XD54563 DIP-18
DESCRIPTION
XD54563 is an eight-circuit output-sourcing Darlington
transistor array. The circuits are made of PNP and NPN transistors. This semiconductor integrated circuit performs highcurrent driving with extremely low input-current supply.
PIN CONFIGURATION
INPUT
FEATURES
Á High breakdown voltage (BV CEO ≥ 50V)
Á High-current driving (Io(max) = –500mA)
Á With clamping diodes
Á Driving available with PMOS IC output of 6 ~ 16V or with TTL output
Á Wide operating temperature range (Ta = –20 to +75°C)
Á Output current-sourcing type
IN1→ 1
18 →O1
IN2→ 2
17 →O2
IN3→ 3
16 →O3
IN4→ 4
15 →O4
IN5→ 5
14 →O5
IN6→ 6
13 →O6
IN7→ 7
12 →O7
IN8→ 8
11 →O8
VS
9
OUTPUT
10 GND
CIRCUIT DIAGRAM
VS
APPLICATION
Drives of relays, printers, LEDs, fluorescent display tubes
and lamps, and interfaces between MOS-bipolar logic systems and relays, solenoids, or small motors
20K
3K
INPUT
7.2K
1.5K
3K
OUTPUT
FUNCTION
The XD54563 each have eight circuits,
which are made of input inverters and current-sourcing outputs. The outputs are made of PNP transistors and NPN
Darlington transistors. The PNP transistor base current is
constant. A clamping diode is provided between each output
and GND. V S and GND are used commonly among the eight
circuits.
The inputs have resistance of 3kΩ, and voltage of up to 10V
is applicable. Output current is 500 mA maximum. Supply
voltage V S is 50V maximum.
The XD54563 is enclosed in a molded small flat package,
enabling space-saving design.
1
GND
The eight circuits share the VS and GND.
The diode, indicated with the dotted line, is parasitic, and cannot
be used.
Unit : Ω
XD54563
ABSOLUTE MAXIMUM RATINGS
Symbol
VCEO
VS
VI
VR
Pd
(Unless otherwise noted, Ta = –20 ~ +75 °C)
Parameter
Conditions
Collector-emitter voltage
Supply voltage
Output, L
Input voltage
IO
IF
Output current
Clamping diode forward current
Topr
Ratings
Unit
–0.5 ~ +50
V
50
V
V
–0.5 ~ +10
–500
Current per circuit output, H
mA
mA
–500
50
Clamping diode reverse voltage
Power dissipation
Ta = 25°C, when mounted on board
Operating temperature
Storage temperature
Tstg
DIP-18
V
W
1.79(P)/1.10(FP)
–20 ~ +75
°C
–55 ~ +125
°C
# : Unused I/O pins must be connected to GND.
RECOMMENDED OPERATING CONDITIONS
Symbol
VS
Parameter
Supply voltage
Output current
(Current per 1 circuit when 8 circuits
are coming on simultaneously)
IO
(Unless otherwise noted, Ta = –20 ~ +75°C)
min
Duty Cycle
P : no more than 8%
FP : no more than 5%
Duty Cycle
P : no more than 55%
FP : no more than 30%
Limits
typ
max
–350
–100
10
V
0.2
V
“H” input voltage
2.4
VIL
“L” input voltage
ELECTRICAL CHARACTERISTICS
Parameter
Test conditions
typ+
max
100
1.6
2.4
VI = 3V
1.45
0.6
2.0
1.0
2.9
5.6
5.0
15.0
–1.2
–2.4
100
Supply leak current
VCE (sat)
VS = 10V, VI = 2.4V, IO = –350mA
Collector-emitter saturation voltage
VS = 10V, VI = 2.4V, IO = –100mA
II
Input current
IS
VF
Supply current
VI = 10V
VS = 50V, VI = 3V (all input)
Clamping diode forward voltage
Clamping diode reverse current
IF = –350mA
VR = 50V
Limits
min
IS (leak) #
IR
V
mA
VIH
Symbol
Unit
VS = 50V, VI = 0.2V
Unit
µA
V
mA
mA
V
µA
+ : The typical values are those measured under ambient temperature (Ta) of 25°C. There is no guarantee that these values are obtained under any
conditions.
SWITCHING CHARACTERISTICS (Unless otherwise noted, Ta = 25°C)
Symbol
ton
toff
Parameter
Turn-on time
Turn-off time
Test conditions
CL = 15pF (note 1)
2
Limits
typ
max
100
4800
min
Unit
ns
ns
XD54563
NOTE 1 TEST CIRCUIT
DIP-18
TIMING DIAGRAM
INPUT
VS
50%
Measured device
50%
INPUT
OUTPUT
PG
50Ω
RL
CL
50%
50%
OUTPUT
ton
toff
(1) Pulse generator (PG) characteristics : PRR = 1kHz,
tw = 10µs, tr = 6ns, tf = 6ns, ZO = 50Ω
VI = 0 to 2.4V
(2) Input-output conditions : RL = 30Ω, VS = 10V
(3) Electrostatic capacity CL includes floating capacitance at
connections and input capacitance at probes
TYPICAL CHARACTERISTICS
Output Saturation Voltage
Output Current Characteristics
Thermal Derating Factor Characteristics
–500
XD54563
Output current IO (mA)
Power dissipation Pd (W)
2.0
1.5
XXXX
1.0
0.5
50
75
–300
–200
–100
VS = 10V
VI = 2.4V
Ta = 75°C
Ta = 25°C
Ta = –20°C
–400
1.0
1.5
2.0
2.5
Output saturation voltage VCE (sat) (V)
Ambient temperature Ta (°C)
Duty-Cycle-Output Current Characteristics
(XD54563)
–500
➀
(XD54563)
–500
–400
–400
➀
➁
–300
➂
–200
–100
•The output current values
represent the current per circuit.
•Repeated frequency ≥ 10Hz
•The value in the circle represents the
value of the simultaneously-operated circuit.
•Ta = 25°C
60
80
➃
➄
➅
➆
➇
–300
➁
–200
➂
–100
Duty cycle (%)
•Ta = 75°C
60
Duty cycle (%)
3
➃
➄
➅
➆
➇
80
100
XD54563
4
DIP-18
很抱歉,暂时无法提供与“XD54563”相匹配的价格&库存,您可以联系我们找货
