High speed CAN transceiver
XL1050 SOP8
FEATURES
GENERAL DESCRIPTION
• High speed (up to 1 Mbaud)
The XL1050 is the interface between the Controller Area
Network (CAN) protocol controller and the physical bus.
The device provides differential transmit capability to the
bus and differential receive capability to the CAN
controller.
• Very low ElectroMagnetic Emission (EME)
• Differential receiver with wide common-mode range for
high ElectroMagnetic Immunity (EMI)
• An unpowered node does not disturb the bus lines
• Transmit Data (TXD) dominant time-out function
• Much lower electromagnetic emission due to optimal
matching of the output signals CANH and CANL
• Silent mode in which the transmitter is disabled
• Bus pins protected against transients in an automotive
environment
• Improved behaviour in case of an unpowered node
• No standby mode.
• Input levels compatible with 3.3 V and 5 V devices
This makes the XL1050 eminently suitable for use in
nodes that are in a power-down situation in partially
powered networks.
• Thermally protected
• Short-circuit proof to battery and to ground
• At least 110 nodes can be connected.
QUICK REFERENCE DATA
SYMBOL
PARAMETER
VCC
supply voltage
CONDITIONS
MIN.
MAX.
UNIT
4.75
5.25
V
VCANH
DC voltage at pin CANH
0 < VCC < 5.25 V; no time limit
−27
+40
V
VCANL
DC voltage at pin CANL
−27
+40
V
Vi(dif)(bus)
differential bus input voltage
dominant
1.5
3
V
tPD(TXD-RXD)
propagation delay TXD to RXD
VS = 0 V; see Fig.7
250
ns
Tvj
virtual junction temperature
−40
+150
°C
1
XL1050 SOP8
BLOCK DIAGRAM
VCC
handbook, full pagewidth
S
3
8
30 µA
VCC
GND
TEMPERATURE
PROTECTION
200
µA
TXD
TXD
DOMINANT
TIME-OUT
TIMER
1
DRIVER
7
VCC
RXD
CANH
25
kΩ
4
RECEIVER
0.5VCC
25
kΩ
GND
GND
CANL
6
Vref
5
REFERENCE
VOLTAGE
XL1050
2
GND
Block diagram.
PINNING
SYMBOL
PIN
DESCRIPTION
TXD
1
transmit data input; reads in data
from the CAN controller to the bus
line drivers
GND
2
ground
VCC
3
supply voltage
RXD
4
receive data output; reads out
data from the bus lines to the
CAN controller
Vref
5
reference voltage output
CANL
6
LOW-level CAN bus line
CANH
7
HIGH-level CAN bus line
S
8
select input for high-speed mode
or silent mode
handbook, halfpage
TXD 1
8 S
GND 2
7
CANH
XL1050
VCC
3
6
CANL
RXD
4
5
Vref
Pin configuration.
2
XL1050 SOP8
Control pin S allows two operating modes to be selected:
high-speed mode or silent mode.
FUNCTIONAL DESCRIPTION
The XL1050 is the interface between the CAN protocol
controller and the physical bus. It is primarily intended for
high-speed automotive applications using baud rates from
60 kbaud up to 1 Mbaud. It provides differential transmit
capability to the bus and differential receiver capability to
the CAN protocol controller.
The high-speed mode is the normal operating mode and is
selected by connecting pin S to ground. It is the default
mode if pin S is not connected. However, to ensure EMI
performance in applications using only the high-speed
mode, it is recommended that pin S is connected to
ground.
A current-limiting circuit protects the transmitter output
stage from damage caused by accidental short-circuit to
either positive or negative supply voltage, although power
dissipation increases during this fault condition.
In the silent mode, the transmitter is disabled. All other
IC functions continue to operate. The silent mode is
selected by connecting pin S to VCC and can be used to
prevent network communication from being blocked, due
to a CAN controller which is out of control.
A thermal protection circuit protects the IC from damage
by switching off the transmitter if the junction temperature
exceeds a value of approximately 165 °C. Because the
transmitter dissipates most of the power, the power
dissipation and temperature of the IC is reduced. All other
IC functions continue to operate. The transmitter off-state
resets when pin TXD goes HIGH. The thermal protection
circuit is particularly needed when a bus line short-circuits.
A ‘TXD dominant time-out’ timer circuit prevents the bus
lines being driven to a permanent dominant state (blocking
all network communication) if pin TXD is forced
permanently LOW by a hardware and/or software
application failure. The timer is triggered by a negative
edge on pin TXD. If the duration of the LOW-level on
pin TXD exceeds the internal timer value, the transmitter is
disabled, driving the bus into a recessive state. The timer
is reset by a positive edge on pin TXD.
The pins CANH and CANL are protected from automotive
electrical transients .
Table 1
Function table of the CAN transceiver; X = don’t care
VCC
TXD
S
CANH
CANL
BUS STATE
RXD
4.75 V to 5.25 V
LOW
LOW (or
floating)
HIGH
LOW
dominant
LOW
4.75 V to 5.25 V
X
HIGH
0.5VCC
0.5VCC
recessive
HIGH
4.75 V to 5.25 V
HIGH (or
floating)
X
0.5VCC
0.5VCC
recessive
HIGH
2 V
X
0 V < VCANH < VCC
0 V < VCANL < VCC
recessive
X
3
XL1050 SOP8
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134). All voltages are referenced to GND (pin 2).
Positive currents flow into the IC.
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
UNIT
−0.3
+6
V
0 < VCC < 5.25 V;
no time limit
−27
+40
V
0 < VCC < 5.25 V;
no time limit
−27
+40
V
DC voltage at pin TXD
−0.3
VCC + 0.3 V
VRXD
DC voltage at pin RXD
−0.3
VCC + 0.3 V
Vref
DC voltage at pin Vref
−0.3
VCC + 0.3 V
VS
DC voltage at pin S
−0.3
VCC + 0.3 V
Vtrt(CANH)
transient voltage at pin CANH
note 1
−200
+200
V
Vtrt(CANL)
transient voltage at pin CANL
note 1
−200
+200
V
Vesd
electrostatic discharge voltage at all pins note 2
−4000
+4000
V
−200
+200
V
−55
+150
°C
−40
+150
°C
VCC
supply voltage
VCANH
VCANL
VTXD
note 3
Tstg
storage temperature
Tvj
note 4
Notes
1. Human body model: C = 100 pF and R = 1.5 kΩ.
2. Machine model: C = 200 pF, R = 10 Ω and L = 0.75 µH.
3. In accordance with “IEC 60747-1”. An alternative definition of Tvj is: Tvj = Tamb + P × Rth(vj-a), where Rth(vj-a) is a fixed
value to be used for the calculation of Tvj. The rating for Tvj limits the allowable combinations of power dissipation (P)
and ambient temperature (Tamb).
THERMAL CHARACTERISTICS
According to IEC 60747-1.
SYMBOL
PARAMETER
CONDITIONS
VALUE
UNIT
Rth(vj-a)
thermal resistance from junction to
ambient in SO8 package
in free air
145
K/W
Rth(vj-s)
substrate of bare die
in free air
50
K/W
4
XL1050 SOP8
CHARACTERISTICS
VCC = 4.75 V to 5.25 V; Tvj = −40 °C to +150 °C; RL = 60 Ω unless specified otherwise; all voltages are referenced to
GND (pin 2); positive currents flow into the IC; see notes 1 and 2.
SYMBOL
PARAMETER
CONDITIONS
MIN.
TYP.
MAX.
UNIT
Supply (pin VCC)
ICC
supply current
dominant; VTXD = 0 V
25
50
75
mA
recessive; VTXD = VCC
2.5
5
10
mA
Transmitter data input (pin TXD)
VIH
HIGH-level input voltage
output recessive
2.0
VCC + 0.3 V
VIL
LOW-level input voltage
output dominant
−0.3
+0.8
V
IIH
HIGH-level input current
VTXD = VCC
−5
µA
IIL
LOW-level input current
VTXD = 0 V
−100
−200
−300
µA
Ci
input capacitance
not tested
5
10
pF
silent mode
2.0
VCC + 0.3 V
Mode select input (pin S)
VIH
VIL
high-speed mode
−0.3
+0.8
V
IIH
VS = 2 V
50
µA
IIL
VS = 0.8 V
15
30
45
µA
Receiver data output (pin RXD)
IOH
HIGH-level output current
VRXD = 0.7VCC
−2
−6
−15
mA
IOL
LOW-level output current
VRXD = 0.45 V
2
8.5
mA
−50 µA < IVref < +50 µA
0.45VCC
0.5VCC
0.55VCC
V
Reference voltage output (pin Vref)
Vref
reference output voltage
Bus lines (pins CANH and CANL)
Vo(reces)(CANH)
recessive bus voltage at
pin CANH
VTXD = VCC; no load
2.0
2.5
3.0
V
Vo(reces)(CANL)
pin CANL
VTXD = VCC; no load
2.0
2.5
3.0
V
Io(reces)(CANH)
recessive output current at
pin CANH
−27 V < VCANH < +32 V; −2.0
0 V < VCC < 5.25 V
+2.5
mA
Io(reces)(CANL)
pin CANL
−27 V < VCANL < +32 V;
0 V < VCC < 5.25 V
−2.0
+2.5
mA
Vo(dom)(CANH)
dominant output voltage at
pin CANH
VTXD = 0 V
3.0
3.6
4.25
V
Vo(dom)(CANL)
pin CANL
VTXD = 0 V
0.5
1.4
1.75
V
Vi(dif)(bus)
(VCANH − VCANL)
VTXD = 0 V; dominant;
42.5 Ω < RL < 60 Ω
1.5
2.25
3.0
V
VTXD = VCC; recessive;
no load
−50
mV
5
SYMBOL
PARAMETER
XL1050 SOP8
CONDITIONS
MIN.
TYP.
MAX.
UNIT
Io(sc)(CANH)
short-circuit output current at VCANH = 0 V; VTXD = 0 V −45
pin CANH
−70
−95
mA
Io(sc)(CANL)
short-circuit output current at VCANL = 36 V;
pin CANL
VTXD = 0 V
45
70
100
mA
Vi(dif)(th)
differential receiver threshold −12 V < VCANL < +12 V; 0.5
voltage
−12 V < VCANH < +12 V;
see Fig.5
0.7
0.9
V
Vi(dif)(hys)
differential receiver input
voltage hysteresis
−12 V < VCANL < +12 V; 50
see Fig.5
70
100
mV
Ri(cm)(CANH)
common mode input
resistance at pin CANH
15
25
35
kΩ
Ri(cm)(CANL)
common mode input
resistance at pin CANL
15
25
35
kΩ
Ri(cm)(m)
matching between
pin CANH and pin CANL
common mode input
resistance
−3
Ri(dif)
differential input resistance
25
50
75
kΩ
Ci(CANH)
input capacitance at
pin CANH
VTXD = VCC; not tested
7.5
pF
Ci(CANL)
pin CANL
7.5
pF
Ci(dif)
differential input capacitance VTXD = VCC; not tested
3.75
10
pF
ILI(CANH)
input leakage current at
pin CANH
VCC = 0 V; VCANH = 5 V
100
170
250
µA
ILI(CANL)
pin CANL
VCC = 0 V; VCANL = 5 V
100
170
250
µA
155
165
180
°C
VCANH = VCANL
Thermal shutdown
Tj(sd)
shutdown junction
temperature
Timing characteristics (see Figs.6 and 7)
td(TXD-BUSon)
delay TXD to bus active
VS = 0 V
25
55
110
ns
td(TXD-BUSoff)
delay TXD to bus inactive
VS = 0 V
25
60
95
ns
td(BUSon-RXD)
delay bus active to RXD
VS = 0 V
110
ns
td(BUSoff-RXD)
delay bus inactive to RXD
VS = 0 V
45
95
155
ns
tdom(TXD)
TXD dominant time for
time-out
VTXD = 0 V
250
450
750
µs
Notes
1. All parameters are guaranteed over the virtual junction temperature range by design, but only 100 % tested at 125 °C
ambient temperature for dies on wafer level and in addition to this 100 % tested at 25 °C ambient temperature for
cased products, unless specified otherwise.
2. For bare die, all parameters are only guaranteed if the backside of the bare die is connected to ground.
6
XL1050 SOP8
APPLICATION AND TEST INFORMATION
+5 V
47 nF
100
nF
60 Ω
60 Ω
VCC
3
TXD
TX0
1
7
XL1000
Vref
CAN
CONTROLLER
5
CAN
BUS LINE
XL1050
6
RXD
RX0
CANH
CANL
4
2
8
GND
S
60 Ω
MICROCONTROLLER
47 nF
Application information.
+5 V
100
nF
VCC
TXD
Vref
RXD
3
1
5
7
CANH
1 nF
TRANSIENT
GENERATOR
XL1050
6
4
2
15 pF
60 Ω
CANL
1 nF
8
GND
S
Test circuit for automotive transients.
7
XL1050 SOP8
VRXD
HIGH
LOW
hysteresis
0.5
0.9
Vi(dif)(bus) (V)
Hysteresis of the receiver.
+5 V
handbook,
halfpage
100
nF
VCC
TXD
Vref
RXD
3
1
5
7
RL
60 Ω
XL1050
6
4
2
15 pF
CANH
CL
100 pF
CANL
8
GND
S
Test circuit for timing characteristics.
8
XL1050 SOP8
HIGH
TXD
LOW
CANH
CANL
dominant
(BUS on)
0.9 V
Vi(dif)(bus)(1)
0.5 V
recessive
(BUS off)
HIGH
RXD
0.7VCC
0.3VCC
LOW
t d(TXD-BUSon)
t d(TXD-BUSoff)
t d(BUSon-RXD)
t d(BUSoff-RXD)
t PD(TXD-RXD)
t PD(TXD-RXD)
(1) Vi(dif)(bus) = VCANH − VCANL.
Timing diagram for AC characteristics.
TX
XL1050
CANL
6.2 kΩ
CANH
6.2 kΩ
30
Ω
10 nF
ACTIVE PROBE
30
Ω
SPECTRUMANALYZER
47 nF
GND
test PCB
Basic test set-up (with split termination) for electromagnetic emission measurement
9
XL1050 SOP8
TX
XL1050
CANL
30 Ω
CANH
30 Ω
4.7 nF
RF VOLTMETER
AND POWER
AMPLIFIER
50
Ω
RX
RF SIGNAL
GENERATOR
XL1050
GND
test PCB
Basic test set-up for electromagnetic immunity measurement
30
VRF(rms)
(V)
max RF voltage reached with no errors
10−1
1
10
Data rate of 500 kbits/s.
Typical electromagnetic immunity.
10
102
f (MHz)
103
XL1050 SOP8
11
很抱歉,暂时无法提供与“XL1050”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.17700
- 50+1.74330
- 150+1.55740
- 500+1.27670
- 2500+1.17340
- 5000+1.11130
