DF37C-10DP-0.4V(51)
DF37C-10DP-0.4V(51)
    HRS(广濑)
    CONN_3.14X1.46MM_SM
    板对板 间距0.40mm 10Pin(2x5) 公 立贴
DF37C-10DP-0.4V(51) 数据手册
0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors DF37 Series ■Further reduction of the board space. ●Comparison of board mounting space 2.98mm DF30 8.22mm Fig.1 ■Features Header 1. Reduced size and board-occupied area With the mated height of 0.98/1.5mm, width of 2.98mm and length of 8.22mm (30 positions) the connectors are one of the smallest in its class. Also 2.6mm depth short-lead type is available. (Fig.1) Sufficiently large flat areas allow pick-up with vacuum nozzles of automatic placement equipment. 2. Reliable electrical and mechanical connection Despite its small mated height, unique contact configuration, with a 2-point contacts and effective mating length of 0.25mm, assures highly reliable connection while confirming a complete mating with a definite tactile feel. 0.98 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF37 4.56mm 30 positions, 0.4 mm pitch, 0.98 mm height Receptacle Lock Fig.2 ●Splatter protection Contact areas 3. Self alignment Recognizing the difficulties of mating extremely small connectors in limited spaces, the connectors will selfalign within 0.3mm. 4. Physical shock and vibration protection 2-point contact assures electrical connection in a shock or vibration applications. (Fig.2) 5. Solder wicking prevention Nickel barriers (receptacles) and unique forming of the contacts (headers) prevent un-intentional solder wicking. Contact areas are not exposed to the outside penetration of the flux or other physical particles. Contact areas 6. Contamination protection Insulator walls protect the contact areas against flux splatter or other physical particles contamination. (Fig.3) Fig.3 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2016.8④ 1 DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors ■Product Specifications Current rating 0.3A Voltage rating 30V AC, DC Operating -35°C to +85°C (Note 1) temperature range Operating RH 20% to 80% humidity range Ratings Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification 1.Insulation resistance 50Mø min 2.Withstanding voltage No flashover or insulation breakdown 3.Contact resistance 100mø max. No electrical discontinuity of 1μs or longer 4.Vibration No damage or parts dislocation Contact resistance : 100mø max., 5.Humidity Insulation resistance : 25Mø min. Contact resistance : 100mø max., Insulation resistance : 50Mø min. 6.Temperature cycle No damage or parts dislocation Contact resistance : 100mø max. 7.Durability No deformation of components affecting 8.Resistance to performance soldering heat Storage -10°C to +60°C (Note 2) temperature range Storage RH 40% to 70% (Note 2) humidity range Conditions 100V DC 100V AC / 1minute 20mV AC, 1kHz, 1mA Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours, 3 axis 96 hours at 40 ±2°C and humidity of 90 to 95% No damage or parts dislocation -55°C ➝ 5 to 35°C ➝ 85°C ➝ 5 to 35°C Time: 30 min. ➝ 10 min. ➝ 30 min. ➝ 10 min. 5 cycles 10 cycles Reflow : At the recommended temperature profile Manual soldering : 350°C for 3 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use. The operating temperature and humidity range covers the non-conducting condition of connectors after board mounting and the temporary storage conditions of transportation, etc. ■Materials / Finish Receptacle Part Material Finish Remarks Insulator LCP Color: Black UL94V-0 Header Part Material Finish Remarks Contacts Phosphor bronze Gold plated --------------- ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacles DF 37 # - (**) - * DS - 0.4 V (**) 1 1 Series name 2 Configuration 2 3 4 6 7 8 5 Connector style : DF37 DS : Receptacle 6 Contact pitch : 0.4mm 7 Terminal type V : SMT vertical mount NB : With metal fittings NC : Without metal fittings SB : Short-lead type with metal fittings 3 Stacking height 8 Packaging (51) Stacking height 0.98mm : Embossed tape packaging (8,000 pcs/reel) Blank : 0.98mm, 1.5 : 1.5mm 4 Number of contacts ●Headers 5 (51) Stacking height 1.5mm : Embossed tape packaging (5,000 pcs/reel) (53) : Embossed tape packaging (1,000 pcs/reel) DF 37 # - * DP - 0.4 V (**) 1 1 Series name 2 Configuration : DF37 B : With metal fittings C : Without metal fittings 3 Number of contacts 2 3 4 5 6 7 4 Connector style DP : Header 5 Contact pitch : 0.4mm 6 Terminal type V : SMT vertical mount 7 Packaging (51) : Embossed tape packaging (8,000 pcs/reel) (53) : Embossed tape packaging (1,000 pcs/reel) Note : The short-lead type is only available for the receptacle side (with hardware). 2 DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors A B ■Receptacles(Stacking Height=0.98mm) Vacuum pick-up area : C 0.15 0.08 0.98 2.98 2.32 P=0.4 BRecommended metal mask dimensions Without metal fittings 0 D -0.05 B±0.02 0.23±0.01 BRecommended PCB mounting pattern Without metal fittings B±0.02 P=0.4±0.02 3.28 +0.05 0 1.1+0.05 0 0 2.02 -0.05 P=0.4±0.02 E +0.05 0 0 D -0.05 B±0.02 2.28±0.01 3.28±0.01 0.23±0.01 With metal fittings B±0.02 P=0.4±0.02 0 2.02 -0.05 3.28±0.01 2.28±0.01 P=0.4±0.02 E +0.05 0 1.1+0.05 0 With metal fittings 3.28 +0.05 0 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.96 (With metal fittings only) 0.23±0.02 0.23±0.02 ●With metal fittings Part No. DF37NB-10DS-0.4V(51) DF37NB-16DS-0.4V(51) DF37NB-20DS-0.4V(51) DF37NB-24DS-0.4V(51) DF37NB-30DS-0.4V(51) DF37NB-34DS-0.4V(51) DF37NB-40DS-0.4V(51) DF37NB-44DS-0.4V(51) DF37NB-50DS-0.4V(51) DF37NB-60DS-0.4V(51) DF37NB-70DS-0.4V(51) Unit : mm HRS No. 684-3301-6 51 684-3302-9 51 684-3303-1 51 684-3304-4 51 684-3305-7 51 684-3082-4 51 684-3306-0 51 684-3407-7 51 684-3307-2 51 684-3308-5 51 684-3409-2 51 No. of Contacts 10 16 20 24 30 34 40 44 50 60 70 A 4.22 5.42 6.22 7.02 8.22 9.02 10.22 11.02 12.22 14.22 16.22 B 1.6 2.8 3.6 4.4 5.6 6.4 7.6 8.4 9.6 11.6 13.6 HRS No. 684-3309-8 51 684-3310-7 51 684-3311-0 51 684-3312-2 51 684-3313-5 51 684-3083-7 51 684-3314-8 51 684-3324-1 51 684-3315-0 51 684-3316-3 51 684-3084-0 51 No. of Contacts 10 16 20 24 30 34 40 44 50 60 70 A 4.22 5.42 6.22 7.02 8.22 9.02 10.22 11.02 12.22 14.22 16.22 B 1.6 2.8 3.6 4.4 5.6 6.4 7.6 8.4 9.6 11.6 13.6 ●Without metal fittings Part No. DF37NC-10DS-0.4V(51) DF37NC-16DS-0.4V(51) DF37NC-20DS-0.4V(51) DF37NC-24DS-0.4V(51) DF37NC-30DS-0.4V(51) DF37NC-34DS-0.4V(51) DF37NC-40DS-0.4V(51) DF37NC-44DS-0.4V(51) DF37NC-50DS-0.4V(51) DF37NC-60DS-0.4V(51) DF37NC-70DS-0.4V(51) C 0.8 1.2 1.6 2 2.4 2.8 3.2 3.6 D 3.7 4.9 5.7 6.5 7.7 8.5 9.7 10.5 11.7 13.7 15.7 E 4.46 5.66 6.46 7.26 8.46 9.26 10.46 11.26 12.46 14.46 16.46 Unit : mm C 0.8 1.2 1.6 2 2.4 2.8 3.2 3.6 Note 1 : Tape and reel packaging (8,000 pcs/reel). Order by number of reels. Note 2 : This connector is NOT polarized. 3 DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors A B ■Receptacles(Stacking Height=1.5mm) 2.98 2.32 P=0.4 Vacuum pick-up area : C 1.5 0.08 0.15 0.96 (With metal fitting only) Without metal fittings 0 D -0.05 B±0.02 3.28±0.01 0.23±0.01 0.23±0.01 BRecommended PCB mounting pattern Without metal fittings B±0.02 P=0.4±0.02 3.28 +0.05 0 0 2.02 -0.05 3.28 +0.05 0 P=0.4±0.02 E +0.05 0 0 D -0.05 B±0.02 1.1+0.05 0 With metal fittings B±0.02 P=0.4±0.02 2.28±0.01 3.28±0.01 2.28±0.01 P=0.4±0.02 E +0.05 0 0 2.02 -0.05 With metal fittings 1.1+0.05 0 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BRecommended metal mask dimensions 0.23±0.02 0.23±0.02 ●With metal fittings Unit : mm Part No. HRS No. DF37NB(1.5)-24DS-0.4V(51) 684-3602-2 51 No. of Contacts 24 A 7.02 B 4.4 No. of Contacts 24 30 34 40 50 60 70 A 7.02 8.22 9.02 10.22 12.22 14.22 16.22 B 4.4 5.6 6.4 7.6 9.6 11.6 13.6 ●Without metal fittings Part No. DF37NC(1.5)-24DS-0.4V(51) DF37NC(1.5)-30DS-0.4V(51) DF37NC(1.5)-34DS-0.4V(51) DF37NC(1.5)-40DS-0.4V(51) DF37NC(1.5)-50DS-0.4V(51) DF37NC(1.5)-60DS-0.4V(51) DF37NC(1.5)-70DS-0.4V(51) Unit : mm HRS No. 684-3603-5 51 684-3604-8 51 684-3618-0 51 684-3606-3 51 684-3610-0 51 684-3613-9 51 684-3614-1 51 Note 1 : Tape and reel packaging (5,000 pcs/reel). Order by number of reels. Note 2 : This connector is NOT polarized. 4 C 2 C 2 2.4 2.8 3.2 3.6 D 6.5 E 7.26 DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors A ■Receptacles(DF37SB) 2.6 B A 2.32 P=0.4 Vacuum pick-up area : C 0.08 0.96 BRecommended metal mask dimensions E +0.05 0 1.1+0.05 0 0 D -0.05 B±0.02 3±0.01 1.84±0.01 P=0.4±0.02 0.23±0.01 BRecommended PCB mounting pattern 1.1+0.05 0 E +0.05 0 0 D -0.05 B±0.02 0 1.9 -0.05 P=0.4±0.02 2.9 +0.05 0 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.98 0.15 0.23±0.02 ●With metal fittings Part No. DF37SB-20DS-0.4V(51) DF37SB-24DS-0.4V(51) DF37SB-30DS-0.4V(51) DF37SB-34DS-0.4V(51) DF37SB-40DS-0.4V(51) DF37SB-50DS-0.4V(51) Unit : mm HRS No. 684-3502-8 51 684-3503-0 51 684-3504-3 51 684-3505-6 51 684-3506-9 51 684-3507-1 51 No. of Contacts 20 24 30 34 40 50 A 6.22 7.02 8.22 9.02 10.22 12.22 B 3.6 4.4 5.6 6.4 7.6 9.6 C 1.6 2 2.4 2.8 D 5.7 6.5 7.7 8.5 9.7 11.7 E 6.46 7.26 8.46 9.26 10.46 12.46 Note 1 : Tape and reel packaging (8,000 pcs/reel). Order by number of reels. Note 2 : This connector is NOT polarized. 5 DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors ■Headers A B 1.98 1.46 P=0.4 Vacuum pick-up area : C 0.58 (With metal fittings only) 0.08 0.76 0.15 2.28±0.01 1.26±0.01 Without metal fittings B±0.02 P=0.4±0.02 2.28±0.01 1.26±0.01 E +0.05 0 0 D-0.05 B±0.02 P=0.4±0.02 With metal fittings 0.68 +0.05 0 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BRecommended metal mask dimensions 0.23±0.02 0.23±0.02 BRecommended PCB mounting pattern Without metal fittings B±0.02 P=0.4±0.02 2.28 +0.05 0 0 0.82 -0.05 0.68+0.05 0 E +0.05 0 0 D-0.05 B±0.02 P=0.4±0.02 2.28 +0.05 0 0 0.82 -0.05 With metal fittings 0.23±0.02 0.23±0.02 ●With metal fittings Part No. DF37B-10DP-0.4V(51) DF37B-16DP-0.4V(51) DF37B-20DP-0.4V(51) DF37B-24DP-0.4V(51) DF37B-30DP-0.4V(51) DF37B-34DP-0.4V(51) DF37B-40DP-0.4V(51) DF37B-44DP-0.4V(51) DF37B-50DP-0.4V(51) DF37B-60DP-0.4V(51) DF37B-70DP-0.4V(51) Unit : mm HRS No. 684-3037-0 51 684-3057-7 51 684-3008-1 51 684-3009-4 51 684-3010-3 51 684-3064-2 51 684-3011-6 51 684-3408-0 51 684-3012-9 51 684-3013-1 51 684-3014-4 51 No. of Contacts 10 16 20 24 30 34 40 44 50 60 70 A 3.14 4.34 5.17 5.94 7.14 7.94 9.14 9.94 11.14 13.14 15.14 B 1.6 2.8 3.6 4.4 5.6 6.4 7.6 8.4 9.6 11.6 13.6 HRS No. 684-3039-5 51 684-3058-0 51 684-3024-8 51 684-3025-0 51 684-3026-3 51 684-3085-2 51 684-3027-6 51 684-3089-3 51 684-3028-9 51 684-3029-1 51 684-3030-0 51 No. of Contacts 10 16 20 24 30 34 40 44 50 60 70 A 3.14 4.34 5.17 5.94 7.14 7.94 9.14 9.94 11.14 13.14 15.14 B 1.6 2.8 3.6 4.4 5.6 6.4 7.6 8.4 9.6 11.6 13.6 ●Without metal fittings Part No. DF37C-10DP-0.4V(51) DF37C-16DP-0.4V(51) DF37C-20DP-0.4V(51) DF37C-24DP-0.4V(51) DF37C-30DP-0.4V(51) DF37C-34DP-0.4V(51) DF37C-40DP-0.4V(51) DF37C-44DP-0.4V(51) DF37C-50DP-0.4V(51) DF37C-60DP-0.4V(51) DF37C-70DP-0.4V(51) 2 2.4 2.8 3.2 3.6 Unit : mm Note 1 : Tape and reel packaging (8,000 pcs/reel). Order by number of reels. Note 2 : This connector is NOT polarized. 6 C 0.8 1.2 1.6 C 0.8 1.2 1.6 2 2.4 2.8 3.2 3.6 D 2.62 3.82 4.62 5.42 6.62 7.42 8.62 9.42 10.62 12.62 14.62 E 3.38 4.58 5.38 6.18 7.38 8.18 9.38 10.18 11.38 13.38 15.38 DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors BEmbossed Carrier Tape Dimensions Ø1 1 0. + 0 .5 8±0.1 2±0.1 4±0.1 F 1.75±0.1 ●Receptacle (less than 70 positions) F-F Unit : mm E±0.15 0.3±0.1 Part No. A DF37#(1.5)-24DS-0.4V(51) 7.5 B 16 C D 17.5 21.5 E 24 25.5 29.5 1.75 32 33.5 37.5 DF37#(1.5)-30DS-0.4V(51) A±0.1 DF37#(1.5)-34DS-0.4V(51) DF37#(1.5)-40DS-0.4V(51) 11.5 DF37#(1.5)-50DS-0.4V(51) B±0.3 DF37#(1.5)-60DS-0.4V(51) DF37#(1.5)-70DS-0.4V(51) 14.2 G F G G-G Unreeling direction 8±0.1 2±0.1 4±0.1 .1 +00 5 F-F E±0.15 0.3±0.1 28.4±0.1 B±0.3 A±0.1 F 1.75±0.1 ●Receptacle (70 positions) Ø1. G G G-G F Unreeling direction Unit : mm ●Reel Dimensions Unreeling direction DF37#-16DS-0.4V(51) DF37#-20DS-0.4V(51) A B 7.5 16 C D E 17.5 21.5 Ø80±1 DF37#-24DS-0.4V(51) Ø380±2 Part Number Label 3± 0 .2 Part No. DF37#-10DS-0.4V(51) Ø1 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. # : NB or NC Tape and reel packaging (5,000 pcs/reel). DF37#-30DS-0.4V(51) DF37#-34DS-0.4V(51) DF37#-40DS-0.4V(51) 1.23 11.5 24 25.5 29.5 C±0.5 DF37#-60DS-0.4V(51) D±1 DF37#-70DS-0.4V(51) 14.2 32 33.5 37.5 DF37#-44DS-0.4V(51) DF37#-50DS-0.4V(51) # : NB or NC, SB Tape and reel packaging (8,000 pcs/reel). 7 DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors BEmbossed Carrier Tape Dimensions E Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A±0.1 .1 +00 2±0.1 4±0.1 F F E-E 1±0.15 0.3±0.1 B±0.3 5 Ø1. 8±0.1 1.75±0.1 ●Header E Unreeling direction F-F Unit : mm Unreeling direction Ø80±1 Ø380±2 Ø1 3± Part Number Label 0.2 ●Reel Dimensions C±0.5 D±1 8 Part No. A DF37#-10DP-0.4V(51) 5.5 DF37#-16DP-0.4V(51) DF37#-20DP-0.4V(51) 7.5 DF37#-24DP-0.4V(51) DF37#-30DP-0.4V(51) DF37#-34DP-0.4V(51) DF37#-40DP-0.4V(51) DF37#-44DP-0.4V(51) 11.5 DF37#-50DP-0.4V(51) DF37#-60DP-0.4V(51) DF37#-70DP-0.4V(51) B 12 C 13.5 D 17.5 16 17.5 21.5 24 25.5 29.5 # : B, C Tape and reel packaging (8,000 pcs/reel). DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors BUsage Recommendations 1.Recommended temperature profile Temperature (ç) 250ç 250 220ç 200 60sec max 180ç 150 150ç 90~120sec Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) Note 1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2.Recommended manual soldering 3.Recommended screen thickness and open area ratio (Pattern area ratio) 4.Board warpage Manual soldering : 340±10ç for 3 seconds Thickness : 0.12mm Open area ratio : Receptacle:80%(NB/NC), Plug : 70% Maximum of 0.02mm at the connector center, with both ends of the connector as reference points. 5.Cleaning conditions Cleaning is not recommended. When cleaning, please evaluate as it can deteriorate the performance including mechanical operation and environmental resistance. 6.Precautions ■ Mating and un-mating of the connectors when not soldered on the boards is not recommended as this may cause deformation of the terminals, damage to the contacts or insulators. ■ Mated connectors should not carry weight of the board by themselves. Provide some other support of the boards. ■ When mating/un-mating do not twist or lift by the corners. Apply the forces evenly across the entire length and width of the connectors taking care NOT to damage or deform soldered terminations. ■ Exercise extreme caution when mating/ un-mating when the connector is mounted on a nonrigid (flexible) substrate. Slight discoloration on the insulating materials will not affect form, fit or function of the connectors. ■ Do NOT pull on the flexible substrate. 9 DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BHandling Precautions when Mating Connectors Keep the connectors parallel to each other when positioning. The connectors will selfalign in horizontal directions. Do not attempt to mate the connectors starting at one end or side. Press-down even until fully mated. 10 DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors BHandling Precautions When Un-mating Connectors Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Lift even, keeping both connectors parallel to each other When handling, circumstances may prevent the connectors from being kept parallel when un-mating. One end may be lifted as shown. However, to use this procedure the connector must be mounted on sufficiently rigid circuit board. Any deflection of the board dur ing this operation may result in damage to the connector or solder joints. Do not attempt to start the un-mating of the connectors from one side or corner. Failure to exercise caution when un-mating the connectors mounted on the non-rigid FPC may also result in connector breakage. It is the responsibility of the user to perform verification of the repeated mating / un-mating cycles with the connectors mounted on the applicable FPC. When the rigidity of the FPC is low, there is a r isk that the connector could break as illustrated in the diagram at left. Please use the connectors after performing a check of repeated operation with the FPC that the customer will be using. Evaluative results of FPC rigidity and various items are available. Please inquire. 11 Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DF37 Series●0.4mm Pitch, 0.98/1.5mm Mated Height, Board-to-Board / Board-to-FPC Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE Regus La Garenne Colombes,Place de La Belgique, 71 Boulevard National La Garenne Colombes, 92250, France Phone : +33 (0) 1 7082 3170 Fax : +33 (1) 7082 3101 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 250, Huimanggongwon-ro, Siheung-si, Gyeonggi-do, Korea, 15083 Phone : +82-31-496-7000 or 7124 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 10 Anson Road #26-16, International Plaza Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India 079903, Singapore Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ MALAYSIA: PENANG REPRESENTATIVE OFFICE 1-21-01, Suntech @ Penang Cybercity (1164), Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ ® 12 INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ THAILAND: BANGKOK OFFICE (REPRESENTATIVE OFFICE) Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Phone : +66-2-686-1255 Fax : +66-2-686-3433 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2016. Contents are subject to change without notice for the purpose of improvements.
DF37C-10DP-0.4V(51) 价格&库存
很抱歉,暂时无法提供与“DF37C-10DP-0.4V(51)”相匹配的价格&库存,您可以联系我们找货
DF37C-10DP-0.4V(51)
    库存:1908
    DF37C-10DP-0.4V(51)
    • 1+7.393501+0.89500
    • 10+6.2273010+0.75380
    • 100+5.59760100+0.67760
    • 500+4.58300500+0.55480
    • 1000+4.069901000+0.49270
    • 2500+3.696702500+0.44750
    • 5000+3.521805000+0.42630
    • 8000+3.440208000+0.41650
    • 24000+3.4052024000+0.41220
    DF37C-10DP-0.4V(51)
      • 5+0.76685
      • 50+0.61795
      • 150+0.54349
      • 500+0.48766
      库存:518
      DF37C-10DP-0.4V(51)
        库存:72680
        DF37C-10DP-0.4V(51)
        • 1+0.45849
        • 10+0.44099
        • 100+0.38849
        • 500+0.37799
        库存:38
