QUARTZ CRYSTAL UNIT
SERIES 6CS/SS, Resistance Welded HC-49S/SSMD Package
深圳市晶科鑫实业有限公司
Shenzhen Crystal Technology Industrial Co., Ltd
APPROVAL SHEET
CUSTOMER P/N:
TYPE:
49SSMD
CRYSTAL
DESCRIPTION:
49SSMD 4.9152MHZ
P N/ SJK:
6CSS04915AG20UCG
ENVIRONMENTAL: ■RoHS
REVISION:
MSL:
A1
20PF ±20PPM
■REACH
■HF
-40~85℃
□PAHS
2014-6-10
□other
MOQ: 1000pcs
Levels 1
SIGNATURE
SUPPLIER
Issue
Check
CUSTOMER
Approve
QA
SJK
Signature
FAE_EMAIL
Date
Date
Check
Approve: □accept
Approve
□unaccepted
Note:
Tel:0755-88352810-837(Mr.huang) Fax:0755-88353718
http://www.q-crystal.com.cn
ADD: Room 1204~1206,Building 3C, TianAn Cloud Park Phase 1,Bantian, Longgang District, Shenzhen
1 /4
QUARTZ CRYSTAL UNIT
1. FEATURE
Leadless type
High precision characteristic covering up to high frequency range
Designed for automatic mounting and reflow soldering
Embossed taping specification
The best choice of Bluetooth wireless communication sets, DSN, PDA and
mobile phone
2. ELECTRICAL SPECIFICATIONS
Output Frequency Range
4.9152 MHz
Mode
AT/Fundamental
Frequency Tolerance
±20 ppm max
Load Capacitance(C L )
20 PF
Frequency Stability Over Operating
Temperature Characteristics
(at 25°C)
±20ppm max
Operating Temperature Range
-40 °C to +85 °C
Storage Temperature Range
-40 °C to +125 °C
Shunt Capacitance (C 0 )
3.0 PF Max
Driver Level (Typical)
100µW
Equivalent Series Resistance(ESR)
80Ω Max
Aging @25°C 1st year (Max)
±3ppm/year
2 /4
QUARTZ CRYSTAL UNIT
3. DIMENSION (Units: mm)
4. MARKING
5. REFLOW CONDITION
3 /4
QUARTZ CRYSTAL UNIT
6. RELIABILITY TEST SPECIFICATION
1.Mechanical Endurance
No.
Test Item
Test Methods
REF.DOC
1.1
Drop Test
150 cm height, 3 times on concrete floor.
JIS C6701
1.2
Mechanical
Shock
1.3
Vibration
1.4
Gross Leak
Standard Sample For Automatic
Detector, Test Pressure: 2Kg / cm2
1.5
Fine Leak
Helium Bombing 4.5 Kg/ cm2 for 2 hr
1.6
Solder ability
Device are shocked to half sine wave ( 1000 G )
three mutually perpendicular axes each 3 times.
0.5m sec. duration time
Frequency range
10 ~ 2000 Hz
Amplitude
1.52 mm/20G
Sweep time
20 minute
Perpendicular axes each test time
4 hours
(Total test time 12 hours)
Temperature
Immersing depth
Immersion time
Flux
Gross
Leak
245 ℃ ± 5℃
0.5 mm minimum
5 ± 1 seconds
Rosin resin methyl alcohol
solvent ( 1 : 4 )
MIL-STD-202F
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
MIL-STD-883E
2.Environmental Endurance
No.
Test Item
Test Methods
2.1
Resistance
To
Soldering Heat
Pre-heat temperature
Pre-heat time 60 ~
Test temperature
Test time
2.2
2.3
High
Temp. Storage
Low
Temp.
Storage
REF.DOC
125 ℃
120 sec.
260 ± 5 ℃
10 ± 1 sec.
MIL-STD-202F
+ 125 ℃ ± 3 ℃ for 500 ± 12 hours
MIL-STD-883E
- 40 ℃ ± 3 ℃ for 500 ± 12 hours
MIL-STD-883E
Total 100 cycles of the following temperature cycle
2.4
2.5
2.6
Thermal Shock
High Temp
&Humidity
Pressure
Cooker Storage
MIL-STD-883E
85℃ ± 3℃, RH 85% , 500Hrs
JIS C5023
121 ± 3℃ , RH100% , 2 bar , 240Hrs
JIS C6701
4 /4
很抱歉,暂时无法提供与“6CSS04915AG20UCG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.63180
- 100+0.59130
- 300+0.55080
- 500+0.51030
- 2000+0.49005
- 5000+0.47790
