74LV32
Quad 2-input OR gate
Rev. 03 — 9 November 2007
Product data sheet
1. General description
The 74LV32 is a low-voltage Si-gate CMOS device that is pin and function compatible with
74HC32 and 74HCT32.
The 74LV32 provides a quad 2-input OR function.
2. Features
Wide operating voltage: 1.0 V to 5.5 V
Optimized for low voltage applications: 1.0 V to 3.6 V
Accepts TTL input levels between VCC = 2.7 V and VCC = 3.6 V
Typical output ground bounce < 0.8 V at VCC = 3.3 V and Tamb = 25 °C
Typical HIGH-level output voltage (VOH) undershoot: > 2 V at VCC = 3.3 V and
Tamb = 25 °C
■ ESD protection:
◆ HBM JESD22-A114E exceeds 2000 V
◆ MM JESD22-A115-A exceeds 200 V
■ Multiple package options
■ Specified from −40 °C to +85 °C and from −40 °C to +125 °C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LV32N
−40 °C to +125 °C
DIP14
plastic dual in-line package; 14 leads (300 mil)
SOT27-1
74LV32D
−40 °C to +125 °C
SO14
plastic small outline package; 14 leads;
body width 3.9 mm
SOT108-1
74LV32DB
−40 °C to +125 °C
SSOP14
plastic shrink small outline package; 14 leads;
body width 5.3 mm
SOT337-1
74LV32PW
−40 °C to +125 °C
TSSOP14
plastic thin shrink small outline package; 14 leads;
body width 4.4 mm
SOT402-1
74LV32BQ
−40 °C to +125 °C
DHVQFN14 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 14 terminals;
body 2.5 × 3 × 0.85 mm
SOT762-1
74LV32
NXP Semiconductors
4. Functional diagram
1
≥1
3
≥1
6
≥1
8
2
4
1
1A
2
1B
4
2A
5
2B
9
3A
10
3B
12
4A
13
4B
1Y
3
2Y
6
5
9
10
3Y
8
A
4Y
12
11
≥1
11
Y
13
B
mna242
mna241
mna243
Fig 1. Logic symbol
Fig 2. IEC logic symbol
Fig 3. Logic diagram (one gate)
5. Pinning information
5.1 Pinning
1
1A
terminal 1
index area
2
1Y
3
12 4A
2A
4
11 4Y
2B
5
10 3B
2Y
6
9
3A
GND
7
8
3Y
1B
2
13 4B
1Y
3
12 4A
2A
4
2B
5
2Y
6
11 4Y
VCC
(1)
10 3B
9
8
1B
14 VCC
13 4B
3Y
1
7
1A
GND
74LV32
14 VCC
74LV32
3A
001aah105
Transparent top view
001aah104
(1) The die substrate is attached to this pad using
conductive die attach material. It can not be used as
a supply pin or input.
Fig 4. Pin configuration DIP14, SO14 and (T)SSOP14
Fig 5. Pin configuration DHVQFN14
74LV32_3
Product data sheet
© NXP B.V. 2007. All rights reserved.
2 of 15
74LV32
NXP Semiconductors
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
1A
1
data input
1B
2
data input
1Y
3
data output
2A
4
data input
2B
5
data input
2Y
6
data output
GND
7
ground (0 V)
3Y
8
data output
3A
9
data input
3B
10
data input
4Y
11
data output
4A
12
data input
4B
13
data input
VCC
14
supply voltage
6. Functional description
Table 3.
Function selection
H = HIGH voltage level; L = LOW voltage level; X = don’t care
Input
Output
nA
nB
nY
H
X
H
X
H
H
L
L
L
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
−0.5
+7.0
V
±20
mA
±50
mA
±25
mA
input clamping current
VI < −0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < −0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = −0.5 V to (VCC + 0.5 V)
ICC
supply current
50
mA
IGND
ground current
−50
mA
Tstg
storage temperature
−65
+150
°C
IIK
74LV32_3
Product data sheet
3 of 15
74LV32
NXP Semiconductors
Table 4.
Limiting values …continued
Symbol
Parameter
Conditions
Ptot
total power dissipation
Tamb = −40 °C to +125 °C
[1]
Min
Max
Unit
DIP14 package
[2]
750
mW
SO14 package
[3]
500
mW
(T)SSOP14 package
[4]
500
mW
DHVQFN14 package
[5]
500
mW
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
Ptot derates linearly with 12 mW/K above 70 °C.
[3]
Ptot derates linearly with 8 mW/K above 70 °C.
[4]
Ptot derates linearly with 5.5 mW/K above 60 °C.
[5]
Ptot derates linearly with 4.5 mW/K above 60 °C.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
voltage[1]
Min
Typ
Max
Unit
VCC
supply
1.0
3.3
5.5
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
−40
+25
+125
°C
∆t/∆V
input transition rise and fall rate
[1]
VCC = 1.0 V to 2.0 V
500
ns/V
VCC = 2.0 V to 2.7 V
200
ns/V
VCC = 2.7 V to 3.6 V
100
ns/V
VCC = 3.6 V to 5.5 V
50
ns/V
The static characteristics are guaranteed from VCC = 1.2 V to VCC = 5.5 V, but LV devices are guaranteed to function down to
VCC = 1.0 V (with input levels GND or VCC).
74LV32_3
Product data sheet
4 of 15
74LV32
NXP Semiconductors
9. Static characteristics
Table 6.
Symbol Parameter
HIGH-level input voltage
VIH
LOW-level input voltage
VIL
VOH
LOW-level output voltage
VOL
Conditions
−40 °C to +85 °C
Min
Typ[1]
−40 °C to +125 °C Unit
Max
Min
Max
VCC = 1.2 V
VCC
0.6
VCC
V
VCC = 2.0 V
1.4
1.4
V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
VCC = 1.2 V
0.4
GND
GND
V
VCC = 2.0 V
0.6
0.6
V
0.8
0.8
V
0.3VCC
lO = −100 µA; VCC = 1.2 V
1.2
V
lO = −100 µA; VCC = 2.0 V
1.8
2.0
1.8
V
lO = −100 µA; VCC = 2.7 V
2.5
2.7
2.5
V
lO = −100 µA; VCC = 3.0 V
2.8
3.0
2.8
V
lO = −100 µA; VCC = 4.5 V
4.3
4.5
4.3
V
lO = −6 mA; VCC = 3.0 V
2.4
2.82
2.2
V
lO = −12 mA; VCC = 4.5 V
3.6
4.2
3.5
V
IO = 100 µA; VCC = 1.2 V
V
IO = 100 µA; VCC = 2.0 V
0.2
V
IO = 100 µA; VCC = 2.7 V
0.2
V
IO = 100 µA; VCC = 3.0 V
0.2
V
IO = 100 µA; VCC = 4.5 V
0.2
V
IO = 6 mA; VCC = 3.0 V
0.25
0.40
0.50
V
IO = 12 mA; VCC = 4.5 V
0.35
0.55
0.65
V
0.3VCC V
VI = VIH or VIL
VI = VIH or VIL
II
input leakage current
VI = VCC or GND;
VCC = 5.5 V
1.0
1.0
µA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
20.0
40
µA
∆ICC
additional supply current
per input; VI = VCC − 0.6 V;
500
850
µA
CI
input capacitance
3.5
pF
[1]
Typical values are measured at Tamb = 25 °C.
74LV32_3
Product data sheet
5 of 15
74LV32
NXP Semiconductors
10. Dynamic characteristics
Table 7.
GND = 0 V; For test circuit see Figure 7.
Symbol Parameter
propagation delay
tpd
−40 °C to +85 °C
Conditions
Min
Max
Min
Max
VCC = 1.2 V
40
ns
VCC = 2.0 V
14
22
28
ns
16
ns
nA, nB to nY; see Figure 6
10
VCC = 3.0 V to 3.6 V; CL = 15 pF
[3]
6.0
ns
[3]
8.0
13
16
ns
10
13
ns
16
pF
power dissipation
capacitance
CL = 50 pF; fi = 1 MHz;
VI = GND to VCC
[4]
[1]
All typical values are measured at Tamb = 25 °C.
[2]
tpd is the same as tPLH and tPHL.
[3]
Typical values are measured at nominal supply voltage (VCC = 3.3 V).
[4]
CPD is used to determine the dynamic power dissipation (PD in µW).
PD = CPD × VCC2 × fi × N + Σ(CL × VCC2 × fo) where:
fi = input frequency in MHz, fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in V
N = number of inputs switching
Σ(CL × VCC2 × fo) = sum of the outputs.
74LV32_3
Product data sheet
Unit
[2]
VCC = 2.7 V
CPD
−40 °C to +125 °C
Typ[1]
6 of 15
74LV32
NXP Semiconductors
11. Waveforms
VI
VM
nA, nB input
GND
t PHL
t PLH
VM
nY output
mna244
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig 6. The input (nA, nB) to output (nY) propagation delays
Table 8.
Measurement points
Supply voltage
Input
Output
VCC
VM
VM
< 2.7 V
0.5VCC
0.5VCC
2.7 V to 3.6 V
1.5 V
1.5 V
≥ 4.5 V
0.5VCC
0.5VCC
VCC
PULSE
GENERATOR
VI
VO
D.U.T.
RT
CL
50 pF
RL
1 kΩ
001aaa663
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
Fig 7. Load circuit for switching times
Table 9.
Test data
Supply voltage
Input
VCC
VI
tr, tf
< 2.7 V
VCC
≤ 2.5 ns
2.7 V to 3.6 V
2.7 V
≤ 2.5 ns
≥ 4.5 V
VCC
≤ 2.5 ns
74LV32_3
Product data sheet
7 of 15
74LV32
NXP Semiconductors
12. Package outline
DIP14: plastic dual in-line package; 14 leads (300 mil)
SOT27-1
ME
seating plane
D
A2
A
A1
L
c
e
Z
w M
b1
(e 1)
b
MH
8
14
pin 1 index
E
1
7
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
min.
A2
max.
b
b1
c
D (1)
E (1)
e
e1
L
ME
MH
w
Z (1)
max.
mm
4.2
0.51
3.2
1.73
1.13
0.53
0.38
0.36
0.23
19.50
18.55
6.48
6.20
2.54
7.62
3.60
3.05
8.25
7.80
10.0
8.3
0.254
2.2
inches
0.17
0.02
0.13
0.068
0.044
0.021
0.015
0.014
0.009
0.77
0.73
0.26
0.24
0.1
0.3
0.14
0.12
0.32
0.31
0.39
0.33
0.01
0.087
Note
1. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT27-1
050G04
MO-001
SC-501-14
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-13
Fig 8. Package outline SOT27-1 (DIP14)
74LV32_3
Product data sheet
8 of 15
74LV32
NXP Semiconductors
SO14: plastic small outline package; 14 leads; body width 3.9 mm
SOT108-1
D
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
7
e
detail X
w M
bp
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
8.75
8.55
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.35
0.014 0.0075 0.34
0.16
0.15
0.010 0.057
inches 0.069
0.004 0.049
0.05
0.244
0.039
0.041
0.228
0.016
0.028
0.024
0.01
0.01
0.028
0.004
0.012
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT108-1
076E06
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 9. Package outline SOT108-1 (SO14)
74LV32_3
Product data sheet
9 of 15
74LV32
NXP Semiconductors
SSOP14: plastic shrink small outline package; 14 leads; body width 5.3 mm
D
SOT337-1
E
A
X
c
y
HE
v M A
Z
8
14
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
7
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.4
0.9
8
o
o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT337-1
REFERENCES
IEC
JEDEC
JEITA
MO-150
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 10. Package outline SOT337-1 (SSOP14)
74LV32_3
Product data sheet
10 of 15
74LV32
NXP Semiconductors
TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm
SOT402-1
E
D
A
X
c
y
HE
v M A
Z
8
14
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
7
e
detail X
w M
bp
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.72
0.38
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT402-1
REFERENCES
IEC
JEDEC
JEITA
MO-153
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
Fig 11. Package outline SOT402-1 (TSSOP14)
74LV32_3
Product data sheet
11 of 15
74LV32
NXP Semiconductors
DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT762-1
14 terminals; body 2.5 x 3 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
6
y
y1 C
v M C A B
w M C
b
L
1
7
Eh
e
14
8
13
9
Dh
X
5 mm
scale
UNIT
mm
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
c
D (1)
Dh
E (1)
Eh
0.2
3.1
2.9
1.65
1.35
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT762-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 12. Package outline SOT762-1 (DHVQFN14)
74LV32_3
Product data sheet
12 of 15
74LV32
NXP Semiconductors
13. Abbreviations
Table 10.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LV32_3
20071109
Product data sheet
74LV32_2
Modifications:
The format of this data sheet has been redesigned to comply with the new identity guidelines
of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Section 3: DHVQFN14 package added.
Section 8: derating values added for DHVQFN14 package.
Section 12: outline drawing added for DHVQFN14 package.
74LV32_2
19980420
Product specification
74LV32_1
74LV32_1
19970203
74LV32_3
Product data sheet
13 of 15
74LV32
NXP Semiconductors
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nxp.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
15.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, NXP Semiconductors does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — NXP Semiconductors products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors accepts no liability for inclusion and/or use of
NXP Semiconductors products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — NXP Semiconductors products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nxp.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by NXP Semiconductors. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For additional information, please visit: http://www.nxp.com
For sales office addresses, send an email to: salesaddresses@nxp.com
74LV32_3
Product data sheet
14 of 15
74LV32
NXP Semiconductors
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 1
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3
Functional description . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Recommended operating conditions. . . . . . . . 4
Static characteristics. . . . . . . . . . . . . . . . . . . . . 5
Dynamic characteristics . . . . . . . . . . . . . . . . . . 6
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 13
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 13
Legal information. . . . . . . . . . . . . . . . . . . . . . . 14
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 14
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Contact information. . . . . . . . . . . . . . . . . . . . . 14
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2007.
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
Date of release: 9 November 2007
Document identifier: 74LV32_3
很抱歉,暂时无法提供与“74LV32DB,118”相匹配的价格&库存,您可以联系我们找货
