KHC500E105M32N0T00
KHC500E155M32N0T00
KHC500E225M32N0T00
KHC500E335M43N0T00
KHC500E475M43N0T00
KHC500E685M55N0T00
KHC500E106M55N0T00
KHC500E156M55N0T00
KHC500E226M76N0T00
KHC101E473M21N0T00
KHC101E683M21N0T00
KHC101E104M31N0T00
KHC101E154M31N0T00
KHC101E224M31N0T00
KHC101E334M32N0T00
KHC101E474M32N0T00
KHC101E684M32N0T00
KHC101E105M43N0T00
KHC101E155M43N0T00
KHC101E225M43N0T00
KHC101E335M55N0T00
KHC101E475M55N0T00
KHC101E685M76N0T00
KHC201E473M31N0T00
KHC201E683M31N0T00
KHC201E104M32N0T00
KHC201E154M32N0T00
KHC201E224M32N0T00
KHC201E334M43N0T00
KHC201E474M43N0T00
KHC201E684M55N0T00
KHC201E105M55N0T00
KHC201E155M76N0T00
KHC201E225M76N0T00
THCS20E1E334MTF
THCS20E1E474MTF
THCS20E1E684MTF
THCS30E1E105MTF
THCS30E1E155MTF
THCS30E1E225MTF
THCS40E1E335MTF
THCS40E1E475MTF
THCS50E1E685MTF
THCS50E1E106MTF
THCS50E1E156MTF
THCS60E1E226MTF
THCS60E1E336MTF
THCS70E1E476MTF
THCS20E1H104MTF
THCS20E1H154MTF
THCS20E1H224MTF
THCS30E1H334MTF
THCS30E1H474MTF
THCS30E1H684MTF
THCS40E1H105MTF
THCS40E1H155MTF
THCS40E1H225MTF
THCS50E1H335MTF
THCS50E1H475MTF
THCS60E1H685MTF
THCS60E1H106MTF
THCS60E1H156MTF
THCS70E1H226MTF
THCS20E2A473MTF
THCS20E2A683MTF
THCS30E2A104MTF
THCS30E2A154MTF
THCS30E2A224MTF
THCS40E2A334MTF
THCS40E2A474MTF
THCS40E2A684MTF
THCS50E2A105MTF
THCS50E2A155MTF
THCS50E2A225MTF
THCS60E2A335MTF
THCS60E2A475MTF
THCS70E2A685MTF
THCS30E2D473MTF
THCS30E2D683MTF
THCS40E2D104MTF
THCS40E2D154MTF
THCS40E2D224MTF
THCS50E2D334MTF
THCS50E2D474MTF
THCS60E2D684MTF
THCS60E2D105MTF
THCS70E2D155MTF
THCS70E2D225MTF
(Just for your reference)
?DIMENSIONS
16
17
18
T
K HC 1 0 1 E 4 7 5 M 5 5 N 0 T 0 0
Supplement code
Taping code
Terminal code
Size code
Capacitance tolerance code
Nominal Capacitance code
Temperature characteristics code
Rated voltage code
Series code
Category
(3/4)
L
W
Rated voltage
(Vdc)
a
CAT. No. E1002P
?STANDARD RATINGS
Dimensions(mm)
Rated voltage Rated Capacitance
(Vdc)
(mF)
L
0.68
1
1.5
2.2
3.3
4.7
6.8
10
0.33
0.47
0.68
1.0
1.5
2.2
3.3
4.7
0.1
0.15
0.22
0.33
0.47
0.68
1.0
1.5
0.033
0.047
0.068
0.1
0.15
0.22
0.33
0.47
25
50
100
200
W
Tmax.
a
3.2P0.2
1.6P0.2
1.6
0.4P0.2
0.3
3.2P0.2
2.5P0.2
2.2
0.5P0.2
0.5
4.5P0.3
3.2P0.2
0.5P0.3
1.0
0.4P0.2
0.3
0.5P0.2
0.5
0.5P0.3
1.0
2.5
3.0
3.2P0.2
1.6P0.2
3.2P0.2
2.5P0.2
1.6
2.2
2.5
4.5P0.3
3.2P0.2
2.5
3.0
3.2P0.2
1.6P0.2
1.6
0.4P0.2
0.3
3.2P0.2
2.5P0.2
2.2
0.5P0.2
0.5
4.5P0.3
3.2P0.2
0.5P0.3
1.0
0.4P0.2
0.3
0.5P0.2
0.5
0.5P0.3
1.0
2.5
3.0
3.2P0.2
1.6P0.2
3.2P0.2
2.5P0.2
1.6
2.2
2.5
4.5P0.3
3.2P0.2
2.5
3.0
1
2
3
4
5
6
7
8
9
(Arms)
10
11
12
13
14
15
Part Number
KMC250E684M31N0T00
KMC250E105M31N0T00
KMC250E155M31N0T00
KMC250E225M32N0T00
KMC250E335M32N0T00
KMC250E475M43N0T00
KMC250E685M43N0T00
KMC250E106M43N0T00
KMC500E334M31N0T00
KMC500E474M31N0T00
KMC500E684M32N0T00
KMC500E105M32N0T00
KMC500E155M32N0T00
KMC500E225M43N0T00
KMC500E335M43N0T00
KMC500E475M43N0T00
KMC101E104M31N0T00
KMC101E154M31N0T00
KMC101E224M32N0T00
KMC101E334M32N0T00
KMC101E474M32N0T00
KMC101E684M43N0T00
KMC101E105M43N0T00
KMC101E155M43N0T00
KMC201E333M31N0T00
KMC201E473M31N0T00
KMC201E683M32N0T00
KMC201E104M32N0T00
KMC201E154M32N0T00
KMC201E224M43N0T00
KMC201E334M43N0T00
KMC201E474M43N0T00
TMCS30E1E684MTF
TMCS30E1E105MTF
TMCS30E1E155MTF
TMCS40E1E225MTF
TMCS40E1E335MTF
TMCS50E1E475MTF
TMCS50E1E685MTF
TMCS50E1E106MTF
TMCS30E1H334MTF
TMCS30E1H474MTF
TMCS40E1H684MTF
TMCS40E1H105MTF
TMCS40E1H155MTF
TMCS50E1H225MTF
TMCS50E1H335MTF
TMCS50E1H475MTF
TMCS30E2A104MTF
TMCS30E2A154MTF
TMCS40E2A224MTF
TMCS40E2A334MTF
TMCS40E2A474MTF
TMCS50E2A684MTF
TMCS50E2A105MTF
TMCS50E2A155MTF
TMCS30E2D333MTF
TMCS30E2D473MTF
TMCS40E2D683MTF
TMCS40E2D104MTF
TMCS40E2D154MTF
TMCS50E2D224MTF
TMCS50E2D334MTF
TMCS50E2D474MTF
?DIMENSIONS
16
17
18
T
K MC 2 0 1 E 1 0 4 M 3 2 N 0 T 0 0
(4/4)
L
W
Supplement code
Taping code
Terminal code
Size code
Rated voltage code
Series code
Category
a
CAT. No. E1002P
很抱歉,暂时无法提供与“KHC500E226M76R0B00”相匹配的价格&库存,您可以联系我们找货
