Quartz Crystal Units
6C
6B
SMD / Thru-hole Type
[ 12.7×4.8×4/3 mm ]
[ 10.7×4.3×2.5 mm ]
6C, 6B
Frequency Range
Fundamental /3rd
3MHz~100MHz
Features
AT-strip crystal inside. Optimized for low spurious
Wide frequency range from 3MHz to 100MHz
Low profile and cost effective
Excellent frequency stability
High stability and reliability with temperature
The crystal package will withstand solder reflow (HC-49S
SMD).
Applications: Bluetooth, Security, IoT, Wireless communications,
Consumer electronic, PC peripherals, etc.
Standard Specifications
Item / Type
6C (12.7×4.8×4/3 mm)
HC-49SS (10.7×4.3×2.5 mm)
Frequency Range
3~100 MHz(Fund. /3rd)
Load Capacitance
5pF~50pF, or specify
Drive Level
10 μW typical (1000 μW max.)
Frequency Tolerance (at 25°C)
± 10ppm, ±20ppm or ±30ppm (max.)
Aging
±5ppm / Year (max.)
Storage Temperature Range
-55°C~+125°C
ESR (Equivalent Series Resistance)
6C /6B (HC-49S /HC-49S SMD)
Frequency Range
E.S.R
Frequency Range
E.S.R
3~3.4MHz
300 Ω max.
27~30MHz
100 Ω max.
3.5~6MHz
120 Ω max.
30~50MHz
80 Ω max.
6.1~10MHz
60 Ω max.
50~100MHz
60 Ω max.
10~14MHz
40 Ω max.
14~30MHz
30 Ω max.
Frequency stability Vs Operating temperature range
ppm
Temp. (°C)
-10~+60
-20~+70
-40~+85
±5
±10
±15
±20
±25
±30
Tel: (+86)-755-8835-2810
www.q-crystal.com
▲: Conditional
○: Available
×: Not available
sjk@q-crystal.com
12
6C
6B
[ 12.7×4.8×4/3 mm ]
[ 10.7×4.3×2.5 mm ]
6C, 6B
Frequency Range
Fundamental /3rd
3MHz~100MHz
Outline Dimensions (Unit: mm)
6C (HC-49SMD / HC-49S SMD)
Top View
12.7±0.6
6.0
Side View
Side View
2.0
4.8±0.2
H
3.9max
10.21max
0.75±0.3
TYPE
H
SMD 4.0±0.2
SSMD 3.0±0.2
4.88±0.2
Buttom View
9.0
Top View Suggested Layout
6B (HC-49S / HC-49SS)
H*
3.8 Max.
Top View
0.43±0.05
13.2±0.5
SJK
16.000
5.0 Max.
11.5 Max.
Side View
www.q-crystal.com
4.88±0.25
Buttom View
TYPE
H
SMD 3.5±0.2
SSMD 2.5±0.2
sjk@q-crystal.com
13
很抱歉,暂时无法提供与“6BS04000F20UGC”相匹配的价格&库存,您可以联系我们找货
