10Φ SERIES
Metal Oxide Varistors (MOV) Data Sheet
Features
Wide operating voltage (V1mA) range from 18V to 1100V
Fast responding to transient over-voltage
Large absorbing transient energy capability
Low clamping ratio and no follow-on current
Meets MSL level 1, per J-STD-020
Operating Temperature:-40℃ ~ +85℃
Storage Temperature:-40℃ ~ +125℃
Safety certification: UL: E327997
CSA: 246579
VDE: 40027827
Applications
Transistor, diode, IC, thyristor or triac semiconductor protection
Surge protection in consumer electronics
Surge protection in industrial electronics
Surge protection in electronic home appliances, gas and petroleum appliances
Relay and electromagnetic valve surge absorption
Part Number Code
Revision:27-Dec-15
1 / 11
www.brightking.com
10Φ SERIES
Dimensions
Table 1
Table 2
Unit: mm
Unit: mm
Symbol
Dimension
Model
T
e
Model
T
e
H(±2.0)
13.0
180K
2.8
1.5
301K
3.9
2.5
H1(±2.0)
15.5
220K
2.9
1.6
331K
3.9
2.5
L(min.)
20.0
270K
3.1
1.8
361K
4.1
2.7
L1(min.)
15.0
330K
3.0
1.7
391K
4.2
2.8
D
10~12.5
390K
3.1
1.8
431K
4.4
3.0
F(±0.8)
7.5
470K
3.3
1.9
471K
4.6
3.2
T(±0.8)
Table 2
560K
3.5
2.1
511K
4.8
3.4
e(±0.8)
Table 2
680K
3.8
2.4
561K
5.0
3.6
d(±0.05)
0.8
820K
3.2
1.8
621K
5.3
3.9
d1(±0.4)
1.4
101K
3.4
2.0
681K
5.6
4.2
121K
3.6
2.2
751K
5.7
4.3
151K
3.2
1.8
781K
5.8
4.4
181K
3.3
1.9
821K
6.0
4.6
201K
3.4
2.0
911K
6.4
5.0
221K
3.5
2.1
102K
6.4
5.0
241K
3.6
2.2
112K
6.8
5.4
271K
3.8
2.4
Revision:27-Dec-15
2 / 11
www.brightking.com
10Φ SERIES
Electrical Characteristics
Maximum
Part
Allowable
Number
Standard
High
Surge
Voltage
VAC(V)
VDC(V)
Varistor
Voltage
V1mA(V)
Maximum
Withstanding
Maximum
Clamping
Surge
Energy
Voltage
Current
(10/1000μs)
IP(A)
VC(V)
I (A)
Standard
I (A)
High
Surge
(J)
Standard
Rated
Power
Typical
Capacitance
(Reference)
(J)
High
(W)
@1KHz (pf)
Surge
180KD10
180KD10J
11
14
18(15~21.6)
5
36
500
1000
2.1
3.0
0.05
5600
220KD10
220KD10J
14
18
22(19.5~26)
5
43
500
1000
2.5
5.0
0.05
4500
270KD10
270KD10J
17
22
27(24~31)
5
53
500
1000
3.0
6.0
0.05
3700
330KD10
330KD10J
33(29.5~36.5)
5
65
500
1000
4.0
7.0
0.05
3000
390KD10
390KD10J
25
31
39(35~43)
5
77
500
1000
4.6
9.0
0.05
2400
470KD10
470KD10J
30
38
47(42~52)
5
93
500
1000
5.5
11.0
0.05
2100
560KD10
560KD10J
35
45
56(50~62)
5
110
500
1000
7.0
13.0
0.05
1800
680KD10
680KD10J
40
56
68(61~75)
5
135
500
1000
8.2
15.0
0.05
1500
820KD10
820KD10J
50
65
82(74~90)
25
135
2500
3500
12.0
17.0
0.4
1200
101KD10
101KD10J
60
85
100(90~110)
25
165
2500
3500
15.0
18.0
0.4
1000
121KD10
121KD10J
75
100
120(108~132)
25
200
2500
3500
18.0
21.0
0.4
830
151KD10
151KD10J
95
125
150(135~165)
25
250
2500
3500
22.0
25.0
0.4
670
181KD10
181KD10J
115
150
180(162~198)
25
300
2500
3500
27.0
30.0
0.4
560
201KD10
201KD10J
130
170
200(180~220)
25
340
2500
3500
30.0
35.0
0.4
500
221KD10
221KD10J
140
180
220(198~242)
25
360
2500
3500
32.0
39.0
0.4
450
241KD10
241KD10J
150
200
240(216~264)
25
395
2500
3500
35.0
42.0
0.4
420
271KD10
271KD10J
175
225
270(243~297)
25
455
2500
3500
37.0
49.0
0.4
370
301KD10
301KD10J
190
250
300(270~330)
25
500
2500
3500
40.0
54.0
0.4
330
331KD10
331KD10J
210
275
330(297~363)
25
550
2500
3500
43.0
58.0
0.4
300
361KD10
361KD10J
230
300
360(324~396)
25
595
2500
3500
47.0
65.0
0.4
280
391KD10
391KD10J
250
320
390(351~429)
25
650
2500
3500
60.0
70.0
0.4
260
431KD10
431KD10J
275
350
430(387~473)
25
710
2500
3500
65.0
80.0
0.4
230
471KD10
471KD10J
300
385
470(423~517)
25
775
2500
3500
67.0
85.0
0.4
210
511KD10
511KD10J
320
415
510(459~561)
25
845
2500
3500
69.0
90.0
0.4
200
561KD10
561KD10J
350
460
560(504~616)
25
925
2500
3500
70.0
92.0
0.4
180
621KD10
621KD10J
385
505
620(558~682)
25
1025
2500
3500
72.0
95.0
0.4
160
681KD10
681KD10J
420
560
680(612~748)
25
1120
2500
3500
75.0
98.0
0.4
150
751KD10
751KD10J
460
615
750(675~825)
25
1240
2500
3500
77.0
100.0
0.4
130
781KD10
781KD10J
485
640
780(702~858)
25
1290
2500
3500
80.0
105.0
0.4
130
821KD10
821KD10J
510
670
820(738~902)
25
1355
2500
3500
85.0
110.0
0.4
120
911KD10
911KD10J
550
745
910(819~1001)
25
1500
2500
3500
93.0
130.0
0.4
110
102KD10
102KD10J
625
825
1000(900~1100)
25
1650
2500
3500
102.0
140.0
0.4
100
112KD10
112KD10J
680
895
1100(990~1210)
25
1815
2500
3500
115.0
155.0
0.4
90
Notes: 1. The tolerance of varistor voltage between 18V and 27V is more than 10%.
2. Leakage Current (@83% of V1mA):IR≤50μA (180K~680K)
IR≤25μA (820K~112K)
Revision:27-Dec-15
3 / 11
www.brightking.com
10Φ SERIES
Electrical Ratings
Items
Varistor Voltage
Maximum Allowable
Voltage
Test Condition/Description
Requirement
The voltage between two terminals with the specified measuring
current 1mA.DC applied is called Vb.
The recommended maximum sine wave voltage (RMS) or the
Maximum DC voltage can be applied continuously.
The maximum voltage between two terminals with the specification
standard impulse current.
Applied waveform: 8/20μs
Maximum Clamping
Voltage
To meet the
Specified value
Rated Wattage
The maximum average power that can be applied within the
specified ambient temperature.
Energy
The maximum energy within the varistor voltage change of ±10%
when one impulse of 10/1000μs or 2ms is applied.
Withstanding Surge
Current
The maximum current within the varistor voltage change of ±10%
with the standard impulse current (8/20μs) applied one time.
Varistor Voltage
Temp. Coefficient
Vb at 20℃ − Vb at 70℃ 1
× 100(%/℃)
50
Vb at 20℃
0.05%/℃ max
The change of Vb shall be measured after the impulse listed below
which is applied 10,000 times continuously with the interval of ten
seconds at room temperature.
Surge Life
10Φ series
Revision:27-Dec-15
180K to 680K
50A (8/20μs)
820K to 112K
100A (8/20μs)
4 / 11
∆Vb
≤ ±10%
Vb
www.brightking.com
10Φ SERIES
Soldering Recommendation
Wave Lead Free Soldering Recommendation
300
Preheating
Maximum Wave 265℃
Soldering
Cooling
250
200
150
100
50
1
1.5
2
2.5
3
3.5
4
Time (minutes)
Item
Conditions
Peak Temperature
265℃
Dipping Time
10 seconds (max.)
Soldering
1 time
Recommendation Reworking Conditions with Soldering Iron
Revision:27-Dec-15
Item
Conditions
Temperature of Soldering Iron-tip
360℃ (max.)
Soldering Time
3 seconds (max.)
Distance from Varistor
2mm (min.)
5 / 11
www.brightking.com
10Φ SERIES
Maximum Surge Current Derating Curve
820KD10 to 751KD10
180KD10 to 680KD10
10000
10000
1000
1000
1
100
2
10
1023
104
105
106
10
100
10
10
1
1
0.1
10
100
1000
0.1
10
10000
Td (μs)
1
2
10
102
1034
10
105
106
100
1000
10000
Td (μs)
820KD10J to 112KD10J
10000
1
2
1000
100
10
102
103
1045
106
10
10
1
0.1
10
100
1000
10000
Td (μs)
Revision:27-Dec-15
6 / 11
www.brightking.com
10Φ SERIES
Maximum Leakage Current and Maximum Clamping Voltage Curve
180KD10 to 680KD10
1000
680KD10
560KD10
470KD10
390KD10
330KD10
270KD10
220KD10
180KD10
Voltage (V)
100
10
1
10-6
10-5
10-4
10-3
10-2
10-1
1
102
10
103
104
Current (A)
820KD10 to 471KD10
10000
471KD10
431KD10
391KD10
361KD10
331KD10
301KD10
271KD10
241KD10
221KD10
201KD10
181KD10
151KD10
121KD10
101KD10
820KD10
Voltage (V)
1000
100
10
10-6
10-5
10-4
10-3
10-2
10-1
1
10
102
103
104
105
Current (A)
Revision:27-Dec-15
7 / 11
www.brightking.com
10Φ SERIES
511KD10 to 112KD10
10000
112KD10
102KD10
911KD10
821KD10
781KD10
751KD10
681KD10
621KD10
561KD10
511KD10
Voltage (V)
1000
100
10
10-6
10-5
10-4
10-3
10-2
10-1
1
102
10
103
104
105
Current (A)
180KD10J to 680KD10J
1000
680KD10J
560KD10J
470KD10J
390KD10J
330KD10J
270KD10J
220KD10J
180KD10J
Voltage (V)
100
10
1
10-6
10-5
10-4
10-3
10-2
10-1
1
10
102
103
104
Current (A)
Revision:27-Dec-15
8 / 11
www.brightking.com
10Φ SERIES
820KD10J to 751KD10J
10000
751KD10J
681KD10J
621KD10J
561KD10J
511KD10J
471KD10J
431KD10J
391KD10J
361KD10J
331KD10J
301KD10J
271KD10J
241KD10J
221KD10J
201KD10J
181KD10J
151KD10J
121KD10J
101KD10J
820KD10J
Voltage (V)
1000
100
10
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
3
10
4
10
5
10
10
Current (A)
781KD10J to 112KD10J
10000
112KD10J
102KD10J
911KD10J
821KD10J
781KD10J
Voltage (V)
1000
100
10-6
-5
10
-4
10
-3
10
-2
10
-1
10
1
10
2
10
3
10
4
10
5
10
Current (A)
Revision:27-Dec-15
9 / 11
www.brightking.com
10Φ SERIES
Marking Code
① Brightking Logo
② Varistor Voltage
③ UL Accreditation Logo
①
XXXKDXXX
②
③
④
⑤
XXX H
Y
VDE
X
④ CSA Accreditation Logo
⑥
⑦
⑧
⑨
⑩
⑤ VDE Accreditation Logo
⑥“J”is High Surge Code, no“J”is Standard Surge
⑦ Disk Size
⑧“H”is Halogen Free Code, no“H”is Halogen
⑨ Date Code
⑩ Product Line Code (“Y”may be A thru Z or blank)
Taping Dimensions
Revision:27-Dec-15
10 / 11
Symbol
Dimension (mm)
P
25.4±1.0
P0
12.7±1.0
P1
8.95±0.7
P2
12.7±1.3
F
7.5±0.8
h
0±2
W
18.0±1.0
W0
12.0±1.0
W1
9.0±0.5
W2
3.0max
H
20.0±2.0
I
1.0max
D0
4.0±0.2
t
0.6±0.3
B
36max
www.brightking.com
10Φ SERIES
Quantity
Packaging Dimensions (Unit: mm)
Quantity
Bulk
500pcs/bag
2bags/box
(180K~621K)
400pcs/bag
2bags/box
(681K~112K)
Tape & Box
750pcs/box
(180K~391K)
500pcs/box
(431K~621K)
300pcs/box
(681K~751K)
Tape & Reel
1000pcs/reel
(180K~391K)
750pcs/reel
(431K~621K)
500pcs/reel
(681K~751K)
Revision:27-Dec-15
11 / 11
www.brightking.com
很抱歉,暂时无法提供与“221KD10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.23830
- 100+0.23060
- 200+0.22300
- 国内价格
- 1+0.24000
- 100+0.22400
- 300+0.20800
- 500+0.19200
- 2000+0.18400
- 5000+0.17920
