XD3525 DIP16
XL3525Z SOP16窄体
XL3525K SOP16宽体
8 TO 35 V OPERATION
5.1 V REFERENCE TRIMMED TO ± 1 %
100 Hz TO 500 KHz OSCILLATOR RANGE
SEPARATE OSCILLATOR SYNC TERMINAL
ADJUSTABLE DEADTIME CONTROL
INTERNAL SOFT-START
PULSE-BY-PULSE SHUTDOWN
INPUT UNDERVOLTAGE LOCKOUT WITH
HYSTERESIS
LATCHING PWM TO PREVENT MULTIPLE
PULSES
DUAL SOURCE/SINK OUTPUT DRIVERS
DESCRIPTION
The XD3525 series of pulse width modulator integrated circuits are designed to offer improved performance and lowered external parts count when
used in designing all types of switching power supplies. The on-chip + 5.1 V reference is trimmed to ±
1 % and the input common-mode range of the error
amplifier includes the reference voltage eliminating
external resistors. A sync input to the oscillator allows multiple units to be slaved or a single unit to be
synchronized to an external system clock. A single
resistor between the CT and the discharge terminals
provide a wide range of dead time ad- justment.
These devices also feature built-in soft-start circuitry
with only an external timing capacitor required. A
shutdown terminal controls both the soft-start circuity and the output stages, providing instantaneous
turn off through the PWM latch with pulsed shutdown, as well as soft-start recycle with longer shutdown commands. These functions are also controlled by an undervoltage lockout which keeps the outputs off and the soft-start capacitor discharged for
sub-normal input voltages. This lockout circuitry includes approximately 500 mV of hysteresis for jitterfree operation. Another feature of these PWM circuits is a latch following the comparator. Once a
PWM pulses has been terminated for any reason,
the outputs will remain off for the duration of the period. The latch is reset with each clock pulse. The
output stages are totem-pole designs capable of
sourcing or sinking in excess of 200 mA. The
XD3525 output stage features NOR logic, giving a
LOW output for an OFF state.
型号
封装
尺寸
XD3525
DIP16
18.70mm*6.23mm
XL3525Z
SOP16窄体
9.97mm*3.93mm
XL3525K
SOP16宽体
10.28mm*7.39mm
XD3525
1
1
XD3525 DIP16/XL3525Z SOP16窄体/XL3525K SOP16宽体
ABSOLUTE MAXIMUM RATINGS
Symbol
Parameter
Value
Unit
Vi
Supply Voltage
40
V
VC
Collector Supply Voltage
40
V
IOSC
5
mA
Io
Output Current, Source or Sink
500
mA
IR
Reference Output Current
50
mA
IT
Current through CT Terminal
Logic Inputs
Analog Inputs
Total Power Dissipation at Tamb = 70 °C
5
– 0.3 to + 5.5
– 0.3 to Vi
1000
mA
V
V
mW
Junction Temperature Range
– 55 to 150
°C
Storage Temperature Range
Operating Ambient Temperature : XD3525
XL3525Z
– 65 to 150
– 25 to 85
0 to 70
°C
°C
°C
Ptot
Tj
Tstg
Top
Oscillator Charging Current
THERMAL DATA
Symbol
Rth j-pins
Rth j-amb
Rth j-alumina
Parameter
SO16
Thermal Resistance Junction-pins
Thermal Resistance Junction-ambient
Thermal Resistance Junction-alumina (*)
Max
Max
Max
50
DIP16
Unit
50
80
°C/W
°C/W
°C/W
* Thermal resistance junction-alumina with the device soldered on the middle of an alumina supporting substrate measuring 15 × 20 mm ; 0.65 mm
thickness with infinite heatsink.
BLOCK DIAGRAM
XD3525
XD3525 OUTPUT STAGE
2
2
ELECTRICAL CHARACTERISTICS
(V# i = 20 V, and over operating temperature, unless otherwise specified)
Symbol
Parameter
XD3525
Test Conditions
XL3525Z/K
Unit
Min.
Typ.
Max.
Min.
Typ.
Max.
5.05
5.1
5.15
5
5.1
5.2
REFERENCE SECTION
Tj = 25 °C
VREF
Output Voltage
∆VREF
Line Regulation
Vi = 8 to 35 V
10
mV
∆VREF
Load Regulation
IL = 0 to 20 mA
mV
Over Operating Range
mV
5.25
V
∆VREF/∆T* Temp. Stability
∆VREF*
5
5.2
4.95
V
Total Output Variation
Line, Load and
Temperature
Short Circuit Current
VREF = 0 Tj = 25 °C
80
100
80
100
mA
Output Noise Voltage
10 Hz ≤f ≤ 10 kHz,
Tj = 25 °C
40
200
40
200
µVrms
Long Term Stability
Tj = 125 °C, 1000 hrs
mV
OSCILLATOR SECTION * *
Initial Accuracy
Tj = 25 °C
Voltage Stability
Vi = 8 to 35 V
∆f/∆T*
Temperature Stability
fMIN
Minimum Frequency
RT = 200 KΩ CT = 0.1 µF
fMAX
Maximum Frequency
RT = 2 KΩ CT = 470 pF
400
Current Mirror
IRT = 2 mA
1.7
2
3
3.5
0.3
0.5
1.2
2
1
2.5
Clock Amplitude
Clock Width
Tj = 25 °C
Sync Threshold
Sync Input Current
±2
±6
±2
±6
± 0.3
±1
±1
±2
±6
±3
±3
120
Sync Voltage = 3.5 V
±6
120
Hz
400
2.2
KHz
1.7
2
2.2
mA
3
3.5
1
0.3
0.5
1
µs
2.8
1.2
2
2.8
V
1
2.5
mA
V
ERROR AMPLIFIER SECTION (VCM = 5.1 V)
VOS
Input Offset Voltage
Ib
Input Bias Current
Ios
Input Offset Current
0.5
5
2
10
mV
1
10
1
10
µA
1
µA
1
DC Open Loop Gain
RL ≥ 10 MΩ
Gain Bandwidth
Product
Gv = 0 dB
DC Transconduct.
30 KΩ ≤ RL ≤ 1 MΩ
Tj = 25 °C
T j = 25 °C
60
75
60
75
dB
1
2
1
2
MHz
1.1
1.5
1.1
1.5
ms
Output Low Level
0.2
Output High Level
0.5
0.2
0.5
V
3.8
5.6
3.8
5.6
V
CMR
Comm. Mode Reject.
VCM = 1.5 to 5.2 V
60
75
60
75
dB
PSR
Supply Voltage
Rejection
Vi = 8 to 35 V
50
60
50
60
dB
3
3
ELECTRICAL CHARACTERISTICS (continued)
Symbol
Parameter
XD3525
Test Conditions
Min.
Typ.
XL3525Z/K
Max.
Min.
Typ.
Unit
Max.
PWM COMPARATOR
Minimum Duty-cycle
Maximum Duty-cycle
Input Threshold
Input Bias Current
Zero Duty-cycle
49
45
49
0.7
0.9
0.7
0.9
V
Maximum Duty-cycle
3.3
3.6
3.3
3.6
V
0.05
1
0.05
1
µA
50
80
50
80
µA
0.4
0.7
0.4
0.7
V
0.8
1
0.8
1
V
SHUTDOWN SECTION
Soft Start Current
VSD = 0 V, VSS = 0 V
Soft Start Low Level
VSD = 2.5 V
Shutdown Threshold
To outputs, VSS = 5.1 V
Tj = 25 °C
25
0.6
Shutdown Input Current VSD = 2.5 V
Shutdown Delay
VSD = 2.5 V Tj = 25 °C
25
0.6
0.4
1
0.4
1
mA
0.2
0.5
0.2
0.5
µs
0.2
0.4
0.2
0.4
V
1
2
1
2
OUTPUT DRIVERS (each output) (VC = 20 V)
Output Low Level
Isink = 20 mA
Output High Level
Isource = 20 mA
18
19
Isource = 100 mA
17
18
Under-Voltage Lockout
Vcomp and Vss = High
6
7
Isink = 100 mA
8
18
19
17
18
6
7
V
V
V
8
V
IC
Collector Leakage
VC = 35 V
200
µA
tr*
Rise Time
CL = 1 nF, Tj = 25 °C
100
600
100
600
ns
tf*
Fall Time
50
300
50
300
ns
14
mA
200
TOTAL STANDBY CURRENT
Is
Supply Current
Vi = 35 V
* These parameters, although guaranteed over the recommended operating conditions, are not 100 % tested in production.
Tested at fosc = 40 KHz (RT = 3.6 KΩ, CT = 10nF, RD = 0 Ω). Approximate oscillator frequency is defined by :
f=
1
CT (0.7 RT + 3 RD)
DC transconductance (gM) relates to DC open-loop voltage gain (Gv) according to the following equation : Gv = gM RL where RL is the resistance
from pin 9 to ground. The minimum gM specification is used to calculate minimum Gv when the error amplifier output is loaded.
4
4
TEST CIRCUIT
5
5
RECOMMENDED OPERATING CONDITIONS (•)
Parameter
Value
Input Voltage (Vi)
8 to 35 V
Collector Supply Voltage (VC)
4.5 to 35 V
Sink/Source Load Current (steady state)
0 to 100 mA
Sink/Source Load Current (peak)
Reference Load Current
0 to 400 mA
0 to 20 mA
Oscillator Frequency Range
100 Hz to 400 KHz
Oscillator Timing Resistor
2 KΩ to 150 KΩ
Oscillator Timing Capacitor
0.001 µF to 0.1 µF
Dead Time Resistor Range
0 to 500 Ω
( ) Range over which the device is functional and parameter limits are guaranteed.
Figure 1 : Oscillator Charge Time vs. R T
and C T .
Figure 2 : Oscillator Discharge Time vs. R D
and C T .
Figure 3 : Output Saturation
Characteristics.
Figure 4 : Error Amplifier Voltage Gain and
Phase vs. Frequency.
6
6
Figure 5 : Error Amplifier.
PRINCIPLES OF OPERATION
ately set providing the fastest turn-off signal to the
outputs ; and a 150 µA current sink begins to discharge the external soft-start capacitor. If the shutdown command is short, the PWM signal is terminated without significant discharge of the soft-start
capacitor, thus, allowing, for example, a convenient
implementation of pulse-by-pulse current limiting.
Holding Pin 10 high for a longer duration, however,
will ultimately discharge this external capacitor, recycling slow turn-on upon release.
SHUTDOWN OPTIONS (see Block Diagram)
Since both the compensation and soft-start terminals (Pins 9 and 8) have current source pull-ups,
either can readily accept a pull-down signal which
only has to sink a maximum of 100 µA to turn off the
outputs. This is subject to the added requirement of
discharging whatever external capacitance may be
attached to these pins.
An alternate approach is the use of the shutdown circuitry of Pin 10 which has been improved to enhance the available shutdown options. Activating
this circuit by applying a positive signal on Pin 10
performs two functions : the PWM latch is immedi-
Pin 10 should not be left floating as noise pickup
could conceivably interrupt normal operation.
7
7
Figure 6 : Oscillator Schematic.
Figure 7 : Output Circuit (1/2 circuit shown).
XD3525
8
8
Figure 8.
Figure 9.
For single-ended supplies, the driver outputs are
grounded. The VC terminal is switched to ground by
the totem-pole source transistors on alternate oscillator cycles.
In conventional push-pull bipolar designs, forward
base drive is controlled by R1 - R3. Rapid turn-off
times for the power devices are achieved with
speed-up capacitors C1 and C2.
Figure 10.
Figure 11.
The low source impedance of the output drivers provides rapid charging of Power Mos input capacitance while minimizing external components.
Low power transformers can be driven directly.
Automatic reset occurs during dead time, when both
ends of the primary winding are switched to ground.
9
DIP
SOP16宽体
910
SOP16窄体
911
很抱歉,暂时无法提供与“XL3525Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.51190
- 50+1.21328
- 150+1.08530
- 500+0.92567
