ESD5471X
ESD5471X
1-Line, Bi-directional, Transient Voltage Suppressors
http//:www.sh-willsemi.com
Descriptions
The ESD5471X is a bi-directional TVS (Transient Voltage
Suppressor). It is specifically designed to protect sensitive
electronic components which are connected to power lines,
low speed data lines and control lines from over-stress
caused by ESD (Electrostatic Discharge), EFT (Electrical
Fast Transients) and Lightning.
FBP-02C (Bottom View)
The ESD5471X may be used to provide ESD protection up to
±30kV
(contact
and
air
discharge)
according
to
IEC61000-4-2, and withstand peak pulse current up to 6A
(8/20μs) according to IEC61000-4-5.
The ESD5471X is available in FBP-02C package. Standard
products are Pb-free and Halogen-free.
Circuit diagram
Features
Reverse stand-off voltage: ±5V Max
Transient protection for each line according to
IEC61000-4-2 (ESD): ±30kV (contact and air discharge)
IEC61000-4-4 (EFT): 40A (5/50ns)
IEC61000-4-5 (surge): 6A (8/20μs)
A = Device code
Capacitance: CJ = 9pF typ.
Low leakage current
Low clamping voltage: VCL = 12V typ. @ IPP = 16A (TLP)
Solid-state silicon technology
* = Month code ( A~Z)
Marking (Top View)
Order information
Applications
Cellular handsets
Tablets
Laptops
Other portable devices
Network communication devices
Will Semiconductor Ltd.
1
Device
Package
Shipping
ESD5471X-2/TR
FBP-02C
10000/Tape&Reel
Revision 1.2, 2014/01/15
ESD5471X
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
72
W
Peak pulse current (tp = 8/20μs)
IPP
6
A
ESD according to IEC61000-4-2 air discharge
VESD
ESD according to IEC61000-4-2 contact discharge
Operation junction temperature
Storage temperature
±30
kV
125
o
TL
260
o
TSTG
-55~150
o
TJ
Lead temperature
±30
C
C
C
Electrical characteristics (TA=25 oC, unless otherwise noted)
Definitions of electrical characteristics
2
ESD5471X
Electrical characteristics (TA=25 C, unless otherwise noted)
o
Parameter
Symbol
Condition
Min.
Typ.
Max.
Unit
±5
V
1
μA
VRWM
Reverse leakage current
IR
VRWM = 5V
VBR
IBR = 1mA
5.1
V
IHOLD = 50mA
5.1
V
Reverse breakdown voltage
Reverse holding voltage
VHOLD
Clamping voltage 1)
VCL
IPP = 16A, tp = 100ns
12
V
Clamping voltage 2)
VCL
VESD = 8kV
12
V
Clamping voltage 3)
VCL
Dynamic resistance 1)
RDYN
Junction capacitance
CJ
IPP = 1A, tp = 8/20μs
8
V
IPP = 6A, tp = 8/20μs
12
V
0.28
Ω
VR = 0V, f = 1MHz
9
12
pF
VR = 5V, f = 1MHz
6
8
pF
Notes:
1) TLP parameter: Z0 = 50Ω , tp = 100ns, tr = 2ns, averaging window from 60ns to 80ns. RDYN is calculated from 4A to
16A.
2)
Contact discharge mode, according to IEC61000-4-2.
3)
Non-repetitive current pulse, according to IEC61000-4-5.
3
ESD5471X
Typical characteristics (TA=25 C, unless otherwise noted)
110
100
90
80
70
60
50
40
30
90
Front time: T1= 1.25 T = 8s
Time to half-value: T2= 20s
Current (%)
Peak pulse current (%)
o
T2
10
T
10
T1
15
Time (s)
30
35
CJ - Junction capacitance (pF)
VC - Clamping voltage (V)
10
Pulse waveform: tp = 8/20s
10
Pin1 to Pin2
9
Pin2 to Pin1
8
7
6
2
3
4
Time (ns)
Contact discharge current waveform per IEC61000-4-2
8/20μs waveform per IEC61000-4-5
11
tr = 0.7~1ns
t
60ns
30ns
40
5
6
f = 1MHz
VAC = 50mV
9
8
7
6
5
-5
7
-4
-3
IPP - Peak pulse current (A)
-2
-1
2
3
4
5
VR - Reverse voltage (V)
Capacitance vs. Reveres voltage
Clamping voltage vs. Peak pulse current
1000
100
% of Rated power
Peak pulse power (W)
100
10
1
1
10
100
Pulse time ( s)
60
40
50
75
100
125
150
o
TA - Ambient temperature ( C)
Power derating vs. Ambient temperature
Non-repetitive peak pulse power vs. Pulse time
80
4
ESD5471X
o
ESD clamping
ESD clamping
(+8kV contact discharge per IEC61000-4-2)
(-8kV contact discharge per IEC61000-4-2)
TLP current (A)
12
8
4
-8
Z0 = 50
-12
tr = 2ns
-16
tp = 100ns
-20
-14 -12 -10 -8 -6 -4 -2 0
2
4
6
8 10 12 14
TLP voltage (V)
TLP Measurement
5
ESD5471X
Package outline dimensions
FBP-02C
Symbol
Dimensions In Millimeters
Min.
Typ.
Max.
A
0.450
0.500
0.550
A1
0.010
0.100
D
0.950
1.000
1.050
E
0.550
0.600
0.650
D1
0.470 Ref.
E1
0.420 Ref.
b
0.270
0.320
0.370
b1
0.250
0.300
0.350
e
0.555
0.605
0.655
e1
L
0.230 Ref.
0.250
0.300
L1
L2
0.350
0.030 Ref.
0.370
0.420
L3
0.470
0.040 Ref.
Recommend land pattern (Unit: mm)
Notes:
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
group to ensure your PCB design guidelines are met.
6
很抱歉,暂时无法提供与“ESD5471X-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16870
- 200+0.13473
- 600+0.11585
- 2000+0.10260
- 国内价格
- 1+0.52860
- 500+0.17580
- 5000+0.11760
- 10000+0.08400
- 国内价格
- 50+0.10500
- 500+0.09450
- 5000+0.08750
- 10000+0.08400
- 30000+0.08050
- 50000+0.07840
