XD555 DIP8 / XL555 SOP8
D Very Low Power Consumption
D
D
D
D
D
D
D
D
D
description
− 1 mW Typ at VDD = 5 V
Capable of Operation in Astable Mode
CMOS Output Capable of Swinging Rail
to Rail
High Output-Current Capability
− Sink 100 mA Typ
− Source 10 mA Typ
Output Fully Compatible With CMOS, TTL,
and MOS
Low Supply Current Reduces Spikes
During Output Transitions
Single-Supply Operation From 2 V to 15 V
Functionally Interchangeable With the
555NE; Has Same Pinout
ESD Protection Exceeds 2000 V Per
MIL-STD-883C, Method 3015.2
Available in Q-Temp Automotive
High Reliability Automotive Applications
Configuration Control/Print Support
Qualification to Automotive Standards
The XD/XL555 is a monolithic timing circuit
fabricated using the TI LinCMOS process. The
timer is fully compatible with CMOS, TTL, and
MOS logic and operates at frequencies up to
2 MHz. Because of its high input impedance, this
device uses smaller timing capacitors than those
used by the 555NE. As a result, more accurate
time delays and oscillations are possible. Power
consumption is low across the full range of power
supply voltage.
D, DB, JG, OR P PACKAGE
(TOP VIEW)
GND
TRIG
OUT
RESET
1
8
2
7
3
6
4
5
VDD
DISCH
THRES
CONT
Like the 555NE, the XD/XL555 has a trigger level equal to approximately one-third of the supply voltage and a
threshold level equal to approximately two-thirds of the supply voltage. These levels can be altered by use of
the control voltage terminal (CONT). When the trigger input (TRIG) falls below the trigger level, the flip-flop is
set and the output goes high. If TRIG is above the trigger level and the threshold input (THRES) is above the
threshold level, the flip-flop is reset and the output is low. The reset input (RESET) can override all other inputs
and can be used to initiate a new timing cycle. If RESET is low, the flip-flop is reset and the output is low.
Whenever the output is low, a low-impedance path is provided between the discharge terminal (DISCH) and
GND. All unused inputs should be tied to an appropriate logic level to prevent false triggering.
While the CMOS output is capable of sinking over 100 mA and sourcing over 10 mA, the XD/XL555 exhibits greatly
reduced supply-current spikes during output transitions. This minimizes the need for the large decoupling
capacitors required by the 555NE.
1
description (continued)
The XD/XL555 is characterized for operation from 0 °C to 70°C. The XD/XL555 is characterized for operation from
−40°C to 85°C. The XD/XL555 is characterized for operation over the automotive temperature range of −40°C
to 125°C. The XD/XL555 is characterized for operation over the full military temperature range of −55°C to
125°C.
AVAILABLE OPTIONS†
PACKAGED DEVICES
TA
VDD
RANGE
0°C to 70°C
2 V to 15 V
−40°C to 85°C
3 V to 15 V
−40°C to 125°C
5 V to 15 V
−55°C to 125°C
5 V to 15 V
SMALL
OUTLINE
(D)‡
SSOP
(DB)‡
CHIP CARRIER
(FK)
CERAMIC DIP
(JG)
PLASTIC DIP
(P)
TSSOP
(PW)‡
XD555
XD555
XD555
XL555
FUNCTION TABLE
RESET VOLTAGE‡
TRIGGER VOLTAGE‡
THRESHOLD VOLTAGE‡
OUTPUT
DISCHARGE SWITCH
On
MAX
MAX
>MAX
>MAX
L
On
>MAX
>MAX
很抱歉,暂时无法提供与“XD555”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.14800
- 50+0.89520
- 150+0.79950
- 500+0.68010
