XD8870
XD8870
    XINLUDA(信路达)
    DIP18
    音频接收器 DIP-18
XD8870 数据手册
XD8870 DIP-18 XL8870 SOP-18 Features Description • Complete DTMF Receiver • Low power consumption • Internal gain setting amplifier • Adjustable guard time • Central office quality The XDXL/8870 is a complete DTMF receiver integrating both the bandsplit filter and digital decoder functions. The filter section uses switched capacitor techniques for high and low group filters; the decoder uses digital counting techniques to detect and decode all 16 DTMF tone-pairs into a 4-bit code. • Power-down mode • Inhibit mode Applications • Paging systems • Repeater systems/mobile radio • Credit card systems • Remote control • Personal computers • Telephone answering machine VDD PWDN VSS VRef Bias Circuit VRef Buffer Q1 Chip Chip Power Bias IN + High Group Filter Dial Tone Filter IN - INH Digital Detection Algorithm Code Converter and Latch Q2 Zero Crossing Detectors Q3 Low Group Filter GS Q4 to all Chip Clocks OSC1 St GT OSC2 St/GT Steering Logic ESt Figure 1 - Functional Block Diagram 1 STD TOE XD8870 DIP-18 XL8870 SOP-18 External component count is minimized by on chip provision of a differential input amplifier, clock oscillator and latched three-state bus interface. IN+ INGS VRef INH PWDN OSC1 OSC2 VSS 18 17 16 15 14 13 12 11 10 1 2 3 4 5 6 7 8 9 VDD St/GT ESt StD Q4 Q3 Q2 Q1 TOE DIP/SOP Figure 2 - Pin Connections Pin Description Pin # Name Description 18 20 1 1 IN+ Non-Inverting Op-Amp (Input). 2 2 IN- Inverting Op-Amp (Input). 3 3 GS Gain Select. Gives access to output of front end differential amplifier for connection of feedback resistor. 4 4 VRef Reference Voltage (Output). Nominally VDD/2 is used to bias inputs at mid-rail (see Fig. 6 and Fig. 10). 5 5 INH Inhibit (Input). Logic high inhibits the detection of tones representing characters A, B, C and D. This pin input is internally pulled down. 6 6 PWDN Power Down (Input). Active high. Powers down the device and inhibits the oscillator. This pin input is internally pulled down. 7 8 OSC1 Clock (Input). 8 9 OSC2 Clock (Output). A 3.579545 MHz crystal connected between pins OSC1 and OSC2 completes the internal oscillator circuit. 9 10 VSS Ground (Input). 0 V typical. 10 11 TOE Three State Output Enable (Input). Logic high enables the outputs Q1-Q4. This pin is pulled up internally. 1114 1215 Q1-Q4 Three State Data (Output). When enabled by TOE, provide the code corresponding to the last valid tone-pair received (see Table 1). When TOE is logic low, the data outputs are high impedance. 15 17 StD Delayed Steering (Output).Presents a logic high when a received tone-pair has been registered and the output latch updated; returns to logic low when the voltage on St/GT falls below VTSt. 16 18 ESt Early Steering (Output). Presents a logic high once the digital algorithm has detected a valid tone pair (signal condition). Any momentary loss of signal condition will cause ESt to return to a logic low. 2 XD8870 DIP-18 XL8870 SOP-18 Pin Description Pin # Name Description 19 St/GT Steering Input/Guard time (Output) Bidirectional. A voltage greater than VTSt detected at St causes the device to register the detected tone pair and update the output latch. A voltage less than VTSt frees the device to accept a new tone pair. The GT output acts to reset the external steering time-constant; its state is a function of ESt and the voltage on St. 20 VDD Positive power supply (Input). +5 V typical. 7, 16 NC No Connection. 18 20 17 18 Functional Description The XDXL/8870 monolithic DTMF receiver of fers small size, low power consumption and high performance. Its architecture consists of a bandsplit filter section, which separates the high and low group tones, followed by a digital counting section which verifies the frequency and duration of the received tones before passing the corresponding code to the output bus. Filter Section Separation of the low-group and high group tones is achieved by applying the DTMF signal to the inputs of two sixth-order switched capacitor bandpass filters, the bandwidths of which correspond to the low and high group frequencies. The filter section also incorporates notches at 350 and 440 Hz for exceptional dial tone rejection (see Figure 3). Each filter output is followed by a single order switched capacitor filter section which smooths the signals prior to limiting. Limiting is performed by high-gain comparators which are provided with hysteresis to prevent detection of unwanted low-level signals. The outputs of the comparators provide full rail logic swings at the frequencies of the incoming DTMF signals. 0 PRECISE DIAL TONES 10 X=350 Hz Y=440 Hz DTMF TONES 20 A=697 Hz B=770 Hz C=852 Hz D=941 Hz E=1209 Hz F=1336 Hz G=1477 Hz H=1633 Hz ATTENUATION (dB) 30 40 50 X Y 1kHz A B C D E FREQUENCY (Hz) F Figure 3 - Filter Response 3 G H XD8870 DIP-18 XL8870 SOP-18 Decoder Section Following the filter section is a decoder employing digital counting techniques to determine the frequencies of the incoming tones and to verify that they correspond to standard DTMF frequencies. A complex averaging algorithm protects against tone simulation by extraneous signals such as voice while providing tolerance to small frequency deviations and variations. This averaging algorithm has been developed to ensure an optimum combination of immunity to talk-off and tolerance to the presence of interfering frequencies (third tones) and noise. When the detector recognizes the presence of two valid tones (this is referred to as the “signal condition” in some industry specifications) the “Early Steering” (ESt) output will go to an active state. Any subsequent loss of signal condition will cause ESt to assume an inactive state (see “Steering Circuit”). VDD C VDD St/GT vc ESt R StD XDXL/8870 tGTA=(RC)In(VDD/VTSt) tGTP=(RC)In[VDD/(VDD-VTSt)] Figure 4 - Basic Steering Circuit Steering Circuit Before registration of a decoded tone pair, the receiver checks for a valid signal duration (referred to as character recognition condition). This check is performed by an external RC time constant driven by ESt. A logic high on ESt causes vc (see Figure 4) to rise as the capacitor discharges. Provided signal condition is maintained (ESt remains high) for the validation period (tGTP), vc reaches the threshold (VTSt) of the steering logic to register the tone pair, latching its corresponding 4-bit code (see Table 1) into the output latch. At this point the GT output is activated and drives vc to VDD. GT continues to drive high as long as ESt remains high. Finally, after a short delay to allow the output latch to settle, the delayed steering output flag (StD) goes high, signalling that a received tone pair has been registered. The contents of the output latch are made available on the 4-bit output bus by raising the three state control input (TOE) to a logic high. The steering circuit works in reverse to validate the interdigit pause between signals. Thus, as well as rejecting signals too short to be considered valid, the receiver will tolerate signal interruptions (dropout) too short to be considered a valid pause. This facility, together with the capability of selecting the steering time constants externally, allows the designer to tailor performance to meet a wide variety of system requirements. Guard Time Adjustment In many situations not requiring selection of tone duration and interdigital pause, the simple steering circuit shown in Figure 4 is applicable. Component values are chosen according to the formula: tREC=tDP+tGTP tID=tDA+tGTA 4 XD8870 DIP-18 XL8870 SOP-18 The value of tDP is a device parameter (see Figure 11) and tREC is the minimum signal duration to be recognized by the receiver. A value for C of 0.1 µF is recommended for most applications, leaving R to be selected by the designer. tGTP=(RPC1)In[VDD/(VDD-VTSt)] VDD tGTA=(R1C1)In(VDD/VTSt) C1 RP=(R1R2)/(R1+R2) St/GT R1 R2 ESt a) decreasing tGTP; (tGTPtGTA) Figure 5 - Guard Time Adjustment Digit TOE INH ESt Q4 Q3 Q2 Q1 ANY L X H Z Z Z Z 1 H X H 0 0 0 1 2 H X H 0 0 1 0 3 H X H 0 0 1 1 4 H X H 0 1 0 0 5 H X H 0 1 0 1 6 H X H 0 1 1 0 7 H X H 0 1 1 1 8 H X H 1 0 0 0 9 H X H 1 0 0 1 0 H X H 1 0 1 0 * H X H 1 0 1 1 # H X H 1 1 0 0 A H L H 1 1 0 1 B H L H 1 1 1 0 C H L H 1 1 1 1 D H L H 0 0 0 0 A H H L B H H L C H H L D H H L undetected, the output code will remain the same as the previous detected code Table 1 - Functional Decode Table L=LOGIC LOW, H=LOGIC HIGH, Z=HIGH IMPEDANCE X = DON‘T CARE 5 XD8870 DIP-18 XL8870 SOP-18 Different steering arrangements may be used to select independently the guard times for tone present (tGTP) and tone absent (tGTA). This may be necessary to meet system specifications which place both accept and reject limits on both tone duration and interdigital pause. Guard time adjustment also allows the designer to tailor system parameters such as talk off and noise immunity. Increasing tREC improves talk-off performance since it reduces the probability that tones simulated by speech will maintain signal condition long enough to be registered. Alternatively, a relatively short tREC with a long tDO would be appropriate for extremely noisy environments where fast acquisition time and immunity to tone drop-outs are required. Design information for guard time adjustment is shown in Figure 5. Power-down and Inhibit Mode A logic high applied to pin 6 (PWDN) will power down the device to minimize the power consumption in a standby mode. It stops the oscillator and the functions of the filters. Inhibit mode is enabled by a logic high input to the pin 5 (INH). It inhibits the detection of tones representing characters A, B, C, and D. The output code will remain the same as the previous detected code (see Table 1). Differential Input Configuration The input arrangement of the XDXL/8870 provides a differential-input operational amplifier as well as a bias source (VRef) which is used to bias the inputs at mid-rail. Provision is made for connection of a feedback resistor to the op-amp output (GS) for adjustment of gain. In a single-ended configuration, the input pins are connected as shown in Figure 10 with the op-amp connected for unity gain and VRef biasing the input at 1/2VDD. Figure 6 shows the differential configuration, which permits the adjustment of gain with the feedback resistor R5. Crystal Oscillator The internal clock circuit is completed with the addition of an external 3.579545 MHz crystal and is normally connected as shown in Figure 10 (Single-Ended Input Configuration). However, it is possible to configure several XDXL/8870 devices employing only a single oscillator crystal. The oscillator output of the first device in the chain is coupled through a 30 pF capacitor to the oscillator input (OSC1) of the next device. Subsequent devices are connected in a similar fashion. Refer to Figure 7 for details. The problems associated with unbalanced loading are not a concern with the arrangement shown, i.e., precision balancing capacitors are not required. 6 XD8870 DIP-18 XL8870 SOP-18 XDXL/8870 C1 R1 IN+ + IN- C2 R4 R5 R3 GS R2 VRef Differential Input Amplifier C1=C2=10 nF R1=R4=R5=100 kΩ All resistors are ±1% tolerance. R2=60kΩ, R3=37.5 kΩ All capacitors are ±5% tolerance. R3= R 2R 5 R2+R5 VOLTAGE GAIN (Av diff)= R5 R1 INPUT IMPEDANCE (ZINDIFF) = 2 R 1 2+ 1 ωc 2 Figure 6 - Differential Input Configuration To OSC1 of next XDXL/8870 C X-tal OSC1 OSC2 OSC2 OSC1 C C=30 pF X-tal=3.579545 MHz Figure 7 - Oscillator Connection 7 XD8870 DIP-18 XL8870 SOP-18 Parameter Unit Resonator R1 Ohms 10.752 L1 mH .432 C1 pF 4.984 C0 pF 37.915 Qm - 896.37 ∆f % ±0.2% Table 2 - Recommended Resonator Specifications Note: Qm=quality factor of RLC model, i.e., 1/2ΠƒR1C1. Applications Receiver System for British Telecom Spec POR 1151 The circuit shown in Fig. 9 illustrates the use of XDXL/8870 device in a typical receiver system. BT Spec defines the input signals less than -34 dBm as the non-operate level. This condition can be attained by choosing a suitable values of R1 and R2 to provide 3 dB attenuation, such that -34 dBm input signal will correspond to -37 dBm at the gain setting pin GS of XDXL/8870. As shown in the diagram, the component values of R3 and C2 are the guard time requirements when the total component tolerance is 6%. For better performance, it is recommended to use the non-symmetric guard time circuit in Fig. 8. tGTP=(RPC1)In[VDD/(VDD-VTSt)] tGTA=(R1C1)In(VDD/VTSt) RP=(R1R2)/(R1+R2) VDD C1 St/GT R1 R2 ESt Notes: R1=368 K Ω ± 1% R2=2.2 M Ω ± 1% C1=100 nF ± 5% Figure 8 - Non-Symmetric Guard Time Circuit 8 XD8870 DIP-18 XL8870 SOP-18 VDD C1 DTMF Input R1 R2 X1 C2 XDXL/8870 IN+ VDD IN- St/GT GS VRef ESt StD INH Q4 PWDN Q3 OSC 1 Q2 OSC 2 VSS Q1 TOE R3 NOTES: R1 = 102 KΩ ± 1% R2 = 71.5 KΩ ± 1% R3 = 390 KΩ ±1% C1,C2 = 100 nF ± 5% X1 = 3.579545 MHz ± 0.1% VDD = 5.0 V ± 5% Figure 9 - Single-Ended Input Configuration for BT or CEPT Spec 9 XD8870 DIP-18 XL8870 SOP-18 Absolute Maximum Ratings† Parameter Symbol 1 DC Power Supply Voltage 2 Voltage on any pin VI 3 Current at any pin (other than supply) II 4 Storage temperature 5 Package power dissipation Min. Max. Units 7 V VDD+0.3 V 10 mA +150 °C 500 mW VDD VSS-0.3 TSTG -65 PD † Exceeding these values may cause permanent damage. Functional operation under these conditions is not implied. Derate above 75°C at 16 mW / °C. All leads soldered to board. Recommended Operating Conditions - Voltages are with respect to ground (VSS) unless otherwise stated. Parameter Sym. Min. Typ.‡ Max. Units 5.0 5.25 V +85 °C 1 DC Power Supply Voltage VDD 4.75 2 Operating Temperature TO -40 3 Crystal/Clock Frequency fc 3.579545 MHz 4 Crystal/Clock Freq.Tolerance ∆fc ±0.1 % Test Conditions ‡ Typical figures are at 25°C and are for design aid only: not guaranteed and not subject to production testing. DC Electrical Characteristics - VDD=5.0V± 5%, VSS=0V, -40°C ≤ TO ≤ +85°C, unless otherwise stated. Typ.‡ Max. Units IDDQ 10 25 µA Operating supply current IDD 3.0 9.0 mA Power consumption PO 15 4 High level input VIH 5 Low level input voltage VIL Characteristics 1 2 3 S U P P L Y 6 Standby supply current Min. mW 3.5 1.5 Test Conditions PWDN=VDD fc=3.579545 MHz V VDD=5.0 V V VDD=5.0 V µA VIN=VSS or VDD IIH/IIL 0.1 Pull up (source) current ISO 7.5 20 µA TOE (pin 10)=0, VDD=5.0 V Pull down (sink) current ISI 15 45 µA INH=5.0 V, PWDN=5.0 V, VDD=5.0 V 9 Input impedance (IN+, IN-) RIN 10 MΩ @ 1 kHz 10 Steering threshold voltage VTSt 7 8 Input leakage current Sym. I N P U T S 2.2 10 2.4 2.5 V VDD = 5.0 V XD8870 DIP-18 XL8870 SOP-18 DC Electrical Characteristics - VDD=5.0V± 5%, VSS=0V, -40°C ≤ TO ≤ +85°C, unless otherwise stated. Characteristics 11 12 13 14 15 O U T P U T S Sym. Typ.‡ Min. Max. Units Test Conditions VSS+0.0 3 V No load V No load Low level output voltage VOL High level output voltage VOH VDD0.03 Output low (sink) current IOL 1.0 2.5 mA VOUT=0.4 V Output high (source) current IOH 0.4 0.8 mA VOUT=4.6 V VRef output voltage VRef 2.3 2.5 2.7 V No load, VDD = 5.0V 16 VRef output resistance ROR 1 kΩ ‡ Typical figures are at 25°C and are for design aid only: not guaranteed and not subject to production testing. Operating Characteristics - VDD=5.0V±5%, VSS=0V, -40°C ≤ TO ≤ +85°C,unless otherwise stated. Gain Setting Amplifier Characteristics Sym. Min. Typ.‡ Max. Units 100 nA Test Conditions VSS ≤ VIN ≤ VDD 1 Input leakage current IIN 2 Input resistance RIN 3 Input offset voltage VOS 4 Power supply rejection PSRR 50 dB 1 kHz 5 Common mode rejection CMRR 40 dB 0.75 V ≤ VIN ≤ 4.25 V biased at VRef =2.5 V 6 DC open loop voltage gain AVOL 32 dB 7 Unity gain bandwidth fC 0.30 MHz 8 Output voltage swing VO 4.0 Vpp 9 Maximum capacitive load (GS) CL 100 pF 10 Resistive load (GS) RL 50 kΩ 11 Common mode range VCM 10 MΩ 25 2.5 mV Vpp 11 Load ≥ 100 kΩ to VSS @ GS No Load XD8870 DIP-18 XL8870 SOP-18 MT8870D AC Electrical Characteristics -VDD=5.0V ±5%, VSS=0V, -40°C ≤ TO ≤ +85°C, using Test Circuit shown in Figure 10. Characteristics Sym. Min. Typ.‡ Max. Units Notes* -29 +1 dBm 1,2,3,5,6,9 27.5 869 mVRMS 1,2,3,5,6,9 1 Valid input signal levels (each tone of composite signal) 2 Negative twist accept 8 dB 2,3,6,9,12 3 Positive twist accept 8 dB 2,3,6,9,12 4 Frequency deviation accept ±1.5% ± 2 Hz 2,3,5,9 5 Frequency deviation reject ±3.5% 2,3,5,9 6 Third tone tolerance -16 dB 2,3,4,5,9,10 7 Noise tolerance -12 dB 2,3,4,5,7,9,10 8 Dial tone tolerance +22 dB 2,3,4,5,8,9,11 ‡ Typical figures are at 25°C and are for design aid only: not guaranteed and not subject to production testing. *NOTES 1. dBm= decibels above or below a reference power of 1 mW into a 600 ohm load. 2. Digit sequence consists of all DTMF tones. 3. Tone duration= 40 ms, tone pause= 40 ms. 4. Signal condition consists of nominal DTMF frequencies. 5. Both tones in composite signal have an equal amplitude. 6. Tone pair is deviated by ±1.5% ± 2 Hz. 7. Bandwidth limited (3 kHz) Gaussian noise. 8. The precise dial tone frequencies are (350 Hz and 440 Hz) ± 2%. 9. For an error rate of better than 1 in 10,000. 10. Referenced to lowest level frequency component in DTMF signal. 11. Referenced to the minimum valid accept level. 12. Guaranteed by design and characterization. 12 XD8870 DIP-18 XL8870 SOP-18 XDXL/8870 AC Electrical Characteristics -VDD=5.0V±5%, VSS=0V, -40°C ≤ TO ≤ +85°C, using Test Circuit shown in Figure 10. Characteristics Sym. Min. Max. Units -31 +1 dBm 21.8 869 mVRMS Notes* Tested at VDD=5.0 V 1,2,3,5,6,9 1 Valid input signal levels (each tone of composite signal) 2 Input Signal Level Reject 3 Negative twist accept 4 Positive twist accept 5 Frequency deviation accept ±1.5%± 2 Hz 2,3,5,9 6 Frequency deviation reject ±3.5% 2,3,5,9 7 Third zone tolerance 8 Noise tolerance -37 dBm 10.9 mVRMS Tested at VDD=5.0 V 1,2,3,5,6,9 8 dB 2,3,6,9,13 8 dB 2,3,6,9,13 9 ‡ Typ.‡ -18.5 dB 2,3,4,5,9,12 -12 dB 2,3,4,5,7,9,10 Dial tone tolerance +22 dB Typical figures are at 25 °C and are for design aid only: not guaranteed and not subject to production testing. 2,3,4,5,8,9,11 *NOTES 1. dBm= decibels above or below a reference power of 1 mW into a 600 ohm load. 2. Digit sequence consists of all DTMF tones. 3. Tone duration= 40 ms, tone pause= 40 ms. 4. Signal condition consists of nominal DTMF frequencies. 5. Both tones in composite signal have an equal amplitude. 6. Tone pair is deviated by ±1.5%± 2 Hz. 7. Bandwidth limited (3 kHz) Gaussian noise. 8. The precise dial tone frequencies are (350 Hz and 440 Hz) ± 2%. 9. For an error rate of better than 1 in 10,000. 10. Referenced to lowest level frequency component in DTMF signal. 11. Referenced to the minimum valid accept level. 12. Referenced to Fig. 10 input DTMF tone level at -25dBm (-28dBm at GS Pin) interference frequency range between 480-3400Hz. 13. Guaranteed by design and characterization. 13 XD8870 DIP-18 XL8870 SOP-18 AC Electrical Characteristics - VDD=5.0V±5%, VSS=0V, -40°C ≤ To ≤ +85°C, using Test Circuit shown in Figure 10. Sym. Min. Typ.‡ Max. Units Tone present detect time tDP 5 11 14 ms Note 1 Tone absent detect time tDA 0.5 4 8.5 ms Note 1 Tone duration accept tREC 40 ms Note 2 Tone duration reject tREC ms Note 2 ms Note 2 ms Note 2 Characteristics 1 2 3 4 5 T I M I N G 20 Interdigit pause accept tID 6 Interdigit pause reject tDO 7 Propagation delay (St to Q) tPQ 8 11 µs TOE=VDD Propagation delay (St to StD) tPStD 12 16 µs TOE=VDD Output data set up (Q to StD) tQStD 3.4 µs TOE=VDD Propagation delay (TOE to Q ENABLE) tPTE 50 ns load of 10 kΩ, 50 pF Propagation delay (TOE to Q DISABLE) tPTD 300 ns load of 10 kΩ, 50 pF Power-up time tPU 30 ms Note 3 Power-down time tPD 20 ms Crystal/clock frequency fC 8 9 10 11 12 13 O U T P U T S P D W N 14 15 16 17 18 C L O C K 40 Conditions 20 3.575 9 3.579 5 3.583 1 MHz Clock input rise time tLHCL 110 ns Ext. clock Clock input fall time tHLCL 110 ns Ext. clock Clock input duty cycle DCCL 60 % Ext. clock 30 pF Capacitive load (OSC2) CLO 40 50 ‡ Typical figures are at 25°C and are for design aid only: not guaranteed and not subject to production testing. *NOTES: 1. Used for guard-time calculation purposes only. 2. These, user adjustable parameters, are not device specifications. The adjustable settings of these minimums and maximums are recommendations based upon network requirements. 3. With valid tone present at input, t PU equals time from PDWN going low until ESt going high. 14 XD8870 DIP-18 XL8870 SOP-18 VDD C1 DTMF Input R1 R2 X-tal C2 XDXL/8870 IN+ VDD IN- St/GT GS VRef StD INH Q4 PDWN Q3 OSC 1 Q2 OSC 2 VSS Q1 TOE R3 ESt NOTES: R1,R2=100 KΩ ± 1% R3=300 KΩ ± 1% C1,C2=100 nF ± 5% X-tal=3.579545 MHz ± 0.1% Figure 10 - Single-Ended Input Configuration 15 XD8870 DIP-18 XL8870 SOP-18 D A EVENTS B C tREC tREC E TONE #n + 1 tDP G tDO tID TONE #n Vin F TONE #n + 1 tDA ESt tGTA tGTP VTSt St/GT tPQ Q1-Q4 tQStD #n DECODED TONE # (n-1) HIGH IMPEDANCE # (n + 1) tPSrD StD tPTD TOE tPTE EXPLANATION OF EVENTS A) TONE BURSTS DETECTED, TONE DURATION INVALID, OUTPUTS NOT UPDATED. B) TONE #n DETECTED, TONE DURATION VALID, TONE DECODED AND LATCHED IN OUTPUTS C) END OF TONE #n DETECTED, TONE ABSENT DURATION VALID, OUTPUTS REMIAN LATCHED UNTIL NEXT VALID TONE. D) OUTPUTS SWITCHED TO HIGH IMPEDANCE STATE. E) TONE #n + 1 DETECTED, TONE DURATION VALID, TONE DECODED AND LATCHED IN OUTPUTS (CURRENTLY HIGH IMPEDANCE). F) ACCEPTABLE DROPOUT OF TONE #n + 1, TONE ABSENT DURATION INVALID, OUTPUTS REMAIN LATCHED. G) END OF TONE #n + 1 DETECTED, TONE ABSENT DURATION VALID, OUTPUTS REMAIN LATCHED UNTIL NEXT VALID TONE. EXPLANATION OF SYMBOLS Vin DTMF COMPOSITE INPUT SIGNAL. ESt EARLY STEERING OUTPUT. INDICATES DETECTION OF VALID TONE FREQUENCIES. St/GT STEERING INPUT/GUARD TIME OUTPUT. DRIVES EXTERNAL RC TIMING CIRCUIT. Q1-Q4 4-BIT DECODED TONE OUTPUT. StD DELAYED STEERING OUTPUT. INDICATES THAT VALID FREQUENCIES HAVE BEEN PRESENT/ABSENT FOR THE REQUIRED GUARD TIME THUS CONSTITUTING A VALID SIGNAL. TOE TONE OUTPUT ENABLE (INPUT). A LOW LEVEL SHIFTS Q1-Q4 TO ITS HIGH IMPEDANCE STATE. tREC MAXIMUM DTMF SIGNAL DURATION NOT DETECED AS VALID tREC MINIMUM DTMF SIGNAL DURATION REQUIRED FOR VALID RECOGNITION tID MAXIMUM TIME BETWEEN VALID DTMF SIGNALS. tDO MAXIMUM ALLOWABLE DROP OUT DURING VALID DTMF SIGNAL. tDP TIME TO DETECT THE PRESENCE OF VALID DTMF SIGNALS. tDA TIME TO DETECT THE ABSENCE OF VALID DTMF SIGNALS. tGTP GUARD TIME, TONE PRESENT. tGTA GUARD TIME, TONE ABSENT. Figure 11 - Timing Diagram 16 XD8870 DIP-18 XL8870 SOP-18 DIP18 17 XD8870 DIP-18 XL8870 SOP-18 SOP-18 18
XD8870 价格&库存
很抱歉,暂时无法提供与“XD8870”相匹配的价格&库存,您可以联系我们找货
