XA214-G4C SOT363 (SC-76-6)
Applications
Pin Out
T/R switch in WLANs, BluetoothTM and medium-power
telecommunication applications
6
2
5
CBL
Features
GND
Low insertion loss (0.4 dB @ 2.4 GHz)
● Isolation 26 dB @ 2.4 GHz
● Low DC power consumption
● PHEMT process
● Operates at 1.8 V control voltage
● Available lead (Pb)-free and RoHS-compliant MSL-1 @ 260 °C
per JEDEC J-STD-020
1
J3
V2
CBL
4
3
J2
CBL
J1
V1
DC blocking capacitors (CBL) must be supplied externally for positive voltage operation.
CBL = 100 pF for operation >500 MHz.
Description
The XA214-G4C is a medium-power IC FET SPDT switch in a lowcost miniature SC-70 6-lead plastic package. The XA214-G4C
features low insertion loss and positive voltage operation with
very low DC power consumption. This general purpose switch
can be used in a variety of telecommunications applications.
Electrical Specifications at 25 °C (0, 3 V)
Parameter(1)
Frequency
Insertion loss(2)
0.5–1.0 GHz
1.0–2.0 GHz
2.0–3.0 GHz
Isolation
0.5–1.0 GHz
1.0–2.0 GHz
2.0–3.0 GHz
VSWR(3)
0.5–1.0 GHz
1.0–2.0 GHz
2.0–3.0 GHz
Min.
27
24
22
Typ.
Max.
Unit
0.3
0.4
0.4
0.5
0.6
0.6
dB
dB
dB
30
27
25
dB
dB
dB
1.1:1
1.1:1
1.4:1
1. All measurements made in a 50 Ω system, unless otherwise specified.
2. Insertion loss changes by 0.003 dB/°C.
3. Insertion loss state.
1
Operating Characteristics at 25 °C (0, 3 V)
Parameter
Condition
Switching characteristics
Rise, fall
On, off
Video feedthru
Frequency
Min.
Typ.
10/90% or 90/10% RF
50% CTL to 90/10% RF
TRISE = 1 ns, BW = 500 MHz
Input power for 1 dB compression
VCTL = 0/1.8 V
VCTL = 0/3 V
0.5–3.0 GHz
0.5–3.0 GHz
Intermodulation intercept point (IP3)
For two-tone input power 5 dBm
VCTL = 0/3 V 0.5–3 GHz
Thermal resistance
Control voltages
Max.
Unit
10
ns
ns
mV
dBm
dBm
40
dBm
25
°C/W
VLOW = 0 to 0.2 V @ 20 µA max.
VHIGH = 2.7 V @ 100 µA max. to 5 V @ 200 µA max.
-0.25
-15
-0.50
-20
Isolation (dB)
Insertion Loss (dB)
Typical Performance Data (0, 3 V)
-0.75
-1.00
-1.25
-35
-40
-1.75
-45
-50
1.0
1.5
2.0
2.5
3.0
0.5
1.0
1.5
2.0
Frequency (GHz)
Insertion Loss vs. Frequency
Isolation vs. Frequency
1.4
1.3
1.2
1.1
1.0
Frequency (GHz)
1.5
VSWR
-30
-1.50
-2.00
0.5
1.0
1.5
2.0
Frequency (GHz)
VSWR vs. Frequency
2
-25
2.5
3.0
2.5
3.0
Absolute Maximum Ratings
Characteristic
RF input power
Truth Table
Value
V1
V2
J1–J2
J1–J3
2 W max. for f > 500 MHz
500 mW for f < 500 MHz
VCTL = 0/8 V
VHIGH
Isolation
Insertion loss
VHIGH
Insertion loss
Isolation
Supply voltage
8V
Control voltage
-0.2 V, +8 V
Operating temperature
Storage temperature
All other conditions not recommended.
VHIGH = 2.7 to 5 V.
-40 °C to +85 °C
-65 °C to +150 °C
Performance is guaranteed only under the conditions listed in the specifications table and is
not guaranteed under the full range(s) described by the Absolute Maximum specifications.
Exceeding any of the absolute maximum/minimum specifications may result in permanent
damage to the device and will void the warranty.
CAUTION: Although this device is designed to be as robust as
possible, ESD (Electrostatic Discharge) can damage
this device. This device must be protected at all times
from ESD. Static charges may easily produce potentials of several kilovolts on the human body or
equipment, which can discharge without detection.
Industry-standard ESD precautions must be employed
at all times.
3
很抱歉,暂时无法提供与“XA214-G4C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.61780
- 20+0.56260
- 100+0.50740
- 500+0.45220
- 1000+0.42644
- 2000+0.40804
