Safety Standard Certified Ceramic Capacitors-CD Series (Class Y1)
Series (Class Y1) Data Sheet
Feature
■Wide operating voltage range from 10pF to 4700pF
■Operating Temperature: -40℃~125℃
■Storage Temperature: 15℃~35℃
■Fix capacitors Y1 for electromagetic interference suppression and connection to the supply mains
has high dielectric coefficient ceramic dielectric and flame retardant epoxy resin package
Applications
■ Can be used for power supply noise suppression circuit in cross connection and bypass.It is a
primary and secondary coupling X/Y capacitor used as AC line filter and switching power supply and
AC converter
Applicable Standard
Approval
Organization
Safety Standards
Certificate No.
USA
Canada
UL
CUL
UL60384
E208107
Korea
KTL
K60384-14
SU03031-7002
China
CQC
GB/T 6346.14-2015
CQC06001018610
Germany
VDE
En 60384-14
40025754
Email: info@songtian.cn
Website: http://www.songtian-ste.com
Revision: 2018-04-29
1
Approval
Organization
Safety Standards
Certificate No.
EU
ENEC
En 60384-14
40025754
IEC
IEC-CB
IEC 60384-14
US-21746-UL
Part Number Code
Q
09
F
Rated
Voltage
Q:Y1
Core Diameter
09:9mm
15:15mm
Temperature
Characteristic
B:Y5P
E:Y5U
F:Y5V
1
D
222
Pitch
D:10.0mm
M
N0
B
S
Package
B: Bulk
T:Tape
Tolerance
K:±10%
M:±20%
Nominal capacitance
470:47pF
471:470pF
222:2200pF
103:10000pF
Foot Type
1:Long straight
2:Outside Crimped
3:Short Straight
8:Vertical Crimped
N
Inner
Management
Environmental
Standard
0:RoHS
2:RoHS+Halogen-Free
Lead Length
S0~S9:1.0~1.9mm
X0~X9:2.0~2.9mm
A0~A9:3.0~3.9mm
B0~B9:4.0~4.9mm
C0~C9:5.0~5.9mm
D0~D9:6.0~6.9mm
E0~E9:7.0~7.9mm
2
Lead Length
F0~F9:8.0~8.9mm
G0~G9:9.0~9.9mm
H0~H9:10.0~10.9mm
J0~J9:11.0~11.9mm
K0~K9:12.0~12.9mm
L0~L9:13.0~13.9mm
M0~M9:14.0~14.9mm
Lead Length
M0~M9:14.0~14.9mm
N0:16~27.0mm(Bulk)
Crimped Lead Taped
N0:H0=16.5mm
P0:H0=17.0mm
Q0:H0=19.0mm
Straight Lead
Q0:20.0mm
Specifications
Capacitance and Dissipation factor testing condition
Dissipation Factor(tanδ)
Y5P/Y5U/Y5V:25℃、1KHz、1Vrms
≤2.5%
Rated Voltage
400VAC
Withstand Voltage
4000VAC
Insulation Resistance (I.R.)
IR≥10000MΩ
Temperature Characteristic
Y5P、Y5U、Y5V
Dimensions (mm) and Approval
Size (mm)
Part No.
Approval
D Max.
T Max.
F±0.8
d±0.05
CQC
VDE
cUL
(Canada)
KTL
ENEC
Y1-Y5P-101K
7.0
4.0
10.0
0.6
Y1-Y5P-151K
7.0
5.0
10.0
0.6
Y1-Y5P-221K
7.0
5.0
10.0
0.6
Y1-Y5P-331K
8.5
5.0
10.0
0.6
Y1-Y5P-471K
9.0
5.0
10.0
0.65
Y1-Y5P-681K
10.0
5.0
10.0
0.65
Y1-Y5P-102K
12.0
5.5
10.0
0.65
Y1-Y5U-331K
7.0
5.0
10.0
0.6
Y1-Y5U-471K
7.0
5.0
10.0
0.6
Y1-Y5U-102M
8.0
5.0
10.0
0.6
Y1-Y5U-152M
10.0
5.0
10.0
0.65
Y1-Y5U-222M
11.0
5.0
10.0
0.65
Y1-Y5V-102M
7.0
5.0
10.0
0.6
Y1-Y5V-152M
8.0
5.0
10.0
0.6
Y1-Y5V-222M
9.0
5.0
10.0
0.65
Y1-Y5V-332M
11.0
5.5
10.0
0.65
Y1-Y5V-472M
12.0
5.5
10.0
0.65
3
Lead Configuration
Lead Style
Lead Length
L (mm)
Drawing
Long Straight
16.0 min
Coating Lead Length
C (mm)
①C≤2.5mm
(Product diameter﹤12mm)
Height
H (mm)
②C≤3.0mm
(Product diameter≥12mm)
Short Straight
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
①C≤2.5mm
②C≤3.0mm
Outside Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
Not exceed the bend point
5.0mm
Max
Vertical Crimped
①[2.5≤L<6.0]+/-0.5;
②[6.0≤L≤10]+/-1.0
4.0mm
Max
4
Taping And Dimensions (mm)
Figure
Symbol
P=10.0
Po
12.7±0.3
P
25.4±1.0
P1
7.7±0.7
P2
12.7±1.3
F
10.0±0.8
Δh
0±2.0
W
18.0 +1.5/-1.0
Wo
10.5 Max
W1
9.0+0.75/-0.5
W2
3.0 Max
Do
4.0±0.2
H
20+1.5/-1.0
Ho
16.5&17.0&19.0
+1.5/-1.0
Straight
Lead
Crimped
Lead
11.0
Max
9.0
Max
L
5
t1
0.5±0.2
t2
1.7 Max
很抱歉,暂时无法提供与“Q09F1D222MN0B0S0N0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.22635
- 50+0.20937
- 200+0.19523
- 600+0.18108
- 1500+0.16976
- 3000+0.16269
