MB6S
MB6S
    SLKOR(萨科微)
    DBS-4P_4X4.7MM_SM
    玻璃钝化单相表面安装桥式整流器 VR=600V IR=5μA MBS
MB6S 数据手册
MB2S-MB10S Miniautre Glass Passivated Single-Phase Surface Mount Bridge Rectifier Reverse Voltage 200 to 1000 Volts Forward Current 0.5 Ampere Features ◆ Plastic package has Underwriters Laboratory Flammability Classification 94V-0 ◆ Glass passivated chip junctions ◆ High surge overload rating:35A peak ◆ Saves space on printed circuit boards ◆ High temperature soldering guaranteed:260℃/10 seconds Mechanical Data ◆ Case:Molded plastic body over passivated junctions ◆ Terminals: plated leads solderable per MIL-STD-750, Method 2026 ◆ Mounting Position:Any ◆ Weight:0.078 oz.,0.22g Maximum Ratings & Electrical Characteristics (TA=25℃ unless otherwise noted) Parameter Symbol MB2S MB4S MB6S MB8S MB10S Unit Maximum repetitive peak reverse voltage VRRM 200 400 600 800 1000 V Maximum RMS voltage VRMS 140 280 420 560 700 V Maximum DC blocking voltage VDC 200 400 600 800 1000 V Maximum Average forward output current (see Fig.1) on glass-epoxy P.C.B 0.5(1) IF(AV) 0.8(2) on aluminum substrate Peak forward surge current 8.3 MS single HALF sine-wav A IFSM 35 A I2t 5 A2sec VF 1.00 V p p superimposed on rated load ((JEDEC Method)) Rating for fusig (t
很抱歉,暂时无法提供与“MB6S”相匹配的价格&库存,您可以联系我们找货
MB6S
  • 1+0.08856
  • 10+0.08528
  • 100+0.07740
  • 500+0.07347
