SS52B-SS510B
SURFACE MOUNT SCHOTTKY BARRIER DIODES
VOLTAGE RANGE: 20 - 100V
CURRENT: 5.0 A
Features
! Schottky Barrier Chip
Ideally Suited for Automatic Assembly
Low Power Loss, High Efficiency
Surge Overload Rating to 175A Peak
For Use in Low Voltage Application
Guard Ring Die Construction
B
SMB(DO-214AA)
Mechanical Data
A
Case: SMB/DO-214AA, Molded Plastic
Terminals: Solder Plated, Solderable
per MIL-STD-750, Method 2026
Polarity: Cathode Band or Cathode Notch
Marking: Type Number
Weight: 0.093 grams (approx.)
C
D
J
G
E
H
Maximum Ratings and Electrical Characteristics
Dim
Min
Max
A
3.30
3.94
B
4.06
4.70
C
1.91
2.21
D
0.15
0.31
E
5.00
5.59
G
0.10
0.20
H
0.76
1.52
J
2.00
2.62
All Dimensions in mm
TA = 25C unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Characteristic
Symbol SS52B SS53B SS54B SS55B SS56B SS58B SS510B
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 5.0A
TA=25 C
Maximum DC reverse current
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
VRRM
VRMS
VDC
40
28
40
30
21
30
50
35
50
60
42
60
100
70
100
80
56
80
V
V
V
I(AV)
5.0
A
IFSM
120.0
A
VF
IR
CJ
RθJA
TJ ,
TSTG
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
www.slkormicro.com
Unit
1
0.70
0.55
0.85
0.5
200
50.0
-65 to +125
-65 to +150
-65 to +150
V
mA
pF
C/W
C
C
FIG. 1- FORWARD CURRENT DERATING CURVE
5.0
4.0
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
3.0
2.0
SS52 -SS56
SS58 -SS510
1.0
50
75
100
125
150
175
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
SS52B-SS510B
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
150
120
90
60
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
50
CURRENT,AMPERES
TJ=25 C
10.0
1
0.1
SS52 -SS54
SS55 -SS56
SS58 -SS510
100
10
TJ=100 C
1
TJ=75 C
0.1
0.01
TJ=25 C
0.001
0.01
0.4
0.6
0.8
1.0
1.2
1.4
TRANSIENT THERMAL IMPEDANCE,
C/W
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
2000
TJ=25 C
100
10
0.1
1.0
10
60
80
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
REVERSE VOLTAGE,VOLTS
www.slkormicro.com
PERCENT OF PEAK REVERSE VOLTAGE,%
1.6
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
1000
100
t,PULSE DURATION,sec.
2
100
很抱歉,暂时无法提供与“SS54B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18257
- 200+0.17137
- 500+0.16017
- 1000+0.14897
- 3000+0.14337
- 6000+0.13553
