SI9435DY-T1
www.VBsemi.tw
P-Channel 30-V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
RDS(on) (Ω)
ID (A)
0.042 at VGS = - 10 V
- 5.8
0.055 at VGS = - 6 V
- 5.0
0.060 at VGS = - 4.5 V
- 4.4
- 30
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• Compliant to RoHS Directive 2002/95/EC
S
SO-8
S
1
8
D
S
2
7
D
S
3
6
D
G
4
5
D
G
D
Top View
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted
Parameter
Symbol
Steady State
10 s
Drain-Source Voltage
VDS
- 30
Gate-Source Voltage
VGS
± 20
Continuous Drain Current (TJ = 150 °C)a
TA = 25 °C
TA = 70 °C
Continuous Source Current (Diode Conduction)a
IS
TA = 25 °C
TA = 70 °C
PD
- 4.1
- 4.6
- 3.2
- 30
- 2.3
A
- 1.1
2.5
1.3
1.6
0.8
TJ, Tstg
Operating Junction and Storage Temperature Range
V
- 5.8
IDM
Pulsed Drain Current
Maximum Power Dissipationa
ID
Unit
- 55 to 150
W
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambienta
Maximum Junction-to-Foot (Drain)
Notes:
a. Surface Mounted on 1" x 1" FR4 board.
E-mail:China@VBsemi TEL:86-755-83251052
Symbol
t ≤ 10 s
Steady State
Steady State
RthJA
RthJF
Typical
Maximum
40
50
70
95
24
30
Unit
°C/W
SI9435DY-T1
www.VBsemi.tw
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
- 0.7
Typ.a
Max.
Unit
Static
VGS(th)
VDS = VGS, ID = - 250 µA
Gate-Body Leakage
IGSS
VDS = 0 V, VGS = ± 20 V
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currentb
ID(on)
Gate Threshold Voltage
Drain-Source On-State
Resistanceb
b
Forward Transconductance
Diode Forward
Voltageb
- 2.0
V
± 100
nA
VDS = - 30 V, VGS = 0 V
-1
VDS = - 30 V, VGS = 0 V, TJ = 70 °C
-5
RDS(on)
VDS ≤ - 10 V, VGS = - 10 V
- 20
VDS ≤ - 5 V, VGS = - 4.5 V
-5
µA
A
VGS = - 10 V, ID = - 5.8 A
0.033
0.042
VGS = - 6 V, ID = - 5 A
0.043
0.055
0.060
VGS = - 4.5 V, ID = - 4.4 A
0.056
gfs
VDS = - 15 V, ID = - 5.8 A
13
VSD
IS = - 2.3 A, VGS = 0 V
- 0.8
- 1.1
16
24
VDS = - 15 V, VGS = - 10 V, ID = - 3.5 A
2.3
Ω
S
V
Dynamica
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
4.5
Gate Resistance
Rg
8.8
td(on)
14
25
14
25
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
tr
td(off)
Fall Time
tf
Source-Drain Reverse Recovery Time
trr
VDD = - 15 V, RL = 15 Ω
ID ≅ - 1 A, VGEN = - 10 V, Rg = 6 Ω
IF = - 1.2 A, dI/dt = 100 A/µs
nC
Ω
42
70
30
50
30
60
ns
Notes:
a. Guaranteed by design, not subject to production testing.
b. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
SI9435DY-T1
www.VBsemi.tw
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
30
30
VGS = 10 V thru 6 V
5V
25
ID - Drain Current (A)
25
4V
10
10
TC = 125 °C
5
5
25 °C
3V
- 55 °C
2
3
4
1
4
5
Transfer Characteristics
Output Characteristics
1100
0.15
880
C - Capacitance (pF)
0.12
0.09
VGS = 4.5 V
0.06
VGS = 6 V
Ciss
660
440
Coss
220
0.03
VGS = 10 V
Crss
8
12
16
10
30
Capacitance
On-Resistance vs. Drain Current
1.6
10
VGS = 10 V
ID = 5.7 A
VDS = 15 V
ID = 3.5 A
1.4
R DS(on) - On-Resistance
(Normalized)
8
6
4
1.2
1.0
0.8
2
15
VDS - Drain-to-Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
3
RDS(on) - On-Resistance (Ω)
2
3.2
6.4
9.6
Qg - Total Gate Charge (nC)
Gate Charge
12.8
16.0
0.6
- 50
- 25
50
75
100
125
TJ - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
150
SI9435DY-T1
www.VBsemi.tw
TYPICAL CHARACTERISTICS 25 C, unless otherwise noted
0.20
50
1
0.0
TJ = 25 °C
TJ = 150 °C
10
IS - Source Current (A)
0.16
ID = 5.8 A
0.12
0.08
0.04
0.00
0.2
0.4
0.6
0.8
1.0
2
8
10
On-Resistance vs. Gate-to-Source Voltage
0.6
150
0.4
120
ID = 250 µA
0.2
90
Power (W)
V GS(th) Variance (V)
6
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
0.0
60
- 0.2
- 0.4
- 50
4
30
- 25
50
75
100
125
150
10- 2
10-1
1
TJ - Temperature (°C)
Time (s)
Threshold Voltage
Single Pulse Power, Junction-to-Ambient
100
Limited by RDS(on)*
10
1 ms
1
0.1
10 ms
100 ms
1s
10 s
TC = 25 °C
Single Pulse
DC
0.01
0.1
1
10
* VDS > minimum VGS at which RDS(on) is specified
Safe Operating Area, Junction-to-Foot
100
10
SI9435DY-T1
www.VBsemi.tw
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
Notes:
0.1
PDM
0.1
0.05
t1
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = R thJA = 70 °C/W
0.02
3. T JM - TA = PDMZthJA(t)
Single Pulse
4. Surface Mounted
0.01
10- 4
10- 3
10- 2
10- 1
1
Square Wave Pulse Duration (s)
10
100
600
Normalized Thermal Transient Impedance, Junction-to-Ambient
2
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10- 4
10- 3
10- 2
10- 1
Normalized Thermal Transient Impedance, Junction-to-Foot
1
10
SI9435DY-T1
www.VBsemi.tw
SOIC (NARROW): 8-LEAD
JEDEC Part Number: MS-012
8
6
7
5
E
1
3
2
H
4
S
h x 45
D
C
0.25 mm (Gage Plane)
A
e
B
All Leads
q
A1
L
0.004"
MILLIMETERS
INCHES
DIM
Min
Max
Min
Max
A
1.35
1.75
0.053
0.069
A1
0.10
0.20
0.004
0.008
B
0.35
0.51
0.014
0.020
C
0.19
0.25
0.0075
0.010
D
4.80
5.00
0.189
0.196
E
3.80
4.00
0.150
e
1.27 BSC
0.157
0.050 BSC
H
5.80
6.20
0.228
0.244
h
0.25
0.50
0.010
0.020
L
0.50
0.93
0.020
0.037
q
0°
8°
0°
8°
S
0.44
0.64
0.018
0.026
ECN: C-06527-Rev. I, 11-Sep-06
DWG: 5498
0.101 mm
SI9435DY-T1
www.VBsemi.tw
RECOMMENDED MINIMUM PADS FOR SO-8
0.172
(4.369)
0.028
0.022
0.050
(0.559)
(1.270)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
0.152
(3.861)
0.047
(1.194)
0.246
(6.248)
(0.711)
SI9435DY-T1
www.VBsemi.tw
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives ( collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to
the product.(www.VBsemi.tw)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: ( 1) any application and all liability arising out of or use of any products; ( 2) any and all liability,
including but not limited to special, consequential damages or incidental ; ( 3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
R oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 R i Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.tw)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
