XD2551 DIP8 / XL2551 SOP8
Features
TXD
1
8
RS
VSS
2
7
CANH
VDD
3
6
CANL
RXD
4
5
VREF
2551
• Suitable for 12V and 24V systems
• Externally-controlled slope for reduced RFI
emissions
• Detection of ground fault (permanent Dominant)
on TXD input
• Power-on Reset and voltage brown-out protection
• An unpowered node or brown-out event will not
disturb the CAN bus
• Low current standby operation
• Protection against damage due to short-circuit
conditions (positive or negative battery voltage)
• Protection against high-voltage transients
• Automatic thermal shutdown protection
• Up to 112 nodes can be connected
• High-noise immunity due to differential bus
implementation
• Temperature ranges:
- Industrial (I): -40°C to +85°C
- Extended (E): -40°C to +125°C
Block Diagram
VDD
TXD
Dominant
Detect
VDD
Driver
Control
TXD
RS
Slope
Control
Power-On
Reset
RXD
VREF
Thermal
Shutdown
CANH
0.5 VDD
GND
Reference
Voltage
CANL
Receiver
VSS
1
TABLE 1-1:
MODES OF OPERATION
Mode
Current at Rs Pin
Standby
Slope-Control
High-Speed
TABLE 1-2:
Resulting Voltage at RS Pin
-IRS < 10 µA
10 µA < -IRS < 200 µA
-IRS < 610 µA
VRS > 0.75 VDD
0.4 VDD < VRS < 0.6 VDD
0 < VRS < 0.3VDD
TRANSCEIVER TRUTH TABLE
VDD
VRS
TXD
CANH
CANL
Bus State( 1)
HIGH
LOW
Dominant
Not Driven
Not Driven
Recessive
VRS > 0.75 VDD
Not Driven
Not Driven
Recessive
HIGH
LOW
Dominant
VRS < 0.75 VDD
VPOR < VDD < 4.5V
Not Driven
Not Driven
Recessive
(See Note 3)
VRS > 0.75 VDD
Not Driven
Not Driven
Recessive
Not Driven/
Not Driven/
0 < VDD < VPOR
X
X
High Impedance
No Load
No Load
Note 1: If another bus node is transmitting a Dominant bit on the CAN bus, then RXD is a logic ‘0’.
2: X = “don’t care”.
3: Device drivers will function, although outputs are not ensured to meet the ISO-11898 specification.
VRS < 0.75 VDD
4.5V ≤ VDD ≤ 5.5V
FIGURE 1-1:
1 or floating
X
1 or floating
X
SLEW RATE VS. SLOPE-CONTROL RESISTANCE VALUE
25
Slew Rate V/μs
10
5
40
49
60
70
76
Resistance (k)
2
90 100 110 120
RXD( 1)
1
1
X
1.0
TXD Permanent Dominant
Detection
1.2.1
TXD is a TTL-compatible input pin. The data on this pin
is driven out on the CANH and CANL differential output
pins. It is usually connected to the transmitter data
output of the CAN controller device. When TXD is Low,
CANH and CANL are in the Dominant state. When TXD
is High, CANH and CANL are in the Recessive state,
provided that another CAN node is not driving the CAN
bus with a Dominant state. TXD has an internal pull-up
resistor (nominal 25 kΩ to VDD).
If the 2551 detects an extended Low state on the
TXD input, it will disable the CANH and CANL output
drivers in order to prevent the corruption of data on the
CAN bus. The drivers are disabled if TXD is Low for
more than 1.25 ms (minimum). This implies a
maximum bit time of 62.5 µs (16 kb/s bus rate),
allowing up to 20 consecutive transmitted Dominant
bits during a multiple bit error and error frame scenario.
The drivers remain disabled as long as TXD remains
Low. A rising edge on TXD will reset the timer logic and
enable the CANH and CANL output drivers.
1.1
1.2.2
GROUND SUPPLY (VSS)
Ground supply pin.
1.2.3
Power-on Reset
SUPPLY VOLTAGE (VDD)
Positive supply voltage pin.
When the device is powered on, CANH and CANL
remain in a high-impedance state until VDD reaches the
voltage-level VPORH. In addition, CANH and CANL will
remain in a high-impedance state if TXD is Low when
VDD reaches VPORH. CANH and CANL will become
active only after TXD is asserted High. Once powered
on, CANH and CANL will enter a high-impedance state
if the voltage level at VDD falls below VPORL, providing
voltage brown-out protection during normal operation.
1.2
TRANSMITTER DATA INPUT (TXD)
1.2.4
RECEIVER DATA OUTPUT (RXD)
RXD is a CMOS-compatible output that drives High or
Low depending on the differential signals on the CANH
and CANL pins and is usually connected to the receiver
data input of the CAN controller device. RXD is High
when the CAN bus is Recessive and Low in the
Dominant state.
1.2.5
Pin Descriptions
REFERENCE VOLTAGE (VREF)
Reference Voltage Output (defined as VDD/2).
The 8-pin pinout is listed in Table 1-3.
1.2.6
TABLE 1-3:
MCP2551 PINOUT
CAN LOW (CANL)
The CANL output drives the Low side of the CAN
differential bus. This pin is also tied internally to the
receive input comparator.
Pin
Number
Pin
Name
1
TXD
Transmit Data Input
1.2.7
2
VSS
Ground
3
VDD
Supply Voltage
4
RXD
Receive Data Output
The CANH output drives the high-side of the CAN
5
VREF
Reference Output Voltage
1.2.8
6
CANL
CAN Low-Level Voltage I/O
7
CANH
CAN High-Level Voltage I/O
The RS pin is used to select High-Speed, Slope-Control
or Standby modes via an external biasing resistor.
8
RS
Pin Function
Slope-Control Input
3
CAN HIGH (CANH)
SLOPE RESISTOR INPUT (RS)
2.0
ELECTRICAL
CHARACTERISTICS
2.1
Terms and Definitions
2.1.5
Differential voltage of the two-wire CAN bus, value
VDIFF = VCANH - VCANL.
2.1.6
A number of terms are defined in ISO-11898 that are
used to describe the electrical characteristics of a CAN
transceiver device. These terms and definitions are
summarized in this section.
2.1.1
BUS VOLTAGE
2.1.7
INTERNAL RESISTANCE, RIN
(OF A CAN NODE)
Resistance seen between CANL (or CANH) and
ground during the Recessive state when the CAN node
is disconnected from the bus (see Figure 2-1).
COMMON MODE BUS VOLTAGE
RANGE
Boundary voltage levels of VCANL and VCANH with
respect to ground, for which proper operation will occur,
if up to the maximum number of CAN nodes are
connected to the bus.
2.1.3
INTERNAL CAPACITANCE, CIN
(OF A CAN NODE)
Capacitance seen between CANL (or CANH) and
VCANL and VCANH denote the voltages of the bus line
wires CANL and CANH relative to ground of each
individual CAN node.
2.1.2
DIFFERENTIAL VOLTAGE, VDIFF
(OF CAN BUS)
FIGURE 2-1:
PHYSICAL LAYER
DEFINITIONS
ECU
DIFFERENTIAL INTERNAL
CAPACITANCE, CDIFF
(OF A CAN NODE)
RIN
Capacitance seen between CANL and CANH during
the Recessive state when the CAN node is
RIN
CANL
CANH
CIN
2.1.4
CDIFF
RDIFF
RESISTANCE, RDIFF
(OF A CAN NODE)
CIN
GROUND
Resistance seen between CANL and CANH during the
Recessive state when the CAN node is disconnected
4
Absolute Maximum Ratings†
VDD .............................................................................................................................................................................7.0V
DC Voltage at TXD, RXD, VREF and VS ............................................................................................ -0.3V to VDD + 0.3V
DC Voltage at CANH, CANL (Note 1) .......................................................................................................... -42V to +42V
Transient Voltage on Pins 6 and 7 (Note 2) ............................................................................................. -250V to +250V
Storage temperature ...............................................................................................................................-55°C to +150°C
Operating ambient temperature ..............................................................................................................-40°C to +125°C
Virtual Junction Temperature, TVJ (Note 3).............................................................................................-40°C to +150°C
Soldering temperature of leads (10 seconds) .......................................................................................................+300°C
ESD protection on CANH and CANL pins (Note 4) ...................................................................................................6 kV
ESD protection on all other pins (Note 4) ..................................................................................................................4 kV
Note 1: Short-circuit applied when TXD is High and Low.
2: In accordance with ISO-7637.
3: In accordance with IEC 60747-1.
4: Classification A: Human Body Model.
5
2.2
DC Characteristics
Electrical Characteristics:
Industrial (I): TAMB = -40°C to +85°C VDD = 4.5V to 5.5V
Extended (E): TAMB = -40°C to +125°C VDD = 4.5V to 5.5V
DC Specifications
Param
No.
Sym
Characteristic
Min
Max
Units
Conditions
D1
75
mA
Dominant; VTXD = 0.8V; VDD
D2
10
mA
Recessive; VTXD = +2V;
RS = 47 kW
365
µA
-40°C ≤ TAMB ≤ +85°C, Standby;
(Note 2)
465
µA
-40°C ≤ TAMB ≤ +125°C,
Standby; (Note 2)
Supply
IDD
Supply Current
D3
D4
VPORH
High-level of the Power-on
Reset comparator
3.8
4.3
V
CANH, CANL outputs are active
when VDD > VPORH
D5
VPORL
Low-level of the Power-on
Reset comparator
3.4
4.0
V
CANH, CANL outputs are not
active when VDD < VPORL
D6
VPORD
Hysteresis of Power-on
Reset comparator
0.3
0.8
V
Note 1
2.0
3.0
V
VTXD = VDD; no load.
-2
+2
mA
-2V < V(CAHL,CANH) < +7V,
0V
很抱歉,暂时无法提供与“XL2551”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.59870
- 10+2.06750
- 30+1.83650
- 100+1.55930
- 500+1.37450
- 1000+1.29360
