IS31BL3233A-DLS2-TR
IS31BL3233A-DLS2-TR
    LUMISSIL
    WFDFN14
    IC LED DVR FLASHTORCH 1.5A 14DFN
IS31BL3233A-DLS2-TR 数据手册
IS31BL3233A 2MHz, 1.5A FLASH/TORCH LED DRIVER July 2021 GENERAL DESCRIPTION FEATURES The IS31BL3233A is the ideal power solution for high-power flash LEDs used with cell phone camera modules or digital still cameras. It is a highly integrated step up DC-DC converter with very high switching frequency, fixed at 2MHz, providing a very small total solution for portable photo flash. The IS31BL3233A has separate Flash Mode and Torch Mode enable pins for maximum flexibility. The Flash Mode and Torch Mode LED current is programmed by external resistors respectively, making the flash LED solution simple to control. If both enable pins are at logic high, the LED current will be programmed by the Torch Mode setting resistor. The two LED output sinks can be shorted together externally for higher power single flash LEDs, up to 1.5A continuous LED current. Thermal regulation is integrated in Flash Mode to limit the IC’s temperature and continuously provide the maximum allowed output current.        Various protection features are built into the IS31BL3233A, including cycle-by-cycle input current limit protection, output over-voltage protection, LED fault (open or short) protection and thermal shutdown protection. The IS31BL3233A is available in a RoHS compliant DFN-14 (2mm × 3mm) package.        Input voltage range: 2.7V~5.5V Dual flash LED outputs Drive up to total 1.5A or 0.75A per channel 1s time out in Flash Mode to protect LED High efficiency up to 93% (1A, Flash Mode) 2MHz step-up converter Independent Flash Mode enable and Torch Mode enable pins Torch Mode dimming via PWM control Integrated thermal regulation control LED open/short protection Over-voltage protection Cycle-by-cycle inductor current limit Pb-free package: DFN-14 (2mm×3mm) -40C° ~ +85C° temperature range APPLICATIONS    Mobile phones Smart phones and PDAs Digital still cameras TYPICAL APPLICATION CIRCUIT Figure 1 Typical Application Circuit (Torch Mode current is100mA and Flash Mode current is 500mA) Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 1 IS31BL3233A LX 1 H VBattery 4 2.2 F VCC LX 0.1 F 10 Micro Controller 11 VOUT 1 RSETF 13.5k 2 3,13 Figure 2 8,9 COUT 4.7 F ENF ENM IS31BL3233A RSETM 68k 5,6 RSETM RSETF AGND D1 D2 PGND 12 14 7 Typical Application Circuit (Drive single LED, Torch Mode current is 200mA and Flash Mode current is 1A) Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 2 IS31BL3233A PIN CONFIGURATION Package Pin Configurations (Top View) DFN-14 PIN DESCRIPTION No. Pin Description 1 RSETM Torch Mode current setting pin. ID1 = ID2 = 6800/RSETM. 2 RSETF Flash Mode current setting pin. ID1 = ID2 = 6800/RSETF. 3, 13 AGND Ground. 4 VCC Supply voltage. 5, 6 LX Switching node of the step-up converter. 7 PGND Input clock for data shift on rising edge. 8, 9 VOUT Output voltage pin. 10 ENF Flash Mode enable pin. This pin has an internal 300kΩ pull down resistor to AGND. 11 ENM Torch Mode enable pin. This pin has an internal 300kΩ pull-down resistor to AGND. 12 D1 Regulated output current sink 1, up to 0.75A current. Pins D1 and D2 can be connected together to sink 1.5A combined. 14 D2 Regulated output current sink 2, up to 0.75A current. Pins D1 and D2 can be connected together to sink 1.5A combined. Thermal Pad Connect to GND. Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 3 IS31BL3233A ORDERING INFORMATION Industrial Range: -40°C to +85°C Order Part No. Package QTY/Reel IS31BL3233A-DLS2-TR DFN-14, Lead-free 2500 Copyright  ©  2021  Lumissil  Microsystems.  All  rights  reserved.  Lumissil  Microsystems  reserves  the  right  to  make  changes  to  this  specification  and  its  products  at  any  time  without  notice.  Lumissil  Microsystems  assumes  no  liability  arising  out  of  the  application  or  use  of  any  information,  products  or  services described herein. Customers are advised to obtain the latest version of this device specification before relying on any published information and  before placing orders for products.  Lumissil Microsystems does not recommend the use of any of its products in life support applications where the failure or malfunction of the product can  reasonably be expected to cause failure of the life support system or to significantly affect its safety or effectiveness. Products are not authorized for use in  such applications unless Lumissil Microsystems receives written assurance to its satisfaction, that:  a.) the risk of injury or damage has been minimized;  b.) the user assume all such risks; and  c.) potential liability of Lumissil Microsystems is adequately protected under the circumstances Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 4 IS31BL3233A ABSOLUTE MAXIMUM RATINGS Supply voltage, VCC Voltage at any input pin Maximum junction temperature, TJMAX Storage temperature range, TSTG Operating temperature range, TA ESD (HBM) ESD (CDM) -0.3V ~ +6.0V -0.3V ~ VCC+0.3V +150°C -65°C ~ +150°C -40°C ~ +85°C ±8kV ±1kV Note: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ELECTRICAL CHARACTERISTICS The following specifications apply for VCC = 3.6V, TA = 25°C, unless otherwise noted. Symbol Description Condition Min. Typ. Max. Units 5.5 V 2.68 V IC Supply VCC UVLO Input operating range Input under voltage lockout UVLOHYST UVLO hysteresis ICC Operating current ISD Shutdown current 2.7 Rising edge 2.1 2.4 0.2 V Not switching (RSETM = 135kΩ) 1.0 1.5 mA Switching (RSETM = 135kΩ) 1.8 2.6 mA VENF = VENM = GND 0.1 1 µA Step-Up Converter ILIM Peak NMOS current limit 3 A fSW Oscillator frequency 2.0 MHz DMAX Maximum duty cycle 75 % VOVP Internal over voltage threshold of VOUT 5.3 V 100 µs tS Flash mode soft start time RSETF = 9.1kΩ (Note 1) Total output current, Torch Mode VENM = VCC, RSETM = 135kΩ, D1+D2 Total output current, Flash Mode VENF = VCC = 3.8V, VENM = GND, RSETF = 9.1kΩ, D1+D2 ∆IOUT Output current matching (Note 2) ISHORT LED short checking current Current Sink IOUT Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 90 100 110 mA 1.305 1.5 1.695 A 50mA/CH 2 10 % 750m/CH 2 10 % 3.5 mA 5 IS31BL3233A ELECTRICAL CHARACTERISTICS (CONTINUE) The following specifications apply for VCC = 3.6V, TA = 25°C, unless otherwise noted. Symbol Description Condition Min. Typ. Max. Units Control VIL ENF, ENM pin logic low threshold VIH ENF, ENM pin logic high threshold 0.4 RPD_F ENF Internal pull-down Resistance 300 kΩ RPD_M ENM Internal pull-down Resistance 300 kΩ TOTP IC junction thermal shutdown threshold (Note 1) 150 °C THYS IC junction thermal shutdown hysteresis (Note 1) 20 °C 1.4 V V Note 1: Guarantee by design. Note 2: The current matching between channels is defined as I OUT Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021  I D1  I D 2 I D1  I D 2 . 6 IS31BL3233A TYPICAL PERFORMANCE CHARACTERISTICS 700 110 ID1 = ID2 = 100mA/CH Torch Mode ID1 = ID2 = 500mA/CH Flash Mode Channel 2 Output Current (mA) Output Current (mA) 105 100 Channel 1 95 90 600 Channel 1 500 Channel 2 400 300 85 80 2.7 3.1 3.5 3.9 4.3 4.7 5.1 5.5 200 2.7 3.1 3.5 Figure 4 Supply Voltage vs. Output Current (Torch Mode) 100 Efficiency (%) 95 4.3 4.7 5.1 5.5 Supply Voltage (V) Supply Voltage (V) Figure 3 3.9 VENM 5V/Div ID1+ID2 = 0.2A Torch Mode Supply Voltage vs. Output Current (Flash Mode) VCC = 4.0V ID1 = ID2 =100mA/CH Torch Mode 90 ID1+ID2 = 0.6A Flash Mode ID1+ID2 = 1.5A Flash Mode 85 VOUT 2V/Div ID1+ID2 = 1.0A Flash Mode 80 VD1 1V/Div 75 70 3.2 3.4 Figure 5 3.6 3.8 4 4.2 ID1 100mA/Div Supply Voltage (V) Time (100µs/Div) Boost Efficiency vs. Supply Voltage Figure 6 VCC = 3.6V ID1 = ID2 = 750mA/CH Flash Mode VCC = 3.9V ID1 = ID2 = 750mA/CH Flash Mode VENF 2V/Div VENF 2V/Div VCC 2V/Div VCC 2V/Div ID1 500mA/Div ILX 1A/Div Time (40µs/Div) Time (40ms/Div) Figure 7 Torch Mode Turn On/Off Flash Mode Operation Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 Figure 8 LX Current 7 IS31BL3233A VENF 2V/Div VENF 2V/Div VOUT 2V/Div VOUT 2V/Div VD1 2V/Div VD1 2V/Div ID1 500mA/Div Time (100µs/Div) Figure 9 VCC = 3.4V ID1 = ID2 =750mA/CH Flash Mode With Boost Flash Soft Start with Boost Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 ID1 500mA/Div Time (100µs/Div) Figure 10 VCC = 3.8V ID1 = ID2 = 750mA/CH Flash Mode Without Boost Flash Soft Start without Boost 8 IS31BL3233A FUNCTIONAL BLOCK DIAGRAM Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 9 IS31BL3233A APPLICATION INFORMATION FUNCTIONAL DESCRIPTION The IS31BL3233A is a very high switching frequency step-up (boost) flash LED driver. Two current regulating devices are integrated to drive up to 2 flash LEDs. The voltage step-up is accomplished by a boost topology, using an inductor-based DC-DC switching converter, in which the inductor serves as an energy storage device. By integrating optimized power MOSFETs, the IS31BL3233A internal switching frequency is 2.0MHz while still maintaining high power efficiency. Unlike a traditional DC-DC boost converter with a fixed output voltage, the IS31BL3233A dynamically changes its output voltage depending on the flash LED forward voltage and current. The use of unique control schemes maintains accurate current regulation in each of the two current sinks while leaving the output voltage at a minimum, increasing the overall conversion efficiency. The internal step-up converter boosts the output voltage high enough to drive the LEDs with the highest forward voltage. The two current sinks can be shorted together to drive a higher current single flash LED, sinking up to 1.5A combined. The control interface is designed for maximum design flexibility and compatibility with various types of system controls. When the ENF is pulled high while the ENM is low, the LED current will be ramped up to the Flash Mode current level which is programmed by RSETF resistor. When ENM is pulled high while the ENF is low, the LED current will be ramped up to the Torch Mode current level which is programmed by RSETM resistor. However, if both ENM and ENF are high, the LED current will be set to Torch Mode current. The driver IC and the flash LEDs will be shutdown when both ENF and ENM are at logic low. CURRENT SETTING Torch Mode Current The Torch Mode LED current can be programmed up to a maximum total current of 500mA or up to 250mA per channel. Just as in Flash Mode operation, the output currents in D1 and D2 are internally matched. The Torch Mode current in each channel is set by the RSETM resistor. For the desired Torch Mode current in each output, the resistor value can be calculated using the following Equation (2): I D1  I D 2  6800 / RSETM The Flash Mode LED current can be programmed up to a maximum total current of 1.5A or up to 0.75A per channel. The sink current in D1 and D2 are internally matched in the IS31BL3233A. The Flash Mode current in each channel is set by the RSETF resistor. For the desired Flash Mode current in each output, the resistor value can be calculated using the following Equation (1): (1) A flash event is initiated by asserting the ENF pin while ENM is at logic low level. A flash event is automatically terminated when ENF is deasserted or when ENM is asserted. (2) A Torch Mode event is initiated by asserting the ENM pin. For additional flexibility, a lower Torch Mode current than the value calculated above can be realized by applying a PWM dimming signal at ENM pin while ENF is held low. The average Torch Mode current will be proportional to the PWM duty ratio. SINGLE/DUAL LED APPLICATIONS Each of the sinks’ (D1 and D2) current is regulated and matched for applications requiring two LEDs. For single LED applications, D1 and D2 can be connected together to drive one LED (see Figure 11). The current per sink follows the Equations (1) and (2) in Current Setting sections above. LX 1 H VBattery Flash Mode Current I D1  I D 2  6800 / RSETF enabled and the flash current is set to a high current value, the temperature of the IC can increase quickly. Once the IC’s temperature goes above 100°C, the two sinks’ currents will be automatically decreased according to the thermal regulation control loop. This can prevent the IC from triggering thermal shutdown and causing the LEDs to flicker. Depending on the thermal layout of the PCB and the Flash Mode current setting, the IS31BL3233A sink current can be lower than the programmed value due to the thermal regulation protection feature. 4 2.2 F VCC LX 0.1 F 10 Micro Controller 11 VOUT RSETF 13.5k 2 3,13 8,9 COUT 4.7 F ENF ENM IS31BL3233A 1 RSETM 68k 5,6 RSETM RSETF AGND D1 D2 PGND 12 14 7 Figure 11 Single LED Application Automatic thermal regulation control is active when IS31BL3233A is in Flash Mode. If Flash Mode is Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 10 IS31BL3233A LED SHORT PROTECTION forward voltage and maximum load current conditions): When the IS31BL3233A is enabled, there is a 2.5mA (Typ.) LED sensing current through each current sink. It is used to detect whether either LED is shorted by generating a voltage drop through each LED. The IC internally compares the voltage difference between VOUT and each sink node (D1 and D2). If this difference is below a preset threshold (Typ. 1.7V), the IC will treat the respective LED as shorted and disable its Flash/Torch Mode current through this LED channel. However, the 2.5mA sensing current will be kept to generate the LED’s voltage drop. If the short circuit is removed during operation, the channel will automatically recover to the programmed current setting. LED OPEN PROTECTION In case of LED open, the open channel will control the loop first so that VOUT will reach OVP, then IS31BL3233A will automatically detect which channel’s LED is open and disable that channel. From that point, the other channel with properly operating LED will control the loop and VOUT will be regulated down to a normal operating voltage. This protection feature avoids unnecessary power consumption in the current sink by regulating the output voltage at the lowest level possible to maintain regulation for the active channel. Not only does this protect from open LEDs failures, but also allows only single flash LED operation with the unused channel floating or open. Open-circuit LED fault protection is reset when the IC is powered down and up again. INDUCTOR SELECTION The IS31BL3233A is designed to use a 1.0μH to 4.7μH inductor. To prevent core saturation, ensure that the inductor-saturation current rating exceeds the peak inductor current for the application. The worst-case peak inductor current can be calculated with the following formula: I PEAK( L)  VOUT(MAX)  I LED(MAX) 0.8 VIN(MIN)  VIN(MIN)  tON(MAX) 2 L (3) where 0.8 is the estimated efficiency of 80%. For example, for a 1.0A total (or 0.5A per channel) LED current, the peak inductor current for a 1.0uH inductor could be as high as (estimated 50% as the maximum duty ratio at the minimum input voltage, maximum LED Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 I PEAK( L)  4V 1A 3.5V  0.25   1.9 A 0.8  3.5V 2 1 If the inductor value is smaller, the inductor peak current will increase. To maintain stable operations for the boost converter, the inductor peak current must be less than both the IS31BL3233A current limit threshold and the inductor saturation current rating. Manufacturer’s specifications of inductors list both the inductor DC current rating, which is a thermal limitation, and peak inductor current rating, which is determined by the saturation characteristics. Measurements at full load and high ambient temperature should be performed to ensure that the inductor does not saturate or overheat due to its parasitic resistance. Bench measurements are recommended to confirm actual inductor peak current IPEAK and to ensure that the inductor does not saturate at maximum LED current and minimum input supply voltage. CAPACITOR SELECTION For good input voltage filtering low ESR ceramic capacitors are recommended. At least a 2.2μF input capacitor is recommended for high current flash LEDs to improve transient behavior of the regulator and EMI behavior of the total power supply circuit. The input capacitor should be placed as close as possible to the input pin and the PGND pin of the IS31BL3233A. The output capacitance required depends on the required LED current. A 4.7μF ceramic capacitor works well in most situations, but a 1.0μF capacitor is acceptable for lower LED current conditions. PCB LAYOUT Due to the fast switching transitions and high-current paths, careful PC board layout is required. Connect AGND pin directly to the exposed paddle underneath the IC; connect the exposed paddle to the PCB ground plane. The output bypass capacitor should be placed as close to the IC as possible. Minimize trace lengths between the IC and the inductor, the input capacitor, and the output capacitor; keep these traces short, direct, and wide. The ground connections of CIN and COUT should be as close together as possible and connected to PGND. 11 IS31BL3233A CLASSIFICATION REFLOW PROFILES Profile Feature Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 150°C 200°C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (TL) Time at liquidous (tL) 217°C 60-150 seconds Peak package body temperature (Tp)* Max 260°C Time (tp)** within 5°C of the specified classification temperature (Tc) Max 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25°C to peak temperature 8 minutes max. Figure 12 Classification Profile Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 12 IS31BL3233A PACKAGE INFORMATION DFN-14 Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 13 IS31BL3233A LAND PATTERN Note: 1. Land pattern complies to IPC-7351. 2. All dimensions in MM. Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 14 IS31BL3233A REVISION HISTORY Revision Detail Information Date A Initial release 2015.04.23 B Add “End of Life” watermark 2021.07.15 Lumissil Microsystems – www.lumissil.com Rev. B, 07/15/2021 15
IS31BL3233A-DLS2-TR 价格&库存
很抱歉,暂时无法提供与“IS31BL3233A-DLS2-TR”相匹配的价格&库存,您可以联系我们找货
