XL1881
XL1881
    XINLUDA(信路达)
    SOP8
    音频接收器 SOP-8
XL1881 数据手册
XD1881 DIP-8 XL1881 SOP-8 FEATURES DESCRIPTION • • • • • • • • • The 1881 Video sync separator extracts timing information including composite and vertical sync, burst/back porch timing, and odd/even field information from standard negative going sync NTSC, PAL (1) and SECAM video signals with amplitude from 0.5V to 2V p-p. The integrated circuit is also capable of providing sync separation for non-standard, faster horizontal rate video signals. The vertical output is produced on the rising edge of the first serration in the vertical sync period. A default vertical output is produced after a time delay if the rising edge mentioned above does not occur within the externally set delay period, such as might be the case for a non-standard video signal. 1 2 AC Coupled Composite Input Signal >10 kΩ Input Resistance
XL1881 价格&库存
很抱歉,暂时无法提供与“XL1881”相匹配的价格&库存,您可以联系我们找货
