PRODUCT DATASHEET
ASMD1812 Series Surface Mount PTC Devices
Description
The ASMD1812 series provides surface mount
resettable overcurrent protection with holding current
from 0.1A to 3.5A.
This series offers complete portfolio in terms of
holding current and working voltage, and is suitable for
wide range of applications.
Features
● RoHS compliant and lead-free
● Low profile
● Halogen-free
● Fast response to fault current
● Compact design saves board space
● Compatible with high temperature solders
Agency Approvals
Agency
Applications
File Number
pending
pending
● USB hubs, ports and peripherals
● Motherboard USB & IEEE 1394 protection
● Set-top-box and HDMI
● Optical disk drives
● Game console port protection
General electronics
Regulation
Standard
2002/95/EC
EN14582
JDT FUSE Industrial Corp.
www.jdtfuse.com
Page 1/7
Performance Specification
Model
V max
(V dc)
I max
(A)
I hold
I trip
Maximum
Time To Trip
Pd
@25°C
(A)
@25°C
(A)
Typ.
(W)
Resistance
Current
(A)
Time
(Sec)
R i min
R1max
(Ω)
(Ω)
ASMD1812-010
30.0
100
0.10
0.30
0.8
0.5
1.50
0.750
15.000
ASMD1812-014
60.0
100
0.14
0.34
0.8
1.5
0.15
0.650
6.000
ASMD1812-020
30.0
100
0.20
0.40
0.8
8.0
0.02
0.350
5.000
ASMD1812-030
30.0
100
0.30
0.60
0.8
8.0
0.10
0.250
3.000
ASMD1812-050
15.0
100
0.50
1.00
0.8
8.0
0.15
0.150
1.000
ASMD1812-050-30
30.0
100
0.50
1.00
0.8
8.0
0.15
0.150
1.000
ASMD1812-050-60
60.0
100
0.50
1.00
0.8
8.0
0.15
0.150
1.400
ASMD1812-075
13.2
100
0.75
1.50
0.8
8.0
0.20
0.090
0.450
ASMD1812-110
8.0
100
1.10
2.20
0.8
8.0
0.30
0.050
0.250
ASMD1812-110-16
16.0
100
1.10
2.20
0.8
8.0
0.30
0.050
0.250
ASMD1812-125
16.0
100
1.25
2.50
0.8
8.0
0.40
0.050
0.140
ASMD1812-150
8.0
100
1.50
3.00
0.8
8.0
0.50
0.040
0.160
ASMD1812-150-16
16.0
100
1.50
3.00
0.8
8.0
0.50
0.040
0.160
ASMD1812-160
8.0
100
1.60
2.80
0.8
8.0
1.00
0.030
0.130
ASMD1812-200
8.0
100
2.00
4.00
0.8
8.0
2.00
0.020
0.100
ASMD1812-260
8.0
100
2.60
5.00
0.8
8.0
2.50
0.015
0.050
ASMD1812-300
8.0
100
3.00
5.00
0.8
8.0
4.00
0.012
0.040
ASMD1812-350
6.0
100
3.50
6.00
2.0
10.0
4.00
0.008
0.030
I hold = Hold Current. Maximum current device will not trip in 25°C still air.
I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air.
V max = Maximum operating voltage device can withstand without damage at rated current (Imax).
I max = Maximum fault current device can withstand without damage at rated voltage (V max).
Pd
= Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage.
Ri min/max
Test= Minimum/Maximum device resistance prior to tripping at 25°C.
R1max = Maximum device resistance is measured one hour post reflow.
CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame.
Environmental Specifications
Conditions
Resistance change
Passive aging
+85°C, 1000 hrs.
±5% typical
Humidity aging
+85°C, 85% R.H. , 168 hours
±5% typical
Thermal shock
+85°C to -40°C, 20 times
±33% typical
Resistance to solvent
MIL-STD-202,Method 215
No change
Vibration
MIL-STD-202,Method 201
No change
Ambient operating conditions : - 40 °C to +85 °C
Maximum surface temperature of the device in the tripped state is 125 °C
www.jdtfuse.com
Page 2/7
Thermal Derating Curve
Percentage of Derated Current
Derating Curves for ASMD1812 Series
160
140
120
100
80
60
40
-20
60
80
Temperature (°C )
Average Time-Current Curve
100
0.30A
TIME IN SECOND
0.50A
0.75A
10
1.00A
1.25A
1.50A
1
1.85A
2.0A
2.50A
0.1
2.60A
3.00A
3.50A
0.01
0.1
1
10
100
CURRENT IN AMPERES
www.jdtfuse.com
Page 3/7
Thermal Derading Chart
Maximum ambient operating temperature (Tmao) vs. hold current (Ihold)
Model
- 40°C
- 20°C
0°C
25°C
40°C
50°C
60°C
70°C
85°C
ASMD1812-010
0.16
0.14
0.12
0.10
0.08
0.07
0.06
0.05
0.03
ASMD1812-014
0.23
0.19
0.17
0.14
0.12
0.10
0.09
0.08
0.06
ASMD1812-020
0.29
0.26
0.23
0.20
0.17
0.15
0.14
0.12
0.10
ASMD1812-030
0.44
0.39
0.35
0.30
0.26
0.23
0.21
0.18
0.15
ASMD1812-050
0.59
0.57
0.55
0.50
0.45
0.43
0.35
0.30
0.23
ASMD1812-075
1.10
0.99
0.87
0.75
0.63
0.57
0.49
0.45
0.35
ASMD1812-110
1.60
1.45
1.28
1.10
0.92
0.83
0.71
0.66
0.52
ASMD1812-110-16V
1.59
1.44
1.27
1.10
0.92
0.82
0.70
0.64
0.50
ASMD1812-125
2.00
1.75
1.52
1.25
1.00
0.95
0.90
0.75
0.53
ASMD1812-150
2.30
2.05
1.77
1.50
1.23
1.09
0.95
0.82
0.61
ASMD1812-150-16V
2.28
2.03
1.75
1.50
1.21
1.07
0.93
0.79
0.58
ASMD1812-160
2.10
1.96
1.88
1.60
1.26
1.12
0.98
0.84
0.63
ASMD1812-200
2.88
2.61
2.25
2.00
1.80
1.66
1.45
1.09
0.80
ASMD1812-260
3.90
3.42
2.96
2.60
2.33
2.07
1.94
1.35
1.00
ASMD1812-300
4.15
3.76
3.46
3.00
2.55
2.28
2.01
1.61
1.33
ASMD1812-350
4.84
4.39
4.04
3.50
2.98
2.66
2.35
1.88
1.55
Soldering Parameters
TP 20~40 S
TP 260
Ramp-up
Profile Feature
Critical Zone
TL to TP
TL 217
tL
Tsmax
Temperature (°C )
Preheat
Tsmin
Ramp-down
ts
Preheat 60~180 s
25
3℃/second mac.
(Ts max to T p)
60~150 s
200
150
Average Ramp-Up Rate
Pb-Free Assembly
t 25°C to peak
Time
Recommended reflow methods: IR, vapor phase oven,
hot air oven, N2 environment for lead-free
Recommended maximum paste thickness is 0.25mm
Devices can be cleaned using standard industry methods
and solvents.
Note 1:All temperature refer to topside of the package,
measured on the package body surface.
Note 2: If reflow temperatures exceed the recommended
profile, devices may not meet the performance
requirements.
www.jdtfuse.com
-Temperature Min(Ts min)
150℃
-Temperature Max(Ts max)
200℃
-Time(Ts min to Ts max)
60~180 seconds
Time maintained above:
-Temperature(TL)
217℃
-Time(tL)
60~150 seconds
Peak Temperature(Tp)
260℃
Ramp-Down Rate
6℃/second max.
Time 25℃ to Peak Temperature 8 minutes max
Storage Condition
0℃~35℃,≤70%RH
Page 4/7
Physical Dimensions(mm.)
A
Model
B
C
D
E
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Min.
ASMD1812-010
4.37
4.73
3.07
3.41
0.50
1.00
0.30
0.25
ASMD1812-014
4.37
4.73
3.07
3.41
0.50
1.00
0.30
0.25
ASMD1812-020
4.37
4.73
3.07
3.41
0.50
1.30
0.30
0.25
ASMD1812-030
4.37
4.73
3.07
3.41
0.50
1.00
0.30
0.25
ASMD1812-050
4.37
4.73
3.07
3.41
0.40
0.90
0.30
0.25
ASMD1812-050-30V
4.37
4.73
3.07
3.41
0.70
1.30
0.30
0.25
ASMD1812-050-60V
4.37
4.73
3.07
3.41
1.10
1.80
0.30
0.25
ASMD1812-075
4.37
4.73
3.07
3.41
0.40
0.90
0.30
0.25
ASMD1812-110
4.37
4.73
3.07
3.41
0.40
0.90
0.30
0.25
ASMD1812-110-16V
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
ASMD1812-125
4.37
4.73
3.07
3.41
0.60
1.30
0.30
0.25
ASMD1812-150
4.37
4.73
3.07
3.41
0.40
1.20
0.30
0.25
ASMD1812-150-16V
4.37
4.73
3.07
3.41
0.40
1.20
0.30
0.25
ASMD1812-160
4.37
4.73
3.07
3.41
0.40
1.20
0.30
0.25
ASMD1812-200
4.37
4.73
3.07
3.41
0.50
1.30
0.30
0.25
ASMD1812-260
4.37
4.73
3.07
3.41
0.50
1.50
0.30
0.25
ASMD1812-300
4.37
4.73
3.07
3.41
0.50
1.50
0.30
0.25
ASMD1812-350
4.37
4.73
3.07
3.41
0.50
1.50
0.30
0.25
Termination Pad Characteristics
Terminal pad materials:Tin-plated Nickel-Copper
Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3.
Packaging Quantity and Marking
3.2±0.1
Part Number
3.2±0.1
SMD812 Series
Quantity
1,500 pcs/reel
Tape & reel packaging per EIA481-1
1.78±0.1
www.jdtfuse.com
1.78±0.1
Page 5/7
Tape And Reel Specifications (mm)
Governing Specifications
EIA 481-1
W
12 ± 0.3
P0
4.0 ± 0.10
P1
8.0 ± 0.10
P2
2.0 ± 0.05
A0
3.5 ± 0.10
B0
5.1 ± 0.10
B1max.
5.9
D0
1.50 + 0.1, -0
F
5.5 ± 0.05
E1
1.75 ± 0.10
E2min.
10.25
T
0.6
T1max.
0.1
K0
0.9 ± 0.1
Leader min.
390
Trailer min.
160
Reel Dimensions
A max.
178
N min.
60
W1
12.4 ± 0.5
W2
18.4
Storage And Handling
● Storage conditions:40°C max, 70% R.H.
● Devices may not meet specified performance
if storage conditions are exceeded.Technology Corp.
www.jdtfuse.com
P1
P2
D0
P0
E1
F
W
T
D2
K0
A0
B0
H
W4
W3
D
C
W2
W
F
W1
H1
Page 6/7
Part Number System
ASMD 1812 -
Special Voltage Rating(Optional)
Holding Current Rating
Device Dimensions:
Length/width(Unit:1/100 inch) Size 4532 mm / 1812 inch
Surface Mount Device
Cross Reference
Cross Reference
Model
Tyco / PolySwitch®
Littelfuse / POLY-FUSE®
Polytronics / EVERFUSE®
ASMD1812-010
miniSMDC010F
1812L010
SMD1812P010TF
ASMD1812-014
-miniSMDC014F
1812L014
SMD1812P014TF
ASMD1812-020
miniSMDC020F
1812L020
SMD1812P020TF
ASMD1812-030
1812L035
SMD1812P030TF
ASMD1812-050
miniSMDC050F
1812L050
SMD1812P050TF
ASMD1812-050-30V
miniSMDC050F
1812L050/30
SMD1812P050TF/30
ASMD1812-050-60V
ASMD1812-075
miniSMDC750F
1812L075
SMD1812P075TF
ASMD1812-110
miniSMDC110F
1812L110
SMD1812P110TF
ASMD1812-110-16V
miniSMDC110F/16
1812L110/16
SMD1812P110TF/16
ASMD1812-125
miniSMDC125F
1812L125
SMD1812P125TF
ASMD1812-150
miniSMDC150F
1812L150
SMD1812P150TF
ASMD1812-150-16V
miniSMDC150F/12
1812L150/12
SMD1812P150TF/12
ASMD1812-160
miniSMDC160F
1812L160
SMD1812P160TF
ASMD1812-200
miniSMDC200F
1812L200
SMD1812P200TF
ASMD1812-260
miniSMDC260F
1812L260
SMD1812P260TF
ASMD1812-300
miniSMDC300F
1812L300
SMD1812P300TF
ASMD1812-350
“PolySwitch” is a registered trademark of Tyco Electronics.
“POLY-FUSE” is a registered trademark of Littelfuse,Inc.
“EVERFUSE” is a registered trademark of Polytronics Technology Corp.
www.jdtfuse.com
Page 7/7
很抱歉,暂时无法提供与“ASMD1812-125”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.25500
- 100+0.23800
- 300+0.22100
- 500+0.20400
- 2000+0.19550
- 5000+0.19040
