SELC2F5V1B
Rev-2021-1
www.elecsuper.com
SuperESD - SELC2F5V1B
1. Description
The SELC2F5V1B is designed to protect voltage sensitive components from ESD and transient voltage
events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for
ESD protection on designs where board space is at a premium.
2. Features
IEC 61000-4-2 Level 4 ESD Protection
Working voltage: 5V
±10kV Contact Discharge
Low leakage current
±15kV Air Discharge
RoHS compliant
80W Peak pulse Power (8/20us)
Protecting one bi-directional lines
Low clamping voltage
Low Junction capacitance: 0.35pF Typ.
3. Applications
USB 2.0/3.0
Notebook computers
Monitors and flat panel display
SIM ports
10/100/1000 ethernet
ATM interface
4. Ordering Information
Part Number
Package
Marking
Material
Packing
SELC2F5V1B
DFN10062L
JJ
Halogen
free
Tape &
Reel
Table-1
Copyright© ElecSuper Incorporated
Quantity
per reel
10,000
PCS
Flammability
Rating
Reel
Size
UL 94V-0
7 inches
Ordering information
Contact Us
1 / 7
SELC2F5V1B
Rev-2021-1
www.elecsuper.com
5. Pin Configuration and Functions
Name
Description
Outline
1
IO1
Connect to IO
1
2
IO2
Connect to IO
Table-2
J
Circuit Diagram
J
Pin
1
2
2
Pin configuration
6. Specification
6.1. Absolute Maximum rating
Over operating free-air temperature range (unless otherwise noted)
Parameters
Symbol
Min.
Max.
Unit
Peak pulse power (tp=8/20us)@25℃
Ppk
80
W
Peak pulse current (tp=8/20us)@25℃
IPP
4
A
ESD (IEC61000-4-2 air discharge) @25℃
VESD
±15
kV
ESD (IEC61000-4-2 contact discharge) @25℃
VESD
±10
kV
TJ
125
Operating temperature
TOP
-40
85
Storage temperature
TSTG
-55
150
TL
260
Junction temperature
Lead temperature
Table-3
Contact Us
2 / 7
SELC2F5V1B
Rev-2021-1
www.elecsuper.com
6.2. Electrical Characteristics
At TA = 25℃ unless otherwise noted
Parameter
Symbol Conditions
Reverse Stand-off Voltage
Reverse Breakdown Voltage
Min.
Typ.
VRWM
Max.
Units
5
V
VBR
IT=1mA
6.0
V
Reverse Leakage Current
IR
VRWM=5V
Clamping Voltage
VC
IPP=1A; tp=8/20us
12
V
Clamping Voltage
VC
IPP=4A; tp=8/20us
18
V
Junction Capacitance
CJ
I/O to GND; VR=0V; f=1MHz
0.35
pF
1
uA
Table-4 Electrical Characteristics
Symbol
VRWM
IR
VBR
Parameters
Peak Reverse Working Voltage
Reverse Leakage Current @ VRWM
Breakdown Voltage @ IT
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
IF
Forward Current
VF
Forward Voltage @ IF
Contact Us
3 / 7
SELC2F5V1B
Rev-2021-1
www.elecsuper.com
7. Typical Characteristic
8. Typical Application
Typical Interface Application
Contact Us
4 / 7
SELC2F5V1B
Rev-2021-1
www.elecsuper.com
9. Dimension
DFN1006-2L
Units in millimeters
Symbol
Min.
Nom.
Max.
A
0.350
0.450
0.550
A1
0.000
0.020
0.050
A2
0.077
0.127
0.207
A3
0.013
0.063
0.113
b
0.070
0.120
0.200
D
0.500
0.600
0.700
D1
0.400
0.500
0.600
D2
0.200
0.300
0.400
E
0.900
1.000
1.100
E1
0.150
0.250
0..350
e
0.460
0.510
0.560
k
0.300
0.400
0.500
Table-6
product dimensions
Contact Us
5 / 7
SELC2F5V1B
Rev-2021-1
www.elecsuper.com
10. Recommended Land Pattern
Note:
1. Controlling dimension: in millimeters
2. General tolerance: ±0.05mm
3. The pad layout is for reference only
Contact Us
6 / 7
SELC2F5V1B
Rev-2021-1
www.elecsuper.com
DISCLAIMER
ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES
(INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER
RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING
WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE
OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS.
These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for
(1) selecting the appropriate ElecSuper products for your application,
(2) designing, validating and testing your application
(3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources
are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an
application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are
prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right.
ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims,
damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to
ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such
ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable
warranties or warranty disclaimers for ElecSuper products
Contact Us
7 / 7
很抱歉,暂时无法提供与“SELC2F5V1B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.12012
- 30+0.11583
- 100+0.11154
- 500+0.10296
- 1000+0.09867
- 2000+0.09610
