EMMC16G-IB29-90F01
EMMC16G-IB29-90F01
    KINGSTON(金士顿)
    BGA153_11.5X13MM
    EMMC 5.1 (HS400) 153B 16GB - IND
EMMC16G-IB29-90F01 数据手册
KINGSTON.COM/EMMC I-Temp eMMC — the perfect storage solution for harsh environment embedded applications. Overview Kingston® I-Temp eMMC™ Flash memory offers JEDEC eMMC5.1 features and is backward compatible to earlier eMMC standards. It has all the advantages of standard eMMC plus the operating temperature range of the device meets industrial operating temperature requirements (-40°C~+85°C), which make it an ideal storage solution for outdoor, harsh environment and automotive applications. Key Benefits • Simplifies system design and reduces time to market. The standard interface makes fast-changing NAND technology invisible to the host and the host processor doesn’t have to keep changing its software to accommodate every NAND technology change and variation. This helps to significantly reduce the design-in complexity and shorten the qualification cycle. • Helps to improve whole system performance. The eMMC controller frees up the host processor’s valuable resources from NAND management so the host processor can use its processing power on other tasks. • Provides a cost-effective solution. As opposed to SLC NAND, eMMC uses MLC NAND so it makes higher capacity storage in embedded applications much more affordable and enables today’s embedded designs to meet increasing demands for storage. • Supports industrial operating temperature range (-40°C~+85°C) I-Temp eMMC Part Numbers and Specifications Part Number EMMC04G-W627 EMMC16G-IB29 Capacity 4GB eMMC Standard 5.0 /5.1 (HS400) Package 11.5x13x1.0 Key Features NAND MLC Operating Temperature JEDEC Standard Features eMMC 5.0 eMMC 5.1 Boot Operation √ √ -40°C~+85°C Partitioning √ √ √ √ 16GB 5.1 (HS400) 11.5x13x0.8 3D TLC -40°C~+85°C Sleep Mode EMMC32G-IX29 32GB 5.1 (HS400) 11.5x13x0.8 3D TLC -40°C~+85°C √ 64GB 5.1 (HS400) 11.5x13x0.8 3D TLC -40°C~+85°C Replay Protected Memory Block √ EMMC64G-IX29 EMMC128-IX29 128GB 5.1 (HS400) 11.5x13x1.0 3D TLC -40°C~+85°C Secure Trim/Secure Erase √ √ Hardware Reset √ √ Reliable Write √ √ Background Operation √ √ High Priority Interrupt √ √ DDR Interface √ √ Discard/Sanitize CMD √ √ Packed Commands, Context IDs √ √ Power OFF Notification √ √ Data Tag √ √ Device Health Report √ √ Field FW Update √ √ Production State Awareness √ √ For more information, please visit kingston.com/emmc CMD Queuing THIS DOCUMENT SUBJECT TO CHANGE WITHOUT NOTICE. ©2021 Kingston Technology Corporation, 17600 Newhope Street, Fountain Valley, CA 92708 USA. All rights reserved. All trademarks and registered trademarks are the property of their respective owners. Printed in the USA MKF-624.4US √
EMMC16G-IB29-90F01 价格&库存
很抱歉,暂时无法提供与“EMMC16G-IB29-90F01”相匹配的价格&库存,您可以联系我们找货
EMMC16G-IB29-90F01
  • 1+70.932011+8.60368
  • 4+70.600544+8.56347
  • 15+70.5989815+8.56328
  • 30+70.5974230+8.56309
  • 75+70.5958675+8.56291
EMMC16G-IB29-90F01
  • 152+74.62263152+9.05133
