XD8574AP DIP-16 XD8574P DIP-16
XL8574AT SOP16 XL8574T SOP16
1. General description
The 8574A/PT provides general-purpose remote I/O expansion via the two-wire
bidirectional I2C-bus (serial clock (SCL), serial data (SDA)).
The devices consist of eight quasi-bidirectional ports, 100 kHz I2C-bus interface, three
hardware address inputs and interrupt output operating between 2.5 V and 6 V. The
quasi-bidirectional port can be independently assigned as an input to monitor interrupt
status or keypads, or as an output to activate indicator devices such as LEDs. System
master can read from the input port or write to the output port through a single register.
The low current consumption of 2.5 A (typical, static) is great for mobile applications and
the latched output ports directly drive LEDs.
The 8574A/PT are identical, except for the different fixed portion of the
slave address. The three hardware address pins allow eight of each device to be on the
same I2C-bus, so there can be up to 16 of these I/O expanders 8574A/PT together on
the same I2C-bus, supporting up to 128 I/Os (for example, 128 LEDs).
The active LOW open-drain interrupt output (INT) can be connected to the interrupt logic
of the microcontroller and is activated when any input state differs from its corresponding
input port register state. It is used to indicate to the microcontroller that an input state has
changed and the device needs to be interrogated without the microcontroller continuously
polling the input register via the I2C-bus.
The internal Power-On Reset (POR) initializes the I/Os as inputs with a weak internal
pull-up 100 A current source.
2. Features and benefits
I2C-bus to parallel port expander
100 kHz I2C-bus interface (Standard-mode I2C-bus)
Operating supply voltage 2.5 V to 6 V with non-overvoltage tolerant I/O held to VDD
with 100 A current source
8-bit remote I/O pins that default to inputs at power-up
Latched outputs directly drive LEDs
Total package sink capability of 80 mA
Active LOW open-drain interrupt output
Eight programmable slave addresses using three address pins
Low standby current (2.5 A typical)
40 C to +85 C operation
ESD protection exceeds 2000 V HBM per JESD22-A114 and 1000 V CDM per
1
Latch-up testing is done to JEDEC standard JESD78 which exceeds 100 mA
Packages offered: DIP16, SOP16
3. Applications
LED signs and displays
Servers
Key pads
Industrial control
Medical equipment
PLC
Cellular telephones
Mobile devices
Gaming machines
Instrumentation and test measurement
4. Ordering options
Table 1.
Ordering options
Type number
Package Packing method
Temperature range
XD8574P
DIP16
Standard marking
* IC’s tube - DSC bulk pack
T amb = 40 C to +85 C
XD8574AP
DIP16
Standard marking
XL8574T
SO16
Standard marking
* tube dry pack
SO16
Reel 13” Q1/T1
*standard mark SMD dry pack
SO16
Standard marking
* tube dry pack
SO16
Reel 13” Q1/T1
XL8574AT
2
5. Block diagram
8574A/PT
INTERRUPT
LOGIC
LP FILTER
INT
A0
A1
A2
SCL
SDA
I2C-BUS
CONTROL
INPUT
FILTER
SHIFT
REGISTER
8 bits
P0
P1
P2
P3
P4
P5
P6
P7
I/O
PORT
write pulse
read pulse
POWER-ON
RESET
VDD
VSS
Fig 1.
Block diagram
write pulse
100 μA
IOH
VDD
Itrt(pu)
data from Shift Register
D
Q
FF
IOL
CI
P0 to P7
S
power-on reset
VSS
D
Q
FF
CI
read pulse
S
to interrupt logic
data to Shift Register
Fig 2.
Simplified schematic diagram of P0 to P7
3
6. Pinning information
6.1 Pinning
A0
1
16 VDD
A1
2
15 SDA
A2
3
14 SCL
P0
4
P1
5
8574P
8574AP
13 INT
12 P7
P2
6
11 P6
P3
7
10 P5
VSS
8
Fig 3.
9
A0
1
16 VDD
A1
2
15 SDA
A2
3
P0
4
P1
5
P2
6
11 P6
P3
7
10 P5
VSS
8
9
14 SCL
8574T
8574AT
12 P7
P4
P4
Pin configuration for DIP16
Fig 4.
Pin configuration for SO16
6.2 Pin description
Table 2.
13 INT
Pin description
Symbol
Pin
Description
A0
1
6
address input 0
A1
2
7
address input 1
A2
3
9
address input 2
P0
4
10
quasi-bidirectional I/O 0
P1
5
11
quasi-bidirectional I/O 1
P2
6
12
quasi-bidirectional I/O 2
P3
7
14
quasi-bidirectional I/O 3
DIP16, SO16
VSS
8
15
supply ground
P4
9
16
quasi-bidirectional I/O 4
P5
10
17
quasi-bidirectional I/O 5
P6
11
19
quasi-bidirectional I/O 6
P7
12
quasi-bidirectional I/O 7
INT
13
1
interrupt output (active LOW)
SCL
14
2
serial clock line
SDA
15
4
serial data line
VDD
16
5
supply voltage
n.c.
3, 8, 13, 18
not connected
4
7. Functional description
Refer to Figure 1 “Block diagram”.
7.1 Device address
Following a START condition, the bus master must send the address of the slave it is
accessing and the operation it wants to perform (read or write). The address format of the
8574A/PT is shown in Figure5 . Slave address pins A2, A1 and A0 are held HIGH or
LOW to choose one of eight slave addresses. To conserve power, no internal pull-up
resistors are incorporated on A2, A1 or A0, so they must be externally held HIGH or LOW.
The address pins (A2, A1, A0) can connect to VDD or VSS directly or through resistors.
R/W
slave address
fixed
A2
A1
A0
hardware
selectable
1
1
fixed
a. XD8574AP
Fig 5.
R/W
slave address
1
A2
A1
A0
hardware
selectable
b.XD8574P
8574A/PT slave addresses
The last bit of the first byte defines the operation to be performed. When set to logic 1 a
read is selected, while a logic 0 selects a write operation (write operation is shown in
Figure 5).
7.1.1 Address maps
The 8574A/PT are functionally the same, but have a different fixed portion
(A6 to A3) of the slave address. This allows eight of the XD8574AP and eight of the
XD8574P to be on the same I 2C-bus without address conflict.
Table 3. 8574A/PT address map
Pin connectivity
Address of PCF8574
Address byte value
Write
Read
7-bit
hexadecimal
address
without R/W
40h
41h
20h
1
42h
43h
21h
1
44h
45h
22h
1
1
46h
47h
23h
1
48h
49h
24h
4Ah
4Bh
25h
1
4Ch
4Dh
26h
1
1
4Eh
4Fh
27h
A2
A1
A0
A6
A5
A4
A3
A2
A1
VSS
VSS
VSS
VSS
VSS
VDD
VSS
VDD
VSS
VSS
VDD
VDD
VDD
VSS
VSS
VDD
VSS
VDD
VDD
VDD
VSS
VDD
VDD
VDD
A0 R/W
Table 4. 8574A/PT address map
Pin connectivity
Address of PCF8574A
Address byte value
Write
Read
7-bit
hexadecimal
address
without R/W
70h
71h
38h
1
72h
73h
39h
1
74h
75h
3Ah
1
1
76h
77h
3Bh
1
78h
79h
3Ch
1
1
7Ah
7Bh
3Dh
1
1
1
1
7Ch
7Dh
3Eh
1
1
1
1
1
7Eh
7Fh
3Fh
A2
A1
A0
A6
A5
A4
A3
A2
A1
A0 R/W
VSS
VSS
VSS
1
1
VSS
VSS
VDD
1
1
VSS
VDD
VSS
1
1
VSS
VDD
VDD
1
1
VDD
VSS
VSS
1
1
VDD
VSS
VDD
1
VDD
VDD
VSS
VDD
VDD
VDD
8. I/O programming
8.1 Quasi-bidirectional I/Os
A quasi-bidirectional I/O is an input or output port without using a direction control register.
Whenever the master reads the register, the value returned to master depends on the
actual voltage or status of the pin. At power on, all the ports are HIGH with a weak 100 A
internal pull-up to VDD, but can be driven LOW by an internal transistor, or an external
signal. The I/O ports are entirely independent of each other, but each I/O octal is
controlled by the same read or write data byte.
Advantages of the quasi-bidirectional I/O over totem pole I/O include:
• Better for driving LEDs since the p-channel (transistor to VDD) is small, which saves
die size and therefore cost. LED drive only requires an internal transistor to ground,
while the LED is connected to VDD through a current-limiting resistor. Totem pole I/O
have both n-channel and p-channel transistors, which allow solid HIGH and LOW
output levels without a pull-up resistor — good for logic levels.
• Simpler architecture — only a single register and the I/O can be both input and output
at the same time. Totem pole I/O have a direction register that specifies the port pin
direction and it is always in that configuration unless the direction is explicitly
changed.
• Does not require a command byte. The simplicity of one register (no need for the
pointer register or, technically, the command byte) is an advantage in some
embedded systems where every byte counts because of memory or bandwidth
limitations.
6
There is only one register to control four possibilities of the port pin: Input HIGH, input
LOW, output HIGH, or output LOW.
Input HIGH: The master needs to write 1 to the register to set the port as an input mode
if the device is not in the default power-on condition. The master reads the register to
check the input status. If the external source pulls the port pin up to VDD or drives
logic 1, then the master will read the value of 1.
Input LOW: The master needs to write 1 to the register to set the port to input mode if
check the input status. If the external source pulls the port pin down to VSS or drives
logic 0, which sinks the weak 100 A current source, then the master will read the value
of 0.
Output HIGH: The master writes 1 to the register. There is an additional ‘accelerator’ or
strong pull-up current when the master sets the port HIGH. The additional strong pull-up
is only active during the HIGH time of the acknowledge clock cycle. This accelerator
current helps the port’s 100 A current source make a faster rising edge into a heavily
loaded output, but only at the start of the acknowledge clock cycle to avoid bus
contention if an external signal is pulling the port LOW to VSS/driving the port with
logic 0 at the same time. After the half clock cycle there is only the 100 A current
source to hold the port HIGH.
Output LOW: The master writes 0 to the register. There is a strong current sink
transistor that holds the port pin LOW. A large current may flow into the port, which
could potentially damage the part if the master writes a 0 to the register and an external
source is pulling the port HIGH at the same time.
VDD
input HIGH
weak 100 µA
current source
(inactive when
output LOW)
pull-up with
resistor to VDD or
external drive HIGH
P port
P7 - P0
output HIGH
accelerator
pull-up
pull-down with
resistor to VSS or
external drive LOW
output LOW
input LOW
VSS
Fig 6.
Simple quasi-bidirectional I/O
7
8.2 Writing to the port (Output mode)
The master (microcontroller) sends the START condition and slave address setting the
last bit of the address byte to logic 0 for the write mode. The 8574A/PT acknowledges
and the master then sends the data byte for P7 to P0 to the port register. As the clock line
goes HIGH, the 8-bit data is presented on the port lines after it has been acknowledged by
the 8574A/PT. If a LOW is written, the strong pull-down turns on and stays on. If a
HIGH is written, the strong pull-up turns on for 1⁄2 of the clock cycle, then the line is held
HIGH by the weak current source. The master can then send a STOP or ReSTART
condition or continue sending data. The number of data bytes that can be sent
successively is not limited and the previous data is overwritten every time a data byte has
been sent and acknowledged.
Ensure a logic 1 is written for any port that is being used as an input to ensure the strong
external pull-down is turned off.
SCL
1
2
3
4
5
6
7
8
9
slave address
data 1
SDA S A6 A5 A4 A3 A2 A1 A0 0
START condition
R/W
data 2
A P7 P6 1 P4 P3 P2 P1 P0 A P7 P6 0 P4 P3 P2 P1 P0 A
P5
acknowledge
from slave
P5
acknowledge
from slave
acknowledge
from slave
write to port
tv(Q)
data output from port
tv(Q)
DATA 1 VALID
DATA 2 VALID
P5 output voltage
Itrt(pu)
P5 pull-up output current
IOH
INT
td(rst)
Fig 7.
Write mode (output)
Simple code WRITE mode:
Remark: Bold type = generated by slave device.
8
8.3 Reading from a port (Input mode)
The port must have been previously written to logic 1, which is the condition after
power-on reset. To enter the Read mode the master (microcontroller) addresses the slave
device and sets the last bit of the address byte to logic 1 (address byte read). The slave
will acknowledge and then send the data byte to the master. The master will NACK and
then send the STOP condition or ACK and read the input register again.
The read of any pin being used as an output will indicate HIGH or LOW depending on the
actual state of the pin.
If the data on the input port changes faster than the master can read, this data may be
lost. The DATA 2 and DATA3 are lost because these data did not meet the setup time and
hold time (see Figure 8).
slave address
data from port
SDA S A6 A5 A4 A3 A2 A1 A0 1
START condition
R/W
A
DATA 1
data from port
A
acknowledge
from slave
DATA 4
acknowledge
from master
no acknowledge
from master
1
P
STOP
condition
read from
port
DATA 2
data at
port
DATA 1
DATA 3
th(D)
DATA 4
tsu(D)
INT
tv(INT)
trst(INT)
trst(INT)
A LOW-to-HIGH transition of SDA while SCL is HIGH is defined as the STOP condition (P). Transfer of data can be stopped at
any moment by a STOP condition. When this occurs, data present at the last acknowledge phase is valid (output mode). Input
data is lost.
Fig 8.
Read mode (input)
Simple code for Read mode:
8.4 Power-on reset
When power is applied to VDD, an internal Power-On Reset (POR) holds the
8574A/PT in a reset condition until VDD has reached VPOR. At that point, the reset
condition is released and the 8574A/PT registers and I 2C-bus/SMBus state machine
will initialize to their default states of all I/Os to inputs with weak current source to VDD.
Thereafter VDD must be lowered below VPOR and back up to the operation voltage for
power-on reset cycle.
9
8.5 Interrupt output (INT)
The 8574A/PT provides an open-drain output (INT ) which can be fed to a
corresponding input of the microcontroller (see Figure 9 ). As soon as a port input is
changed, the INT will be active (LOW) and notify the microcontroller.
An interrupt is generated at any rising or falling edge of the port inputs. After time tv(Q), the
signal INT is valid.
The interrupt will reset to HIGH when data on the port is changed to the original setting or
data is read or written by the master.
In the Write mode, the interrupt may be reset (HIGH) on the rising edge of the
acknowledge bit of the address byte and also on the rising edge of the write to port pulse.
The interrupt will always be reset (HIGH) on the falling edge of the write to port pulse (see
Figure 7).
The interrupt is reset (HIGH) in the Read mode on the rising edge of the read from port
pulse (see Figure8 ).
During the interrupt reset, any I/O change close to the read or write pulse may not
generate an interrupt, or the interrupt will have a very short pulse. After the interrupt is
reset, any change in I/Os will be detected and transmitted as an INT.
At power-on reset all ports are in Input mode and the initial state of the ports is HIGH,
therefore, for any port pin that is pulled LOW or driven LOW by external source, the
interrupt output will be active (output LOW).
VDD
device 1
device 2
device 16
XD8574AP
XD8574AP
XD8574P
INT
INT
INT
MICROCONTROLLER
INT
Fig 9. Application of multiple 8574A/PT with interrupt
10
9. Characteristics of the I2C-bus
The I2C-bus is for 2-way, 2-wire communication between different ICs or modules. The
two wires are a serial data line (SDA) and a serial clock line (SCL). Both lines must be
connected to a positive supply via a pull-up resistor when connected to the output stages
of a device. Data transfer may be initiated only when the bus is not busy.
9.1 Bit transfer
One data bit is transferred during each clock pulse. The data on the SDA line must remain
stable during the HIGH period of the clock pulse as changes in the data line at this time
will be interpreted as control signals (see Figure10 ).
SDA
SCL
change
of data
allowed
data line
stable;
data valid
Fig 10. Bit transfer
9.1.1 START and STOP conditions
Both data and clock lines remain HIGH when the bus is not busy. A HIGH-to-LOW
transition of the data line while the clock is HIGH is defined as the START condition (S). A
LOW-to-HIGH transition of the data line while the clock is HIGH is defined as the STOP
condition (P) (see Figure 11).
SDA
SCL
S
P
START condition
STOP condition
Fig 11. Definition of START and STOP conditions
9.2 System configuration
A device generating a message is a ‘transmitter’; a device receiving is the ‘receiver’. The
device that controls the message is the ‘master’ and the devices which are controlled by
the master are the ‘slaves’ (see Figure 12).
11
SDA
SCL
MASTER
TRANSMITTER/
RECEIVER
SLAVE
TRANSMITTER/
RECEIVER
SLAVE
RECEIVER
MASTER
TRANSMITTER/
RECEIVER
MASTER
TRANSMITTER
I2C-BUS
MULTIPLEXER
SLAVE
Fig 12. System configuration
9.3 Acknowledge
The number of data bytes transferred between the START and the STOP conditions from
transmitter to receiver is not limited. Each byte of eight bits is followed by one
acknowledge bit (see Figure 13). The acknowledge bit is an active LOW level (generated
by the receiving device) that indicates to the transmitter that the data transfer was
successful.
A slave receiver which is addressed must generate an acknowledge after the reception of
each byte. Also a master must generate an acknowledge after the reception of each byte
that has been clocked out of the slave transmitter. The device that wants to issue an
acknowledge bit has to pull down the SDA line during the acknowledge clock pulse, so
that the SDA line is stable LOW during the HIGH period of the acknowledge bit related
clock pulse; set-up and hold times must be taken into account.
A master receiver must signal an end of data to the transmitter by not generating an
acknowledge on the last byte that has been clocked out of the slave. In this event, the
transmitter must leave the data line HIGH to enable the master to generate a STOP
condition.
data output
by transmitter
not acknowledge
data output
by receiver
acknowledge
SCL from master
1
2
S
8
clock pulse for
acknowledgement
START
condition
Fig 13. Acknowledgement on the I2C-bus
12
9
10. Application design-in information
10.1 Bidirectional I/O expander applications
In the 8-bit I/O expander application shown in Figure 14, P0 and P1 are inputs, and
P2 to P7 are outputs. When used in this configuration, during a write, the input (P0 and
P1) must be written as HIGH so the external devices fully control the input ports.
The desired HIGH or LOW logic levels may be written to the ports used as outputs (P2 to
P7). If 10 A internal output HIGH is not enough current source, the port needs external
pull-up resistor. During a read, the logic levels of the external devices driving the input
ports (P0 and P1) and the previous written logic level to the output ports (P2 to P7) will be
read.
The GPIO also has an interrupt line (INT) that can be connected to the interrupt logic of
the microcontroller. By sending an interrupt signal on this line, the remote I/O informs the
microprocessor that there has been a change of data on its ports without having to
communicate via the I2C-bus.
VDD
VDD
CORE
PROCESSOR
VDD
SDA
SCL
INT
A0
A1
A2
P0
P1
P2
P3
P4
P5
P6
P7
temperature sensor
battery status
control for latch
control for switch
control for audio
control for camera
control for MP3
Fig 14. Bidirectional I/O expander application
10.2 How to read and write to I/O expander (example)
In the application example of 8574A/PT shown in Figure 14, the microcontroller wants to
control the P3 switch ON and the P7 LED ON when the temperature sensor P0 changes.
1. When the system power on:
Core Processor needs to issue an initial command to set P0 and P1 as inputs and
P[7:2] as outputs with value 1010 00 (LED off, MP3 off, camera on, audio off,
switch off and latch off).
2. Operation:
When the temperature changes above the threshold, the temperature sensor signal
will toggle from HIGH to LOW. The INT will be activated and notifies the ‘core
processor’ that there have been changes on the input pins. Read the input register.
If P0 = 0 (temperature sensor has changed), then turn on LED and turn on switch.
3. Software code:
//System Power on
// write to 8574A/PT with data 1010 0011b to set P[7:2] outputs and P[1:0] inputs
//Initial setting for 9574
13
while (INT == 1); //Monitor the interrupt pin. If INT = 1 do nothing
//When INT = 0 then read input ports
//Read 8574A/PT data
If (P0 == 0) //Temperature sensor activated
// write to 8574A/PT with data 0010 1011b to turn on LED (P7), on Switch (P3)
and keep P[1:0] as input ports.
// Write to 8574A/PT
10.3 High current-drive load applications
The GPIO has a minimum guaranteed sinking current of 10 mA per bit at 5 V. In
applications requiring additional drive, two port pins may be connected together to sink up
to 20 mA current. Both bits must then always be turned on or off together. Up to five pins
can be connected together to drive 80 mA, which is the device recommended total limit.
Each pin needs its own limiting resistor as shown in Figure 15 to prevent damage to the
device should all ports not be turned on at the same time.
VDD
VDD
SDA
SCL
INT
CORE
PROCESSOR
A0
A1
A2
VDD
P0
P1
P2
P3
P4
P5
P6
P7
LOAD
Fig 15. High current-drive load application
10.4 Migration path
NXP offers newer, more capable drop-in replacements for the 8574A/PT in newer
space-saving packages.
Table 5.
Migration path
Type number
I2C-bus
frequency
Voltage range
Number of
addresses
per device
Interrupt
Reset
Total package
sink current
8574A/PT
100 kHz
2.5 V to 6 V
8
yes
no
80 mA
8574A/PT
400 kHz
2.3 V to 5.5 V
8
yes
no
200 mA
9674/74A
1 MHz Fm+
2.3 V to 5.5 V
64
yes
14
no
200 mA
11. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDD
supply voltage
IDD
ISS
Conditions
Min
Max
Unit
0.5
+7
V
supply current
100
mA
ground supply current
100
mA
VI
input voltage
VSS 0.5
VDD + 0.5 V
II
input current
mA
IO
output current
25
mA
Ptot
total power dissipation
400
mW
P/out
power dissipation per output
100
mW
Tj(max)
maximum junction temperature
125
C
Tstg
storage temperature
65
+150
C
Tamb
ambient temperature
40
+85
C
operating
12. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
Typ
Unit
Rth(j-a)
thermal resistance from junction
to ambient
SO16 package
115
C/W
SSOP20 package
136
C/W
15
13. Static characteristics
Table 8.
VDD = 2.5 V to 6 V; VSS = 0 V; Tamb = 40 C to +85 C; unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Supply
VDD
supply voltage
2.5
6.0
V
IDD
supply current
operating mode; VDD = 6 V; no load;
VI = VDD or VSS; fSCL = 100 kHz
40
100
A
Istb
standby current
standby mode; VDD = 6 V; no load;
VI = VDD or VSS
2.5
10
A
VPOR
power-on reset voltage
VDD = 6 V; no load; VI = VDD or VSS
1.3
2.4
V
0.5
+0.3VDD
V
[1]
Input SCL; input/output SDA
VIL
LOW-level input voltage
VIH
HIGH-level input voltage
0.7VDD
VDD + 0.5
V
IOL
LOW-level output current
VOL = 0.4 V
3
mA
IL
leakage current
VI = VDD or VSS
1
+1
A
Ci
input capacitance
VI = VSS
7
pF
I/Os; P0 to P7
VIL
0.5
+0.3VDD
V
VIH
0.7VDD
VDD + 0.5
V
IIHL(max)
maximum allowed input current
through protection diode
VI VDD or VI VSS
400
A
IOL
VOL = 1 V; VDD = 5 V
10
25
mA
IOH
HIGH-level output current
VOH = VSS
30
300
A
Itrt(pu)
transient boosted pull-up current HIGH during acknowledge (see
Figure7 ); VOH = VSS; VDD = 2.5 V
1
mA
Ci
input capacitance
10
pF
Co
output capacitance
10
pF
Interrupt INT (see Figure7 )
IOL
VOL = 0.4 V
1.6
mA
IL
leakage current
VI = VDD or VSS
1
+1
A
0.5
+0.3VDD
V
Select inputs A0, A1, A2
VIL
VIH
ILI
input leakage current
[1]
pin at VDD or VSS
0.7VDD
VDD + 0.5
V
250
+250
nA
The power-on reset circuit resets the I2C-bus logic at VDD < VPOR and sets all I/Os to logic 1 (with current source to VDD).
16
14. Dynamic characteristics
Table 9. Dynamic characteristics
Symbol
I2C-bus
Parameter
timing[1]
Conditions
Min
Typ
Max
Unit
(see Figure 16)
fSCL
SCL clock frequency
100
kHz
tBUF
bus free time between a STOP and
START condition
4.7
s
tHD;STA
hold time (repeated) START condition
4
s
tSU;STA
set-up time for a repeated START condition
4.7
s
tSU;STO
set-up time for STOP condition
4
s
tHD;DAT
data hold time
ns
tVD;DAT
data valid time
3.4
s
tSU;DAT
data set-up time
250
ns
tLOW
LOW period of the SCL clock
4.7
s
tHIGH
HIGH period of the SCL clock
4
s
tr
rise time of both SDA and SCL signals
1
s
tf
fall time of both SDA and SCL signals
0.3
s
Port timing (see Figure7 and Figure8 )
tv(Q)
data output valid time
CL 100 pF
4
s
tsu(D)
data input set-up time
CL 100 pF
s
th(D)
data input hold time
CL 100 pF
4
s
Interrupt INT timing (see Figure8 )
tv(INT)
valid time on pin INT
from port to INT;
CL 100 pF
4
s
trst(INT)
reset time on pin INT
from SCL to INT;
CL 100 pF
4
s
[1]
All the timing values are valid within the operating supply voltage and ambient temperature range and refer to VIL and VIH with an input
voltage swing of VSS to VDD.
protocol
START
condition
(S)
tSU;STA
bit 7
MSB
(A7)
tLOW
bit 6
(A6)
tHIGH
bit 0
(R/W)
acknowledge
(A)
STOP
condition
(P)
1 / fSCL
0.7 × VDD
SCL
0.3 × VDD
tBUF
tr
tf
0.7 × VDD
SDA
0.3 × VDD
tHD;STA
tSU;DAT
tHD;DAT
Rise and fall times refer to VIL and VIH.
Fig 16. I2C-bus timing diagram
17
tVD;DAT
tVD;ACK
tSU;STO
17
18
