Designated client product
This product will be discontinued its production in the near term.
And it is provided for customers currently in use only, with a time limit.
It can not be available for your new project. Please select other new or
existing products.
For more information, please contact our sales office in your region.
New Japan Radio Co.,Ltd.
www.njr.com
NJM022B
DUAL LOW POWER OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
The NJM022B is a dual low-power operational amplifier.Like
the NJM022,the NJM022B is the wide operating voltage
range,high input inpedance,low operating current,low input
noise voltage,internally frequency compensated,latch-up
free,high slew rate amplifier with the short circuit protection.The
NJM022B is twice the slew rate and half the input noise voltage
comparing to the NJM022 with increased operating current.
■ FEATURES
● Operating Voltage
● Low Operating Current
● Slew Rate
● Short-Circuit Protection
● Package Outline
● Bipolar Technology
■ PACKAGE OUTLINE
NJM022BD
NJM022BM
( ±2V~±18V )
( 250µA typ. )
( 1V/µs typ. )
NJM022BL
DIP8,DMP8,SIP8
■ PIN CONFIGURATION
NJM022BD
NJM022BM
PIN FUNCTION
1.A OUTPUT
2.A -INPUT
3.A +INPUT
4.V5.B +INPUT
6.B -INPUT
7.B OUTPUT
8.V+
NJM022BL
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
Ver.2012-06-13
-1-
NJM022B
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
Supply Voltage
Input Voltage
Differential Input Voltage
SYMBOL
V+/VVIC
VID
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
RATINGS
± 18
± 15
± 30
( DIP8 ) 500
( DMP8 ) 300
( SIP8 ) 800
-40~+85
-40~+125
UNIT
V
V
V
mW
˚C
˚C
( note ) For supply voltage less than ±15V. the absolute maximum input voltage is equal to the supply voltage.
■ ELECTRICAL CHARACTERISTICS
( Ta=+25˚C,V+/V-=±15V )
PARAMETER
Input Offset Voltage
Input Offset Current
Input Bias Current
Large Singal Voltage Gain
Common Mode Rejection Ratio
Response Time ( Rise Time )
Slew Rate
Input Common Mode Voltage Range
Supply Voltage Rejection Ratio
Equivalent Input Noise Voltage
Short-circuit Output Current
Operating Current
Maximum Peak-to-Peak Output Voltage
-2-
SYMBOL
VIO
IIO
IB
AV
CMR
tR
SR
VICM
SVR
en
IOS
ICC
VOM
TEST CONDITION
RS≤10kΩ
RL≥10kΩ,VO=±10V
RS≤10kΩ
VIN=20mV,RL=10kΩ,CL=100PF
VIN=10V,RL=10kΩ,CL=100PF
RS≤10kΩ
AV=20dB,f=1kHz
RL=10kΩ
MIN.
60
60
± 12
74
± 10
TYP.
1
1
92
0.18
1
± 13
110
25
±8
250
± 14
MAX.
5
80
250
500
UNIT
mV
nA
nA
dB
dB
µs
V/µs
V
dB
nV/√Hz
mA
µA
V
Ver.2012-06-13
NJM022B
■ TYPICAL CHARACTERISTICS
Maximum Output Voltage Swing
vs. Frequency
(µA)
Ver.2012-06-13
-3-
NJM022B
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-4-
Ver.2012-06-13
很抱歉,暂时无法提供与“NJM022BM-TE3”相匹配的价格&库存,您可以联系我们找货
