SOTXXC
Integrated in
OVP&OCP products
provider
3.3V~36V 2Line Uni-directional TVS DiodeArray
Description
Mechanical Characteristics
The SOTXXC is an uni-directional TVS diode array,
Package: SOT-23
utilizing leading monolithic silicon technology to provide
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
Moisture Sensitivity: Level 3 per J-STD-020
complies with the IEC 61000-4-2 (ESD) standard with
Terminal Connections: See Diagram Below
±30kV air and ±30kV contact discharge. It is assembled
Marking Information: See Below
fast response time and low ESD clamping voltage, making
this device an ideal solution for protecting sensitive
semiconductor components from damage. The SOTXXC
into a lead-free SOT-23 package. It is designed to protect
components which are connected to data and transmission
lines from voltage surges.
Applications
Features
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Portable Instrumentation
Set Top Box
Industrial Controls
Server and Desktop PC
350W peak pulse power (8/20us)
Protects one bi-directional or two uni-directional
line(s)
Ultra low leakage: nA level
Stand−off Voltage: 3.3 V ~ 36 V
Ultra low clamping voltage
Complies with following standards:
Marking information
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±30kV
Contact discharge: ±30kV
RoHS Compliant
Dimensions & Symbol(Unit: mm Max)
Details marking code reference customer approval list
Ordering Information
Part Number
SOT03C
SOT05C
SOT12C
SOT15C
SOT24C
SOT36C
Rev.A_Aug,2016
-1-
Packaging
3000/Tape & Reel
3000/Tape & Reel
3000/Tape & Reel
3000/Tape & Reel
3000/Tape & Reel
3000/Tape & Reel
Reel Size
7 inch
7 inch
7 inch
7 inch
7 inch
7 inch
www.wpmtek.com
SOTXXC
Integrated in
OVP&OCP products
provider
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
SOT03C
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
350
W
Peak Pulse Current (8/20µs)
Ipp
25
A
ESD per IEC 61000−4−2 (Air)
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
±30
±30
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Symbol
Value
Unit
Ppk
350
W
Ipp
23
A
Storage Temperature Range
SOT05C
Parameter
VESD
±30
±30
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Symbol
Value
Unit
Ppk
350
W
Ipp
12
A
SOT12C
Parameter
VESD
Rev.A_Aug,2016
-2-
±30
±30
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
www.wpmtek.com
SOTXXC
Integrated in
OVP&OCP products
provider
SOT15C
Parameter
Symbol
Value
Unit
Ppk
350
W
Ipp
10
A
VESD
±30
±30
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Symbol
Value
Unit
Ppk
350
W
Ipp
6
A
SOT24C
Parameter
VESD
±30
±30
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Symbol
Value
Unit
Ppk
350
W
Ipp
4
A
SOT36C
Parameter
VESD
Rev.A_Aug,2016
-3-
±30
±30
kV
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
www.wpmtek.com
SOTXXC
Integrated in
OVP&OCP products
provider
Electrical Characteristics (TA=25°C unless otherwise specified)
SOT03C
Parameter
Reverse Working Voltage
Symbol
Min
Typ
VRWM
Breakdown Voltage
VBR
Reverse Leakage Current
IR
Clamping Voltage
VC
Clamping Voltage
VC
Junction Capacitance
CJ
Max
Unit
3.3
V
4.0
Test Condition
V
IT = 1mA
uA
VRWM = 3.3V
V
IPP = 1A (8 x 20uS pulse)
15
V
IPP = 25A (8 x 20uS pulse)
240
pF
Max
Unit
5
V
1
7.5
VR = 0V, f = 1MHz
SOT05C
Parameter
Symbol
Min
Typ
VRWM
6.0
V
Test Condition
Breakdown Voltage
VBR
IR
1
Clamping Voltage
VC
8
V
Clamping Voltage
VC
14
V
IPP = 23A (8 x 20uS pulse)
CJ
160
IT = 1mA
VRWM = 5V
pF
VR = 0V, f = 1MHz
SOT12C
Parameter
Symbol
Min
Typ
VRWM
Breakdown Voltage
VBR
IR
Clamping Voltage
Max
Unit
12
V
V
IT = 1mA
1
uA
VRWM = 12V
VC
16
V
Clamping Voltage
VC
30
V
IPP =12A (8 x 20uS pulse)
CJ
90
pF
Rev.A_Aug,2016
13.3
Test Condition
-4-
VR = 0V, f = 1MHz
www.wpmtek.com
SOTXXC
Integrated in
OVP&OCP products
provider
SOT15C
Parameter
Symbol
Min
Typ
VRWM
Breakdown Voltage
VBR
IR
Clamping Voltage
VC
Clamping Voltage
VC
CJ
Max
Unit
15
V
16.7
Test Condition
V
IT = 1mA
uA
VRWM =15V
V
35
V
IPP = 10A (8 x 20uS pulse)
55
pF
Max
Unit
24
V
1
24
VR = 0V, f = 1MHz
SOT24C
Parameter
Symbol
Min
Typ
VRWM
Breakdown Voltage
VBR
IR
Clamping Voltage
VC
Clamping Voltage
VC
CJ
26.7
Test Condition
V
IT = 1mA
uA
VRWM =24V
V
55
V
IPP = 6A (8 x 20uS pulse)
40
pF
Max
Unit
36
V
1
35
VR = 0V, f = 1MHz
SOT36C
Parameter
Symbol
Typ
VRWM
Breakdown Voltage
VBR
IR
Clamping Voltage
VC
Clamping Voltage
VC
CJ
Rev.A_Aug,2016
Min
40
V
IT = 1mA
uA
VRWM =36V
V
75
V
IPP = 4A (8 x 20uS pulse)
35
pF
1
55
-5-
Test Condition
VR = 0V, f = 1MHz
www.wpmtek.com
SOTXXC
Integrated in
OVP&OCP products
provider
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Rev.A_Aug,2016
-6-
www.wpmtek.com
SOTXXC
Integrated in
OVP&OCP products
provider
Soldering parameters
Pb-Free assembly
(see FIG.2)
Reflow Condition
Pre Heat
-Temperature Min (Ts(min))
+150℃
-Temperature Max(Ts(max))
+200℃
-Time (Min to Max) (ts)
60-180 secs.
Average ramp up rate (Liquid us Temp (TL) to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
-Temperature(TL) (Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
Rev.A_Aug,2016
-7-
www.wpmtek.com
SOTXXC
Integrated in
OVP&OCP products
provider
Package mechanical data
Suggested Land Pattern
Contact information
WPMTEK Incorporated Limited
Floor 1 Building 4#, Binxianghua Industry Park, No.7,
Huada Road, Hualian Community, Longhua New District, Shenzhen
TEL:86755-29308003
FAX:86755-23739900
wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability
arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special,
consequential or incidental damages.
Rev.A_Aug,2016
-8-
www.wpmtek.com
很抱歉,暂时无法提供与“SOT23C”相匹配的价格&库存,您可以联系我们找货
