TRANSISTOR (NPN)
FEATURE
Excellent hFE Linearity
SOT-23
Low noise
Complementary to A733
MARKING:
1.BASE
2.EMITTER
3.COLLECTOR
CR
MAXIMUM RATINGS (TA=25℃ unless otherwise noted)
Symbol
Parameter
Value
Units
VCBO
Collector-Base Voltage
60
V
VCEO
Collector-Emitter Voltage
50
V
VEBO
Emitter-Base Voltage
5
V
IC
Collector Current -Continuous
150
mA
PC
Collector Power Dissipation
200
mW
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55-150
ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified)
Parameter
Symbol
Test
conditions
MIN
TYP
MAX
UNIT
Collector-base breakdown voltage
V(BR)CBO
IC=100uA, IE=0
60
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=1mA , IB=0
50
V
Emitter-base breakdown voltage
V(BR)EBO
IE=0.1mA, IC=0
5
V
Collector cut-off current
ICBO
VCB=60V, IE=0
0.1
µA
ICER
VCE=55V, R=10MΩ
0.1
µA
Emitter cut-off current
IEBO
VEB=5V,
IC=0
0.1
µA
hFE(1)
VCE=6V,
IC=1mA
200
hFE(2)
VCE=6V,
IC=0.1mA
40
DC current gain
400
Collector-emitter saturation voltage
VCE(sat)
IC=100mA, IB=10mA
0.3
V
Base-emitter saturation voltage
VBE(sat)
IC=100mA, IB=10mA
1
V
Transition frequency
fT
Collector output capacitance
Cob
Noise figure
NF
VCE=6V,IC=10mA,f =30 MHz
VCB=10V, IE=0,
150
MHz
f=1MHZ
VCE=6V,
IC=0.1mA
Rg=10kΩ,
f=1kMHZ
4
1 of 3
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
3.0
pF
10
dB
Typical Characteristics
C945
2 of 3
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
SOT-23
3 of 3
很抱歉,暂时无法提供与“C945”相匹配的价格&库存,您可以联系我们找货
