CPU
Bad Block Management
Wear levelling
Garbage Collection
NAND I/F
CPU
Host
CPU
Wear levelling
Garbage Collection
ECC
Host
Host
MMC I/F
NAND I/F
Wear levelling
Garbage Collection
ECC
Built in ECC
VALID FROM JULY TO SEPTEMBER 2013
Item Name
Design
rule
Page Size
Vcc
Vccq
ECC
level
Operation
Temperature
Package
TC58NVG0S3HTAI0
TC58NVG0S3HBAI4
TC58NYG0S3HBAI4
TC58NVG1S3HTAI0
TC58NVG1S3HBAI4
TC58NYG1S3HBAI4
TC58NVG2S0HTA00
TH58NVG2S3HTAI0
TC58NVG3S0FTAI0
TC58NYG3S0FBAID
TH58NVG4S0FTAK0
TH58NYG4S0FBAID
TC58NVG5H2HTAI0
TH58NVG6H2HTAK0
TH58NVG7H2HTAK0
24nm
24nm
24nm
24nm
24nm
24nm
24nm
24nm
32nm
32nm
32nm
32nm
24nm
24nm
24nm
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(2048+128)x8 bit
(4096+256)x8 bit
(2048+128)x8 bit
(4096+232)x8 bit
(4096+232)x8 bit
(4096+232)x8 bit
(4096+232)x8 bit
(8192+1024)x8 bit
(8192+1024)x8 bit
(8192+1024)x8 bit
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
3.3V
1.8V
3.3V
1.8V
3.3V
3.3V
3.3V
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
3.3V
1.8V
3.3V
1.8V
3.3V
3.3V
3.3V
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
8bit/512B
4bit/512B
4bit/512B
4bit/512B
4bit/512B
24bit/1024B
24bit/1024B
24bit/1024B
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
0°C to 70°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 70°C
-40°C to 70°C
-40°C to 70°C
48TSOP 12x20
63BGA 9x11
63BGA 9x11
48TSOP 12x20
63BGA 9x11
63BGA 9x11
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
63BGA 10x11
48TSOP 12x20
63BGA 10x11
48TSOP 12x20
48TSOP 12x20
48TSOP 12x20
BENAND™ - SLC NAND with build in ECC
TC58BVG0S3HTAI0
24nm
1Gbit
TC58BVG0S3HBAI4
24nm
TC58BYG0S3HBAI4
24nm
TC58BVG1S3HTAI0
24nm
2Gbit
TC58BVG1S3HBAI4
24nm
TC58BYG1S3HBAI4
24nm
TH58BVG2S3HTAI0
24nm
4Gbit
TC58BVG2S0HTAI0
24nm
TH58BYG2S3HBAI4
24nm
TC58BYG2S0HBAI4
24nm
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(2048+64)x8 bit
(4096+128) x 8 bit
(2048+64)x8 bit
(4096+128)x 8 bit
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
3.3V
3.3V
1.8V
1.8V
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
-40°C to 85°C
48TSOP 12x20
63BGA 9x11
63BGA 9x11
48TSOP 12x20
63BGA 9x11
63BGA 9x11
48TSOP 12x20
48TSOP 12x20
63BGA 9x11
63BGA 9x11
3.3V
3.3V
3.3V
3.3V
3.3V
1.8V, 3.3V
1.8V, 3.3V
1.8V, 3.3V
1.8V, 3.3V
1.8V, 3.3V
internal ECC
internal ECC
internal ECC
internal ECC
internal ECC
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
Density
SLC NAND
1Gbit
2Gbit
4Gbit
8Gbit
16Gbit
32Gbit
64Gbit
128Gbit
e MMC™
4GBytes
8GByte
16GByte
32GByte
64GByte
THGBM5G5A1JBAIR
THGBMBG6D1KBAIL
THGBMBG7D2KBAIL
THGBMBG8D4KBAIR
THGBMBG9D8KBAIG
19nm
A19nm
A19nm
A19nm
A19nm
153FBGA
153FBGA
153FBGA
153FBGA
153FBGA
11.5x13
11.5x13
11.5x13
11.5x13
11.5x13
www.toshiba-components.com
Speed class
Density
Item Name
Design Rule
Bit/Cell
Operation
Temperature
4GB
8GB
16GB
32GB
8GB
16GB
32GB
64GB
SD-C04GET2(RZCLH)
SD-C08G2T2(RZCKH)
SD-C16G2T2(PZCKH)
SD-C32G2T2(PZCKP)
SD-C08G2T2(22GKP)
SD-C16G2T2(2ZGKP)
SD-C32G2T2(2ZGKP)
SD-C64G2T2(2ZGKY)
19nm
19nm
19nm
19nm
19nm
19nm
19nm
19nm
3b/c
3b/c
3b/c
3b/c
2b/c
3b/c
3b/c
3b/c
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
4GB
8GB
16GB
32GB
8GB
16GB
32GB
64GB
SD-K04G2B8(PZCFN)
SD-K08G2B8(PZCFN)
SD-K16G2B8(P1CFN)
SD-K32G2B8(P1CFN)
SD-K08G2B8(22GFN)
SD-K16G2B8(2ZGFN)
SD-K32G2B8(2ZGFN)
SD-K64G2B8(21GFN)
19nm
19nm
19nm
19nm
19nm
19nm
19nm
19nm
3b/c
3b/c
3b/c
3b/c
2b/c
3b/c
3b/c
3b/c
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
-25°C to 85°C
8GB
16GB
THNSW008GAA-B(xxx)
THNSW016GAA-B(QB8)
19nm
19nm
2b/c
2b/c
-25°C to 85°C
-25°C to 85°C
microSD Cards
cl4
cl10 U1
SD Cards
cl4
cl10 U1
FlashAirTM SD Cards
cl10
Note: The microSD and SD Card line up will change to A19nm generation within Q4 2013
FlashAir™ is a standard SDHC™ memory card class 10, which offers you 8 and 16GB of high quality memory.
But FlashAir™ is more than a standard memory card. It offers embedded Wireless LAN and creates it’s own
access point, accessible from other Wireless LAN enabled devices. Industrial or consumer products which
have an SD Card slot can now transmit any kind of data stored on a FlashAir™ SD card. Log files, firmware
updates, configuration settings, pictures, templates and even more types of data can now be easily transmitted
and accessed remotely.
No special software or driver required
WPA2 Secured Access Point
Easy access to Data via integrated HTML Server
Compatible with Windows, Android, iOS, etc.
很抱歉,暂时无法提供与“TH58NVG2S3HTAI0”相匹配的价格&库存,您可以联系我们找货
