XD3140
XD3140
    XINLUDA(信路达)
    DIP8
    模拟开关芯片 DIP-8
XD3140 数据手册
XD3140 DIP8 / XL3140 SOP8 4.5MHz, BiMOS Operational Amplifier with MOSFET Input/Bipolar Output Features • MOSFET Input Stage - Very High Input Impedance (ZIN) -1.5TΩ (Typ) - Very Low Input Current (Il) -10pA (Typ) at ±15V - Wide Common Mode Input Voltage Range (VlCR) - Can be Swung 0.5V Below Negative Supply Voltage Rail - Output Swing Complements Input Common Mode Range The 3140 are integrated circuit operational amplifiers that combine the advantages of high voltage PMOS transistors with high voltage bipolar transistors on a single monolithic chip. The 3140 BiMOS operational amplifiers feature gate protected MOSFET (PMOS) transistors in the input circuit to provide very high input impedance, very low input current, and high speed performance. The 3140 operate at supply voltage from 4V to 36V (either single or dual supply). These operational amplifiers are internally phase compensated to achieve stable operation in unity gain follower operation, and additionally, have access terminal for a supplementary external capacitor if additional frequency roll-off is desired. Terminals are also provided for use in applications requiring input offset voltage nulling. The use of PMOS field effect transistors in the input stage results in common mode input voltage capability down to 0.5V below the negative supply terminal, an important attribute for single supply applications. The output stage uses bipolar transistors and includes built-in protection against damage from load terminal short circuiting to either supply rail or to ground. • Directly Replaces Industry Type 741 in Most Applications • Pb-Free Plus Anneal Available (RoHS Compliant) Applications • Ground-Referenced Single Supply Amplifiers in Automobile and Portable Instrumentation • Sample and Hold Amplifiers • Long Duration Timers/Multivibrators (µseconds-Minutes-Hours) • Photocurrent Instrumentation • Peak Detectors • Active Filters • Comparators • Interface in 5V TTL Systems and Other Low Supply Voltage Systems The 3140 are intended for operation at supply voltages up to 36V (±18V). • All Standard Operational Amplifier Applications • Function Generators • Tone Controls 3140 DIP/SOP TOP VIEW • Power Supplies • Portable Instruments OFFSET NULL 1 8 STROBE INV. INPUT 2 7 V+ 6 OUTPUT 5 OFFSET NULL • Intrusion Alarm Systems NON-INV. INPUT 3 V- 4 + 1 XD3140 DIP8 / XL3140 SOP8 Absolute Maximum Ratings Thermal Information DC Supply Voltage (Between V+ and V- Terminals) . . . . . . . . . 36V Differential Mode Input Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . 8V DC Input Voltage . . . . . . . . . . . . . . . . . . . . . . (V+ +8V) To (V- -0.5V) Input Terminal Current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1mA Output Short Circuit Duration∞ (Note 2) . . . . . . . . . . . . . . Indefinite Thermal Resistance (Typical, Note 1) θJA (oC/W) θJC (oC/W) PDIP Package*. . . . . . . . . . . . . . . . . . . 115 N/A SOIC Package . . . . . . . . . . . . . . . . . . . 165 N/A Maximum Junction Temperature (Plastic Package) . . . . . . . 150oC Maximum Storage Temperature Range . . . . . . . . . . -65oC to 150oC Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . 300oC (SOIC - Lead Tips Only) Operating Conditions Temperature Range . . . . . . . . . . . . . . . . . . . . . . . . . -55oC to 125oC *Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications. CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTES: 1. θJA is measured with the component mounted on a low effective thermal conductivity test board in free air. See Tech Brief TB379 for details 2. Short circuit may be applied to ground or to either supply. Electrical Specifications VSUPPLY = ±15V, TA = 25oC TYPICAL VALUES PARAMETER SYMBOL Input Offset Voltage Adjustment Resistor TEST CONDITIONS UNITS 3140 Typical Value of Resistor Between Terminals 4 and 5 or 4 and 1 to Adjust Max VIO 4.7 18 kΩ Input Resistance RI 1.5 1.5 TΩ Input Capacitance CI 4 4 pF Output Resistance RO 60 60 Ω Equivalent Wideband Input Noise Voltage (See Figure 27) eN BW = 140kHz, RS = 1MΩ 48 48 µV Equivalent Input Noise Voltage (See Figure 35) eN RS = 100Ω f = 1kHz 40 40 nV/√Hz f = 10kHz 12 12 nV/√Hz IOM+ Source 40 40 mA IOM- Sink 18 18 mA Short Circuit Current to Opposite Supply Gain-Bandwidth Product, (See Figures 6, 30) fT 4.5 4.5 MHz Slew Rate, (See Figure 31) SR 9 9 V/µs 220 220 µA Rise Time 0.08 0.08 µs Overshoot 10 10 % To 1mV 4.5 4.5 µs To 10mV 1.4 1.4 µs Sink Current From Terminal 8 To Terminal 4 to Swing Output Low Transient Response (See Figure 28) tr OS Settling Time at 10VP-P, (See Figure 5) Electrical Specifications tS RL = 2kΩ CL = 100pF RL = 2kΩ CL = 100pF Voltage Follower For Equipment Design, at VSUPPLY = ±15V, TA = 25oC, Unless Otherwise Specified 3140 PARAMETER SYMBOL MIN TYP MAX MIN TYP MAX UNITS Input Offset Voltage |VIO| - 5 15 - 2 5 mV Input Offset Current |IIO| - 0.5 30 - 0.5 20 pA II - 10 50 - 10 40 pA Input Current 2 XD3140 DIP8 / XL3140 SOP8 For Equipment Design, at VSUPPLY = ±15V, TA = 25oC, Unless Otherwise Specified (Continued) Electrical Specifications 3140 PARAMETER Large Signal Voltage Gain (Note 3) (See Figures 6, 29) Common Mode Rejection Ratio (See Figure 34) SYMBOL MIN TYP MAX MIN TYP MAX UNITS AOL 20 100 - 20 100 - kV/V 86 100 - 86 100 - dB - 32 320 - 32 320 µV/V 70 90 - 70 90 - dB CMRR Common Mode Input Voltage Range (See Figure 8) VICR -15 -15.5 to +12.5 11 -15 -15.5 to +12.5 12 V Power-Supply Rejection Ratio, ∆VIO/∆VS (See Figure 36) PSRR - 100 150 - 100 150 µV/V 76 80 - 76 80 - dB Max Output Voltage (Note 4) (See Figures 2, 8) VOM+ +12 13 - +12 13 - V VOM- -14 -14.4 - -14 -14.4 - V Supply Current (See Figure 32) I+ - 4 6 - 4 6 mA Device Dissipation PD - 120 180 - 120 180 mW ∆VIO/∆T - 8 - - 6 - µV/oC Input Offset Voltage Temperature Drift NOTES: 3. At VO = 26VP-P , +12V, -14V and RL = 2kΩ. 4. At RL = 2kΩ. Electrical Specifications For Design Guidance At V+ = 5V, V- = 0V, TA = 25oC TYPICAL VALUES PARAMETER 3140 SYMBOL UNITS Input Offset Voltage |VIO| 5 2 mV Input Offset Current |IIO| 0.1 0.1 pA Input Current II 2 2 pA Input Resistance RI 1 1 TΩ AOL 100 100 kV/V 100 100 dB 32 32 µV/V 90 90 dB -0.5 -0.5 V 2.6 2.6 V PSRR ∆VIO/∆VS 100 100 µV/V 80 80 dB VOM+ 3 3 V Large Signal Voltage Gain (See Figures 6, 29) Common Mode Rejection Ratio CMRR Common Mode Input Voltage Range (See Figure 8) VICR Power Supply Rejection Ratio Maximum Output Voltage (See Figures 2, 8) VOM- 0.13 0.13 V Source IOM+ 10 10 mA Sink I OM- 1 1 mA Slew Rate (See Figure 31) SR 7 7 V/µs Gain-Bandwidth Product (See Figure 30) fT 3.7 3.7 MHz Supply Current (See Figure 32) I+ 1.6 1.6 mA Device Dissipation PD 8 8 mW 200 200 µA Maximum Output Current: Sink Current from Terminal 8 to Terminal 4 to Swing Output Low 3 XD3140 DIP8 / XL3140 SOP8 Block Diagram 2mA 4mA 7 V+ BIAS CIRCUIT CURRENT SOURCES AND REGULATOR 200µA + 1.6mA 3 - 2µA A≈ 10,000 A ≈ 10 INPUT 200µA 2mA A≈1 6 OUTPUT 2 C1 12pF 5 1 OFFSET NULL 4 VSTROBE 8 Schematic Diagram BIAS CIRCUIT INPUT STAGE SECOND STAGE OUTPUT STAGE DYNAMIC CURRENT SINK 7 V+ D1 D7 Q1 Q3 Q2 D8 R10 1K Q4 Q5 Q6 Q20 R9 50Ω Q19 R11 20Ω Q7 R12 12K R14 20K Q21 Q17 R1 8K R13 5K R8 Q8 1K Q 18 6 OUTPUT D2 D3 D4 D5 INVERTING INPUT 2 NON-INVERTING INPUT 3 - Q9 + Q10 C1 R2 500Ω R3 500Ω 12pF Q14 Q11 R4 500Ω Q12 R5 500Ω 5 NOTE: Q16 D6 R6 50Ω 1 OFFSET NULL Q15 Q13 R7 30Ω 8 4 STROBE V- All resistance values are in ohms. 4 XD3140 DIP8 / XL3140 SOP8 Output Circuit Considerations level shifting circuitry usually associated with the 741 series of operational amplifiers. Excellent interfacing with TTL circuitry is easily achieved with a single 6.2V zener diode connected to Terminal 8 as shown in Figure 1. This connection assures that the maximum output signal swing will not go more positive than the zener voltage minus two base-to-emitter voltage drops within the 3140 . These voltages are independent of the operating supply voltage. Figure 4 shows some typical configurations. Note that a series resistor, RL, is used in both cases to limit the drive available to the driven device. Moreover, it is recommended that a series diode and shunt diode be used at the thyristor input to prevent large negative transient surges that can appear at the gate of thyristors, from damaging the integrated circuit. V+ 5V TO 36V 8 2 Offset Voltage Nulling LOGIC SUPPLY 5V 7 6.2V 6 3140 TYPICAL TTL GATE ≈ 5V 3 The input offset voltage can be nulled by connecting a 10kΩ potentiometer between Terminals 1 and 5 and returning its wiper arm to terminal 4, see Figure 3A. This technique, however, gives more adjustment range than required and therefore, a considerable portion of the potentiometer rotation is not fully utilized. Typical values of series resistors (R) that may be placed at either end of the potentiometer, see Figure 3B, to optimize its utilization range are given in the Electrical Specifications table. 4 OUTPUT STAGE TRANSISTOR (Q15, Q16) SATURATION VOLTAGE (mV) FIGURE 1. ZENER CLAMPING DIODE CONNECTED TO TERMINALS 8 AND 4 TO LIMIT 3140 OUTPUT SWING TO TTL LEVELS 1000 100 An alternate system is shown in Figure 3C. This circuit uses only one additional resistor of approximately the value shown in the table. For potentiometers, in which the resistance does not drop to 0Ω at either end of rotation, a value of resistance 10% lower than the values shown in the table should be used. SUPPLY VOLTAGE (V-) = 0V TA = 25oC SUPPLY VOLTAGE (V+) = +5V +15V +30V Low Voltage Operation Operation at total supply voltages as low as 4V is possible with the 3140. A current regulator based upon the PMOS threshold voltage maintains reasonable constant operating current and hence consistent performance down to these lower voltages. 10 1 0.01 0.1 1.0 LOAD (SINKING) CURRENT (mA) 10 The low voltage limitation occurs when the upper extreme of the input common mode voltage range extends down to the voltage at Terminal 4. This limit is reached at a total supply voltage just below 4V. The output voltage range also begins to extend down to the negative supply rail, but is slightly higher than that of the input. Figure 8 shows these characteristics and shows that with 2V dual supplies, the lower extreme of the input common mode voltage range is below ground potential. FIGURE 2. VOLTAGE ACROSS OUTPUT TRANSISTORS (Q15 AND Q16) vs LOAD CURRENT Figure 2 shows output current sinking capabilities of the 3140 at various supply volt ages. Output voltage swing to the negative supply rail permits this device to operate both power transistors and thyristors directly without the need for V+ V+ 2 2 V+ 7 2 7 6 3140 3140 4 4 3 5 5 R 1 4 5 1 R 1 10kΩ 10kΩ 6 3140 6 3 3 7 10kΩ R V- FIGURE 3A. BASIC V- V- FIGURE 3B. IMPROVED RESOLUTION FIGURE 3C. SIMPLER IMPROVED RESOLUTION FIGURE 3. THREE OFFSET VOLTAGE NULLING METHODS 5 XD3140 DIP8 / XL3140 SOP8 RS V+ LOAD 30V NO LOAD 2 MT2 7 120VAC +HV 7 LOAD 6 3140 RL 2 3 4 6 3140 MT1 RL 3 4 FIGURE 4. METHODS OF UTILIZING THE VCE(SAT) SINKING CURRENT CAPABILITY OF THE 3140 SERIES FOLLOWER +15V 7 0.1µF 3 SIMULATED LOAD 10kΩ 6 3140 2kΩ 100pF 2 4 0.1µF -15V 2kΩ LOAD RESISTANCE (RL) = 2kΩ LOAD CAPACITANCE (CL) = 100pF SUPPLY VOLTAGE: VS = ±15V TA = 25oC 0.05µF 10 1mV 1mV INVERTING 5kΩ 8 INPUT VOLTAGE (V) 6 10mV 10mV +15V 4 7 2 0 -10 0.1 6 3140 200Ω -4 100pF 3 -6 1mV 10mV 2kΩ 4 1mV 0.1µF 4.99kΩ 10mV 1.0 SETTLING TIME (µs) SIMULATED LOAD 5kΩ INVERTING -2 -8 0.1µF 2 FOLLOWER 5.11kΩ -15V SETTLING POINT 10 D1 D2 1N914 FIGURE 5A. WAVEFORM 1N914 FIGURE 5B. TEST CIRCUITS FIGURE 5. SETTLING TIME vs INPUT VOLTAGE Bandwidth and Slew Rate The exceptionally fast settling time characteristics are largely due to the high combination of high gain and wide bandwidth of the 3140; as shown in Figure 6. For those cases where bandwidth reduction is desired, for example, broadband noise reduction, an external capacitor connected between Terminals 1 and 8 can reduce the open loop -3dB bandwidth. The slew rate will, however, also be proportionally reduced by using this additional capacitor. Thus, a 20% reduction in bandwidth by this technique will also reduce the slew rate by about 20%. Input Circuit Considerations As mentioned previously, the amplifier inputs can be driven below the Terminal 4 potential, but a series current limiting resistor is recommended to limit the maximum input terminal current to less than 1mA to prevent damage to the input protection circuitry. Figure 5 shows the typical settling time required to reach 1mV or 10mV of the final value for various levels of large signal inputs for the voltage follower and inverting unity gain amplifiers. Moreover, some current limiting resistance should be provided between the inverting input and the output when 6 XD3140 DIP8 / XL3140 SOP8 the 3140 is used as a unity gain voltage follower. This resistance prevents the possibility of extremely large input signal transients from forcing a signal through the input protection network and directly driving the internal constant current source which could result in positive feedback via the output terminal. A 3.9kΩ resistor is sufficient. input offset voltage) due to the application of large differential input voltages that are sustained over long periods at elevated temperatures. Both applied voltage and temperature accelerate these changes. The process is reversible and offset voltage shifts of the opposite polarity reverse the offset. Figure 9 shows the typical offset voltage change as a function of various stress voltages at the maximum rating of 125oC (for metal can); at lower temperatures (metal can and plastic), for example, at 85oC, this change in voltage is considerably less. In typical linear applications, where the differential voltage is small and symmetrical, these incremental changes are of about the same magnitude as those encountered in an operational amplifier employing a bipolar transistor input stage. The typical input current is on the order of 10pA when the inputs are centered at nominal device dissipation. As the output supplies load current, device dissipation will increase, raising the chip temperature and resulting in increased input current. Figure 7 shows typical input terminal current versus ambient temperature for the 3140. 100 φOL RL = 2kΩ, CL = 0pF -90 -105 -120 -135 80 -150 10K INPUT CURRENT (pA) -75 SUPPLY VOLTAGE: VS = ±15V TA = 25oC OPEN LOOP PHASE (DEGREES) OPEN LOOP VOLTAGE GAIN (dB) It is well known that MOSFET devices can exhibit slight changes in characteristics (for example, small changes in 60 RL = 2kΩ, CL = 100pF 40 SUPPLY VOLTAGE: VS = ±15V 1K 100 10 20 0 101 102 103 104 105 106 FREQUENCY (Hz) 107 1 -60 108 RL = ∞ 0 +VICR AT TA = 125oC +VICR AT TA = 25oC +VICR AT TA = -55oC -0.5 -1.0 +VOUT AT TA = 125oC +VOUT AT TA = 25oC +VOUT AT TA = -55oC -1.5 -2.0 -2.5 -3.0 0 5 10 15 SUPPLY VOLTAGE (V+, V-) 20 -20 0 20 40 60 80 TEMPERATURE (oC) 100 120 140 FIGURE 7. INPUT CURRENT vs TEMPERATURE INPUT AND OUTPUT VOLTAGE EXCURSIONS FROM TERMINAL 4 (V-) INPUT AND OUTPUT VOLTAGE EXCURSIONS FROM TERMINAL 7 (V+) FIGURE 6. OPEN LOOP VOLTAGE GAIN AND PHASE vs FREQUENCY -40 25 1.5 -VICR AT TA = 125oC 1.0 -VICR AT TA = 25oC 0.5 0 -0.5 -1.0 -1.5 0 FIGURE 8. OUTPUT VOLTAGE SWING CAPABILITY AND COMMON MODE INPUT VOLTAGE RANGE vs SUPPLY VOLTAGE 7 -VICR AT TA = -55oC -VOUT FOR TA = -55oC to 125oC 5 10 15 SUPPLY VOLTAGE (V+, V-) FIGURE 9. 20 25 XD3140 DIP8 / XL3140 SOP8 CENTERING -15V 10kΩ 7.5kΩ +15V 360Ω 3 7 + 15kΩ - 2 4 5 2MΩ 51 pF 7-60 pF -15V +15V 39kΩ 120Ω -15V 6 - 2 FREQUENCY ADJUSTMENT 10kΩ 5.1kΩ EXTERNAL OUTPUT 7 - 6 3080 + 3 2.7kΩ 4 0.1 µF -15V 2kΩ 10kΩ 62kΩ 2 11kΩ 11kΩ 10kΩ 4 HIGH FREQ. SHAPE +15V 5 + 3140 3 100kΩ FROM BUFFER METER DRIVER (OPTIONAL) 0.1 µF 7 6 3080 360Ω SYMMETRY -15V +15V HIGH FREQUENCY LEVEL 910kΩ 7-60pF EXTERNAL OUTPUT -15V 13kΩ TO OUTPUT AMPLIFIER TO SINE WAVE SHAPER 1N914 OUTPUT AMPLIFIER +15V THIS NETWORK IS USED WHEN THE OPTIONAL BUFFER CIRCUIT IS NOT USED FIGURE 10A. CIRCUIT FREQUENCY ADJUSTMENT Top Trace: Output at junction of 2.7Ω and 51Ω resistors; 5V/Div., 500ms/Div. Center Trace: External output of triangular function generator; 2V/Div., 500ms/Div. +15V METER DRIVER AND BUFFER AMPLIFIER Bottom Trace: Output of “Log” generator; 10V/Div., 500ms/Div. FIGURE 10B. FIGURE FUNCTION GENERATOR SWEEPING POWER SUPPLY ±15V M -15V FUNCTION GENERATOR WIDEBAND LINE DRIVER SINE WAVE SHAPER 51Ω SWEEP GENERATOR FINE RATE GATE DC LEVEL SWEEP ADJUST OFF INT. COARSE RATE 1V/Div., 1s/Div. V- EXT. EXTERNAL INPUT SWEEP LENGTH Three tone test signals, highest frequency ≥0.5MHz. Note the slight asymmetry at the three second/cycle signal. This asymmetry is due to slightly different positive and negative integration from the 3080 and from the PC board and component leakages at the 100pA level. V- FIGURE 10C. FUNCTION GENERATOR WITH FIXED FREQUENCIES FIGURE 10D. INTERCONNECTIONS FIGURE 10. FUNCTION GENERATOR 8 XD3140 DIP8 / XL3140 SOP8 500kΩ FREQUENCY ADJUSTMENT 10kΩ FREQUENCY CALIBRATION MAXIMUM 620kΩ 7 51kΩ 3 + 6 3140 SWEEP IN 3MΩ - 2 0.1µF 3 4 4.7kΩ 5.1kΩ 5 4 +15V 2kΩ 12kΩ FREQUENCY 2.4kΩ CALIBRATION MINIMUM 2.5 kΩ 510Ω 6 5 9 3.6kΩ 13 8 D6 D3 12 METER POSITION ADJUSTMENT D4 9.1kΩ R1 10kΩ 14 2kΩ 6 7 EXTERNAL OUTPUT D1 -15V 2 D2 1 3 4 D5 3019 DIODE ARRAY 3/ OF 3086 5 -15V FIGURE 11. METER DRIVER AND BUFFER AMPLIFIER FIGURE 12. SINE WAVE SHAPER 750kΩ “LOG” SAWTOOTH 18MΩ 1N914 100kΩ 100kΩ FINE RATE 1MΩ 22MΩ SAWTOOTH SYMMETRY 1N914 0.47µF 0.047µF 8.2kΩ +15V SAWTOOTH AND RAMP LOW LEVEL SET (-14.5V) COARSE RATE 4700pF 50kΩ 75kΩ 470pF 2 - 3 + 7 +15V 0.1 µF “LOG”+15V 4 50kΩ LOG RATE ADJUST -15V 43kΩ 10kΩ 10kΩ 7 - 3 6 3140 100kΩ TO OUTPUT 2 AMPLIFIER 30kΩ 0.1 µF +15V 36kΩ TRIANGLE 6 3140 51kΩ SAWTOOTH + 10kΩ 4 -15V EXTERNAL OUTPUT TO FUNCTION GENERATOR “SWEEP IN” SWEEP WIDTH -15V 3 6 3140 2 LOGVIO +15V 7 + 5 1 51kΩ 4 6.8kΩ 91kΩ 10kΩ TRIANGLE 25kΩ 3.9Ω -15V 5 1 4 TRANSISTORS FROM CA3086 ARRAY 2 100Ω 390Ω 3 FIGURE 13. SWEEPING GENERATOR 9 TO WIDEBAND OUTPUT AMPLIFIER 10kΩ 1MΩ 100 kΩ 10 SUBSTRATE OF CA3019 7 -15V R3 10kΩ +15V 9 8 4 0.1µF 1kΩ 200µA M METER 510Ω 6 - 620Ω 11 5.6kΩ 7.5kΩ 7 + 3140 2 METER SENSITIVITY ADJUSTMENT 0.1µF -15V +15V TO CA3080A OF FUNCTION 3080 GENERATOR (FIGURE 10) SAWTOOTH “LOG” GATE PULSE OUTPUT 430Ω R2 1kΩ XD3140 DIP8 / XL3140 SOP8 This circuit can be adjusted most easily with a distortion analyzer, but a good first approximation can be made by comparing the output signal with that of a sine wave generator. The initial slope is adjusted with the potentiometer R1, followed by an adjustment of R2. The final slope is established by adjusting R3, thereby adding additional segments that are contributed by these diodes. Because there is some interaction among these controls, repetition of the adjustment procedure may be necessary. REFERENCE VOLTAGE VOLTAGE ADJUSTMENT 3 + 7 6 3140 INPUT 2 REGULATED OUTPUT 4 Sweeping Generator FIGURE 15. BASIC SINGLE SUPPLY VOLTAGE REGULATOR SHOWING VOLTAGE FOLLOWER CONFIGURATION Figure 13 shows a sweeping generator. Three 3140 are used in this circuit. One 3140 is used as an integrator, a second device is used as a hysteresis switch that determines the starting and stopping points of the sweep. A third 3140 is used as a logarithmic shaping network for the log function. Rates and slopes, as well as sawtooth, triangle, and logarithmic sweeps are generated by this circuit. Essentially, the regulators, shown in Figures 16 and 17, are connected as non inverting power operational amplifiers with a gain of 3.2. An 8V reference input yields a maximum output voltage slightly greater than 25V. As a voltage follower, when the reference input goes to 0V the output will be 0V. Because the offset voltage is also multiplied by the 3.2 gain factor, a potentiometer is needed to null the offset voltage. Wideband Output Amplifier Figure 14 shows a high slew rate, wideband amplifier suitable for use as a 50Ω transmission line driver. This circuit, when used in conjunction with the function generator and sine wave shaper circuits shown in Figures 10 and 12 provides 18VP-P output open circuited, or 9VP-P output when terminated in 50Ω. The slew rate required of this amplifier is 28V/µs (18VP-P x π x 0.5MHz). Series pass transistors with high ICBO levels will also prevent the output voltage from reaching zero because there is a finite voltage drop (VCESAT) across the output of the 3140 (see Figure 2). This saturation voltage level may indeed set the lowest voltage obtainable. The high impedance presented by Terminal 8 is advantageous in effecting current limiting. Thus, only a small signal transistor is required for the current-limit sensing amplifier. Resistive decoupling is provided for this transistor to minimize damage to it or the 3140 in the event of unusual input or output transients on the supply rail. +15V + SIGNAL LEVEL ADJUSTMENT 2.5kΩ 3 7 + 2 - 4 + +15V 3kΩ -15V 200Ω 2.4pF 2pF 1.8kΩ 2N3053 1N914 2.7Ω 1N914 2.7Ω 51Ω OUT 2W Figures 16 and 17, show circuits in which a D2201 high speed diode is used for the current sensor. This diode was chosen for its slightly higher forward voltage drop characteristic, thus giving greater sensitivity. It must be emphasized that heat sinking of this diode is essential to minimize variation of the current trip point due to internal heating of the diode. That is, 1A at 1V forward drop represents one watt which can result in significant regenerative changes in the current trip point as the diode temperature rises. Placing the small signal reference amplifier in the proximity of the current sensing diode also helps minimize the variability in the trip level due to the negative temperature coefficient of the diode. In spite of those limitations, the current limiting point can easily be adjusted over the range from 10mA to 1A with a single adjustment potentiometer. If the temperature stability of the current limiting system is a serious consideration, the more usual current sampling resistor type of circuitry should be employed. 8 1 OUTPUT DC LEVEL ADJUSTMENT 2.2 kΩ 6 3140 200Ω 50µF 25V 50µF 25V 2.2 kΩ 2N4037 -15V NOMINAL BANDWIDTH = 10MHz tr = 35ns FIGURE 14. WIDEBAND OUTPUT AMPLIFIER Power Supplies High input impedance, common mode capability down to the negative supply and high output drive current capability are key factors in the design of wide range output voltage supplies that use a single input voltage to provide a regulated output voltage that can be adjusted from essentially 0V to 24V. A power Darlington transistor (in a metal can with heatsink), is used as the series pass element for the conventional current limiting system, Figure 16, because high power Darlington dissipation will be encountered at low output voltage and high currents. Unlike many regulator systems using comparators having a bipolar transistor input stage, a high impedance reference voltage divider from a single supply can be used in connection with the 3140 (see Figure 15). 10 XD3140 DIP8 / XL3140 SOP8 A small heat sink VERSAWATT transistor is used as the series pass element in the fold back current system, Figure 17, since dissipation levels will only approach 10W. In this system, the D2201 diode is used for current sampling. Foldback is provided by the 3kΩ and 100kΩ divider network connected to the base of the current sensing transistor. regulation also remains constant. Line regulation is 0.1% per volt. Hum and noise voltage is less than 200µV as read with a meter having a 10MHz bandwidth. Figure 18A shows the turn ON and turn OFF characteristics of both regulators. The slow turn on rise is due to the slow rate of rise of the reference voltage. Figure 18B shows the transient response of the regulator with the switching of a 20Ω load at 20V output. Both regulators provide better than 0.02% load regulation. Because there is constant loop gain at all voltage settings, the +30V 3 2N6385 CURRENT POWER DARLINGTON LIMITING ADJUST D2201 2 OUTPUT 0.1 ⇒ 24V AT 1A +30V 1kΩ 200Ω 75Ω 1kΩ 1kΩ 1 1kΩ 100Ω 8 56pF 8 2.7kΩ 10µF 1kΩ 5 - 2.2kΩ + 2.7kΩ 10µF 4 - 10 11 1 2 9 3 8 7 5 6 4 5µF 50kΩ 14 180kΩ 1kΩ 3140 6 82kΩ 5 - 1 100kΩ 82kΩ 3 4 INPUT INPUT + 56pF 2 3 1 100kΩ 1kΩ 7 180kΩ 2 3140 3kΩ 2N2102 3 1kΩ 7 + 100kΩ 100kΩ 2N2102 1 1 2 3kΩ 6 OUTPUT ⇒ 0V TO 25V 25V AT 1A “FOLDS BACK” TO 40mA “FOLDBACK” CURRENT LIMITER 2N5294 D2201 2 3 VOLTAGE ADJUST 100kΩ + - + 2.2kΩ 250µF 12 0.01µF - 10 11 1 2 9 3 8 7 5 6 4 5µF 50kΩ 14 VOLTAGE ADJUST 100kΩ + - 250µF 12 0.01µF 13 13 3086 3086 1kΩ 1kΩ 62kΩ 62kΩ HUM AND NOISE OUTPUT
XD3140 价格&库存
很抱歉,暂时无法提供与“XD3140”相匹配的价格&库存,您可以联系我们找货
XD3140
    • 2000+2.11600
    库存:2000000
